Date/Time: Sun, 12 May 2024 17:09:16 +0000
Countdown Timer Alert
View Count: 555
[2024-01-27 13:57:42] |
TomasVill - Posts: 9 |
Hi there I have set my countdown timer alert 'Alert on new bar' to Yes then on Alerts --- Alert Condition: =SG1 <=10. 'Enabled' and 'Alert Only Once per New Bar' are both ticked but No sound goes off at all. Should it work even on replay mode too? Many thanks |
[2024-01-29 15:52:37] |
John - SC Support - Posts: 31555 |
Refer to the following: General Settings Window: Troubleshooting for Alert Sounds That Do Not Play For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-29 16:02:24] |
Sawtooth - Posts: 3995 |
The CountDown Timer study does not output any value in SG1, so you cannot reference it for an alert. If you want an alert just before a new bar, here is a custom spreadsheet study that does it: https://www.sawtoothtrade.com/free-stuff-11.html Date Time Of Last Edit: 2024-01-29 16:02:43
[2024-01-29 18:46:15] |
I hate to disagree with you Sawtooth, but you can alert on SG1 of the Countdown Timer. We even have documentation for this here: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=201#Examples_AlertWhenBarWithinTime The important thing is to have the Input for "Display Remaining Time as Seconds Only", then the data is directly accessible. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-29 20:50:03] |
Oops, I missed that detail.
[2024-03-31 22:41:57] |
User35525 - Posts: 180 |
Support, does putting the value into SG1 depend upon the chart being a time-based chart? I have a non-time based chart I'd like to get the remaining value for. Setting "display value only" and/or "display remaining time as seconds only" didn't allow me to read it into SG1. I can however use "TextDisplay for Study" to grab the SG1 value, as a text string for display. I'm not sure how to convert that string back into a number value for a simple alert. I tried this within a spreadsheet formula: =VALUE(TEXT(ID128.SG1,"0")) Date Time Of Last Edit: 2024-03-31 22:45:35
[2024-04-01 15:03:38] |
What kind of chart are you using?
