Date/Time: Mon, 25 Nov 2024 22:21:45 +0000
Line Tool - Labels - Horizontal Align (left/right) issue.
View Count: 526
[2024-01-27 11:24:47] |
User92573 - Posts: 530 |
Dear Support Line Tool - Labels - Horizontal Align (left/right) is not working correctly. The tool is fixed left. Selecting "Horizontal Align - Right" has no impact. Many thanks. |
[2024-01-29 15:51:15] |
John - SC Support - Posts: 36283 |
We are not fully understanding this. When you select the options for the Horizontal Alignment for text and change between right and left, do you not see it change? Please get us an image of how you are setup by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-30 00:03:45] |
Sierra_Chart Engineering - Posts: 17175 |
We are checking on this.
