Date/Time: Fri, 10 May 2024 12:38:11 +0000
Alerts
View Count: 960
[2024-04-25 16:11:38] |
coachted - Posts: 286 |
yes
[2024-04-25 17:39:11] |
John - SC Support - Posts: 31509 |
One item of note is that the Limit price you have set is 0.00. If you are entering the order by selecting the "Buy" or "Sell" buttons on the Trade Window, then this will not work. You should be getting a different error in this case, but perhaps there is a miscommunication somehow. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-25 18:06:19] |
I am entering the order directly in the DOM
[2024-04-25 21:17:48] |
In this case, you must not be working with the correct Trade Window. Refer to the following: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-26 15:18:48] |
it is the correct trade window and i am still getting the error... please advise
[2024-04-26 15:39:21] |
Are you having this problem with all symbols and/or all charts, or is it just a specific chart? If you open a new chart do you have the same problem? Also, try changing your Attached Orders configuration so you have a single Target and Stop both with a quantity of 1 and the parent order has a quantity of 1. Then try to put in an order and let us know what happens. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-26 16:01:53] |
ok
[2024-04-29 17:33:28] |
I sent a copy of my trade log once already and i really dont understand why i keep getting kicked off the Rithmic server please advise
[2024-04-29 17:36:42] |
I am unable to use SC for topstep with this problem going on
[2024-04-29 17:44:45] |
2024-04-29 17:36:04.347 | Trade activity files set size: 19 2024-04-29 17:36:04.364 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:04.364 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0 2024-04-29 17:36:04.364 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 38.79.0.89. 2024-04-29 17:36:04.382 | Reading Internal Order ID file. 2024-04-29 17:36:04.398 | Reading Trade Orders file. 2024-04-29 17:36:04.398 | Reading Trade Positions file. 2024-04-29 17:36:04.398 | Reading Trade Account Data files. 2024-04-29 17:36:04.400 | Software version: 2629 64-bit 2024-04-29 17:36:04.400 | Primary Thread ID: 120396 2024-04-29 17:36:04.400 | Usage end date: 2024-05-16 2024-04-29 17:36:04.400 | Enabled for: Advanced Features 2. 2024-04-29 17:36:04.400 | Enabled for: Sierra Chart Historical Data Service. 2024-04-29 17:36:04.400 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-04-29 17:36:04.400 | Enabled for: Delayed Denali Exchange Data Feed. 2024-04-29 17:36:04.400 | Enabled for exchange2: CME (Trading Account Required) 2024-04-29 17:36:04.400 | Enabled for exchange2: CBOT (Trading Account Required) 2024-04-29 17:36:04.400 | Enabled for exchange2: COMEX (Trading Account Required) 2024-04-29 17:36:04.400 | Enabled for exchange2: NYMEX (Trading Account Required) 2024-04-29 17:36:04.400 | Enabled for exchange2: NASDAQ Global Indexes 2024-04-29 17:36:04.400 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-04-29 17:36:04.400 | Current selected Data/Trading service: Rithmic Direct - DTC 2024-04-29 17:36:04.400 | Custom symbol settings values: enabled 2024-04-29 17:36:04.400 | Chart Update Interval: 400 2024-04-29 17:36:04.400 | Intraday Data Storage Time Unit: 0 2024-04-29 17:36:04.400 | Time Zone: +00:00:00 (UTC+00) 2024-04-29 17:36:04.400 | 2024-04-29 17:36:04 Local computer time in UTC 2024-04-29 17:36:04.400 | 2024-04-29 17:36:04 Local computer time in SC Time Zone 2024-04-29 17:36:04.400 | 2024-04-29 17:36:02 Server time in UTC 2024-04-29 17:36:04.400 | Local computer UTC time and Server UTC time difference: 2 seconds. 2024-04-29 17:36:04.400 | Program path: C:\SierraChart2\ 2024-04-29 17:36:04.400 | Data Files path: C:\SierraChart2\Data\ 2024-04-29 17:36:04.400 | OS Version Number: 10.0 2024-04-29 17:36:04.400 | Locale Setting: C 2024-04-29 17:36:04.400 | DLLs: OrderFlowLabs.com.free_64.dll, OrderFlowLabs.com.free_ARM64.dll, Smaug_SC_Library_64.dll, sst_FreeBundle_64.dll, SST_LocalCopier_64.dll, UserContributedStudies_64.dll 2024-04-29 17:36:04.400 | Allowed protected custom studies: OrderFlowLabs.com FREE, Smaug_SC_Library, SST_FreeBundle, SST_LocalCopier 2024-04-29 17:36:04.400 | Crash reporter started: true 2024-04-29 17:36:04.400 | 2024-04-29 17:36:04.413 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. 2024-04-29 17:36:04.473 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2024-04-29 17:36:04.539 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2024-04-29 17:36:04.539 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2024-04-29 17:36:04.636 | Received 5 login tokens. 2024-04-29 17:36:04.676 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | Number times message added: 1 2024-04-29 17:36:04.677 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | CloseSocket call. 2024-04-29 17:36:04.677 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:36:04.677 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Closed. 2024-04-29 17:36:04.985 | Symbol settings MD5 received. Request ID: 1. 2024-04-29 17:36:04.985 | Symbol settings are up-to-date for rithmic_v2.trading. 2024-04-29 17:36:06.901 | Requested user files to download. 2024-04-29 17:36:07.322 | User files to download complete 2024-04-29 17:36:08.906 | 2024-04-29 17:36:08.906 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:36:08.909 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508 2024-04-29 17:36:08.910 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:08.910 | DTC Client socket (1) | New receive buffer size: 0 2024-04-29 17:36:08.910 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:08.967 | Rithmic Direct - DTC | Network connection to server complete. 2024-04-29 17:36:08.967 | Rithmic Direct - DTC | Starting socket receive thread. 2024-04-29 17:36:08.967 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-04-29 17:36:08.967 | Rithmic Direct - DTC | Sending logon request message. 2024-04-29 17:36:09.136 | Rithmic Direct - DTC | Received logon response. 2024-04-29 17:36:09.136 | Rithmic Direct - DTC | Server Name: . 2024-04-29 17:36:09.136 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:09.136 | Rithmic Direct - DTC | Successfully connected. 2024-04-29 17:36:09.136 | Rithmic Direct - DTC | Trading is supported. 2024-04-29 17:36:09.136 | Rithmic Direct - DTC | Order cancel and replace is supported. 2024-04-29 17:36:09.136 | Rithmic Direct - DTC | OCO Orders supported. 2024-04-29 17:36:09.136 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2024-04-29 17:36:09.136 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2024-04-29 17:36:09.136 | Rithmic Direct - DTC | Connected to server complete. 2024-04-29 17:36:09.136 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-04-29 17:36:12.125 | Files to Open on Startup | Opening file: ExampleChartbook.cht 2024-04-29 17:36:12.138 | XAUUSD 1 Min #1 | Reloading chart. 2024-04-29 17:36:12.147 | XAUUSD Daily #2 | Reloading chart. 2024-04-29 17:36:12.156 | US30 1 Min #3 | Reloading chart. 2024-04-29 17:36:12.166 | USOil 1 Min #4 | Reloading chart. 2024-04-29 17:36:12.174 | ESM24-CME 1 Min #5 | Reloading chart. 2024-04-29 17:36:12.183 | SPX500 Daily #6 | Reloading chart. 2024-04-29 17:36:12.194 | EURUSD Daily #7 | Reloading chart. 2024-04-29 17:36:12.203 | EURUSD 5 Min #8 | Reloading chart. 2024-04-29 17:36:12.225 | ESM24-CME #9 | Reloading chart. 2024-04-29 17:36:12.362 | ESM24-CME 1 Min #10 | Reloading chart. 2024-04-29 17:36:12.372 | AAPL-NQTV 5 Min #11 | Reloading chart. 2024-04-29 17:36:12.382 | SPY 1 Min #12 | Reloading chart. 2024-04-29 17:36:12.523 | ESM24-CME #13 | Reloading chart. 2024-04-29 17:36:12.523 | ESM24-CME #13 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-04-29 17:36:12.532 | ESM24-CME #13 | Chart data loading complete. 2024-04-29 17:36:12.558 | XAUUSD Daily #2 | Chart data loading complete. 2024-04-29 17:36:12.561 | USOil 1 Min #4 | Chart data loading complete. 2024-04-29 17:36:12.562 | SPX500 Daily #6 | Chart data loading complete. 2024-04-29 17:36:12.564 | EURUSD Daily #7 | Chart data loading complete. 2024-04-29 17:36:12.566 | US30 1 Min #3 | Chart data loading complete. 2024-04-29 17:36:12.566 | EURUSD 5 Min #8 | Chart data loading complete. 2024-04-29 17:36:12.568 | XAUUSD 1 Min #1 | Chart data loading complete. 2024-04-29 17:36:12.569 | ESM24-CME 1 Min #5 | Chart data loading complete. 2024-04-29 17:36:12.571 | AAPL-NQTV 5 Min #11 | Chart data loading complete. 2024-04-29 17:36:12.572 | SPY 1 Min #12 | Chart data loading complete. 2024-04-29 17:36:12.574 | ESM24-CME 1 Min #10 | StartDateTimeForLoadingOrderFills: 2024-04-25 16:15:00 2024-04-29 17:36:12.574 | ESM24-CME 1 Min #10 | Chart data loading complete. 2024-04-29 17:36:12.590 | ESM24-CME #9 | Chart data loading complete. 2024-04-29 17:36:12.619 | Using Bid/Ask average for last trade price for XAUUSD 2024-04-29 17:36:12.619 | Using symbol data fast lookup vector 2024-04-29 17:36:12.620 | SC Data with Depth | Starting real-time market data updates for: XAUUSD. ID: 1 Service code: fxcm 2024-04-29 17:36:12.621 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 2024-04-29 17:36:12.621 | DTC Client socket (2) | Creating socket. 2024-04-29 17:36:12.621 | DTC Client socket (2) | New receive buffer size: 0 2024-04-29 17:36:12.621 | DTC Client socket (2) | Connecting to IP: 38.103.112.181. 2024-04-29 17:36:12.623 | SC Data with Depth | Requesting security definition data for: XAUUSD. ID: 1 2024-04-29 17:36:12.623 | Starting DelayedDownloadMonitoringTimer 2024-04-29 17:36:12.623 | Starting HDTimeoutTimer 2024-04-29 17:36:12.623 | Added historical Intraday data request for XAUUSD to the queue. 2024-04-29 17:36:12.623 | Intraday data recording state for symbol XAUUSD is set to download 'Pending'. 2024-04-29 17:36:12.625 | Triggering next historical data download in queue. 2024-04-29 17:36:12.625 | Delaying start of download for XAUUSD. 2024-04-29 17:36:12.625 | Using Bid/Ask average for last trade price for US30 2024-04-29 17:36:12.625 | SC Data with Depth | Starting real-time market data updates for: US30. ID: 2 Service code: fxcm 2024-04-29 17:36:12.625 | SC Data with Depth | Requesting security definition data for: US30. ID: 2 2024-04-29 17:36:12.625 | Added historical Intraday data request for US30 to the queue. 2024-04-29 17:36:12.625 | Intraday data recording state for symbol US30 is set to download 'Pending'. 2024-04-29 17:36:12.625 | Triggering next historical data download in queue. 2024-04-29 17:36:12.626 | Using Bid/Ask average for last trade price for USOil 2024-04-29 17:36:12.626 | SC Data with Depth | Starting real-time market data updates for: USOil. ID: 3 Service code: fxcm 2024-04-29 17:36:12.626 | SC Data with Depth | Requesting security definition data for: USOil. ID: 3 2024-04-29 17:36:12.626 | Added historical Intraday data request for USOil to the queue. 2024-04-29 17:36:12.626 | Intraday data recording state for symbol USOil is set to download 'Pending'. 2024-04-29 17:36:12.626 | Triggering next historical data download in queue. 2024-04-29 17:36:12.627 | Using Bid/Ask average for last trade price for SPX500 2024-04-29 17:36:12.627 | SC Data with Depth | Starting real-time market data updates for: SPX500. ID: 4 Service code: fxcm 2024-04-29 17:36:12.627 | SC Data with Depth | Requesting security definition data for: SPX500. ID: 4 2024-04-29 17:36:12.627 | Rithmic Direct - DTC | Starting real-time market data updates for: ESM24-CME. ID: 5 2024-04-29 17:36:12.629 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:36:12.629 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:12.629 | DTC Client socket (3) | New receive buffer size: 0 2024-04-29 17:36:12.629 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:12.631 | Rithmic Direct - DTC | Requesting security definition data for: ESM24-CME. ID: 5 2024-04-29 17:36:12.631 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:36:12.631 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:36:12.631 | Triggering next historical data download in queue. 2024-04-29 17:36:12.636 | Using Bid/Ask average for last trade price for EURUSD 2024-04-29 17:36:12.636 | SC Data with Depth | Starting real-time market data updates for: EURUSD. ID: 6 Service code: fxcm 2024-04-29 17:36:12.636 | SC Data with Depth | Requesting security definition data for: EURUSD. ID: 6 2024-04-29 17:36:12.636 | Added historical Intraday data request for EURUSD to the queue. 2024-04-29 17:36:12.636 | Intraday data recording state for symbol EURUSD is set to download 'Pending'. 2024-04-29 17:36:12.636 | Triggering next historical data download in queue. 2024-04-29 17:36:12.661 | SC Data with Depth | Network connection to server complete. 2024-04-29 17:36:12.661 | SC Data with Depth | Starting socket receive thread. 2024-04-29 17:36:12.661 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2024-04-29 17:36:12.681 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:36:12.681 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:36:12.681 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:36:12.681 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:36:12.738 | SC Data with Depth | Setting DTC encoding to Binary VLS 2024-04-29 17:36:12.738 | SC Data with Depth | Sending logon request message. 2024-04-29 17:36:12.770 | Mapping AAPL-NQTV to AAPL-NQTV. Service code: nasdaq_exchange.data 2024-04-29 17:36:12.770 | Delayed Data Feed | Starting real-time market data updates for: AAPL-NQTV (AAPL-NQTV). ID: 7 Service code: nasdaq_exchange.data 2024-04-29 17:36:12.772 | Delayed Data Feed | Connecting to the server ds31.sierracharts.com. Port 10043 2024-04-29 17:36:12.773 | DTC Client socket (4) | Creating socket. 2024-04-29 17:36:12.773 | DTC Client socket (4) | New receive buffer size: 0 2024-04-29 17:36:12.773 | DTC Client socket (4) | Connecting to IP: 38.103.112.189. 2024-04-29 17:36:12.776 | Delayed Data Feed | Requesting security definition data for: AAPL-NQTV (AAPL-NQTV). ID: 7 2024-04-29 17:36:12.776 | Added historical Intraday data request for AAPL-NQTV to the queue. 2024-04-29 17:36:12.776 | Intraday data recording state for symbol AAPL-NQTV is set to download 'Pending'. 2024-04-29 17:36:12.776 | Triggering next historical data download in queue. 2024-04-29 17:36:12.785 | Mapping SPY to SPY. Service code: us_equities_utp_cta_exchange.data 2024-04-29 17:36:12.786 | Delayed Data Feed | Starting real-time market data updates for: SPY (SPY). ID: 8 Service code: us_equities_utp_cta_exchange.data 2024-04-29 17:36:12.788 | Delayed Data Feed | Connecting to the server ds3.sierracharts.com. Port 10043 2024-04-29 17:36:12.789 | DTC Client socket (5) | Creating socket. 2024-04-29 17:36:12.789 | DTC Client socket (5) | New receive buffer size: 0 2024-04-29 17:36:12.789 | DTC Client socket (5) | Connecting to IP: 38.103.112.199. 2024-04-29 17:36:12.791 | Delayed Data Feed | Requesting security definition data for: SPY (SPY). ID: 8 2024-04-29 17:36:12.791 | Added historical Intraday data request for SPY to the queue. 2024-04-29 17:36:12.791 | Intraday data recording state for symbol SPY is set to download 'Pending'. 2024-04-29 17:36:12.791 | Triggering next historical data download in queue. 2024-04-29 17:36:12.811 | Delayed Data Feed | Network connection to server complete. 2024-04-29 17:36:12.811 | Delayed Data Feed | Starting socket receive thread. 2024-04-29 17:36:12.811 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-04-29 17:36:12.828 | Delayed Data Feed | Network connection to server complete. 2024-04-29 17:36:12.828 | Delayed Data Feed | Starting socket receive thread. 2024-04-29 17:36:12.828 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-04-29 17:36:12.842 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:36:12.842 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:36:12.842 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:12.842 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:36:12.842 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:36:12.842 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:36:12.842 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:36:12.842 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:36:12.878 | Delayed Data Feed | Setting DTC encoding to Binary VLS 2024-04-29 17:36:12.878 | Delayed Data Feed | Sending logon request message. 2024-04-29 17:36:12.882 | Delayed Data Feed | Setting DTC encoding to Binary VLS 2024-04-29 17:36:12.882 | Delayed Data Feed | Sending logon request message. 2024-04-29 17:36:12.895 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-04-29 17:36:12.895 | DTC Client socket (3) | CloseSocket call. 2024-04-29 17:36:12.895 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:36:12.895 | DTC Client socket (3) | Closed. 2024-04-29 17:36:12.896 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:36:12.896 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:36:12.896 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:36:12.896 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:36:13.114 | SC Data with Depth | Received logon response. 2024-04-29 17:36:13.114 | SC Data with Depth | Server Name: SC Realtime Server. 2024-04-29 17:36:13.114 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:13.114 | SC Data with Depth | Successfully connected. 2024-04-29 17:36:13.114 | SC Data with Depth | Trading is not supported. 2024-04-29 17:36:13.114 | SC Data with Depth | MarketDepthIsSupported: 1 2024-04-29 17:36:13.114 | SC Data with Depth | Restarting real-time data updates for symbol: EURUSD 2024-04-29 17:36:13.114 | SC Data with Depth | Restarting real-time data updates for symbol: SPX500 2024-04-29 17:36:13.114 | SC Data with Depth | Restarting real-time data updates for symbol: US30 2024-04-29 17:36:13.114 | SC Data with Depth | Restarting real-time data updates for symbol: USOil 2024-04-29 17:36:13.114 | SC Data with Depth | Restarting real-time data updates for symbol: XAUUSD 2024-04-29 17:36:13.241 | SC Data with Depth | Received security definition for symbol EURUSD 2024-04-29 17:36:13.241 | SC Data with Depth | Received security definition for symbol SPX500 2024-04-29 17:36:13.241 | SC Data with Depth | Received security definition for symbol US30 2024-04-29 17:36:13.241 | SC Data with Depth | Received security definition for symbol USOil 2024-04-29 17:36:13.241 | SC Data with Depth | Received security definition for symbol XAUUSD 2024-04-29 17:36:13.260 | Delayed Data Feed | Received logon response. 2024-04-29 17:36:13.260 | Delayed Data Feed | Server Name: SC Realtime Server. 2024-04-29 17:36:13.260 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:13.260 | Delayed Data Feed | Successfully connected. 2024-04-29 17:36:13.260 | Delayed Data Feed | Trading is not supported. 2024-04-29 17:36:13.260 | Delayed Data Feed | MarketDepthIsSupported: 1 2024-04-29 17:36:13.260 | Delayed Data Feed | Restarting real-time data updates for symbol: SPY -> SPY 2024-04-29 17:36:13.285 | Delayed Data Feed | Received logon response. 2024-04-29 17:36:13.285 | Delayed Data Feed | Server Name: SC Realtime Server. 2024-04-29 17:36:13.285 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:13.285 | Delayed Data Feed | Successfully connected. 2024-04-29 17:36:13.285 | Delayed Data Feed | Trading is not supported. 2024-04-29 17:36:13.285 | Delayed Data Feed | MarketDepthIsSupported: 1 2024-04-29 17:36:13.285 | Delayed Data Feed | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV 2024-04-29 17:36:13.386 | Delayed Data Feed | Received security definition for symbol SPY 2024-04-29 17:36:13.410 | Delayed Data Feed | Received security definition for symbol AAPL-NQTV 2024-04-29 17:36:14.133 | Requesting market depth updates for: ESM24-CME if supported. NumLevels=1400 2024-04-29 17:36:14.885 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:36:14.885 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:36:14.886 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:14.886 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:36:14.886 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:15.003 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:36:15.003 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:36:15.003 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:36:15.003 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:36:15.675 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:36:15.675 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:36:15.675 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:15.675 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:36:15.675 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:36:15.675 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:36:15.675 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:36:15.675 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME. Market Depth data restarted. 2024-04-29 17:36:15.728 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:36:15.728 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:36:15.728 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:36:15.728 | DTC Client socket (6) | Closed. 2024-04-29 17:36:15.729 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:36:15.729 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:36:15.729 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:36:15.729 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:36:17.726 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:36:17.726 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:36:17.727 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:17.727 | DTC Client socket (3) | New receive buffer size: 0 2024-04-29 17:36:17.727 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:17.781 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:36:17.781 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:36:17.781 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:36:17.781 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:36:17.945 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:36:17.945 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:36:17.945 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:17.945 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:36:17.945 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:36:17.945 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:36:17.945 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:36:17.945 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME. Market Depth data restarted. 2024-04-29 17:36:17.999 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-04-29 17:36:17.999 | DTC Client socket (3) | CloseSocket call. 2024-04-29 17:36:17.999 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:36:17.999 | DTC Client socket (3) | Closed. 2024-04-29 17:36:17.999 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:36:17.999 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:36:17.999 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:36:17.999 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:36:18.605 | HD Request # 1 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm 2024-04-29 17:36:18.605 | HD Request # 1 | Download start date-time: 2024-04-29 17:34:29.000000. File last date-time: 2024-04-29 17:34:29.401000 2024-04-29 17:36:18.605 | HD Request # 1 | Using server: ds12.sierracharts.com port 10149 2024-04-29 17:36:18.606 | Socket (3) | Creating socket. 2024-04-29 17:36:18.606 | Socket (3) | New receive buffer size: 0 2024-04-29 17:36:18.606 | Socket (3) | Connecting to IP: 38.103.112.181. 2024-04-29 17:36:18.702 | HD Request # 1 | Setting DTC encoding to Binary VLS 2024-04-29 17:36:18.702 | HD Request # 1 | Sending historical data logon request message. 2024-04-29 17:36:18.977 | HD Request # 1 | Requesting Intraday data. Start date-time: 2024-04-29 17:34:29. Record interval: 0. Symbol: XAUUSD 2024-04-29 17:36:19.019 | HD Request # 1 | Decompressing data. 2024-04-29 17:36:19.063 | HD Request # 1 | Receiving Intraday data for XAUUSD starting at 2024-04-29 17:34:29.062000 2024-04-29 17:36:19.063 | Socket (3) | CloseSocket call. 2024-04-29 17:36:19.063 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-04-29 17:36:19.063 | Historical data download thread signaled to stop. 2024-04-29 17:36:19.063 | HD Request # 1 | Timestamp of first Intraday data file record written: 2024-04-29 17:34:30.331000. 2024-04-29 17:36:19.063 | HD Request # 1 | Received 483 Intraday data records from 2024-04-29 17:34:29.062000 to 2024-04-29 17:36:18.141000 (109.1 seconds. Delay: 0.9 seconds) and wrote 478 records for XAUUSD 2024-04-29 17:36:19.064 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2024-04-29 17:36:18.141000 2024-04-29 17:36:19.064 | HD Request # 1 | Completion time: 1s. 2024-04-29 17:36:19.064 | HD Request # 1 | Intraday data download complete for XAUUSD. Unique request ID: 1 2024-04-29 17:36:19.064 | Removing historical data download ID 1. 2024-04-29 17:36:19.064 | Real-time Intraday chart data file updates started for XAUUSD 2024-04-29 17:36:19.064 | Intraday chart data file opened for XAUUSD 2024-04-29 17:36:19.064 | HD Request # 1 | Enabling Intraday chart updating for symbol. 2024-04-29 17:36:19.064 | 2024-04-29 17:36:19.064 | Triggering next historical data download in queue. 2024-04-29 17:36:19.064 | HD Request # 2 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm 2024-04-29 17:36:19.064 | HD Request # 2 | Download start date-time: 2024-04-29 17:34:29.000000. File last date-time: 2024-04-29 17:34:29.220001 2024-04-29 17:36:19.064 | HD Request # 2 | Using server: ds13-2.sierracharts.com port 10150 2024-04-29 17:36:19.064 | Socket (6) | Creating socket. 2024-04-29 17:36:19.064 | Socket (6) | New receive buffer size: 0 2024-04-29 17:36:19.064 | Socket (6) | Connecting to IP: 38.142.170.156. 2024-04-29 17:36:19.103 | Socket (3) | Socket gracefully closed by remote side. 2024-04-29 17:36:19.103 | Socket (3) | Closed. 2024-04-29 17:36:19.209 | HD Request # 2 | Setting DTC encoding to Binary VLS 2024-04-29 17:36:19.209 | HD Request # 2 | Sending historical data logon request message. 2024-04-29 17:36:19.303 | HD Request # 2 | Requesting Intraday data. Start date-time: 2024-04-29 17:34:29. Record interval: 0. Symbol: US30 2024-04-29 17:36:19.366 | HD Request # 2 | Decompressing data. 2024-04-29 17:36:19.431 | HD Request # 2 | Receiving Intraday data for US30 starting at 2024-04-29 17:34:29.020000 2024-04-29 17:36:19.431 | Socket (6) | CloseSocket call. 2024-04-29 17:36:19.431 | Socket (6) | Shutdown started. Waiting for graceful close. 2024-04-29 17:36:19.431 | Historical data download thread signaled to stop. 2024-04-29 17:36:19.431 | HD Request # 2 | Timestamp of first Intraday data file record written: 2024-04-29 17:34:30.005000. 2024-04-29 17:36:19.431 | HD Request # 2 | Received 319 Intraday data records from 2024-04-29 17:34:29.020000 to 2024-04-29 17:36:17.203000 (108.2 seconds. Delay: 2.2 seconds) and wrote 317 records for US30 2024-04-29 17:36:19.431 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2024-04-29 17:36:17.203000 2024-04-29 17:36:19.431 | Added 8 Time and Sales records to Intraday data file for US30 after download. 2024-04-29 17:36:19.431 | HD Request # 2 | Completion time: 0s. 2024-04-29 17:36:19.431 | HD Request # 2 | Intraday data download complete for US30. Unique request ID: 2 2024-04-29 17:36:19.431 | Removing historical data download ID 2. 2024-04-29 17:36:19.431 | Real-time Intraday chart data file updates started for US30 2024-04-29 17:36:19.431 | Intraday chart data file opened for US30 2024-04-29 17:36:19.431 | HD Request # 2 | Enabling Intraday chart updating for symbol. 2024-04-29 17:36:19.431 | 2024-04-29 17:36:19.431 | Triggering next historical data download in queue. 2024-04-29 17:36:19.431 | HD Request # 3 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm 2024-04-29 17:36:19.432 | HD Request # 3 | Download start date-time: 2024-04-29 17:34:28.000000. File last date-time: 2024-04-29 17:34:28.973000 2024-04-29 17:36:19.432 | HD Request # 3 | Using server: ds4.sierracharts.com port 10149 2024-04-29 17:36:19.432 | Socket (3) | Creating socket. 2024-04-29 17:36:19.432 | Socket (3) | New receive buffer size: 0 2024-04-29 17:36:19.432 | Socket (3) | Connecting to IP: 38.103.112.200. 2024-04-29 17:36:19.476 | Opened cached Intraday file: C:\SierraChart2\Data\XAUUSD.scid. Thread ID: 130408 2024-04-29 17:36:19.493 | Socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:36:19.493 | Socket (6) | Closed. 2024-04-29 17:36:19.522 | HD Request # 3 | Setting DTC encoding to Binary VLS 2024-04-29 17:36:19.522 | HD Request # 3 | Sending historical data logon request message. 2024-04-29 17:36:19.802 | HD Request # 3 | Requesting Intraday data. Start date-time: 2024-04-29 17:34:28. Record interval: 0. Symbol: USOil 2024-04-29 17:36:19.843 | HD Request # 3 | Decompressing data. 2024-04-29 17:36:19.883 | HD Request # 3 | Receiving Intraday data for USOil starting at 2024-04-29 17:34:28.973000 2024-04-29 17:36:19.883 | Socket (3) | CloseSocket call. 2024-04-29 17:36:19.883 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-04-29 17:36:19.883 | Historical data download thread signaled to stop. 2024-04-29 17:36:19.883 | HD Request # 3 | Timestamp of first Intraday data file record written: 2024-04-29 17:34:30.201000. 2024-04-29 17:36:19.883 | HD Request # 3 | Received 76 Intraday data records from 2024-04-29 17:34:28.973000 to 2024-04-29 17:36:14.199000 (105.2 seconds. Delay: 5.7 seconds) and wrote 75 records for USOil 2024-04-29 17:36:19.883 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2024-04-29 17:36:14.199000 2024-04-29 17:36:19.883 | HD Request # 3 | Completion time: 0s. 2024-04-29 17:36:19.883 | HD Request # 3 | Intraday data download complete for USOil. Unique request ID: 3 2024-04-29 17:36:19.883 | Removing historical data download ID 3. 2024-04-29 17:36:19.883 | Real-time Intraday chart data file updates started for USOil 2024-04-29 17:36:19.883 | Intraday chart data file opened for USOil 2024-04-29 17:36:19.883 | HD Request # 3 | Enabling Intraday chart updating for symbol. 2024-04-29 17:36:19.883 | 2024-04-29 17:36:19.883 | Triggering next historical data download in queue. 2024-04-29 17:36:19.883 | Delaying start of download for ESM24-CME. 2024-04-29 17:36:19.923 | Socket (3) | Socket gracefully closed by remote side. 2024-04-29 17:36:19.923 | Socket (3) | Closed. 2024-04-29 17:36:19.984 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:36:19.984 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:36:19.984 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:19.984 | DTC Client socket (3) | New receive buffer size: 0 2024-04-29 17:36:19.984 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:20.038 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:36:20.038 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:36:20.038 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:36:20.038 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:36:20.204 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:36:20.204 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:36:20.204 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:20.204 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:36:20.204 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:36:20.204 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:36:20.204 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:36:20.204 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME. Market Depth data restarted. 2024-04-29 17:36:20.257 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-04-29 17:36:20.257 | DTC Client socket (3) | CloseSocket call. 2024-04-29 17:36:20.257 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:36:20.257 | DTC Client socket (3) | Closed. 2024-04-29 17:36:20.258 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:36:20.258 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:36:20.258 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:36:20.258 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:36:22.253 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:36:22.253 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:36:22.254 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:22.254 | DTC Client socket (3) | New receive buffer size: 0 2024-04-29 17:36:22.254 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:22.309 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:36:22.309 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:36:22.309 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:36:22.309 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:36:22.471 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:36:22.471 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:36:22.471 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:22.471 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:36:22.471 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:36:22.471 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:36:22.471 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:36:22.471 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME. Market Depth data restarted. 2024-04-29 17:36:22.528 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-04-29 17:36:22.528 | DTC Client socket (3) | CloseSocket call. 2024-04-29 17:36:22.528 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:36:22.528 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:36:22.528 | DTC Client socket (3) | Closed. 2024-04-29 17:36:22.528 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:36:22.528 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:36:22.528 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:36:24.129 | Unsubscribed from market depth data for ESM24-CME 2024-04-29 17:36:24.492 | Opened cached Intraday file: C:\SierraChart2\Data\US30.scid. Thread ID: 130408 2024-04-29 17:36:24.492 | Opened cached Intraday file: C:\SierraChart2\Data\USOil.scid. Thread ID: 130408 2024-04-29 17:36:24.523 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:36:24.523 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:36:24.524 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:24.524 | DTC Client socket (3) | New receive buffer size: 0 2024-04-29 17:36:24.524 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:24.577 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:36:24.577 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:36:24.577 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:36:24.577 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:36:24.741 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:36:24.741 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:36:24.741 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:24.741 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:36:24.741 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:36:24.741 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:36:24.741 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:36:24.741 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:36:24.795 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-04-29 17:36:24.795 | DTC Client socket (3) | CloseSocket call. 2024-04-29 17:36:24.795 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:36:24.795 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:36:24.795 | DTC Client socket (3) | Closed. 2024-04-29 17:36:24.795 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:36:24.795 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:36:24.795 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:36:26.808 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:36:26.808 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:36:26.808 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:26.808 | DTC Client socket (3) | New receive buffer size: 0 2024-04-29 17:36:26.808 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:26.863 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:36:26.863 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:36:26.863 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:36:26.863 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:36:27.027 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:36:27.027 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:36:27.027 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:27.027 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:36:27.027 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:36:27.027 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:36:27.027 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:36:27.027 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:36:27.081 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-04-29 17:36:27.081 | DTC Client socket (3) | CloseSocket call. 2024-04-29 17:36:27.082 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:36:27.082 | DTC Client socket (3) | Closed. 2024-04-29 17:36:27.082 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:36:27.082 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:36:27.082 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:36:27.082 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:36:28.909 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (3) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:28.909 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (3) | New receive buffer size: 0 2024-04-29 17:36:28.909 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (3) | Connecting to IP: 38.79.0.89. 