Date/Time: Mon, 16 Sep 2024 20:11:21 +0000
Spacing between the two candlestick bars
View Count: 565
[2024-01-27 09:19:08] |
SatG - Posts: 23 |
Hello, I am looking to decrease the space between two candlestick bars. To be precise, please look into the attachment, I am specifically looking to reduce the space in the red circled area between two candlestick bars. I already tried decrease bar spacing (which just changes the scaling or just zooms in or out), decrease width of the bar, default chart bar spacing in graphics settings under global settings and chart etc., but none where helpful to what I am looking for. Can you please advice? Regards, Sat |
2024-01-27_14-36-37.pdf - Attached On 2024-01-27 09:17:26 UTC - Size: 7.4 KB - 95 views |
[2024-01-29 15:35:35] |
John - SC Support - Posts: 34457 |
For what you show, it looks to us like you want to change the "Graphics Settings >> Other >> Candlestick Width" to a larger value - something close to 100. A value of 100 will have the candlesticks bump up right next to each other - or no spacing between the bars at all. Refer to the following: Graphics Settings: Changing the Candlestick Width % or OHLC Width % For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
