Date/Time: Mon, 25 Nov 2024 23:29:23 +0000
MessageLog filter
View Count: 162
[2024-01-26 13:41:25]
tomas262 - Posts: 141
I am unable to distinguish my study messages in a million of others from IB API,
could you add some "message log filter" .. I would type in "Chart: " and see only message from my strategies - studies
currently reading logs is a nightmare :-)
Date Time Of Last Edit: 2024-01-26 13:42:44
image2024-01-26_14-41-00.png / V - Attached On 2024-01-26 13:41:20 UTC - Size: 246.08 KB - 56 views
[2024-01-26 17:04:05]
John - SC Support - Posts: 36286
Set the option for "Global Settings >> General Settings >> Log >> Save Message Log to File" to "Yes". Then you can edit the file and search within it, or use other tools as you find appropriate. Refer to the following:
General Settings Window: Save Message Log to File (Global Settings >> General Settings >> Log >> Log)
[2024-01-26 19:36:08]
Sierra_Chart Engineering - Posts: 17178
The filtering capability is actually coming soon.