2024-04-29 17:36:29.092 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:36:29.092 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:36:29.093 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:29.093 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:36:29.093 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:29.147 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:36:29.147 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:36:29.147 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:36:29.147 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:36:29.203 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (3) | Socket gracefully closed by remote side. | Number times message added: 1 2024-04-29 17:36:29.204 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (3) | CloseSocket call. 2024-04-29 17:36:29.204 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:36:29.204 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (3) | Closed. 2024-04-29 17:36:29.311 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:36:29.311 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:36:29.311 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:29.311 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:36:29.311 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:36:29.311 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:36:29.311 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:36:29.311 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:36:29.366 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:36:29.366 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:36:29.366 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:36:29.366 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:36:29.366 | DTC Client socket (6) | Closed. 2024-04-29 17:36:29.366 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:36:29.366 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:36:29.366 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:36:31.356 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:36:31.356 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:36:31.356 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:31.356 | DTC Client socket (3) | New receive buffer size: 0 2024-04-29 17:36:31.356 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:31.410 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:36:31.410 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:36:31.410 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:36:31.410 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:36:31.576 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:36:31.576 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:36:31.576 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:31.576 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:36:31.576 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:36:31.576 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:36:31.576 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:36:31.576 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:36:31.631 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-04-29 17:36:31.631 | DTC Client socket (3) | CloseSocket call. 2024-04-29 17:36:31.631 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:36:31.631 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:36:31.631 | DTC Client socket (3) | Closed. 2024-04-29 17:36:31.632 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:36:31.632 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:36:31.632 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:36:33.622 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:36:33.622 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:36:33.629 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:33.629 | DTC Client socket (3) | New receive buffer size: 0 2024-04-29 17:36:33.629 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:33.684 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:36:33.684 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:36:33.684 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:36:33.684 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:36:33.848 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:36:33.848 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:36:33.848 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:33.848 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:36:33.848 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:36:33.848 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:36:33.848 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:36:33.848 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:36:33.901 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-04-29 17:36:33.901 | DTC Client socket (3) | CloseSocket call. 2024-04-29 17:36:33.901 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:36:33.901 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:36:33.901 | DTC Client socket (3) | Closed. 2024-04-29 17:36:33.902 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:36:33.902 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:36:33.902 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:36:35.891 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:36:35.891 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:36:35.891 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:35.891 | DTC Client socket (3) | New receive buffer size: 0 2024-04-29 17:36:35.891 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:35.944 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:36:35.944 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:36:35.944 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:36:35.944 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:36:36.111 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:36:36.111 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:36:36.111 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:36.111 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:36:36.111 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:36:36.111 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:36:36.111 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:36:36.111 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:36:36.165 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-04-29 17:36:36.165 | DTC Client socket (3) | CloseSocket call. 2024-04-29 17:36:36.166 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:36:36.166 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:36:36.166 | DTC Client socket (3) | Closed. 2024-04-29 17:36:36.167 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:36:36.167 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:36:36.167 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:36:38.152 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:36:38.152 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:36:38.152 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:38.152 | DTC Client socket (3) | New receive buffer size: 0 2024-04-29 17:36:38.152 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:38.207 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:36:38.207 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:36:38.208 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:36:38.208 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:36:38.375 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:36:38.375 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:36:38.375 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:38.375 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:36:38.375 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:36:38.375 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:36:38.375 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:36:38.375 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:36:38.428 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-04-29 17:36:38.428 | DTC Client socket (3) | CloseSocket call. 2024-04-29 17:36:38.428 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:36:38.428 | DTC Client socket (3) | Closed. 2024-04-29 17:36:38.428 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:36:38.428 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:36:38.428 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:36:38.428 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:36:40.423 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:36:40.423 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:36:40.424 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:40.424 | DTC Client socket (3) | New receive buffer size: 0 2024-04-29 17:36:40.424 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:40.478 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:36:40.478 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:36:40.478 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:36:40.478 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:36:40.640 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:36:40.640 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:36:40.640 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:40.640 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:36:40.640 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:36:40.640 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:36:40.640 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:36:40.640 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:36:40.695 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-04-29 17:36:40.695 | DTC Client socket (3) | CloseSocket call. 2024-04-29 17:36:40.695 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:36:40.695 | DTC Client socket (3) | Closed. 2024-04-29 17:36:40.695 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:36:40.695 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:36:40.695 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:36:40.695 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:36:42.692 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:36:42.692 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:36:42.692 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:42.692 | DTC Client socket (3) | New receive buffer size: 0 2024-04-29 17:36:42.692 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:42.746 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:36:42.746 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:36:42.746 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:36:42.746 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:36:42.911 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:36:42.911 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:36:42.911 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:42.911 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:36:42.911 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:36:42.911 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:36:42.911 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:36:42.911 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:36:42.965 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-04-29 17:36:42.965 | DTC Client socket (3) | CloseSocket call. 2024-04-29 17:36:42.965 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:36:42.965 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:36:42.965 | DTC Client socket (3) | Closed. 2024-04-29 17:36:42.965 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:36:42.965 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:36:42.965 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:36:43.622 | HD Request # 4 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:36:43.622 | HD Request # 4 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:36:43.622 | HD Request # 4 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:36:43.622 | Socket (3) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:43.623 | Socket (3) | New receive buffer size: 0 2024-04-29 17:36:43.623 | Socket (3) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:43.677 | HD Request # 4 | Sending historical data logon request message. 2024-04-29 17:36:43.839 | HD Request # 4 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:36:43.893 | Socket (3) | CloseSocket call. 2024-04-29 17:36:43.894 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-04-29 17:36:43.894 | HD Request # 4 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:36:43.894 | Historical data download thread signaled to stop. 2024-04-29 17:36:43.894 | HD Request # 4 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:36:43.894 | HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:36:43.894 | HD Request # 4 | Completion time: 0s. 2024-04-29 17:36:43.894 | HD Request # 4 | Intraday data download complete for ESM24-CME. Unique request ID: 4 2024-04-29 17:36:43.894 | Removing historical data download ID 4. 2024-04-29 17:36:43.894 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:36:43.894 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:36:43.894 | HD Request # 4 | Enabling Intraday chart updating for symbol. 2024-04-29 17:36:43.894 | 2024-04-29 17:36:43.894 | Triggering next historical data download in queue. 2024-04-29 17:36:43.894 | HD Request # 5 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm 2024-04-29 17:36:43.894 | HD Request # 5 | Download start date-time: 2024-04-29 17:34:27.000000. File last date-time: 2024-04-29 17:34:27.247000 2024-04-29 17:36:43.894 | HD Request # 5 | Using server: ds12.sierracharts.com port 10149 2024-04-29 17:36:43.894 | Socket (6) | Creating socket. 2024-04-29 17:36:43.894 | Socket (6) | New receive buffer size: 0 2024-04-29 17:36:43.894 | Socket (6) | Connecting to IP: 38.103.112.181. 2024-04-29 17:36:43.950 | Socket (3) | Socket gracefully closed by remote side. 2024-04-29 17:36:43.950 | Socket (3) | Closed. 2024-04-29 17:36:43.988 | HD Request # 5 | Setting DTC encoding to Binary VLS 2024-04-29 17:36:43.988 | HD Request # 5 | Sending historical data logon request message. 2024-04-29 17:36:44.028 | HD Request # 5 | Requesting Intraday data. Start date-time: 2024-04-29 17:34:27. Record interval: 0. Symbol: EURUSD 2024-04-29 17:36:44.071 | HD Request # 5 | Decompressing data. 2024-04-29 17:36:44.112 | HD Request # 5 | Receiving Intraday data for EURUSD starting at 2024-04-29 17:34:27.242000 2024-04-29 17:36:44.112 | Socket (6) | CloseSocket call. 2024-04-29 17:36:44.112 | Socket (6) | Shutdown started. Waiting for graceful close. 2024-04-29 17:36:44.112 | Historical data download thread signaled to stop. 2024-04-29 17:36:44.112 | HD Request # 5 | Timestamp of first Intraday data file record written: 2024-04-29 17:34:31.850000. 2024-04-29 17:36:44.112 | HD Request # 5 | Received 206 Intraday data records from 2024-04-29 17:34:27.242000 to 2024-04-29 17:36:40.651000 (2.2 minutes. Delay: 3.5 seconds) and wrote 204 records for EURUSD 2024-04-29 17:36:44.112 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2024-04-29 17:36:40.651000 2024-04-29 17:36:44.112 | Added 2 Time and Sales records to Intraday data file for EURUSD after download. 2024-04-29 17:36:44.112 | HD Request # 5 | Completion time: 1s. 2024-04-29 17:36:44.112 | HD Request # 5 | Intraday data download complete for EURUSD. Unique request ID: 5 2024-04-29 17:36:44.112 | Removing historical data download ID 5. 2024-04-29 17:36:44.112 | Real-time Intraday chart data file updates started for EURUSD 2024-04-29 17:36:44.112 | Intraday chart data file opened for EURUSD 2024-04-29 17:36:44.112 | HD Request # 5 | Enabling Intraday chart updating for symbol. 2024-04-29 17:36:44.112 | 2024-04-29 17:36:44.112 | Triggering next historical data download in queue. 2024-04-29 17:36:44.112 | HD Request # 6 | Downloading Intraday chart data for AAPL-NQTV to the file AAPL-NQTV.scid. Service: nasdaq_exchange.data 2024-04-29 17:36:44.112 | HD Request # 6 | Download start date-time: 2024-04-29 17:19:26.000000. File last date-time: 2024-04-29 17:19:26.681006 2024-04-29 17:36:44.112 | HD Request # 6 | Using server: ds3.sierracharts.com port 10150 2024-04-29 17:36:44.112 | Socket (3) | Creating socket. 2024-04-29 17:36:44.112 | Socket (3) | New receive buffer size: 0 2024-04-29 17:36:44.112 | Socket (3) | Connecting to IP: 38.103.112.199. 2024-04-29 17:36:44.152 | Socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:36:44.152 | Socket (6) | Closed. 2024-04-29 17:36:44.202 | HD Request # 6 | Setting DTC encoding to Binary VLS 2024-04-29 17:36:44.202 | HD Request # 6 | Sending historical data logon request message. 2024-04-29 17:36:44.490 | HD Request # 6 | Requesting Intraday data. Start date-time: 2024-04-29 17:19:26. Record interval: 0. Symbol: AAPL-NQTV 2024-04-29 17:36:44.531 | HD Request # 6 | Decompressing data. 2024-04-29 17:36:44.572 | HD Request # 6 | Receiving Intraday data for AAPL-NQTV starting at 2024-04-29 17:19:26.681000 2024-04-29 17:36:44.572 | Socket (3) | CloseSocket call. 2024-04-29 17:36:44.572 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-04-29 17:36:44.572 | Historical data download thread signaled to stop. 2024-04-29 17:36:44.572 | HD Request # 6 | Timestamp of first Intraday data file record written: 2024-04-29 17:19:30.401000. 2024-04-29 17:36:44.572 | HD Request # 6 | Received 397 Intraday data records from 2024-04-29 17:19:26.681000 to 2024-04-29 17:21:43.806000 (2.3 minutes. Delay: 15.0 minutes) and wrote 390 records for AAPL-NQTV 2024-04-29 17:36:44.572 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2024-04-29 17:21:43.806000 2024-04-29 17:36:44.572 | Added 7 Time and Sales records to Intraday data file for AAPL-NQTV after download. 2024-04-29 17:36:44.572 | HD Request # 6 | Completion time: 0s. 2024-04-29 17:36:44.572 | HD Request # 6 | Intraday data download complete for AAPL-NQTV. Unique request ID: 6 2024-04-29 17:36:44.572 | Removing historical data download ID 6. 2024-04-29 17:36:44.572 | Real-time Intraday chart data file updates started for AAPL-NQTV 2024-04-29 17:36:44.572 | Intraday chart data file opened for AAPL-NQTV 2024-04-29 17:36:44.572 | HD Request # 6 | Enabling Intraday chart updating for symbol. 2024-04-29 17:36:44.572 | 2024-04-29 17:36:44.572 | Triggering next historical data download in queue. 2024-04-29 17:36:44.572 | HD Request # 7 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: us_equities_utp_cta_exchange.data 2024-04-29 17:36:44.572 | HD Request # 7 | Download start date-time: 2024-04-29 17:19:29.000000. File last date-time: 2024-04-29 17:19:29.847001 2024-04-29 17:36:44.572 | HD Request # 7 | Using server: ds31.sierracharts.com port 10149 2024-04-29 17:36:44.573 | Socket (6) | Creating socket. 2024-04-29 17:36:44.573 | Socket (6) | New receive buffer size: 0 2024-04-29 17:36:44.573 | Socket (6) | Connecting to IP: 38.103.112.189. 2024-04-29 17:36:44.613 | Socket (3) | Socket gracefully closed by remote side. 2024-04-29 17:36:44.613 | Socket (3) | Closed. 2024-04-29 17:36:44.637 | Opened cached Intraday file: C:\SierraChart2\Data\EURUSD.scid. Thread ID: 130408 2024-04-29 17:36:44.678 | HD Request # 7 | Setting DTC encoding to Binary VLS 2024-04-29 17:36:44.678 | HD Request # 7 | Sending historical data logon request message. 2024-04-29 17:36:44.952 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:36:44.952 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:36:44.952 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:44.952 | DTC Client socket (3) | New receive buffer size: 0 2024-04-29 17:36:44.952 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:44.965 | HD Request # 7 | Requesting Intraday data. Start date-time: 2024-04-29 17:19:29. Record interval: 0. Symbol: SPY 2024-04-29 17:36:45.005 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:36:45.005 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:36:45.005 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:36:45.005 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:36:45.013 | HD Request # 7 | Decompressing data. 2024-04-29 17:36:45.100 | HD Request # 7 | Receiving Intraday data for SPY starting at 2024-04-29 17:19:29.376000 2024-04-29 17:36:45.101 | Socket (6) | CloseSocket call. 2024-04-29 17:36:45.101 | Socket (6) | Shutdown started. Waiting for graceful close. 2024-04-29 17:36:45.101 | Historical data download thread signaled to stop. 2024-04-29 17:36:45.101 | HD Request # 7 | Timestamp of first Intraday data file record written: 2024-04-29 17:19:29.847002. 2024-04-29 17:36:45.101 | HD Request # 7 | Received 1437 Intraday data records from 2024-04-29 17:19:29.376000 to 2024-04-29 17:21:43.904000 (2.2 minutes. Delay: 15.0 minutes) and wrote 617 records for SPY 2024-04-29 17:36:45.102 | HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2024-04-29 17:21:43.828002 2024-04-29 17:36:45.102 | Added 4 Time and Sales records to Intraday data file for SPY after download. 2024-04-29 17:36:45.102 | HD Request # 7 | Completion time: 1s. 2024-04-29 17:36:45.102 | HD Request # 7 | Intraday data download complete for SPY. Unique request ID: 7 2024-04-29 17:36:45.102 | Removing historical data download ID 7. 2024-04-29 17:36:45.102 | Real-time Intraday chart data file updates started for SPY 2024-04-29 17:36:45.102 | Intraday chart data file opened for SPY 2024-04-29 17:36:45.102 | HD Request # 7 | Enabling Intraday chart updating for symbol. 2024-04-29 17:36:45.102 | 2024-04-29 17:36:45.102 | No download requests in the queue to start downloads for. 2024-04-29 17:36:45.142 | Socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:36:45.142 | Socket (6) | Closed. 2024-04-29 17:36:45.172 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:36:45.172 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:36:45.172 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:45.172 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:36:45.172 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:36:45.172 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:36:45.172 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:36:45.172 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:36:45.172 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:36:45.172 | Triggering next historical data download in queue. 2024-04-29 17:36:45.172 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:36:45.172 | HD Request # 8 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:36:45.172 | HD Request # 8 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:36:45.172 | HD Request # 8 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:36:45.172 | Socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:45.172 | Socket (6) | New receive buffer size: 0 2024-04-29 17:36:45.172 | Socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:45.225 | HD Request # 8 | Sending historical data logon request message. 2024-04-29 17:36:45.226 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-04-29 17:36:45.226 | DTC Client socket (3) | CloseSocket call. 2024-04-29 17:36:45.226 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:36:45.226 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:36:45.226 | DTC Client socket (3) | Closed. 2024-04-29 17:36:45.226 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:36:45.226 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:36:45.226 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:36:45.346 | Opened cached Intraday file: C:\SierraChart2\Data\AAPL-NQTV.scid. Thread ID: 123844 2024-04-29 17:36:45.389 | HD Request # 8 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:36:45.417 | Opened cached Intraday file: C:\SierraChart2\Data\SPY.scid. Thread ID: 122048 2024-04-29 17:36:45.444 | Socket (6) | CloseSocket call. 2024-04-29 17:36:45.444 | HD Request # 8 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:36:45.444 | Historical data download thread signaled to stop. 2024-04-29 17:36:45.444 | Socket (6) | Shutdown started. Waiting for graceful close. 2024-04-29 17:36:45.444 | HD Request # 8 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:36:45.444 | HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:36:45.444 | HD Request # 8 | Completion time: 0s. 2024-04-29 17:36:45.444 | HD Request # 8 | Intraday data download complete for ESM24-CME. Unique request ID: 8 2024-04-29 17:36:45.444 | Removing historical data download ID 8. 2024-04-29 17:36:45.444 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:36:45.444 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:36:45.444 | HD Request # 8 | Enabling Intraday chart updating for symbol. 2024-04-29 17:36:45.444 | 2024-04-29 17:36:45.444 | No download requests in the queue to start downloads for. 2024-04-29 17:36:45.498 | Socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:36:45.498 | Socket (6) | Closed. 2024-04-29 17:36:47.220 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:36:47.220 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:36:47.221 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:47.221 | DTC Client socket (3) | New receive buffer size: 0 2024-04-29 17:36:47.221 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:47.273 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:36:47.273 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:36:47.273 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:36:47.273 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:36:47.438 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:36:47.438 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:36:47.438 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:47.438 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:36:47.438 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:36:47.438 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:36:47.438 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:36:47.438 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:36:47.438 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:36:47.438 | Triggering next historical data download in queue. 2024-04-29 17:36:47.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:36:47.438 | HD Request # 9 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:36:47.438 | HD Request # 9 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:36:47.438 | HD Request # 9 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:36:47.438 | Socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:47.438 | Socket (6) | New receive buffer size: 0 2024-04-29 17:36:47.438 | Socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:47.490 | HD Request # 9 | Sending historical data logon request message. 2024-04-29 17:36:47.491 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-04-29 17:36:47.491 | DTC Client socket (3) | CloseSocket call. 2024-04-29 17:36:47.491 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:36:47.491 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:36:47.491 | DTC Client socket (3) | Closed. 2024-04-29 17:36:47.491 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:36:47.491 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:36:47.491 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:36:47.655 | HD Request # 9 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:36:47.710 | Socket (6) | CloseSocket call. 2024-04-29 17:36:47.710 | HD Request # 9 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:36:47.710 | Socket (6) | Shutdown started. Waiting for graceful close. 2024-04-29 17:36:47.710 | Historical data download thread signaled to stop. 2024-04-29 17:36:47.710 | HD Request # 9 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:36:47.710 | HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:36:47.710 | HD Request # 9 | Completion time: 0s. 2024-04-29 17:36:47.710 | HD Request # 9 | Intraday data download complete for ESM24-CME. Unique request ID: 9 2024-04-29 17:36:47.710 | Removing historical data download ID 9. 2024-04-29 17:36:47.710 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:36:47.710 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:36:47.710 | HD Request # 9 | Enabling Intraday chart updating for symbol. 2024-04-29 17:36:47.710 | 2024-04-29 17:36:47.710 | No download requests in the queue to start downloads for. 2024-04-29 17:36:47.766 | Socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:36:47.766 | Socket (6) | Closed. 2024-04-29 17:36:49.488 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:36:49.488 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:36:49.490 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:49.490 | DTC Client socket (3) | New receive buffer size: 0 2024-04-29 17:36:49.490 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:49.544 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:36:49.544 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:36:49.544 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:36:49.544 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:36:49.727 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:36:49.727 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:36:49.727 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:49.727 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:36:49.727 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:36:49.727 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:36:49.727 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:36:49.727 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:36:49.727 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:36:49.727 | Triggering next historical data download in queue. 2024-04-29 17:36:49.727 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:36:49.727 | HD Request # 10 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:36:49.727 | HD Request # 10 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:36:49.727 | HD Request # 10 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:36:49.727 | Socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:49.727 | Socket (6) | New receive buffer size: 0 2024-04-29 17:36:49.727 | Socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:49.780 | HD Request # 10 | Sending historical data logon request message. 2024-04-29 17:36:49.781 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-04-29 17:36:49.781 | DTC Client socket (3) | CloseSocket call. 2024-04-29 17:36:49.781 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:36:49.781 | DTC Client socket (3) | Closed. 2024-04-29 17:36:49.781 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:36:49.781 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:36:49.781 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:36:49.781 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:36:49.944 | HD Request # 10 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:36:49.997 | Socket (6) | CloseSocket call. 2024-04-29 17:36:49.997 | HD Request # 10 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:36:49.997 | Socket (6) | Shutdown started. Waiting for graceful close. 2024-04-29 17:36:49.998 | Historical data download thread signaled to stop. 2024-04-29 17:36:49.998 | HD Request # 10 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:36:49.998 | HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:36:49.998 | HD Request # 10 | Completion time: 0s. 2024-04-29 17:36:49.998 | HD Request # 10 | Intraday data download complete for ESM24-CME. Unique request ID: 10 2024-04-29 17:36:49.998 | Removing historical data download ID 10. 2024-04-29 17:36:49.998 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:36:49.998 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:36:49.998 | HD Request # 10 | Enabling Intraday chart updating for symbol. 2024-04-29 17:36:49.998 | 2024-04-29 17:36:49.998 | No download requests in the queue to start downloads for. 2024-04-29 17:36:50.051 | Socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:36:50.051 | Socket (6) | Closed. 2024-04-29 17:36:51.772 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:36:51.772 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:36:51.772 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:51.772 | DTC Client socket (3) | New receive buffer size: 0 2024-04-29 17:36:51.772 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:51.848 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:36:51.848 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:36:51.848 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:36:51.848 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:36:52.021 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:36:52.021 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:36:52.021 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:52.021 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:36:52.021 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:36:52.021 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:36:52.021 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:36:52.021 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:36:52.021 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:36:52.021 | Triggering next historical data download in queue. 2024-04-29 17:36:52.021 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:36:52.021 | HD Request # 11 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:36:52.021 | HD Request # 11 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:36:52.021 | HD Request # 11 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:36:52.021 | Socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:52.021 | Socket (6) | New receive buffer size: 0 2024-04-29 17:36:52.021 | Socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:52.075 | HD Request # 11 | Sending historical data logon request message. 2024-04-29 17:36:52.075 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-04-29 17:36:52.075 | DTC Client socket (3) | CloseSocket call. 2024-04-29 17:36:52.076 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:36:52.076 | DTC Client socket (3) | Closed. 2024-04-29 17:36:52.076 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:36:52.077 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:36:52.077 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:36:52.077 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:36:52.244 | HD Request # 11 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:36:52.298 | Socket (6) | CloseSocket call. 2024-04-29 17:36:52.298 | Socket (6) | Shutdown started. Waiting for graceful close. 2024-04-29 17:36:52.298 | HD Request # 11 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:36:52.298 | Historical data download thread signaled to stop. 2024-04-29 17:36:52.298 | HD Request # 11 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:36:52.298 | HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:36:52.298 | HD Request # 11 | Completion time: 0s. 2024-04-29 17:36:52.298 | HD Request # 11 | Intraday data download complete for ESM24-CME. Unique request ID: 11 2024-04-29 17:36:52.298 | Removing historical data download ID 11. 2024-04-29 17:36:52.298 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:36:52.298 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:36:52.298 | HD Request # 11 | Enabling Intraday chart updating for symbol. 2024-04-29 17:36:52.298 | 2024-04-29 17:36:52.298 | No download requests in the queue to start downloads for. 2024-04-29 17:36:52.350 | Socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:36:52.350 | Socket (6) | Closed. 2024-04-29 17:36:54.070 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:36:54.070 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:36:54.071 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:54.071 | DTC Client socket (3) | New receive buffer size: 0 2024-04-29 17:36:54.071 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:54.123 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:36:54.123 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:36:54.124 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:36:54.124 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:36:54.287 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:36:54.287 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:36:54.287 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:54.287 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:36:54.287 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:36:54.287 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:36:54.287 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:36:54.287 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:36:54.287 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:36:54.287 | Triggering next historical data download in queue. 2024-04-29 17:36:54.287 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:36:54.287 | HD Request # 12 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:36:54.287 | HD Request # 12 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:36:54.287 | HD Request # 12 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:36:54.288 | Socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:54.288 | Socket (6) | New receive buffer size: 0 2024-04-29 17:36:54.288 | Socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:54.341 | HD Request # 12 | Sending historical data logon request message. 2024-04-29 17:36:54.341 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-04-29 17:36:54.341 | DTC Client socket (3) | CloseSocket call. 2024-04-29 17:36:54.341 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:36:54.341 | DTC Client socket (3) | Closed. 2024-04-29 17:36:54.342 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:36:54.342 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:36:54.342 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:36:54.342 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:36:54.506 | HD Request # 12 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:36:54.558 | Socket (6) | CloseSocket call. 2024-04-29 17:36:54.558 | HD Request # 12 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:36:54.558 | Historical data download thread signaled to stop. 2024-04-29 17:36:54.558 | HD Request # 12 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:36:54.558 | Socket (6) | Shutdown started. Waiting for graceful close. 