Date/Time: Mon, 25 Nov 2024 23:17:29 +0000
Trade Window not showing up
View Count: 145
[2024-01-26 15:29:23] |
ssangha84 - Posts: 122 |
My detached trade window doesn't seem to be showing up at all. I tried Window>Reset Windows as that has worked in the past, but no luck. The message log pops up when I try to reset windows. The following is what it says: ESH4.CME [CS] 1 Min #5 | StartDateTimeForLoadingOrderFills: 2023-09-22 06:30:00 | 2024-01-26 09:58:43.352 ESH4.CME [CS] 1 Min #6 | StartDateTimeForLoadingOrderFills: 2023-09-18 00:07:00 | 2024-01-26 10:05:31.875 ESH4.CME [CS] 1 Min #6 | StartDateTimeForLoadingOrderFills: 2023-09-18 00:07:00 | 2024-01-26 10:05:43.869 ESH4.CME [CS] 1 Min #6 | StartDateTimeForLoadingOrderFills: 2023-09-18 00:07:00 | 2024-01-26 10:16:44.702 ESH4.CME [CS] 1 Min #6 | StartDateTimeForLoadingOrderFills: 2023-09-18 00:07:00 | 2024-01-26 10:16:45.407 |
[2024-01-26 17:12:48] |
John - SC Support - Posts: 36286 |
The Message Log always comes up after selecting "Windows >> Reset Windows", it is not something to be concerned with. The Trade Window is considered a child window of the chart, therefore you would need to select "Chart >> Reset Child Windows" in order to reset the position of the Trade Window. Refer to the following: Chart Menu: Reset Child Window (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
