Date/Time: Mon, 25 Nov 2024 22:19:19 +0000
Horizontal Lines Moved or Changed No Longer Appear on Linked Charts
View Count: 163
[2024-01-26 11:53:26] |
Gsleeve1 - Posts: 5 |
Existing horizontal lines drawn on chart #2 show on chart #4 as they always did. However, if I try to move a line, it disappears from chart #4 while still visible on chart #2. This was not a problem before the update suggested to fix the problem of the crosshairs not appearing.
[2024-01-26 16:57:46] |
John - SC Support - Posts: 36283 |
We are not seeing any issues with this in the current release. If you are able to reproduce this, then please get us a chartbook that contains these two charts so we can see if we can reproduce it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