2024-04-29 17:36:54.558 | HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:36:54.558 | HD Request # 12 | Completion time: 0s. 2024-04-29 17:36:54.558 | HD Request # 12 | Intraday data download complete for ESM24-CME. Unique request ID: 12 2024-04-29 17:36:54.558 | Removing historical data download ID 12. 2024-04-29 17:36:54.558 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:36:54.558 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:36:54.558 | HD Request # 12 | Enabling Intraday chart updating for symbol. 2024-04-29 17:36:54.558 | 2024-04-29 17:36:54.558 | No download requests in the queue to start downloads for. 2024-04-29 17:36:54.613 | Socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:36:54.613 | Socket (6) | Closed. 2024-04-29 17:36:55.116 | MESM4.CME 1 Min #1 | Reloading chart. 2024-04-29 17:36:55.509 | Mapping MESM4.CME to MESM24. Service code: cme 2024-04-29 17:36:55.510 | Denali Data Feed | Starting real-time market data updates for: MESM4.CME (MESM24). ID: 9 Service code: cme 2024-04-29 17:36:55.512 | Denali Data Feed | Connecting to the server ds26.sierracharts.com. Port 10048 2024-04-29 17:36:55.512 | DTC Client socket (3) | Creating socket. 2024-04-29 17:36:55.512 | DTC Client socket (3) | New receive buffer size: 0 2024-04-29 17:36:55.512 | DTC Client socket (3) | Connecting to IP: 38.103.112.197. 2024-04-29 17:36:55.514 | Denali Data Feed | Requesting security definition data for: MESM4.CME (MESM24). ID: 9 2024-04-29 17:36:55.514 | Added historical Intraday data request for MESM4.CME to the queue. 2024-04-29 17:36:55.514 | Intraday data recording state for symbol MESM4.CME is set to download 'Pending'. 2024-04-29 17:36:55.514 | Triggering next historical data download in queue. 2024-04-29 17:36:55.515 | Delaying start of download for MESM4.CME. 2024-04-29 17:36:55.553 | Denali Data Feed | Network connection to server complete. 2024-04-29 17:36:55.553 | Denali Data Feed | Starting socket receive thread. 2024-04-29 17:36:55.553 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-04-29 17:36:55.615 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-04-29 17:36:55.615 | Denali Data Feed | Sending logon request message. 2024-04-29 17:36:55.757 | MESM4.CME[M] 1 Min #1 | Chart data loading complete. 2024-04-29 17:36:56.147 | Denali Data Feed | Received logon response. 2024-04-29 17:36:56.147 | Denali Data Feed | Server Name: SC Realtime Server. 2024-04-29 17:36:56.147 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:56.147 | Denali Data Feed | Successfully connected. 2024-04-29 17:36:56.147 | Denali Data Feed | Trading is not supported. 2024-04-29 17:36:56.147 | Denali Data Feed | MarketDepthIsSupported: 1 2024-04-29 17:36:56.147 | Denali Data Feed | Restarting real-time data updates for symbol: MESM4.CME -> MESM24 2024-04-29 17:36:56.272 | Denali Data Feed | Received security definition for symbol MESM4.CME 2024-04-29 17:36:56.322 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:36:56.322 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:36:56.322 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:56.322 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:36:56.322 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:56.377 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:36:56.377 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:36:56.377 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:36:56.377 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:36:56.543 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:36:56.543 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:36:56.543 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:56.543 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:36:56.543 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:36:56.543 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:36:56.543 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:36:56.543 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:36:56.543 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:36:56.543 | Triggering next historical data download in queue. 2024-04-29 17:36:56.543 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:36:56.598 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:36:56.598 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:36:56.598 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:36:56.598 | DTC Client socket (6) | Closed. 2024-04-29 17:36:56.598 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:36:56.598 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:36:56.598 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:36:56.598 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:36:58.592 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:36:58.592 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:36:58.592 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:36:58.592 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:36:58.592 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:36:58.647 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:36:58.647 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:36:58.647 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:36:58.647 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:36:58.810 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:36:58.810 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:36:58.810 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:36:58.810 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:36:58.810 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:36:58.810 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:36:58.810 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:36:58.810 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:36:58.866 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:36:58.866 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:36:58.866 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:36:58.866 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:36:58.866 | DTC Client socket (6) | Closed. 2024-04-29 17:36:58.867 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:36:58.867 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:36:58.867 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:00.867 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:00.867 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:00.868 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:00.868 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:00.868 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:00.922 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:00.922 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:00.922 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:00.922 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:01.086 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:01.086 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:01.086 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:01.086 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:01.086 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:01.086 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:01.086 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:01.086 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:01.139 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:01.139 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:01.139 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:01.139 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:01.139 | DTC Client socket (6) | Closed. 2024-04-29 17:37:01.140 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:01.140 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:01.140 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:01.618 | HD Request # 13 | Downloading Intraday chart data for MESM4.CME to the file MESM4.CME.scid. Service: cme 2024-04-29 17:37:01.619 | HD Request # 13 | Download start date-time: 2024-04-26 01:46:05.000000. File last date-time: 2024-04-26 01:46:05.275003 2024-04-29 17:37:01.619 | HD Request # 13 | Using server: ds13.sierracharts.com port 10149 2024-04-29 17:37:01.619 | Socket (6) | Creating socket. 2024-04-29 17:37:01.619 | Socket (6) | New receive buffer size: 0 2024-04-29 17:37:01.619 | Socket (6) | Connecting to IP: 38.142.170.155. 2024-04-29 17:37:01.766 | HD Request # 13 | Setting DTC encoding to Binary VLS 2024-04-29 17:37:01.766 | HD Request # 13 | Sending historical data logon request message. 2024-04-29 17:37:01.878 | HD Request # 13 | Requesting Intraday data. Start date-time: 2024-04-26 01:46:05. Record interval: 0. Symbol: MESM24 2024-04-29 17:37:01.942 | HD Request # 13 | Decompressing data. 2024-04-29 17:37:02.099 | HD Request # 13 | Receiving Intraday data for MESM4.CME starting at 2024-04-26 01:46:05.275000 2024-04-29 17:37:02.353 | HD Request # 13 | Timestamp of first Intraday data file record written: 2024-04-26 01:46:08.841000. 2024-04-29 17:37:03.127 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:03.127 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:03.127 | DTC Client socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:03.127 | DTC Client socket (7) | New receive buffer size: 0 2024-04-29 17:37:03.127 | DTC Client socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:03.180 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:03.180 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:03.180 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:03.180 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:03.349 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:03.349 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:03.349 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:03.349 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:03.349 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:03.349 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:03.349 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:03.349 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:03.403 | DTC Client socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:03.404 | DTC Client socket (7) | CloseSocket call. 2024-04-29 17:37:03.404 | DTC Client socket (7) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:03.404 | DTC Client socket (7) | Closed. 2024-04-29 17:37:03.404 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:03.404 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:03.404 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:03.404 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:04.266 | Socket (6) | CloseSocket call. 2024-04-29 17:37:04.266 | Socket (6) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:04.266 | Historical data download thread signaled to stop. 2024-04-29 17:37:04.266 | HD Request # 13 | Received 668589 Intraday data records from 2024-04-26 01:46:05.275000 to 2024-04-29 17:37:00.961000 (3.7 days. Delay: 3.3 seconds) and wrote 668585 records for MESM4.CME 2024-04-29 17:37:04.266 | HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2024-04-29 17:37:00.961000 2024-04-29 17:37:04.266 | Added 26 Time and Sales records to Intraday data file for MESM4.CME after download. 2024-04-29 17:37:04.267 | HD Request # 13 | Completion time: 3s. 2024-04-29 17:37:04.267 | HD Request # 13 | Intraday data download complete for MESM4.CME. Unique request ID: 13 2024-04-29 17:37:04.267 | Removing historical data download ID 13. 2024-04-29 17:37:04.267 | Real-time Intraday chart data file updates started for MESM4.CME 2024-04-29 17:37:04.267 | Intraday chart data file opened for MESM4.CME 2024-04-29 17:37:04.267 | HD Request # 13 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:04.267 | 2024-04-29 17:37:04.267 | Triggering next historical data download in queue. 2024-04-29 17:37:04.267 | HD Request # 14 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:04.267 | HD Request # 14 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:04.267 | HD Request # 14 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:04.267 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:04.267 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:04.267 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:04.321 | HD Request # 14 | Sending historical data logon request message. 2024-04-29 17:37:04.332 | Socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:04.332 | Socket (6) | Closed. 2024-04-29 17:37:04.482 | HD Request # 14 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:04.537 | Socket (7) | CloseSocket call. 2024-04-29 17:37:04.537 | HD Request # 14 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:04.537 | Historical data download thread signaled to stop. 2024-04-29 17:37:04.537 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:04.537 | HD Request # 14 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:04.537 | HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:04.537 | HD Request # 14 | Completion time: 0s. 2024-04-29 17:37:04.537 | HD Request # 14 | Intraday data download complete for ESM24-CME. Unique request ID: 14 2024-04-29 17:37:04.537 | Removing historical data download ID 14. 2024-04-29 17:37:04.537 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:04.537 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:04.537 | HD Request # 14 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:04.537 | 2024-04-29 17:37:04.537 | No download requests in the queue to start downloads for. 2024-04-29 17:37:04.592 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:04.592 | Socket (7) | Closed. 2024-04-29 17:37:04.714 | Opened cached Intraday file: C:\SierraChart2\Data\MESM4.CME.scid. Thread ID: 130408 2024-04-29 17:37:05.389 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:05.389 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:05.389 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:05.390 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:05.390 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:05.442 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:05.442 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:05.442 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:05.442 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:05.607 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:05.607 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:05.607 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:05.607 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:05.607 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:05.607 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:05.607 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:05.607 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:37:05.607 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:37:05.607 | Triggering next historical data download in queue. 2024-04-29 17:37:05.607 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:05.607 | HD Request # 15 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:05.607 | HD Request # 15 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:05.607 | HD Request # 15 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:05.607 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:05.608 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:05.608 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:05.660 | HD Request # 15 | Sending historical data logon request message. 2024-04-29 17:37:05.661 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:05.661 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:05.661 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:05.661 | DTC Client socket (6) | Closed. 2024-04-29 17:37:05.661 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:05.661 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:05.661 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:05.661 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:05.826 | HD Request # 15 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:05.882 | Socket (7) | CloseSocket call. 2024-04-29 17:37:05.883 | HD Request # 15 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:05.883 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:05.883 | Historical data download thread signaled to stop. 2024-04-29 17:37:05.883 | HD Request # 15 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:05.883 | HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:05.883 | HD Request # 15 | Completion time: 0s. 2024-04-29 17:37:05.883 | HD Request # 15 | Intraday data download complete for ESM24-CME. Unique request ID: 15 2024-04-29 17:37:05.883 | Removing historical data download ID 15. 2024-04-29 17:37:05.883 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:05.883 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:05.883 | HD Request # 15 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:05.883 | 2024-04-29 17:37:05.883 | No download requests in the queue to start downloads for. 2024-04-29 17:37:05.937 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:05.937 | Socket (7) | Closed. 2024-04-29 17:37:07.661 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:07.661 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:07.662 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:07.662 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:07.662 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:07.714 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:07.714 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:07.714 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:07.714 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:07.877 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:07.877 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:07.877 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:07.877 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:07.877 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:07.877 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:07.877 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:07.877 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:37:07.877 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:37:07.877 | Triggering next historical data download in queue. 2024-04-29 17:37:07.877 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:07.877 | HD Request # 16 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:07.878 | HD Request # 16 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:07.878 | HD Request # 16 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:07.878 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:07.878 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:07.878 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:07.905 | ESM4.CME[M] 1 Min #1 | Reloading chart. 2024-04-29 17:37:07.931 | HD Request # 16 | Sending historical data logon request message. 2024-04-29 17:37:07.932 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:07.932 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:07.932 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:07.932 | DTC Client socket (6) | Closed. 2024-04-29 17:37:07.932 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:07.932 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:07.932 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:07.932 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:08.095 | HD Request # 16 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:08.148 | Socket (7) | CloseSocket call. 2024-04-29 17:37:08.148 | HD Request # 16 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:08.148 | Historical data download thread signaled to stop. 2024-04-29 17:37:08.148 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:08.148 | HD Request # 16 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:08.148 | HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:08.148 | HD Request # 16 | Completion time: 1s. 2024-04-29 17:37:08.148 | HD Request # 16 | Intraday data download complete for ESM24-CME. Unique request ID: 16 2024-04-29 17:37:08.148 | Removing historical data download ID 16. 2024-04-29 17:37:08.148 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:08.148 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:08.148 | HD Request # 16 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:08.148 | 2024-04-29 17:37:08.148 | No download requests in the queue to start downloads for. 2024-04-29 17:37:08.189 | ESM4.CME[M] 1 Min #1 | Chart data loading complete. 2024-04-29 17:37:08.202 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:08.202 | Socket (7) | Closed. 2024-04-29 17:37:08.303 | Mapping ESM4.CME to ESM24. Service code: cme 2024-04-29 17:37:08.304 | Denali Data Feed | Starting real-time market data updates for: ESM4.CME (ESM24). ID: 10 Service code: cme 2024-04-29 17:37:08.304 | Denali Data Feed | Requesting security definition data for: ESM4.CME (ESM24). ID: 10 2024-04-29 17:37:08.304 | Added historical Intraday data request for ESM4.CME to the queue. 2024-04-29 17:37:08.304 | Intraday data recording state for symbol ESM4.CME is set to download 'Pending'. 2024-04-29 17:37:08.304 | Triggering next historical data download in queue. 2024-04-29 17:37:08.306 | Delaying start of download for ESM4.CME. 2024-04-29 17:37:08.430 | Denali Data Feed | Received security definition for symbol ESM4.CME 2024-04-29 17:37:09.919 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:09.919 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:09.920 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:09.920 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:09.920 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:09.973 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:09.973 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:09.973 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:09.973 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:10.137 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:10.137 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:10.137 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:10.137 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:10.137 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:10.137 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:10.137 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:10.137 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:37:10.137 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:37:10.137 | Triggering next historical data download in queue. 2024-04-29 17:37:10.137 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:10.191 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:10.191 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:10.191 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:10.191 | DTC Client socket (6) | Closed. 2024-04-29 17:37:10.192 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:10.192 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:10.192 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:10.192 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:12.191 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:12.191 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:12.191 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:12.191 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:12.191 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:12.247 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:12.247 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:12.247 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:12.247 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:12.415 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:12.415 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:12.415 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:12.415 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:12.415 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:12.415 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:12.415 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:12.415 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:12.469 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:12.469 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:12.469 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:12.469 | DTC Client socket (6) | Closed. 2024-04-29 17:37:12.469 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:12.470 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:12.470 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:12.470 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:13.631 | HD Request # 17 | Downloading Intraday chart data for ESM4.CME to the file ESM4.CME.scid. Service: cme 2024-04-29 17:37:13.631 | HD Request # 17 | Download start date-time: 2024-04-29 17:35:08.000000. File last date-time: 2024-04-29 17:35:08.492000 2024-04-29 17:37:13.631 | HD Request # 17 | Using server: ds23.sierracharts.com port 10149 2024-04-29 17:37:13.631 | Socket (6) | Creating socket. 2024-04-29 17:37:13.631 | Socket (6) | New receive buffer size: 0 2024-04-29 17:37:13.631 | Socket (6) | Connecting to IP: 38.103.112.183. 2024-04-29 17:37:13.721 | HD Request # 17 | Setting DTC encoding to Binary VLS 2024-04-29 17:37:13.721 | HD Request # 17 | Sending historical data logon request message. 2024-04-29 17:37:14.013 | HD Request # 17 | Requesting Intraday data. Start date-time: 2024-04-29 17:35:08. Record interval: 0. Symbol: ESM24 2024-04-29 17:37:14.053 | HD Request # 17 | Decompressing data. 2024-04-29 17:37:14.134 | HD Request # 17 | Receiving Intraday data for ESM4.CME starting at 2024-04-29 17:35:08.492000 2024-04-29 17:37:14.136 | Socket (6) | CloseSocket call. 2024-04-29 17:37:14.136 | Socket (6) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:14.136 | Historical data download thread signaled to stop. 2024-04-29 17:37:14.136 | HD Request # 17 | Timestamp of first Intraday data file record written: 2024-04-29 17:35:09.691000. 2024-04-29 17:37:14.137 | HD Request # 17 | Received 1308 Intraday data records from 2024-04-29 17:35:08.492000 to 2024-04-29 17:37:12.972000 (2.1 minutes. Delay: 1.2 seconds) and wrote 1307 records for ESM4.CME 2024-04-29 17:37:14.137 | HD Request # 17 | Add time&sales data | Remembered last file record date-time: 2024-04-29 17:37:12.972000 2024-04-29 17:37:14.137 | HD Request # 17 | Completion time: 1s. 2024-04-29 17:37:14.137 | HD Request # 17 | Intraday data download complete for ESM4.CME. Unique request ID: 17 2024-04-29 17:37:14.137 | Removing historical data download ID 17. 2024-04-29 17:37:14.137 | Real-time Intraday chart data file updates started for ESM4.CME 2024-04-29 17:37:14.137 | Intraday chart data file opened for ESM4.CME 2024-04-29 17:37:14.137 | HD Request # 17 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:14.137 | 2024-04-29 17:37:14.137 | Triggering next historical data download in queue. 2024-04-29 17:37:14.137 | HD Request # 18 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:14.137 | HD Request # 18 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:14.137 | HD Request # 18 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:14.138 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:14.138 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:14.138 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:14.178 | Socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:14.178 | Socket (6) | Closed. 2024-04-29 17:37:14.193 | HD Request # 18 | Sending historical data logon request message. 2024-04-29 17:37:14.357 | HD Request # 18 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:14.410 | Socket (7) | CloseSocket call. 2024-04-29 17:37:14.410 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:14.410 | HD Request # 18 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:14.410 | Historical data download thread signaled to stop. 2024-04-29 17:37:14.410 | HD Request # 18 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:14.410 | HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:14.410 | HD Request # 18 | Completion time: 0s. 2024-04-29 17:37:14.410 | HD Request # 18 | Intraday data download complete for ESM24-CME. Unique request ID: 18 2024-04-29 17:37:14.410 | Removing historical data download ID 18. 2024-04-29 17:37:14.410 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:14.410 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:14.410 | HD Request # 18 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:14.410 | 2024-04-29 17:37:14.410 | No download requests in the queue to start downloads for. 2024-04-29 17:37:14.447 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:14.447 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:14.447 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:14.448 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:14.448 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:14.466 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:14.466 | Socket (7) | Closed. 2024-04-29 17:37:14.503 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:14.503 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:14.503 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:14.503 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:14.710 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:14.710 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:14.710 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:14.710 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:14.710 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:14.710 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:14.710 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:14.710 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:37:14.710 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:37:14.710 | Triggering next historical data download in queue. 2024-04-29 17:37:14.710 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:14.710 | HD Request # 19 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:14.710 | HD Request # 19 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:14.710 | HD Request # 19 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:14.710 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:14.710 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:14.710 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:14.763 | HD Request # 19 | Sending historical data logon request message. 2024-04-29 17:37:14.763 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:14.763 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:14.763 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:14.763 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:14.763 | DTC Client socket (6) | Closed. 2024-04-29 17:37:14.763 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:14.763 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:14.763 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:14.926 | HD Request # 19 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:14.980 | Socket (7) | CloseSocket call. 2024-04-29 17:37:14.980 | HD Request # 19 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:14.980 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:14.980 | Historical data download thread signaled to stop. 2024-04-29 17:37:14.980 | HD Request # 19 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:14.980 | HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:14.980 | HD Request # 19 | Completion time: 0s. 2024-04-29 17:37:14.980 | HD Request # 19 | Intraday data download complete for ESM24-CME. Unique request ID: 19 2024-04-29 17:37:14.980 | Removing historical data download ID 19. 2024-04-29 17:37:14.980 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:14.980 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:14.980 | HD Request # 19 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:14.980 | 2024-04-29 17:37:14.980 | No download requests in the queue to start downloads for. 2024-04-29 17:37:15.035 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:15.035 | Socket (7) | Closed. 2024-04-29 17:37:16.759 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:16.759 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:16.759 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:16.759 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:16.759 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:16.812 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:16.812 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:16.812 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:16.812 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:16.977 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:16.977 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:16.977 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:16.977 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:16.977 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:16.977 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:16.977 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:16.977 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:37:16.977 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:37:16.977 | Triggering next historical data download in queue. 2024-04-29 17:37:16.977 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:16.977 | HD Request # 20 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:16.977 | HD Request # 20 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:16.977 | HD Request # 20 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:16.977 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:16.978 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:16.978 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:17.030 | HD Request # 20 | Sending historical data logon request message. 2024-04-29 17:37:17.030 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:17.030 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:17.030 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:17.030 | DTC Client socket (6) | Closed. 2024-04-29 17:37:17.031 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:17.031 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:17.031 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:17.031 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:17.194 | HD Request # 20 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:17.247 | Socket (7) | CloseSocket call. 2024-04-29 17:37:17.247 | HD Request # 20 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:17.247 | Historical data download thread signaled to stop. 2024-04-29 17:37:17.247 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:17.247 | HD Request # 20 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:17.247 | HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:17.247 | HD Request # 20 | Completion time: 1s. 2024-04-29 17:37:17.247 | HD Request # 20 | Intraday data download complete for ESM24-CME. Unique request ID: 20 2024-04-29 17:37:17.247 | Removing historical data download ID 20. 2024-04-29 17:37:17.247 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:17.247 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:17.247 | HD Request # 20 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:17.247 | 2024-04-29 17:37:17.247 | No download requests in the queue to start downloads for. 2024-04-29 17:37:17.303 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:17.303 | Socket (7) | Closed. 2024-04-29 17:37:19.027 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:19.027 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:19.027 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:19.027 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:19.027 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:19.080 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:19.080 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:19.080 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:19.080 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:19.243 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:19.243 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:19.243 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:19.243 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:19.243 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:19.243 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:19.243 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:19.243 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:37:19.243 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:37:19.243 | Triggering next historical data download in queue. 2024-04-29 17:37:19.243 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:19.243 | HD Request # 21 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:19.244 | HD Request # 21 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:19.244 | HD Request # 21 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:19.244 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:19.244 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:19.244 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:19.297 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:19.297 | HD Request # 21 | Sending historical data logon request message. 2024-04-29 17:37:19.297 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:19.297 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:19.297 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:19.297 | DTC Client socket (6) | Closed. 