Date/Time: Mon, 25 Nov 2024 22:50:10 +0000
Auto place stop loss based on the low/high of last X candles
View Count: 342
[2024-01-26 05:56:47]
user8222 - Posts: 21
I trade divergences where my stop loss will be 1 tick below the low (for a long position) of the candle. You can look back say 5 candles, and my stop loss will always be 1 tick below the low of those candles. Is it possible for me to setup a command to buy and automatically place my attached order stop loss at that exact level? 1 tick below the recent low of the last X candles or X minutes. I could then see exactly what my risk is on the position as well, and decide how many contracts to purchase. Or even better if I could somehow calculate the risk in $ so that it detects the stop loss, and then buys the corresponding amount of contracts to closest match that stop loss. I.e. stop loss is detected as 1 tick below the low, buy order sends X contracts to have my risk be as close to $250 as possible. Whether that is 1, or 10 contracts, etc.
[2024-01-26 15:56:17]
John - SC Support - Posts: 36286
There is not a way to setup a Stop order to be 1 tick below the low of the last 5 bars when you are opening a position, but you can use the "Trade Management by Study" to have it move to that position fairly quickly after you put in the order. Refer to the following:
Attached Orders: Study Controlled Targets and Stops
In order to do what you are wanting with regards to the rest, there is no built-in support for this. You would have to create a custom study to do this. Refer to the following:
Automated Trading From an Advanced Custom Study
List of Third Party Sierra Chart Study and System Programmers
