Date/Time: Fri, 22 Nov 2024 17:47:10 +0000
keep chart drawing selected after drawing it
View Count: 233
[2024-01-27 21:48:29] |
User756079 - Posts: 9 |
I want to 'keep drawing selected after drawing it' Couldn't find the option. There is similar 'Keep Chart drawing selected after modification' - but that's not helping I wanna draw, and right after adjust the drawing with keyboard shortcut, which now seems impossible, and I must select the tool with mouse before adjustment. I'd like very much to avoid selecting with mouse step Date Time Of Last Edit: 2024-01-27 21:50:31
[2024-07-31 20:47:53] |
Sierra_Chart Engineering - Posts: 17145 |
We will see if we can add this option in Tool Settings .
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-31 20:48:17
[2024-09-27 12:54:10] |
Hi. is there any ETA for the feature already? (got the version 2671 but feature does not seem to exist there yet) really waiting for it |
[2024-09-27 14:14:51] |
John - SC Support - Posts: 36222 |
Refer to the following: Chart Drawing Tools: Keep Chart Drawing Selected After Creation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