2024-04-29 17:37:19.297 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:19.297 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:19.297 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:19.465 | HD Request # 21 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:19.517 | Socket (7) | CloseSocket call. 2024-04-29 17:37:19.517 | HD Request # 21 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:19.517 | Historical data download thread signaled to stop. 2024-04-29 17:37:19.517 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:19.517 | HD Request # 21 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:19.517 | HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:19.517 | HD Request # 21 | Completion time: 0s. 2024-04-29 17:37:19.517 | HD Request # 21 | Intraday data download complete for ESM24-CME. Unique request ID: 21 2024-04-29 17:37:19.517 | Removing historical data download ID 21. 2024-04-29 17:37:19.517 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:19.517 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:19.517 | HD Request # 21 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:19.517 | 2024-04-29 17:37:19.517 | No download requests in the queue to start downloads for. 2024-04-29 17:37:19.572 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:19.572 | Socket (7) | Closed. 2024-04-29 17:37:19.777 | Opened cached Intraday file: C:\SierraChart2\Data\ESM4.CME.scid. Thread ID: 130408 2024-04-29 17:37:21.298 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:21.298 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:21.298 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:21.298 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:21.298 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:21.353 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:21.353 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:21.353 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:21.353 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:21.518 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:21.518 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:21.518 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:21.518 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:21.518 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:21.518 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:21.518 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:21.519 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:37:21.519 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:37:21.519 | Triggering next historical data download in queue. 2024-04-29 17:37:21.519 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:21.519 | HD Request # 22 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:21.519 | HD Request # 22 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:21.519 | HD Request # 22 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:21.520 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:21.520 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:21.520 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:21.573 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:21.573 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:21.573 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:21.573 | DTC Client socket (6) | Closed. 2024-04-29 17:37:21.573 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:21.573 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:21.573 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:21.573 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:21.574 | HD Request # 22 | Sending historical data logon request message. 2024-04-29 17:37:21.740 | HD Request # 22 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:21.795 | Socket (7) | CloseSocket call. 2024-04-29 17:37:21.795 | HD Request # 22 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:21.795 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:21.795 | Historical data download thread signaled to stop. 2024-04-29 17:37:21.795 | HD Request # 22 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:21.795 | HD Request # 22 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:21.795 | HD Request # 22 | Completion time: 0s. 2024-04-29 17:37:21.795 | HD Request # 22 | Intraday data download complete for ESM24-CME. Unique request ID: 22 2024-04-29 17:37:21.795 | Removing historical data download ID 22. 2024-04-29 17:37:21.795 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:21.795 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:21.795 | HD Request # 22 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:21.795 | 2024-04-29 17:37:21.795 | No download requests in the queue to start downloads for. 2024-04-29 17:37:21.850 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:21.850 | Socket (7) | Closed. 2024-04-29 17:37:23.565 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:23.565 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:23.566 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:23.566 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:23.566 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:23.619 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:23.619 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:23.619 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:23.619 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:23.786 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:23.786 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:23.786 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:23.786 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:23.786 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:23.786 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:23.786 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:23.786 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:37:23.786 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:37:23.786 | Triggering next historical data download in queue. 2024-04-29 17:37:23.786 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:23.786 | HD Request # 23 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:23.786 | HD Request # 23 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:23.786 | HD Request # 23 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:23.786 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:23.786 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:23.786 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:23.839 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:23.839 | HD Request # 23 | Sending historical data logon request message. 2024-04-29 17:37:23.839 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:23.839 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:23.839 | DTC Client socket (6) | Closed. 2024-04-29 17:37:23.839 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:23.840 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:23.840 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:23.840 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:24.008 | HD Request # 23 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:24.063 | Socket (7) | CloseSocket call. 2024-04-29 17:37:24.063 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:24.063 | HD Request # 23 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:24.063 | Historical data download thread signaled to stop. 2024-04-29 17:37:24.063 | HD Request # 23 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:24.063 | HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:24.063 | HD Request # 23 | Completion time: 1s. 2024-04-29 17:37:24.063 | HD Request # 23 | Intraday data download complete for ESM24-CME. Unique request ID: 23 2024-04-29 17:37:24.063 | Removing historical data download ID 23. 2024-04-29 17:37:24.063 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:24.063 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:24.063 | HD Request # 23 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:24.063 | 2024-04-29 17:37:24.063 | No download requests in the queue to start downloads for. 2024-04-29 17:37:24.117 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:24.117 | Socket (7) | Closed. 2024-04-29 17:37:25.836 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:25.836 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:25.836 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:25.836 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:25.836 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:25.891 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:25.891 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:25.891 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:25.891 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:26.059 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:26.059 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:26.059 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:26.059 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:26.059 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:26.059 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:26.059 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:26.059 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:37:26.059 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:37:26.059 | Triggering next historical data download in queue. 2024-04-29 17:37:26.059 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:26.059 | HD Request # 24 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:26.059 | HD Request # 24 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:26.059 | HD Request # 24 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:26.059 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:26.059 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:26.059 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:26.112 | HD Request # 24 | Sending historical data logon request message. 2024-04-29 17:37:26.112 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:26.112 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:26.113 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:26.113 | DTC Client socket (6) | Closed. 2024-04-29 17:37:26.113 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:26.113 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:26.113 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:26.113 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:26.280 | HD Request # 24 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:26.334 | Socket (7) | CloseSocket call. 2024-04-29 17:37:26.334 | HD Request # 24 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:26.334 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:26.334 | Historical data download thread signaled to stop. 2024-04-29 17:37:26.334 | HD Request # 24 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:26.334 | HD Request # 24 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:26.334 | HD Request # 24 | Completion time: 0s. 2024-04-29 17:37:26.334 | HD Request # 24 | Intraday data download complete for ESM24-CME. Unique request ID: 24 2024-04-29 17:37:26.334 | Removing historical data download ID 24. 2024-04-29 17:37:26.334 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:26.334 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:26.334 | HD Request # 24 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:26.334 | 2024-04-29 17:37:26.334 | No download requests in the queue to start downloads for. 2024-04-29 17:37:26.389 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:26.389 | Socket (7) | Closed. 2024-04-29 17:37:28.108 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:28.108 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:28.108 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:28.108 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:28.108 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:28.162 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:28.162 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:28.162 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:28.162 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:28.327 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:28.327 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:28.327 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:28.327 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:28.327 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:28.327 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:28.327 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:28.327 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:37:28.327 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:37:28.327 | Triggering next historical data download in queue. 2024-04-29 17:37:28.327 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:28.327 | HD Request # 25 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:28.327 | HD Request # 25 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:28.327 | HD Request # 25 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:28.327 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:28.327 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:28.327 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:28.380 | HD Request # 25 | Sending historical data logon request message. 2024-04-29 17:37:28.381 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:28.381 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:28.381 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:28.381 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:28.381 | DTC Client socket (6) | Closed. 2024-04-29 17:37:28.381 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:28.381 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:28.381 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:28.544 | HD Request # 25 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:28.597 | Socket (7) | CloseSocket call. 2024-04-29 17:37:28.597 | HD Request # 25 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:28.597 | Historical data download thread signaled to stop. 2024-04-29 17:37:28.597 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:28.597 | HD Request # 25 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:28.597 | HD Request # 25 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:28.597 | HD Request # 25 | Completion time: 0s. 2024-04-29 17:37:28.597 | HD Request # 25 | Intraday data download complete for ESM24-CME. Unique request ID: 25 2024-04-29 17:37:28.597 | Removing historical data download ID 25. 2024-04-29 17:37:28.597 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:28.597 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:28.597 | HD Request # 25 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:28.597 | 2024-04-29 17:37:28.597 | No download requests in the queue to start downloads for. 2024-04-29 17:37:28.651 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:28.651 | Socket (7) | Closed. 2024-04-29 17:37:30.371 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:30.371 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:30.372 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:30.372 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:30.372 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:30.428 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:30.428 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:30.428 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:30.428 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:30.593 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:30.593 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:30.593 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:30.593 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:30.593 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:30.593 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:30.593 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:30.593 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:37:30.593 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:37:30.593 | Triggering next historical data download in queue. 2024-04-29 17:37:30.593 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:30.593 | HD Request # 26 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:30.594 | HD Request # 26 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:30.594 | HD Request # 26 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:30.594 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:30.595 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:30.595 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:30.649 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:30.650 | HD Request # 26 | Sending historical data logon request message. 2024-04-29 17:37:30.654 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:30.654 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:30.654 | DTC Client socket (6) | Closed. 2024-04-29 17:37:30.655 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:30.656 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:30.656 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:30.656 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:30.811 | HD Request # 26 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:30.866 | Socket (7) | CloseSocket call. 2024-04-29 17:37:30.866 | HD Request # 26 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:30.866 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:30.866 | Historical data download thread signaled to stop. 2024-04-29 17:37:30.866 | HD Request # 26 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:30.866 | HD Request # 26 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:30.866 | HD Request # 26 | Completion time: 0s. 2024-04-29 17:37:30.866 | HD Request # 26 | Intraday data download complete for ESM24-CME. Unique request ID: 26 2024-04-29 17:37:30.866 | Removing historical data download ID 26. 2024-04-29 17:37:30.866 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:30.866 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:30.866 | HD Request # 26 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:30.866 | 2024-04-29 17:37:30.866 | No download requests in the queue to start downloads for. 2024-04-29 17:37:30.921 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:30.921 | Socket (7) | Closed. 2024-04-29 17:37:32.634 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:32.634 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:32.636 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:32.636 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:32.636 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:32.689 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:32.689 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:32.689 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:32.689 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:32.855 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:32.855 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:32.855 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:32.855 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:32.855 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:32.855 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:32.855 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:32.855 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:37:32.855 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:37:32.855 | Triggering next historical data download in queue. 2024-04-29 17:37:32.855 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:32.855 | HD Request # 27 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:32.855 | HD Request # 27 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:32.855 | HD Request # 27 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:32.855 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:32.855 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:32.855 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:32.910 | HD Request # 27 | Sending historical data logon request message. 2024-04-29 17:37:32.910 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:32.910 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:32.910 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:32.910 | DTC Client socket (6) | Closed. 2024-04-29 17:37:32.911 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:32.911 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:32.911 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:32.911 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:33.074 | HD Request # 27 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:33.130 | Socket (7) | CloseSocket call. 2024-04-29 17:37:33.130 | HD Request # 27 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:33.130 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:33.130 | Historical data download thread signaled to stop. 2024-04-29 17:37:33.130 | HD Request # 27 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:33.130 | HD Request # 27 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:33.130 | HD Request # 27 | Completion time: 1s. 2024-04-29 17:37:33.130 | HD Request # 27 | Intraday data download complete for ESM24-CME. Unique request ID: 27 2024-04-29 17:37:33.130 | Removing historical data download ID 27. 2024-04-29 17:37:33.130 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:33.130 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:33.130 | HD Request # 27 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:33.130 | 2024-04-29 17:37:33.130 | No download requests in the queue to start downloads for. 2024-04-29 17:37:33.185 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:33.185 | Socket (7) | Closed. 2024-04-29 17:37:34.901 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:34.901 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:34.902 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:34.902 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:34.902 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:34.955 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:34.955 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:34.955 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:34.955 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:35.120 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:35.120 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:35.120 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:35.120 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:35.120 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:35.120 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:35.120 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:35.120 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:37:35.120 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:37:35.120 | Triggering next historical data download in queue. 2024-04-29 17:37:35.120 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:35.120 | HD Request # 28 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:35.120 | HD Request # 28 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:35.120 | HD Request # 28 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:35.120 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:35.120 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:35.120 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:35.173 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:35.173 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:35.173 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:35.173 | DTC Client socket (6) | Closed. 2024-04-29 17:37:35.173 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:35.173 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:35.173 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:35.173 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:35.175 | HD Request # 28 | Sending historical data logon request message. 2024-04-29 17:37:35.340 | HD Request # 28 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:35.393 | Socket (7) | CloseSocket call. 2024-04-29 17:37:35.393 | HD Request # 28 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:35.393 | Historical data download thread signaled to stop. 2024-04-29 17:37:35.393 | HD Request # 28 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:35.393 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:35.393 | HD Request # 28 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:35.393 | HD Request # 28 | Completion time: 0s. 2024-04-29 17:37:35.393 | HD Request # 28 | Intraday data download complete for ESM24-CME. Unique request ID: 28 2024-04-29 17:37:35.393 | Removing historical data download ID 28. 2024-04-29 17:37:35.393 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:35.393 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:35.393 | HD Request # 28 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:35.393 | 2024-04-29 17:37:35.393 | No download requests in the queue to start downloads for. 2024-04-29 17:37:35.447 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:35.447 | Socket (7) | Closed. 2024-04-29 17:37:37.175 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:37.175 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:37.175 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:37.175 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:37.175 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:37.228 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:37.228 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:37.228 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:37.228 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:37.393 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:37.393 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:37.393 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:37.393 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:37.393 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:37.393 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:37.393 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:37.393 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:37:37.393 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:37:37.393 | Triggering next historical data download in queue. 2024-04-29 17:37:37.393 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:37.393 | HD Request # 29 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:37.393 | HD Request # 29 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:37.393 | HD Request # 29 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:37.393 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:37.393 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:37.393 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:37.447 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:37.447 | HD Request # 29 | Sending historical data logon request message. 2024-04-29 17:37:37.448 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:37.448 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:37.448 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:37.448 | DTC Client socket (6) | Closed. 2024-04-29 17:37:37.448 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:37.448 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:37.448 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:37.615 | HD Request # 29 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:37.670 | Socket (7) | CloseSocket call. 2024-04-29 17:37:37.670 | HD Request # 29 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:37.670 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:37.670 | Historical data download thread signaled to stop. 2024-04-29 17:37:37.670 | HD Request # 29 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:37.671 | HD Request # 29 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:37.671 | HD Request # 29 | Completion time: 0s. 2024-04-29 17:37:37.671 | HD Request # 29 | Intraday data download complete for ESM24-CME. Unique request ID: 29 2024-04-29 17:37:37.671 | Removing historical data download ID 29. 2024-04-29 17:37:37.671 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:37.671 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:37.671 | HD Request # 29 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:37.671 | 2024-04-29 17:37:37.671 | No download requests in the queue to start downloads for. 2024-04-29 17:37:37.724 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:37.724 | Socket (7) | Closed. 2024-04-29 17:37:39.444 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:39.444 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:39.444 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:39.444 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:39.444 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:39.499 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:39.499 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:39.499 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:39.499 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:39.666 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:39.666 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:39.666 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:39.666 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:39.666 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:39.666 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:39.666 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:39.666 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:37:39.666 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:37:39.666 | Triggering next historical data download in queue. 2024-04-29 17:37:39.666 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:39.666 | HD Request # 30 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:39.666 | HD Request # 30 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:39.666 | HD Request # 30 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:39.667 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:39.667 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:39.667 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:39.719 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:39.719 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:39.719 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:39.719 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:39.719 | DTC Client socket (6) | Closed. 2024-04-29 17:37:39.720 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:39.720 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:39.720 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:39.722 | HD Request # 30 | Sending historical data logon request message. 2024-04-29 17:37:39.884 | HD Request # 30 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:39.955 | Socket (7) | CloseSocket call. 2024-04-29 17:37:39.955 | HD Request # 30 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:39.955 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:39.955 | Historical data download thread signaled to stop. 2024-04-29 17:37:39.955 | HD Request # 30 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:39.955 | HD Request # 30 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:39.955 | HD Request # 30 | Completion time: 0s. 2024-04-29 17:37:39.955 | HD Request # 30 | Intraday data download complete for ESM24-CME. Unique request ID: 30 2024-04-29 17:37:39.955 | Removing historical data download ID 30. 2024-04-29 17:37:39.955 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:39.955 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:39.955 | HD Request # 30 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:39.955 | 2024-04-29 17:37:39.955 | No download requests in the queue to start downloads for. 2024-04-29 17:37:40.009 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:40.009 | Socket (7) | Closed. 2024-04-29 17:37:41.701 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:41.701 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:41.702 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:41.702 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:41.702 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:41.756 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:41.756 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:41.756 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:41.756 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:41.922 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:41.922 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:41.922 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:41.922 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:41.922 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:41.922 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:41.922 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:41.922 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:37:41.922 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:37:41.922 | Triggering next historical data download in queue. 2024-04-29 17:37:41.922 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:41.922 | HD Request # 31 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:41.923 | HD Request # 31 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:41.923 | HD Request # 31 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:41.923 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:41.923 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:41.923 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:41.977 | HD Request # 31 | Sending historical data logon request message. 2024-04-29 17:37:41.977 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:41.978 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:41.978 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:41.978 | DTC Client socket (6) | Closed. 2024-04-29 17:37:41.978 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:41.978 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:41.978 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:41.978 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:42.142 | HD Request # 31 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:42.197 | Socket (7) | CloseSocket call. 2024-04-29 17:37:42.197 | HD Request # 31 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:42.197 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:42.197 | Historical data download thread signaled to stop. 2024-04-29 17:37:42.197 | HD Request # 31 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:42.197 | HD Request # 31 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:42.197 | HD Request # 31 | Completion time: 1s. 2024-04-29 17:37:42.197 | HD Request # 31 | Intraday data download complete for ESM24-CME. Unique request ID: 31 2024-04-29 17:37:42.197 | Removing historical data download ID 31. 2024-04-29 17:37:42.197 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:42.197 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:42.197 | HD Request # 31 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:42.197 | 2024-04-29 17:37:42.197 | No download requests in the queue to start downloads for. 2024-04-29 17:37:42.251 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:42.251 | Socket (7) | Closed. 2024-04-29 17:37:43.974 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:43.974 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:43.974 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:43.974 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:43.974 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:44.030 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:44.030 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:44.030 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:44.030 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:44.196 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:44.196 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:44.196 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:44.196 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:44.196 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:44.196 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:44.196 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:44.196 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:37:44.196 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:37:44.196 | Triggering next historical data download in queue. 2024-04-29 17:37:44.196 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:44.196 | HD Request # 32 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:44.196 | HD Request # 32 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:44.196 | HD Request # 32 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:44.196 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:44.196 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:44.196 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:44.249 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:44.249 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:44.249 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:44.249 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:44.249 | DTC Client socket (6) | Closed. 2024-04-29 17:37:44.249 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:44.249 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:44.249 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:44.251 | HD Request # 32 | Sending historical data logon request message. 