Date/Time: Mon, 25 Nov 2024 23:38:11 +0000
Help!
View Count: 178
[2024-01-26 14:52:00]
User228762 - Posts: 8
I made horizontal lines however when I right click on the horizontal line and click on the “chart drawing properties” no window opens up for me to edit the horizontal line?
Also, I noticed nothing comes up (ie. No window opens) when I click on “open trade window for chart” under the “trade” drop down list at the top.
Can anyone help please?
Date Time Of Last Edit: 2024-01-26 15:48:53
[2024-01-26 17:09:24]
John - SC Support - Posts: 36286
There was a problem with the Chart Drawing Properties window in a release. So please update to the most recent version in order to ensure that this is no longer the issue you are seeing.
If you continue to have an issue after you update, then select "Window >> Reset Windows" followed by "Chart >> Reset Child Windows". This will set your windows back to their default positions, which should make them visible for you.
[2024-01-27 06:30:04]
Thank you so much- Appreciate it! It worked after I tried the “reset child windows”