2024-04-29 17:37:44.420 | HD Request # 32 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:44.472 | Socket (7) | CloseSocket call. 2024-04-29 17:37:44.472 | HD Request # 32 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:44.472 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:44.472 | Historical data download thread signaled to stop. 2024-04-29 17:37:44.472 | HD Request # 32 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:44.472 | HD Request # 32 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:44.472 | HD Request # 32 | Completion time: 0s. 2024-04-29 17:37:44.472 | HD Request # 32 | Intraday data download complete for ESM24-CME. Unique request ID: 32 2024-04-29 17:37:44.472 | Removing historical data download ID 32. 2024-04-29 17:37:44.472 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:44.472 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:44.472 | HD Request # 32 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:44.472 | 2024-04-29 17:37:44.472 | No download requests in the queue to start downloads for. 2024-04-29 17:37:44.528 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:44.528 | Socket (7) | Closed. 2024-04-29 17:37:46.230 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:46.230 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:46.231 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:46.231 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:46.231 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:46.286 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:46.286 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:46.286 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:46.286 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:46.452 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:46.452 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:46.452 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:46.452 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:46.452 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:46.452 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:46.452 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:46.452 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:37:46.452 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:37:46.452 | Triggering next historical data download in queue. 2024-04-29 17:37:46.452 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:46.452 | HD Request # 33 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:46.452 | HD Request # 33 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:46.452 | HD Request # 33 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:46.452 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:46.452 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:46.453 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:46.506 | HD Request # 33 | Sending historical data logon request message. 2024-04-29 17:37:46.507 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:46.507 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:46.507 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:46.507 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:46.507 | DTC Client socket (6) | Closed. 2024-04-29 17:37:46.507 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:46.507 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:46.507 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:46.670 | HD Request # 33 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:46.724 | Socket (7) | CloseSocket call. 2024-04-29 17:37:46.724 | HD Request # 33 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:46.724 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:46.724 | Historical data download thread signaled to stop. 2024-04-29 17:37:46.724 | HD Request # 33 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:46.724 | HD Request # 33 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:46.724 | HD Request # 33 | Completion time: 0s. 2024-04-29 17:37:46.724 | HD Request # 33 | Intraday data download complete for ESM24-CME. Unique request ID: 33 2024-04-29 17:37:46.724 | Removing historical data download ID 33. 2024-04-29 17:37:46.724 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:46.724 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:46.724 | HD Request # 33 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:46.724 | 2024-04-29 17:37:46.724 | No download requests in the queue to start downloads for. 2024-04-29 17:37:46.779 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:46.779 | Socket (7) | Closed. 2024-04-29 17:37:48.504 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:48.504 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:48.505 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:48.505 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:48.505 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:48.561 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:48.561 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:48.561 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:48.561 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:48.622 | Found DLL: OrderFlowLabs.com.free_64.dll 2024-04-29 17:37:48.622 | Found DLL: OrderFlowLabs.com.free_ARM64.dll 2024-04-29 17:37:48.622 | Found DLL: Smaug_SC_Library_64.dll 2024-04-29 17:37:48.622 | Found DLL: sst_FreeBundle_64.dll 2024-04-29 17:37:48.622 | Found DLL: SST_LocalCopier_64.dll 2024-04-29 17:37:48.622 | Found DLL: UserContributedStudies_64.dll 2024-04-29 17:37:48.624 | Loading DLL: C:\SierraChart2\Data\OrderFlowLabs.com.free.dll (OrderFlowLabs.com.free_64.dll). Handle: 7ff893d60000 2024-04-29 17:37:48.624 | InternalVersionNumberToFileNameMap is empty for OrderFlowLabs.com.free_ARM64 2024-04-29 17:37:48.624 | Closest match search for: C:\SierraChart2\Data\OrderFlowLabs.com.free_ARM64.dll returned empty result. * 2024-04-29 17:37:48.625 | Loading DLL: C:\SierraChart2\Data\Smaug_SC_Library.dll (Smaug_SC_Library_64.dll). Handle: 7ff8949a0000 2024-04-29 17:37:48.627 | Loading DLL: C:\SierraChart2\Data\sst_FreeBundle.dll (sst_FreeBundle_64.dll). Handle: 7ff8946b0000 2024-04-29 17:37:48.631 | Loading DLL: C:\SierraChart2\Data\SST_LocalCopier.dll (SST_LocalCopier_64.dll). Handle: 7ff870ca0000 2024-04-29 17:37:48.636 | Loading DLL: C:\SierraChart2\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ff86c370000 2024-04-29 17:37:48.729 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:48.729 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:48.729 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:48.729 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:48.729 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:48.729 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:48.729 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:48.729 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:37:48.729 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:37:48.729 | Triggering next historical data download in queue. 2024-04-29 17:37:48.729 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:48.729 | HD Request # 34 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:48.729 | HD Request # 34 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:48.729 | HD Request # 34 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:48.729 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:48.729 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:48.729 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:48.782 | HD Request # 34 | Sending historical data logon request message. 2024-04-29 17:37:48.783 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:48.783 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:48.783 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:48.783 | DTC Client socket (6) | Closed. 2024-04-29 17:37:48.783 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:48.783 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:48.783 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:48.783 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:48.949 | HD Request # 34 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:49.003 | Socket (7) | CloseSocket call. 2024-04-29 17:37:49.003 | HD Request # 34 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:49.003 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:49.003 | Historical data download thread signaled to stop. 2024-04-29 17:37:49.003 | HD Request # 34 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:49.003 | HD Request # 34 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:49.003 | HD Request # 34 | Completion time: 1s. 2024-04-29 17:37:49.003 | HD Request # 34 | Intraday data download complete for ESM24-CME. Unique request ID: 34 2024-04-29 17:37:49.003 | Removing historical data download ID 34. 2024-04-29 17:37:49.003 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:49.003 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:49.003 | HD Request # 34 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:49.003 | 2024-04-29 17:37:49.003 | No download requests in the queue to start downloads for. 2024-04-29 17:37:49.058 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:49.058 | Socket (7) | Closed. 2024-04-29 17:37:50.768 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:50.768 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:50.768 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:50.768 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:50.768 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:50.824 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:50.824 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:50.824 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:50.824 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:50.990 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:50.990 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:50.990 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:50.990 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:50.990 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:50.990 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:50.990 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:50.990 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:37:50.990 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:37:50.990 | Triggering next historical data download in queue. 2024-04-29 17:37:50.990 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:50.990 | HD Request # 35 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:50.990 | HD Request # 35 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:50.990 | HD Request # 35 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:50.990 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:50.991 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:50.991 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:51.043 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:51.043 | HD Request # 35 | Sending historical data logon request message. 2024-04-29 17:37:51.043 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:51.043 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:51.043 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:51.043 | DTC Client socket (6) | Closed. 2024-04-29 17:37:51.043 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:51.043 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:51.043 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:51.209 | HD Request # 35 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:51.261 | Socket (7) | CloseSocket call. 2024-04-29 17:37:51.261 | HD Request # 35 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:51.262 | Historical data download thread signaled to stop. 2024-04-29 17:37:51.262 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:51.262 | HD Request # 35 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:51.262 | HD Request # 35 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:51.262 | HD Request # 35 | Completion time: 1s. 2024-04-29 17:37:51.262 | HD Request # 35 | Intraday data download complete for ESM24-CME. Unique request ID: 35 2024-04-29 17:37:51.262 | Removing historical data download ID 35. 2024-04-29 17:37:51.262 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:51.262 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:51.262 | HD Request # 35 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:51.262 | 2024-04-29 17:37:51.262 | No download requests in the queue to start downloads for. 2024-04-29 17:37:51.315 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:51.315 | Socket (7) | Closed. 2024-04-29 17:37:53.033 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:53.033 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:53.033 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:53.033 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:53.033 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:53.086 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:53.086 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:53.086 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:53.086 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:53.254 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:53.254 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:53.254 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:53.254 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:53.254 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:53.254 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:53.254 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:53.254 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:37:53.254 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:37:53.254 | Triggering next historical data download in queue. 2024-04-29 17:37:53.254 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:53.254 | HD Request # 36 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:53.254 | HD Request # 36 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:53.254 | HD Request # 36 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:53.254 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:53.254 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:53.254 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:53.306 | HD Request # 36 | Sending historical data logon request message. 2024-04-29 17:37:53.307 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:53.307 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:53.307 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:53.307 | DTC Client socket (6) | Closed. 2024-04-29 17:37:53.307 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:53.307 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:53.307 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:53.307 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:53.469 | HD Request # 36 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:53.523 | Socket (7) | CloseSocket call. 2024-04-29 17:37:53.523 | HD Request # 36 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:53.523 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:53.523 | Historical data download thread signaled to stop. 2024-04-29 17:37:53.523 | HD Request # 36 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:53.523 | HD Request # 36 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:53.523 | HD Request # 36 | Completion time: 0s. 2024-04-29 17:37:53.523 | HD Request # 36 | Intraday data download complete for ESM24-CME. Unique request ID: 36 2024-04-29 17:37:53.523 | Removing historical data download ID 36. 2024-04-29 17:37:53.523 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:53.523 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:53.523 | HD Request # 36 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:53.523 | 2024-04-29 17:37:53.523 | No download requests in the queue to start downloads for. 2024-04-29 17:37:53.577 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:53.577 | Socket (7) | Closed. 2024-04-29 17:37:55.291 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:55.291 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:55.292 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:55.292 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:55.292 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:55.345 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:55.345 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:55.345 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:55.345 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:55.512 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:55.512 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:55.512 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:55.512 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:55.512 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:55.512 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:55.512 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:55.512 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:37:55.512 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:37:55.512 | Triggering next historical data download in queue. 2024-04-29 17:37:55.512 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:55.512 | HD Request # 37 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:55.513 | HD Request # 37 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:55.513 | HD Request # 37 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:55.513 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:55.513 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:55.513 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:55.567 | HD Request # 37 | Sending historical data logon request message. 2024-04-29 17:37:55.568 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:55.568 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:55.568 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:55.568 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:55.568 | DTC Client socket (6) | Closed. 2024-04-29 17:37:55.568 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:55.568 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:55.568 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:55.734 | HD Request # 37 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:55.788 | Socket (7) | CloseSocket call. 2024-04-29 17:37:55.788 | HD Request # 37 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:55.788 | Historical data download thread signaled to stop. 2024-04-29 17:37:55.788 | HD Request # 37 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:55.788 | HD Request # 37 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:55.788 | HD Request # 37 | Completion time: 0s. 2024-04-29 17:37:55.788 | HD Request # 37 | Intraday data download complete for ESM24-CME. Unique request ID: 37 2024-04-29 17:37:55.788 | Removing historical data download ID 37. 2024-04-29 17:37:55.788 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:55.788 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:55.788 | HD Request # 37 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:55.788 | 2024-04-29 17:37:55.788 | No download requests in the queue to start downloads for. 2024-04-29 17:37:55.788 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:55.843 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:55.843 | Socket (7) | Closed. 2024-04-29 17:37:57.562 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:57.562 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:57.562 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:57.562 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:57.562 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:57.617 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:57.617 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:57.617 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:57.617 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:37:57.781 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:37:57.781 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:37:57.781 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:37:57.781 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:37:57.781 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:37:57.781 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:37:57.781 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:37:57.781 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:37:57.781 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:37:57.781 | Triggering next historical data download in queue. 2024-04-29 17:37:57.781 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:37:57.781 | HD Request # 38 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:37:57.781 | HD Request # 38 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:57.781 | HD Request # 38 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:37:57.781 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:57.781 | Socket (7) | New receive buffer size: 0 2024-04-29 17:37:57.781 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:57.833 | HD Request # 38 | Sending historical data logon request message. 2024-04-29 17:37:57.834 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:37:57.834 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:37:57.834 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:37:57.834 | DTC Client socket (6) | Closed. 2024-04-29 17:37:57.834 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:37:57.834 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:37:57.834 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:37:57.834 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:37:58.002 | HD Request # 38 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:37:58.056 | Socket (7) | CloseSocket call. 2024-04-29 17:37:58.056 | HD Request # 38 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:37:58.056 | Historical data download thread signaled to stop. 2024-04-29 17:37:58.056 | HD Request # 38 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:37:58.056 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:37:58.056 | HD Request # 38 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:37:58.056 | HD Request # 38 | Completion time: 1s. 2024-04-29 17:37:58.056 | HD Request # 38 | Intraday data download complete for ESM24-CME. Unique request ID: 38 2024-04-29 17:37:58.056 | Removing historical data download ID 38. 2024-04-29 17:37:58.056 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:37:58.056 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:37:58.056 | HD Request # 38 | Enabling Intraday chart updating for symbol. 2024-04-29 17:37:58.056 | 2024-04-29 17:37:58.056 | No download requests in the queue to start downloads for. 2024-04-29 17:37:58.111 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:37:58.111 | Socket (7) | Closed. 2024-04-29 17:37:59.836 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:37:59.836 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:37:59.836 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:37:59.836 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:37:59.836 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:37:59.889 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:37:59.889 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:37:59.889 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:37:59.889 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:00.053 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:00.053 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:00.053 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:00.053 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:00.053 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:00.053 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:00.053 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:00.053 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:00.053 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:00.053 | Triggering next historical data download in queue. 2024-04-29 17:38:00.053 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:00.053 | HD Request # 39 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:00.053 | HD Request # 39 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:00.053 | HD Request # 39 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:00.053 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:00.053 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:00.053 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:00.106 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:00.106 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:00.106 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:00.106 | HD Request # 39 | Sending historical data logon request message. 2024-04-29 17:38:00.106 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:00.106 | DTC Client socket (6) | Closed. 2024-04-29 17:38:00.106 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:00.106 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:00.106 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:00.269 | HD Request # 39 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:00.323 | Socket (7) | CloseSocket call. 2024-04-29 17:38:00.323 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:00.323 | HD Request # 39 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:00.323 | Historical data download thread signaled to stop. 2024-04-29 17:38:00.323 | HD Request # 39 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:00.323 | HD Request # 39 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:00.323 | HD Request # 39 | Completion time: 0s. 2024-04-29 17:38:00.323 | HD Request # 39 | Intraday data download complete for ESM24-CME. Unique request ID: 39 2024-04-29 17:38:00.323 | Removing historical data download ID 39. 2024-04-29 17:38:00.323 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:00.323 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:00.323 | HD Request # 39 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:00.323 | 2024-04-29 17:38:00.323 | No download requests in the queue to start downloads for. 2024-04-29 17:38:00.377 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:00.377 | Socket (7) | Closed. 2024-04-29 17:38:01.813 | ESM4.CME[M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 2024-03-31 22:00:00 2024-04-29 17:38:01.814 | Chart: ESM4.CME[M] 1 Min #1 | Study: LTC: Trade Receiver Study V2 | Loading Rx study -- v2.1.52 -- * 2024-04-29 17:38:02.089 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:02.089 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:02.091 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:02.091 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:02.091 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:02.144 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:02.144 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:02.144 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:02.144 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:02.311 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:02.311 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:02.311 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:02.311 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:02.311 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:02.311 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:02.311 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:02.311 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:02.311 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:02.311 | Triggering next historical data download in queue. 2024-04-29 17:38:02.311 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:02.311 | HD Request # 40 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:02.311 | HD Request # 40 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:02.311 | HD Request # 40 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:02.311 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:02.311 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:02.311 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:02.324 | Chart: ESM4.CME[M] 1 Min #1 | Study: LTC: Trade Receiver Study V2 | Rx Connection: Starting Connection to local copier. * 2024-04-29 17:38:02.363 | HD Request # 40 | Sending historical data logon request message. 2024-04-29 17:38:02.364 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:02.364 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:02.364 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:02.364 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:02.364 | DTC Client socket (6) | Closed. 2024-04-29 17:38:02.364 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:02.364 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:02.364 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:02.526 | HD Request # 40 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:02.581 | Socket (7) | CloseSocket call. 2024-04-29 17:38:02.581 | HD Request # 40 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:02.581 | Historical data download thread signaled to stop. 2024-04-29 17:38:02.581 | HD Request # 40 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:02.581 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:02.582 | HD Request # 40 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:02.582 | HD Request # 40 | Completion time: 0s. 2024-04-29 17:38:02.582 | HD Request # 40 | Intraday data download complete for ESM24-CME. Unique request ID: 40 2024-04-29 17:38:02.582 | Removing historical data download ID 40. 2024-04-29 17:38:02.582 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:02.582 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:02.582 | HD Request # 40 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:02.582 | 2024-04-29 17:38:02.582 | No download requests in the queue to start downloads for. 2024-04-29 17:38:02.636 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:02.636 | Socket (7) | Closed. 2024-04-29 17:38:02.731 | Chart: ESM4.CME[M] 1 Min #1 | Study: LTC: Trade Receiver Study V2 | Rx Connection: Connected. * 2024-04-29 17:38:04.361 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:04.361 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:04.362 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:04.362 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:04.362 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:04.416 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:04.416 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:04.416 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:04.416 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:04.586 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:04.586 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:04.586 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:04.586 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:04.586 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:04.586 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:04.586 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:04.586 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:04.586 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:04.586 | Triggering next historical data download in queue. 2024-04-29 17:38:04.586 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:04.586 | HD Request # 41 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:04.586 | HD Request # 41 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:04.587 | HD Request # 41 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:04.587 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:04.587 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:04.587 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:04.638 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:04.638 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:04.638 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:04.638 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:04.638 | DTC Client socket (6) | Closed. 2024-04-29 17:38:04.639 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:04.639 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:04.639 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:04.641 | HD Request # 41 | Sending historical data logon request message. 2024-04-29 17:38:04.807 | HD Request # 41 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:04.861 | Socket (7) | CloseSocket call. 2024-04-29 17:38:04.861 | HD Request # 41 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:04.861 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:04.861 | Historical data download thread signaled to stop. 2024-04-29 17:38:04.861 | HD Request # 41 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:04.861 | HD Request # 41 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:04.861 | HD Request # 41 | Completion time: 0s. 2024-04-29 17:38:04.861 | HD Request # 41 | Intraday data download complete for ESM24-CME. Unique request ID: 41 2024-04-29 17:38:04.861 | Removing historical data download ID 41. 2024-04-29 17:38:04.861 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:04.861 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:04.861 | HD Request # 41 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:04.861 | 2024-04-29 17:38:04.861 | No download requests in the queue to start downloads for. 2024-04-29 17:38:04.915 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:04.915 | Socket (7) | Closed. 2024-04-29 17:38:06.633 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:06.633 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:06.634 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:06.634 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:06.634 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:06.689 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:06.689 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:06.689 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:06.689 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:06.851 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:06.851 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:06.851 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:06.851 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:06.851 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:06.851 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:06.851 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:06.851 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:06.851 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:06.851 | Triggering next historical data download in queue. 2024-04-29 17:38:06.851 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:06.851 | HD Request # 42 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:06.851 | HD Request # 42 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:06.851 | HD Request # 42 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:06.851 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:06.851 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:06.851 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:06.905 | HD Request # 42 | Sending historical data logon request message. 2024-04-29 17:38:06.905 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:06.905 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:06.905 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:06.905 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:06.905 | DTC Client socket (6) | Closed. 2024-04-29 17:38:06.906 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:06.906 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:06.906 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:07.073 | HD Request # 42 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:07.125 | Socket (7) | CloseSocket call. 2024-04-29 17:38:07.125 | HD Request # 42 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:07.125 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:07.126 | Historical data download thread signaled to stop. 2024-04-29 17:38:07.126 | HD Request # 42 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:07.126 | HD Request # 42 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:07.126 | HD Request # 42 | Completion time: 1s. 2024-04-29 17:38:07.126 | HD Request # 42 | Intraday data download complete for ESM24-CME. Unique request ID: 42 2024-04-29 17:38:07.126 | Removing historical data download ID 42. 2024-04-29 17:38:07.126 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:07.126 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:07.126 | HD Request # 42 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:07.126 | 2024-04-29 17:38:07.126 | No download requests in the queue to start downloads for. 2024-04-29 17:38:07.183 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:07.183 | Socket (7) | Closed. 2024-04-29 17:38:08.888 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:08.888 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:08.888 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:08.889 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:08.889 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:08.943 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:08.943 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:08.943 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:08.943 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:09.107 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:09.107 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:09.107 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:09.107 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:09.107 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:09.107 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:09.107 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:09.107 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:09.107 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:09.107 | Triggering next historical data download in queue. 2024-04-29 17:38:09.107 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:09.107 | HD Request # 43 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:09.107 | HD Request # 43 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:09.107 | HD Request # 43 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:09.107 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:09.107 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:09.107 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:09.160 | HD Request # 43 | Sending historical data logon request message. 2024-04-29 17:38:09.161 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:09.161 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:09.161 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:09.161 | DTC Client socket (6) | Closed. 2024-04-29 17:38:09.161 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:09.161 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:09.161 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:09.161 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:09.325 | HD Request # 43 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:09.377 | Socket (7) | CloseSocket call. 2024-04-29 17:38:09.377 | HD Request # 43 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:09.377 | Historical data download thread signaled to stop. 2024-04-29 17:38:09.377 | HD Request # 43 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:09.377 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:09.378 | HD Request # 43 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:09.378 | HD Request # 43 | Completion time: 0s. 2024-04-29 17:38:09.378 | HD Request # 43 | Intraday data download complete for ESM24-CME. Unique request ID: 43 2024-04-29 17:38:09.378 | Removing historical data download ID 43. 2024-04-29 17:38:09.378 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:09.378 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:09.378 | HD Request # 43 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:09.378 | 2024-04-29 17:38:09.378 | No download requests in the queue to start downloads for. 2024-04-29 17:38:09.432 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:09.432 | Socket (7) | Closed. 2024-04-29 17:38:11.157 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:11.157 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:11.158 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:11.158 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:11.158 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:11.211 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:11.211 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:11.212 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:11.212 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:11.378 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:11.378 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:11.378 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:11.378 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:11.378 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:11.378 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:11.378 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:11.378 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:11.378 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:11.378 | Triggering next historical data download in queue. 2024-04-29 17:38:11.378 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:11.378 | HD Request # 44 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:11.378 | HD Request # 44 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:11.378 | HD Request # 44 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:11.379 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:11.379 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:11.379 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:11.431 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:11.431 | HD Request # 44 | Sending historical data logon request message. 2024-04-29 17:38:11.431 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:11.432 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:11.432 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:11.432 | DTC Client socket (6) | Closed. 2024-04-29 17:38:11.432 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:11.432 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:11.432 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:11.598 | HD Request # 44 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:11.653 | Socket (7) | CloseSocket call. 2024-04-29 17:38:11.653 | HD Request # 44 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:11.653 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:11.653 | Historical data download thread signaled to stop. 2024-04-29 17:38:11.653 | HD Request # 44 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:11.653 | HD Request # 44 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:11.653 | HD Request # 44 | Completion time: 0s. 2024-04-29 17:38:11.653 | HD Request # 44 | Intraday data download complete for ESM24-CME. Unique request ID: 44 2024-04-29 17:38:11.653 | Removing historical data download ID 44. 2024-04-29 17:38:11.653 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:11.653 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:11.653 | HD Request # 44 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:11.653 | 2024-04-29 17:38:11.653 | No download requests in the queue to start downloads for. 2024-04-29 17:38:11.706 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:11.706 | Socket (7) | Closed. 2024-04-29 17:38:13.429 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:13.429 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:13.429 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:13.429 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:13.429 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:13.482 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:13.482 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:13.482 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:13.482 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:13.644 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:13.644 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:13.644 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:13.644 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:13.644 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:13.644 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:13.644 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:13.644 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:13.644 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:13.644 | Triggering next historical data download in queue. 2024-04-29 17:38:13.644 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:13.644 | HD Request # 45 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:13.644 | HD Request # 45 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:13.644 | HD Request # 45 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:13.644 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:13.644 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:13.644 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:13.698 | HD Request # 45 | Sending historical data logon request message. 2024-04-29 17:38:13.698 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:13.699 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:13.699 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:13.699 | DTC Client socket (6) | Closed. 2024-04-29 17:38:13.700 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:13.700 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:13.700 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:13.700 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:13.864 | HD Request # 45 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:13.919 | Socket (7) | CloseSocket call. 2024-04-29 17:38:13.919 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:13.919 | HD Request # 45 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:13.919 | Historical data download thread signaled to stop. 2024-04-29 17:38:13.919 | HD Request # 45 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:13.919 | HD Request # 45 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:13.919 | HD Request # 45 | Completion time: 0s. 2024-04-29 17:38:13.919 | HD Request # 45 | Intraday data download complete for ESM24-CME. Unique request ID: 45 2024-04-29 17:38:13.919 | Removing historical data download ID 45. 2024-04-29 17:38:13.919 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:13.919 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:13.919 | HD Request # 45 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:13.919 | 2024-04-29 17:38:13.919 | No download requests in the queue to start downloads for. 2024-04-29 17:38:13.975 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:13.975 | Socket (7) | Closed. 2024-04-29 17:38:15.685 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:15.685 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:15.686 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:15.686 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:15.686 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:15.739 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:15.739 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:15.739 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:15.739 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:15.906 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:15.906 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:15.906 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:15.906 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:15.906 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:15.906 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:15.906 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:15.906 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:15.906 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:15.906 | Triggering next historical data download in queue. 2024-04-29 17:38:15.906 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:15.906 | HD Request # 46 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:15.906 | HD Request # 46 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:15.906 | HD Request # 46 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:15.907 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:15.907 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:15.907 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:15.960 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:15.960 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:15.960 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:15.960 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:15.960 | DTC Client socket (6) | Closed. 2024-04-29 17:38:15.960 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:15.960 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:15.960 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:15.961 | HD Request # 46 | Sending historical data logon request message. 2024-04-29 17:38:16.128 | HD Request # 46 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:16.181 | Socket (7) | CloseSocket call. 2024-04-29 17:38:16.181 | HD Request # 46 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:16.181 | Historical data download thread signaled to stop. 2024-04-29 17:38:16.181 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:16.181 | HD Request # 46 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:16.181 | HD Request # 46 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:16.181 | HD Request # 46 | Completion time: 1s. 2024-04-29 17:38:16.181 | HD Request # 46 | Intraday data download complete for ESM24-CME. Unique request ID: 46 2024-04-29 17:38:16.181 | Removing historical data download ID 46. 2024-04-29 17:38:16.181 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:16.181 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:16.181 | HD Request # 46 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:16.181 | 2024-04-29 17:38:16.181 | No download requests in the queue to start downloads for. 2024-04-29 17:38:16.235 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:16.235 | Socket (7) | Closed. 2024-04-29 17:38:17.958 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:17.958 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:17.961 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:17.961 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:17.961 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:18.015 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:18.015 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:18.015 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:18.015 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:18.186 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:18.186 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:18.186 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:18.186 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:18.186 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:18.186 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:18.186 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:18.186 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:18.186 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:18.186 | Triggering next historical data download in queue. 2024-04-29 17:38:18.186 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:18.186 | HD Request # 47 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:18.187 | HD Request # 47 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:18.187 | HD Request # 47 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:18.187 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:18.187 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:18.187 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:18.240 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:18.240 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:18.240 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:18.240 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:18.240 | DTC Client socket (6) | Closed. 2024-04-29 17:38:18.242 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:18.242 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:18.242 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:18.242 | HD Request # 47 | Sending historical data logon request message. 2024-04-29 17:38:18.407 | HD Request # 47 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:18.459 | Socket (7) | CloseSocket call. 2024-04-29 17:38:18.459 | HD Request # 47 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:18.459 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:18.459 | Historical data download thread signaled to stop. 2024-04-29 17:38:18.459 | HD Request # 47 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:18.460 | HD Request # 47 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:18.460 | HD Request # 47 | Completion time: 0s. 2024-04-29 17:38:18.460 | HD Request # 47 | Intraday data download complete for ESM24-CME. Unique request ID: 47 2024-04-29 17:38:18.460 | Removing historical data download ID 47. 2024-04-29 17:38:18.460 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:18.460 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:18.460 | HD Request # 47 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:18.460 | 2024-04-29 17:38:18.460 | No download requests in the queue to start downloads for. 2024-04-29 17:38:18.515 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:18.515 | Socket (7) | Closed. 2024-04-29 17:38:20.236 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:20.236 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:20.236 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:20.236 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:20.236 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:20.289 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:20.289 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:20.289 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:20.289 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:20.458 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:20.458 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:20.458 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:20.458 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:20.458 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:20.458 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:20.458 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:20.458 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:20.458 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:20.458 | Triggering next historical data download in queue. 2024-04-29 17:38:20.458 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:20.458 | HD Request # 48 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:20.458 | HD Request # 48 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:20.458 | HD Request # 48 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:20.458 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:20.458 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:20.458 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:20.511 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:20.511 | HD Request # 48 | Sending historical data logon request message. 2024-04-29 17:38:20.511 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:20.511 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:20.511 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:20.511 | DTC Client socket (6) | Closed. 2024-04-29 17:38:20.511 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:20.511 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:20.511 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:20.679 | HD Request # 48 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:20.731 | Socket (7) | CloseSocket call. 2024-04-29 17:38:20.731 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:20.731 | HD Request # 48 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:20.731 | Historical data download thread signaled to stop. 2024-04-29 17:38:20.731 | HD Request # 48 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:20.731 | HD Request # 48 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:20.731 | HD Request # 48 | Completion time: 0s. 2024-04-29 17:38:20.731 | HD Request # 48 | Intraday data download complete for ESM24-CME. Unique request ID: 48 2024-04-29 17:38:20.731 | Removing historical data download ID 48. 2024-04-29 17:38:20.731 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:20.731 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:20.731 | HD Request # 48 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:20.731 | 2024-04-29 17:38:20.731 | No download requests in the queue to start downloads for. 2024-04-29 17:38:20.786 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:20.786 | Socket (7) | Closed. 2024-04-29 17:38:22.495 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:22.495 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:22.495 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:22.495 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:22.495 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:22.549 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:22.549 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:22.549 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:22.549 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:22.712 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:22.712 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:22.712 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:22.712 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:22.712 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:22.712 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:22.712 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:22.712 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:22.712 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:22.712 | Triggering next historical data download in queue. 2024-04-29 17:38:22.712 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:22.712 | HD Request # 49 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:22.712 | HD Request # 49 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:22.712 | HD Request # 49 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:22.712 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:22.712 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:22.712 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:22.766 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:22.767 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:22.767 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:22.767 | HD Request # 49 | Sending historical data logon request message. 2024-04-29 17:38:22.767 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:22.767 | DTC Client socket (6) | Closed. 2024-04-29 17:38:22.767 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:22.767 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:22.767 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:22.929 | HD Request # 49 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:22.983 | Socket (7) | CloseSocket call. 2024-04-29 17:38:22.983 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:22.983 | HD Request # 49 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:22.983 | Historical data download thread signaled to stop. 2024-04-29 17:38:22.983 | HD Request # 49 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:22.984 | HD Request # 49 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:22.984 | HD Request # 49 | Completion time: 0s. 2024-04-29 17:38:22.984 | HD Request # 49 | Intraday data download complete for ESM24-CME. Unique request ID: 49 2024-04-29 17:38:22.984 | Removing historical data download ID 49. 2024-04-29 17:38:22.984 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:22.984 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:22.984 | HD Request # 49 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:22.984 | 2024-04-29 17:38:22.984 | No download requests in the queue to start downloads for. 2024-04-29 17:38:23.037 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:23.037 | Socket (7) | Closed. 2024-04-29 17:38:24.766 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:24.766 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:24.766 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:24.766 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:24.766 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:24.819 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:24.819 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:24.819 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:24.819 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:24.983 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:24.983 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:24.983 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:24.983 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:24.983 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:24.983 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:24.983 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:24.983 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:24.983 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:24.983 | Triggering next historical data download in queue. 2024-04-29 17:38:24.983 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:24.983 | HD Request # 50 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:24.983 | HD Request # 50 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:24.983 | HD Request # 50 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:24.983 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:24.983 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:24.983 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:25.037 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:25.039 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:25.039 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:25.039 | DTC Client socket (6) | Closed. 2024-04-29 17:38:25.039 | HD Request # 50 | Sending historical data logon request message. 2024-04-29 17:38:25.040 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:25.041 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:25.041 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:25.041 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:25.202 | HD Request # 50 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:25.255 | Socket (7) | CloseSocket call. 2024-04-29 17:38:25.255 | HD Request # 50 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:25.255 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:25.255 | Historical data download thread signaled to stop. 2024-04-29 17:38:25.255 | HD Request # 50 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:25.255 | HD Request # 50 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:25.255 | HD Request # 50 | Completion time: 1s. 2024-04-29 17:38:25.255 | HD Request # 50 | Intraday data download complete for ESM24-CME. Unique request ID: 50 2024-04-29 17:38:25.255 | Removing historical data download ID 50. 2024-04-29 17:38:25.255 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:25.255 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:25.255 | HD Request # 50 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:25.255 | 2024-04-29 17:38:25.255 | No download requests in the queue to start downloads for. 2024-04-29 17:38:25.311 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:25.311 | Socket (7) | Closed. 2024-04-29 17:38:27.049 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:27.049 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:27.049 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:27.049 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:27.049 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:27.104 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:27.104 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:27.104 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:27.104 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:27.268 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:27.268 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:27.268 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:27.268 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:27.268 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:27.268 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:27.268 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:27.268 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:27.268 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:27.268 | Triggering next historical data download in queue. 2024-04-29 17:38:27.268 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:27.268 | HD Request # 51 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:27.268 | HD Request # 51 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:27.268 | HD Request # 51 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:27.269 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:27.269 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:27.269 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:27.322 | HD Request # 51 | Sending historical data logon request message. 2024-04-29 17:38:27.323 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:27.323 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:27.323 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:27.323 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:27.323 | DTC Client socket (6) | Closed. 2024-04-29 17:38:27.323 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:27.323 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:27.323 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:27.486 | HD Request # 51 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:27.540 | Socket (7) | CloseSocket call. 2024-04-29 17:38:27.540 | HD Request # 51 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:27.540 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:27.540 | Historical data download thread signaled to stop. 2024-04-29 17:38:27.540 | HD Request # 51 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:27.540 | HD Request # 51 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:27.540 | HD Request # 51 | Completion time: 0s. 2024-04-29 17:38:27.540 | HD Request # 51 | Intraday data download complete for ESM24-CME. Unique request ID: 51 2024-04-29 17:38:27.540 | Removing historical data download ID 51. 2024-04-29 17:38:27.540 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:27.540 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:27.540 | HD Request # 51 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:27.540 | 2024-04-29 17:38:27.540 | No download requests in the queue to start downloads for. 2024-04-29 17:38:27.594 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:27.595 | Socket (7) | Closed. 2024-04-29 17:38:29.306 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:29.306 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:29.307 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:29.307 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:29.307 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:29.361 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:29.361 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:29.361 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:29.361 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:29.527 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:29.527 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:29.527 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:29.527 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:29.527 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:29.527 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:29.527 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:29.527 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:29.527 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:29.527 | Triggering next historical data download in queue. 2024-04-29 17:38:29.527 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:29.527 | HD Request # 52 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:29.528 | HD Request # 52 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:29.528 | HD Request # 52 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:29.528 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:29.528 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:29.528 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:29.582 | HD Request # 52 | Sending historical data logon request message. 2024-04-29 17:38:29.583 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:29.583 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:29.583 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:29.583 | DTC Client socket (6) | Closed. 2024-04-29 17:38:29.583 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:29.583 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:29.583 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:29.583 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:29.749 | HD Request # 52 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:29.802 | Socket (7) | CloseSocket call. 2024-04-29 17:38:29.802 | HD Request # 52 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:29.802 | Historical data download thread signaled to stop. 2024-04-29 17:38:29.802 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:29.802 | HD Request # 52 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:29.802 | HD Request # 52 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:29.802 | HD Request # 52 | Completion time: 0s. 2024-04-29 17:38:29.802 | HD Request # 52 | Intraday data download complete for ESM24-CME. Unique request ID: 52 2024-04-29 17:38:29.802 | Removing historical data download ID 52. 2024-04-29 17:38:29.802 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:29.802 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:29.802 | HD Request # 52 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:29.802 | 2024-04-29 17:38:29.802 | No download requests in the queue to start downloads for. 2024-04-29 17:38:29.857 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:29.857 | Socket (7) | Closed. 2024-04-29 17:38:31.581 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:31.581 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:31.582 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:31.582 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:31.582 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:31.636 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:31.636 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:31.636 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:31.636 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:31.803 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:31.803 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:31.803 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:31.803 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:31.803 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:31.803 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:31.803 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:31.803 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:31.803 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:31.803 | Triggering next historical data download in queue. 2024-04-29 17:38:31.803 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:31.803 | HD Request # 53 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:31.803 | HD Request # 53 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:31.803 | HD Request # 53 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:31.803 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:31.803 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:31.803 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:31.856 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:31.856 | HD Request # 53 | Sending historical data logon request message. 2024-04-29 17:38:31.856 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:31.856 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:31.856 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:31.856 | DTC Client socket (6) | Closed. 2024-04-29 17:38:31.857 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:31.857 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:31.857 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:32.024 | HD Request # 53 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:32.078 | Socket (7) | CloseSocket call. 2024-04-29 17:38:32.078 | HD Request # 53 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:32.078 | Historical data download thread signaled to stop. 2024-04-29 17:38:32.078 | HD Request # 53 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:32.078 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:32.078 | HD Request # 53 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:32.078 | HD Request # 53 | Completion time: 1s. 2024-04-29 17:38:32.078 | HD Request # 53 | Intraday data download complete for ESM24-CME. Unique request ID: 53 2024-04-29 17:38:32.078 | Removing historical data download ID 53. 2024-04-29 17:38:32.078 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:32.078 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:32.078 | HD Request # 53 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:32.078 | 2024-04-29 17:38:32.078 | No download requests in the queue to start downloads for. 2024-04-29 17:38:32.132 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:32.132 | Socket (7) | Closed. 2024-04-29 17:38:33.841 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:33.841 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:33.843 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:33.843 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:33.843 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:33.896 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:33.896 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:33.896 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:33.896 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:34.062 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:34.062 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:34.062 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:34.062 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:34.062 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:34.062 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:34.062 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:34.062 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:34.062 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:34.062 | Triggering next historical data download in queue. 2024-04-29 17:38:34.062 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:34.062 | HD Request # 54 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:34.062 | HD Request # 54 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:34.062 | HD Request # 54 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:34.063 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:34.063 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:34.063 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:34.116 | HD Request # 54 | Sending historical data logon request message. 2024-04-29 17:38:34.116 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:34.116 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:34.116 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:34.116 | DTC Client socket (6) | Closed. 2024-04-29 17:38:34.116 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:34.117 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:34.117 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:34.117 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:34.283 | HD Request # 54 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:34.336 | Socket (7) | CloseSocket call. 2024-04-29 17:38:34.336 | HD Request # 54 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:34.336 | Historical data download thread signaled to stop. 2024-04-29 17:38:34.336 | HD Request # 54 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:34.336 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:34.336 | HD Request # 54 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:34.336 | HD Request # 54 | Completion time: 0s. 2024-04-29 17:38:34.336 | HD Request # 54 | Intraday data download complete for ESM24-CME. Unique request ID: 54 2024-04-29 17:38:34.336 | Removing historical data download ID 54. 2024-04-29 17:38:34.336 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:34.336 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:34.336 | HD Request # 54 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:34.336 | 2024-04-29 17:38:34.336 | No download requests in the queue to start downloads for. 2024-04-29 17:38:34.390 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:34.390 | Socket (7) | Closed. 2024-04-29 17:38:36.114 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:36.114 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:36.115 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:36.115 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:36.115 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:36.167 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:36.167 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:36.168 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:36.168 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:36.336 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:36.336 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:36.336 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:36.336 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:36.336 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:36.336 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:36.336 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:36.336 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:36.336 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:36.336 | Triggering next historical data download in queue. 2024-04-29 17:38:36.336 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:36.336 | HD Request # 55 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:36.337 | HD Request # 55 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:36.337 | HD Request # 55 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:36.337 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:36.337 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:36.337 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:36.389 | HD Request # 55 | Sending historical data logon request message. 2024-04-29 17:38:36.390 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:36.390 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:36.390 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:36.390 | DTC Client socket (6) | Closed. 2024-04-29 17:38:36.390 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:36.390 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:36.390 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:36.390 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:36.561 | HD Request # 55 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:36.616 | Socket (7) | CloseSocket call. 2024-04-29 17:38:36.616 | HD Request # 55 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:36.616 | Historical data download thread signaled to stop. 2024-04-29 17:38:36.616 | HD Request # 55 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:36.616 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:36.616 | HD Request # 55 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:36.616 | HD Request # 55 | Completion time: 0s. 2024-04-29 17:38:36.616 | HD Request # 55 | Intraday data download complete for ESM24-CME. Unique request ID: 55 2024-04-29 17:38:36.616 | Removing historical data download ID 55. 2024-04-29 17:38:36.616 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:36.616 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:36.616 | HD Request # 55 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:36.616 | 2024-04-29 17:38:36.616 | No download requests in the queue to start downloads for. 2024-04-29 17:38:36.671 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:36.671 | Socket (7) | Closed. 2024-04-29 17:38:38.370 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:38.370 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:38.371 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:38.371 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:38.371 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:38.423 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:38.423 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:38.423 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:38.423 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:38.595 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:38.595 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:38.595 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:38.595 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:38.595 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:38.595 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:38.595 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:38.595 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:38.595 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:38.595 | Triggering next historical data download in queue. 2024-04-29 17:38:38.595 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:38.595 | HD Request # 56 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:38.595 | HD Request # 56 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:38.595 | HD Request # 56 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:38.595 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:38.596 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:38.596 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:38.649 | HD Request # 56 | Sending historical data logon request message. 2024-04-29 17:38:38.649 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:38.649 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:38.649 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:38.649 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:38.649 | DTC Client socket (6) | Closed. 2024-04-29 17:38:38.650 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:38.650 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:38.650 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:38.820 | HD Request # 56 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:38.875 | Socket (7) | CloseSocket call. 2024-04-29 17:38:38.875 | HD Request # 56 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:38.875 | Historical data download thread signaled to stop. 2024-04-29 17:38:38.875 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:38.875 | HD Request # 56 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:38.875 | HD Request # 56 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:38.875 | HD Request # 56 | Completion time: 0s. 2024-04-29 17:38:38.875 | HD Request # 56 | Intraday data download complete for ESM24-CME. Unique request ID: 56 2024-04-29 17:38:38.875 | Removing historical data download ID 56. 2024-04-29 17:38:38.875 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:38.875 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:38.875 | HD Request # 56 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:38.875 | 2024-04-29 17:38:38.875 | No download requests in the queue to start downloads for. 2024-04-29 17:38:38.931 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:38.931 | Socket (7) | Closed. 2024-04-29 17:38:40.640 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:40.640 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:40.641 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:40.641 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:40.641 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:40.695 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:40.695 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:40.695 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:40.695 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:40.863 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:40.863 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:40.863 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:40.863 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:40.863 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:40.863 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:40.863 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:40.863 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:40.863 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:40.863 | Triggering next historical data download in queue. 2024-04-29 17:38:40.863 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:40.863 | HD Request # 57 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:40.863 | HD Request # 57 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:40.863 | HD Request # 57 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:40.863 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:40.863 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:40.863 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:40.917 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:40.917 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:40.917 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:40.917 | HD Request # 57 | Sending historical data logon request message. 2024-04-29 17:38:40.917 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:40.917 | DTC Client socket (6) | Closed. 2024-04-29 17:38:40.918 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:40.918 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:40.918 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:41.081 | HD Request # 57 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:41.133 | Socket (7) | CloseSocket call. 2024-04-29 17:38:41.133 | HD Request # 57 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:41.133 | Historical data download thread signaled to stop. 2024-04-29 17:38:41.133 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:41.133 | HD Request # 57 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:41.133 | HD Request # 57 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:41.133 | HD Request # 57 | Completion time: 1s. 2024-04-29 17:38:41.133 | HD Request # 57 | Intraday data download complete for ESM24-CME. Unique request ID: 57 2024-04-29 17:38:41.133 | Removing historical data download ID 57. 2024-04-29 17:38:41.133 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:41.133 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:41.133 | HD Request # 57 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:41.133 | 2024-04-29 17:38:41.133 | No download requests in the queue to start downloads for. 2024-04-29 17:38:41.187 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:41.187 | Socket (7) | Closed. 2024-04-29 17:38:42.926 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:42.926 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:42.927 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:42.927 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:42.927 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:42.981 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:42.981 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:42.981 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:42.981 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:43.154 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:43.154 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:43.154 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:43.154 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:43.154 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:43.154 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:43.154 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:43.154 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:43.154 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:43.154 | Triggering next historical data download in queue. 2024-04-29 17:38:43.154 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:43.154 | HD Request # 58 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:43.154 | HD Request # 58 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:43.154 | HD Request # 58 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:43.154 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:43.154 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:43.154 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:43.207 | HD Request # 58 | Sending historical data logon request message. 2024-04-29 17:38:43.209 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:43.209 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:43.209 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:43.209 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:43.209 | DTC Client socket (6) | Closed. 2024-04-29 17:38:43.209 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:43.209 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:43.209 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:43.371 | HD Request # 58 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:43.422 | Socket (7) | CloseSocket call. 2024-04-29 17:38:43.422 | HD Request # 58 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:43.422 | Historical data download thread signaled to stop. 2024-04-29 17:38:43.422 | HD Request # 58 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:43.422 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:43.423 | HD Request # 58 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:43.423 | HD Request # 58 | Completion time: 0s. 2024-04-29 17:38:43.423 | HD Request # 58 | Intraday data download complete for ESM24-CME. Unique request ID: 58 2024-04-29 17:38:43.423 | Removing historical data download ID 58. 2024-04-29 17:38:43.423 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:43.423 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:43.423 | HD Request # 58 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:43.423 | 2024-04-29 17:38:43.423 | No download requests in the queue to start downloads for. 2024-04-29 17:38:43.480 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:43.480 | Socket (7) | Closed. 2024-04-29 17:38:45.208 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:45.209 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:45.209 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:45.209 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:45.209 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:45.264 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:45.264 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:45.264 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:45.264 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:45.430 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:45.430 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:45.430 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:45.430 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:45.430 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:45.430 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:45.430 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:45.430 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:45.430 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:45.430 | Triggering next historical data download in queue. 2024-04-29 17:38:45.430 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:45.430 | HD Request # 59 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:45.431 | HD Request # 59 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:45.431 | HD Request # 59 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:45.431 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:45.431 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:45.431 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:45.486 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:45.486 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:45.486 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:45.486 | HD Request # 59 | Sending historical data logon request message. 2024-04-29 17:38:45.486 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:45.486 | DTC Client socket (6) | Closed. 2024-04-29 17:38:45.486 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:45.486 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:45.486 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:45.655 | HD Request # 59 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:45.708 | Socket (7) | CloseSocket call. 2024-04-29 17:38:45.708 | HD Request # 59 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:45.708 | Historical data download thread signaled to stop. 2024-04-29 17:38:45.708 | HD Request # 59 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:45.708 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:45.709 | HD Request # 59 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:45.709 | HD Request # 59 | Completion time: 0s. 2024-04-29 17:38:45.709 | HD Request # 59 | Intraday data download complete for ESM24-CME. Unique request ID: 59 2024-04-29 17:38:45.709 | Removing historical data download ID 59. 2024-04-29 17:38:45.709 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:45.709 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:45.709 | HD Request # 59 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:45.709 | 2024-04-29 17:38:45.709 | No download requests in the queue to start downloads for. 2024-04-29 17:38:45.765 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:45.765 | Socket (7) | Closed. 2024-04-29 17:38:47.478 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:47.478 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:47.479 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:47.479 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:47.479 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:47.534 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:47.534 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:47.534 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:47.534 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:47.698 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:47.698 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:47.698 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:47.698 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:47.698 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:47.698 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:47.698 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:47.698 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:47.698 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:47.698 | Triggering next historical data download in queue. 2024-04-29 17:38:47.698 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:47.698 | HD Request # 60 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:47.698 | HD Request # 60 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:47.698 | HD Request # 60 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:47.698 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:47.698 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:47.698 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:47.752 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:47.752 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:47.752 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:47.752 | HD Request # 60 | Sending historical data logon request message. 2024-04-29 17:38:47.752 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:47.752 | DTC Client socket (6) | Closed. 2024-04-29 17:38:47.752 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:47.752 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:47.752 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:47.918 | HD Request # 60 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:47.972 | Socket (7) | CloseSocket call. 2024-04-29 17:38:47.972 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:47.972 | HD Request # 60 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:47.972 | Historical data download thread signaled to stop. 2024-04-29 17:38:47.973 | HD Request # 60 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:47.973 | HD Request # 60 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:47.973 | HD Request # 60 | Completion time: 0s. 2024-04-29 17:38:47.973 | HD Request # 60 | Intraday data download complete for ESM24-CME. Unique request ID: 60 2024-04-29 17:38:47.973 | Removing historical data download ID 60. 2024-04-29 17:38:47.973 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:47.973 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:47.973 | HD Request # 60 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:47.973 | 2024-04-29 17:38:47.973 | No download requests in the queue to start downloads for. 2024-04-29 17:38:48.028 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:48.028 | Socket (7) | Closed. 2024-04-29 17:38:49.751 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:49.751 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:49.754 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:49.754 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:49.754 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:49.810 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:49.810 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:49.810 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:49.810 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:49.973 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:49.973 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:49.973 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:49.973 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:49.973 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:49.973 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:49.973 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:49.973 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:49.973 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:49.973 | Triggering next historical data download in queue. 2024-04-29 17:38:49.973 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:49.973 | HD Request # 61 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:49.973 | HD Request # 61 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:49.973 | HD Request # 61 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:49.973 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:49.973 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:49.973 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:50.025 | HD Request # 61 | Sending historical data logon request message. 2024-04-29 17:38:50.026 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:50.026 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:50.026 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:50.026 | DTC Client socket (6) | Closed. 2024-04-29 17:38:50.026 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:50.026 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:50.026 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:50.026 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:50.194 | HD Request # 61 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:50.247 | Socket (7) | CloseSocket call. 2024-04-29 17:38:50.247 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:50.247 | HD Request # 61 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:50.247 | Historical data download thread signaled to stop. 2024-04-29 17:38:50.247 | HD Request # 61 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:50.247 | HD Request # 61 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:50.247 | HD Request # 61 | Completion time: 1s. 2024-04-29 17:38:50.247 | HD Request # 61 | Intraday data download complete for ESM24-CME. Unique request ID: 61 2024-04-29 17:38:50.247 | Removing historical data download ID 61. 2024-04-29 17:38:50.247 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:50.247 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:50.247 | HD Request # 61 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:50.247 | 2024-04-29 17:38:50.247 | No download requests in the queue to start downloads for. 2024-04-29 17:38:50.303 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:50.303 | Socket (7) | Closed. 2024-04-29 17:38:52.019 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:52.019 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:52.019 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:52.019 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:52.019 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:52.074 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:52.074 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:52.074 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:52.074 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:52.243 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:52.243 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:52.243 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:52.243 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:52.243 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:52.243 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:52.243 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:52.243 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:52.243 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:52.243 | Triggering next historical data download in queue. 2024-04-29 17:38:52.243 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:52.243 | HD Request # 62 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:52.244 | HD Request # 62 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:52.244 | HD Request # 62 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:52.244 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:52.244 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:52.244 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:52.297 | HD Request # 62 | Sending historical data logon request message. 2024-04-29 17:38:52.298 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:52.298 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:52.298 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:52.298 | DTC Client socket (6) | Closed. 2024-04-29 17:38:52.298 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:52.298 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:52.298 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:52.298 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:52.466 | HD Request # 62 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:52.522 | Socket (7) | CloseSocket call. 2024-04-29 17:38:52.522 | HD Request # 62 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:52.522 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:52.522 | Historical data download thread signaled to stop. 2024-04-29 17:38:52.522 | HD Request # 62 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:52.522 | HD Request # 62 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:52.522 | HD Request # 62 | Completion time: 0s. 2024-04-29 17:38:52.522 | HD Request # 62 | Intraday data download complete for ESM24-CME. Unique request ID: 62 2024-04-29 17:38:52.522 | Removing historical data download ID 62. 2024-04-29 17:38:52.522 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:52.522 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:52.522 | HD Request # 62 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:52.522 | 2024-04-29 17:38:52.522 | No download requests in the queue to start downloads for. 2024-04-29 17:38:52.575 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:52.575 | Socket (7) | Closed. 2024-04-29 17:38:54.284 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:54.284 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:54.284 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:54.284 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:54.284 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:54.339 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:54.339 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:54.339 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:54.339 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:54.507 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:54.507 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:54.507 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:54.507 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:54.507 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:54.507 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:54.507 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:54.507 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:54.507 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:54.507 | Triggering next historical data download in queue. 2024-04-29 17:38:54.507 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:54.507 | HD Request # 63 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:54.508 | HD Request # 63 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:54.508 | HD Request # 63 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:54.508 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:54.508 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:54.508 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:54.562 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:54.562 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:54.562 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:54.562 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:54.562 | DTC Client socket (6) | Closed. 2024-04-29 17:38:54.562 | HD Request # 63 | Sending historical data logon request message. 2024-04-29 17:38:54.562 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:54.562 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:54.562 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:54.725 | HD Request # 63 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:54.778 | Socket (7) | CloseSocket call. 2024-04-29 17:38:54.778 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:54.778 | HD Request # 63 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:54.778 | Historical data download thread signaled to stop. 2024-04-29 17:38:54.778 | HD Request # 63 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:54.778 | HD Request # 63 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:54.778 | HD Request # 63 | Completion time: 0s. 2024-04-29 17:38:54.778 | HD Request # 63 | Intraday data download complete for ESM24-CME. Unique request ID: 63 2024-04-29 17:38:54.778 | Removing historical data download ID 63. 2024-04-29 17:38:54.778 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:54.778 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:54.778 | HD Request # 63 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:54.778 | 2024-04-29 17:38:54.778 | No download requests in the queue to start downloads for. 2024-04-29 17:38:54.833 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:54.833 | Socket (7) | Closed. 2024-04-29 17:38:56.560 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:56.560 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:56.561 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:56.561 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:56.561 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:56.615 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:56.615 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:56.615 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:56.615 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:56.781 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:56.781 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:56.781 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:56.781 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:56.781 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:56.781 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:56.781 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:56.781 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:56.781 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:56.781 | Triggering next historical data download in queue. 2024-04-29 17:38:56.781 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:56.781 | HD Request # 64 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:56.781 | HD Request # 64 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:56.781 | HD Request # 64 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:56.781 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:56.781 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:56.781 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:56.834 | HD Request # 64 | Sending historical data logon request message. 2024-04-29 17:38:56.835 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:56.835 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:56.835 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:56.835 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:56.835 | DTC Client socket (6) | Closed. 2024-04-29 17:38:56.835 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:56.835 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:56.835 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:56.999 | HD Request # 64 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:57.051 | Socket (7) | CloseSocket call. 2024-04-29 17:38:57.051 | HD Request # 64 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:57.051 | Historical data download thread signaled to stop. 2024-04-29 17:38:57.051 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:57.051 | HD Request # 64 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:57.051 | HD Request # 64 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:57.051 | HD Request # 64 | Completion time: 1s. 2024-04-29 17:38:57.051 | HD Request # 64 | Intraday data download complete for ESM24-CME. Unique request ID: 64 2024-04-29 17:38:57.051 | Removing historical data download ID 64. 2024-04-29 17:38:57.051 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:57.051 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:57.051 | HD Request # 64 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:57.051 | 2024-04-29 17:38:57.051 | No download requests in the queue to start downloads for. 2024-04-29 17:38:57.105 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:57.105 | Socket (7) | Closed. 2024-04-29 17:38:58.823 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:38:58.823 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:38:58.824 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:58.825 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:38:58.825 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:58.877 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:38:58.877 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:38:58.877 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:38:58.877 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:38:59.040 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:38:59.040 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:38:59.040 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:38:59.040 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:38:59.040 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:38:59.040 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:38:59.040 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:38:59.040 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:38:59.040 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:38:59.040 | Triggering next historical data download in queue. 2024-04-29 17:38:59.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:38:59.040 | HD Request # 65 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:38:59.040 | HD Request # 65 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:59.040 | HD Request # 65 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:38:59.040 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:38:59.040 | Socket (7) | New receive buffer size: 0 2024-04-29 17:38:59.040 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:38:59.093 | HD Request # 65 | Sending historical data logon request message. 2024-04-29 17:38:59.094 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:38:59.094 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:38:59.094 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:38:59.094 | DTC Client socket (6) | Closed. 2024-04-29 17:38:59.094 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:38:59.094 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:38:59.094 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:38:59.094 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:38:59.260 | HD Request # 65 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:38:59.314 | Socket (7) | CloseSocket call. 2024-04-29 17:38:59.314 | HD Request # 65 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:38:59.314 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:38:59.314 | Historical data download thread signaled to stop. 2024-04-29 17:38:59.314 | HD Request # 65 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:38:59.315 | HD Request # 65 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:38:59.315 | HD Request # 65 | Completion time: 0s. 2024-04-29 17:38:59.315 | HD Request # 65 | Intraday data download complete for ESM24-CME. Unique request ID: 65 2024-04-29 17:38:59.315 | Removing historical data download ID 65. 2024-04-29 17:38:59.315 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:38:59.315 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:38:59.315 | HD Request # 65 | Enabling Intraday chart updating for symbol. 2024-04-29 17:38:59.315 | 2024-04-29 17:38:59.315 | No download requests in the queue to start downloads for. 2024-04-29 17:38:59.368 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:38:59.368 | Socket (7) | Closed. 2024-04-29 17:39:01.072 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:01.072 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:01.072 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:01.072 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:01.072 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:01.125 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:01.125 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:01.125 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:01.125 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:01.286 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:01.286 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:01.286 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:01.286 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:01.286 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:01.286 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:01.286 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:01.286 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:01.286 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:01.286 | Triggering next historical data download in queue. 2024-04-29 17:39:01.286 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:01.286 | HD Request # 66 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:01.286 | HD Request # 66 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:01.286 | HD Request # 66 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:01.286 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:01.286 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:01.286 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:01.339 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:01.339 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:01.339 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:01.339 | DTC Client socket (6) | Closed. 2024-04-29 17:39:01.339 | HD Request # 66 | Sending historical data logon request message. 2024-04-29 17:39:01.339 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:01.340 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:01.340 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:01.340 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:01.505 | HD Request # 66 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:01.558 | Socket (7) | CloseSocket call. 2024-04-29 17:39:01.558 | HD Request # 66 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:01.558 | Historical data download thread signaled to stop. 2024-04-29 17:39:01.558 | HD Request # 66 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:01.558 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:01.558 | HD Request # 66 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:01.558 | HD Request # 66 | Completion time: 0s. 2024-04-29 17:39:01.558 | HD Request # 66 | Intraday data download complete for ESM24-CME. Unique request ID: 66 2024-04-29 17:39:01.558 | Removing historical data download ID 66. 2024-04-29 17:39:01.558 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:01.558 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:01.558 | HD Request # 66 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:01.558 | 2024-04-29 17:39:01.558 | No download requests in the queue to start downloads for. 2024-04-29 17:39:01.613 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:01.613 | Socket (7) | Closed. 2024-04-29 17:39:03.349 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:03.349 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:03.350 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:03.350 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:03.350 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:03.403 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:03.403 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:03.404 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:03.404 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:03.568 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:03.568 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:03.568 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:03.568 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:03.568 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:03.568 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:03.568 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:03.568 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:03.568 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:03.568 | Triggering next historical data download in queue. 2024-04-29 17:39:03.568 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:03.568 | HD Request # 67 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:03.568 | HD Request # 67 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:03.568 | HD Request # 67 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:03.568 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:03.568 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:03.568 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:03.621 | HD Request # 67 | Sending historical data logon request message. 2024-04-29 17:39:03.621 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:03.621 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:03.621 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:03.621 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:03.621 | DTC Client socket (6) | Closed. 2024-04-29 17:39:03.622 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:03.622 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:03.622 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:03.782 | HD Request # 67 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:03.852 | Socket (7) | CloseSocket call. 2024-04-29 17:39:03.852 | HD Request # 67 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:03.852 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:03.852 | Historical data download thread signaled to stop. 2024-04-29 17:39:03.852 | HD Request # 67 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:03.852 | HD Request # 67 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:03.852 | HD Request # 67 | Completion time: 0s. 2024-04-29 17:39:03.852 | HD Request # 67 | Intraday data download complete for ESM24-CME. Unique request ID: 67 2024-04-29 17:39:03.852 | Removing historical data download ID 67. 2024-04-29 17:39:03.852 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:03.852 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:03.852 | HD Request # 67 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:03.852 | 2024-04-29 17:39:03.852 | No download requests in the queue to start downloads for. 2024-04-29 17:39:03.907 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:03.907 | Socket (7) | Closed. 2024-04-29 17:39:05.617 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:05.617 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:05.617 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:05.617 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:05.617 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:05.670 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:05.670 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:05.670 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:05.670 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:05.836 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:05.836 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:05.836 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:05.836 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:05.836 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:05.836 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:05.836 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:05.836 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:05.836 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:05.836 | Triggering next historical data download in queue. 2024-04-29 17:39:05.836 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:05.836 | HD Request # 68 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:05.836 | HD Request # 68 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:05.836 | HD Request # 68 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:05.836 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:05.836 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:05.836 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:05.890 | HD Request # 68 | Sending historical data logon request message. 2024-04-29 17:39:05.891 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:05.891 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:05.891 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:05.891 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:05.891 | DTC Client socket (6) | Closed. 2024-04-29 17:39:05.891 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:05.891 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:05.891 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:06.054 | HD Request # 68 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:06.108 | Socket (7) | CloseSocket call. 2024-04-29 17:39:06.108 | HD Request # 68 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:06.108 | Historical data download thread signaled to stop. 2024-04-29 17:39:06.108 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:06.108 | HD Request # 68 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:06.108 | HD Request # 68 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:06.108 | HD Request # 68 | Completion time: 1s. 2024-04-29 17:39:06.108 | HD Request # 68 | Intraday data download complete for ESM24-CME. Unique request ID: 68 2024-04-29 17:39:06.108 | Removing historical data download ID 68. 2024-04-29 17:39:06.108 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:06.108 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:06.108 | HD Request # 68 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:06.108 | 2024-04-29 17:39:06.108 | No download requests in the queue to start downloads for. 2024-04-29 17:39:06.162 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:06.162 | Socket (7) | Closed. 2024-04-29 17:39:07.875 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:07.875 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:07.875 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:07.875 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:07.875 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:07.928 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:07.928 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:07.928 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:07.928 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:08.096 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:08.096 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:08.096 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:08.096 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:08.096 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:08.096 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:08.096 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:08.096 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:08.096 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:08.096 | Triggering next historical data download in queue. 2024-04-29 17:39:08.096 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:08.096 | HD Request # 69 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:08.097 | HD Request # 69 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:08.097 | HD Request # 69 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:08.097 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:08.097 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:08.097 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:08.151 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:08.151 | HD Request # 69 | Sending historical data logon request message. 2024-04-29 17:39:08.151 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:08.151 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:08.151 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:08.151 | DTC Client socket (6) | Closed. 2024-04-29 17:39:08.151 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:08.151 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:08.151 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:08.318 | HD Request # 69 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:08.371 | Socket (7) | CloseSocket call. 2024-04-29 17:39:08.371 | HD Request # 69 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:08.371 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:08.371 | Historical data download thread signaled to stop. 2024-04-29 17:39:08.371 | HD Request # 69 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:08.371 | HD Request # 69 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:08.371 | HD Request # 69 | Completion time: 0s. 2024-04-29 17:39:08.371 | HD Request # 69 | Intraday data download complete for ESM24-CME. Unique request ID: 69 2024-04-29 17:39:08.371 | Removing historical data download ID 69. 2024-04-29 17:39:08.371 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:08.371 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:08.371 | HD Request # 69 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:08.371 | 2024-04-29 17:39:08.371 | No download requests in the queue to start downloads for. 2024-04-29 17:39:08.425 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:08.425 | Socket (7) | Closed. 2024-04-29 17:39:10.139 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:10.139 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:10.139 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:10.139 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:10.139 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:10.192 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:10.192 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:10.193 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:10.193 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:10.359 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:10.359 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:10.359 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:10.359 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:10.359 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:10.359 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:10.359 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:10.359 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:10.359 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:10.359 | Triggering next historical data download in queue. 2024-04-29 17:39:10.359 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:10.359 | HD Request # 70 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:10.359 | HD Request # 70 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:10.359 | HD Request # 70 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:10.359 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:10.359 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:10.359 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:10.412 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:10.412 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:10.412 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:10.412 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:10.412 | DTC Client socket (6) | Closed. 2024-04-29 17:39:10.412 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:10.412 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:10.412 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:10.413 | HD Request # 70 | Sending historical data logon request message. 2024-04-29 17:39:10.584 | HD Request # 70 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:10.641 | Socket (7) | CloseSocket call. 2024-04-29 17:39:10.641 | HD Request # 70 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:10.641 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:10.641 | Historical data download thread signaled to stop. 2024-04-29 17:39:10.641 | HD Request # 70 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:10.641 | HD Request # 70 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:10.641 | HD Request # 70 | Completion time: 0s. 2024-04-29 17:39:10.641 | HD Request # 70 | Intraday data download complete for ESM24-CME. Unique request ID: 70 2024-04-29 17:39:10.641 | Removing historical data download ID 70. 2024-04-29 17:39:10.641 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:10.641 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:10.641 | HD Request # 70 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:10.641 | 2024-04-29 17:39:10.641 | No download requests in the queue to start downloads for. 2024-04-29 17:39:10.694 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:10.694 | Socket (7) | Closed. 2024-04-29 17:39:12.408 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:12.408 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:12.408 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:12.408 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:12.408 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:12.462 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:12.462 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:12.462 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:12.462 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:12.627 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:12.627 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:12.627 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:12.627 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:12.627 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:12.627 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:12.627 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:12.627 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:12.627 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:12.627 | Triggering next historical data download in queue. 2024-04-29 17:39:12.627 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:12.627 | HD Request # 71 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:12.627 | HD Request # 71 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:12.627 | HD Request # 71 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:12.627 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:12.627 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:12.627 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:12.681 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:12.681 | HD Request # 71 | Sending historical data logon request message. 2024-04-29 17:39:12.681 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:12.681 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:12.681 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:12.681 | DTC Client socket (6) | Closed. 2024-04-29 17:39:12.681 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:12.681 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:12.681 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:12.850 | HD Request # 71 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:12.903 | Socket (7) | CloseSocket call. 2024-04-29 17:39:12.903 | HD Request # 71 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:12.903 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:12.903 | Historical data download thread signaled to stop. 2024-04-29 17:39:12.903 | HD Request # 71 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:12.903 | HD Request # 71 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:12.903 | HD Request # 71 | Completion time: 0s. 2024-04-29 17:39:12.903 | HD Request # 71 | Intraday data download complete for ESM24-CME. Unique request ID: 71 2024-04-29 17:39:12.903 | Removing historical data download ID 71. 2024-04-29 17:39:12.903 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:12.903 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:12.903 | HD Request # 71 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:12.903 | 2024-04-29 17:39:12.903 | No download requests in the queue to start downloads for. 2024-04-29 17:39:12.956 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:12.956 | Socket (7) | Closed. 2024-04-29 17:39:14.665 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:14.665 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:14.666 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:14.666 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:14.666 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:14.719 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:14.719 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:14.719 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:14.719 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:14.883 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:14.883 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:14.883 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:14.883 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:14.883 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:14.883 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:14.883 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:14.883 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:14.883 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:14.883 | Triggering next historical data download in queue. 2024-04-29 17:39:14.883 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:14.883 | HD Request # 72 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:14.883 | HD Request # 72 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:14.883 | HD Request # 72 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:14.883 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:14.883 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:14.883 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:14.935 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:14.935 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:14.935 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:14.935 | DTC Client socket (6) | Closed. 2024-04-29 17:39:14.935 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:14.935 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:14.935 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:14.935 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:14.936 | HD Request # 72 | Sending historical data logon request message. 2024-04-29 17:39:15.104 | HD Request # 72 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:15.158 | Socket (7) | CloseSocket call. 2024-04-29 17:39:15.158 | HD Request # 72 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:15.158 | Historical data download thread signaled to stop. 2024-04-29 17:39:15.158 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:15.158 | HD Request # 72 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:15.158 | HD Request # 72 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:15.158 | HD Request # 72 | Completion time: 1s. 2024-04-29 17:39:15.158 | HD Request # 72 | Intraday data download complete for ESM24-CME. Unique request ID: 72 2024-04-29 17:39:15.158 | Removing historical data download ID 72. 2024-04-29 17:39:15.158 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:15.158 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:15.158 | HD Request # 72 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:15.158 | 2024-04-29 17:39:15.158 | No download requests in the queue to start downloads for. 2024-04-29 17:39:15.213 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:15.213 | Socket (7) | Closed. 2024-04-29 17:39:16.936 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:16.936 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:16.936 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:16.936 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:16.936 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:16.990 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:16.990 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:16.990 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:16.990 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:17.154 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:17.154 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:17.155 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:17.155 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:17.155 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:17.155 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:17.155 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:17.155 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:17.155 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:17.155 | Triggering next historical data download in queue. 2024-04-29 17:39:17.155 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:17.155 | HD Request # 73 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:17.155 | HD Request # 73 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:17.155 | HD Request # 73 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:17.155 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:17.155 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:17.155 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:17.208 | HD Request # 73 | Sending historical data logon request message. 2024-04-29 17:39:17.208 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:17.208 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:17.208 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:17.208 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:17.208 | DTC Client socket (6) | Closed. 2024-04-29 17:39:17.208 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:17.208 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:17.208 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:17.377 | HD Request # 73 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:17.431 | Socket (7) | CloseSocket call. 2024-04-29 17:39:17.431 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:17.431 | HD Request # 73 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:17.432 | Historical data download thread signaled to stop. 2024-04-29 17:39:17.432 | HD Request # 73 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:17.432 | HD Request # 73 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:17.432 | HD Request # 73 | Completion time: 0s. 2024-04-29 17:39:17.432 | HD Request # 73 | Intraday data download complete for ESM24-CME. Unique request ID: 73 2024-04-29 17:39:17.432 | Removing historical data download ID 73. 2024-04-29 17:39:17.432 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:17.432 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:17.432 | HD Request # 73 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:17.432 | 2024-04-29 17:39:17.432 | No download requests in the queue to start downloads for. 2024-04-29 17:39:17.486 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:17.486 | Socket (7) | Closed. 2024-04-29 17:39:19.207 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:19.207 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:19.207 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:19.208 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:19.208 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:19.264 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:19.264 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:19.264 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:19.264 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:19.427 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:19.427 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:19.427 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:19.427 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:19.427 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:19.427 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:19.427 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:19.427 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:19.427 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:19.427 | Triggering next historical data download in queue. 2024-04-29 17:39:19.427 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:19.427 | HD Request # 74 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:19.428 | HD Request # 74 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:19.428 | HD Request # 74 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:19.428 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:19.428 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:19.428 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:19.481 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:19.481 | HD Request # 74 | Sending historical data logon request message. 2024-04-29 17:39:19.481 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:19.481 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:19.481 | DTC Client socket (6) | Closed. 2024-04-29 17:39:19.481 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:19.482 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:19.482 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:19.482 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:19.646 | HD Request # 74 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:19.703 | Socket (7) | CloseSocket call. 2024-04-29 17:39:19.703 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:19.703 | HD Request # 74 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:19.703 | Historical data download thread signaled to stop. 2024-04-29 17:39:19.703 | HD Request # 74 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:19.703 | HD Request # 74 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:19.704 | HD Request # 74 | Completion time: 0s. 2024-04-29 17:39:19.704 | HD Request # 74 | Intraday data download complete for ESM24-CME. Unique request ID: 74 2024-04-29 17:39:19.704 | Removing historical data download ID 74. 2024-04-29 17:39:19.704 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:19.704 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:19.704 | HD Request # 74 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:19.704 | 2024-04-29 17:39:19.704 | No download requests in the queue to start downloads for. 2024-04-29 17:39:19.758 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:19.758 | Socket (7) | Closed. 2024-04-29 17:39:21.479 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:21.479 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:21.480 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:21.480 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:21.480 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:21.536 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:21.536 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:21.536 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:21.536 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:21.701 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:21.701 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:21.701 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:21.701 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:21.701 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:21.701 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:21.701 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:21.701 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:21.701 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:21.701 | Triggering next historical data download in queue. 2024-04-29 17:39:21.701 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:21.701 | HD Request # 75 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:21.702 | HD Request # 75 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:21.702 | HD Request # 75 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:21.702 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:21.702 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:21.702 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:21.755 | HD Request # 75 | Sending historical data logon request message. 2024-04-29 17:39:21.766 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:21.766 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:21.766 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:21.766 | DTC Client socket (6) | Closed. 2024-04-29 17:39:21.766 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:21.767 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:21.767 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:21.767 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:21.920 | HD Request # 75 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:21.972 | Socket (7) | CloseSocket call. 2024-04-29 17:39:21.972 | HD Request # 75 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:21.972 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:21.972 | Historical data download thread signaled to stop. 2024-04-29 17:39:21.972 | HD Request # 75 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:21.972 | HD Request # 75 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:21.972 | HD Request # 75 | Completion time: 0s. 2024-04-29 17:39:21.972 | HD Request # 75 | Intraday data download complete for ESM24-CME. Unique request ID: 75 2024-04-29 17:39:21.972 | Removing historical data download ID 75. 2024-04-29 17:39:21.972 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:21.972 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:21.972 | HD Request # 75 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:21.972 | 2024-04-29 17:39:21.972 | No download requests in the queue to start downloads for. 2024-04-29 17:39:22.029 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:22.029 | Socket (7) | Closed. 2024-04-29 17:39:23.763 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:23.763 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:23.764 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:23.764 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:23.764 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:23.818 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:23.818 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:23.818 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:23.818 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:23.981 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:23.981 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:23.981 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:23.981 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:23.981 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:23.981 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:23.981 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:23.981 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:23.981 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:23.981 | Triggering next historical data download in queue. 2024-04-29 17:39:23.981 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:23.981 | HD Request # 76 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:23.982 | HD Request # 76 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:23.982 | HD Request # 76 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:23.982 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:23.982 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:23.982 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:24.033 | HD Request # 76 | Sending historical data logon request message. 2024-04-29 17:39:24.034 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:24.034 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:24.034 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:24.034 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:24.034 | DTC Client socket (6) | Closed. 2024-04-29 17:39:24.034 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:24.034 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:24.034 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:24.197 | HD Request # 76 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:24.250 | Socket (7) | CloseSocket call. 2024-04-29 17:39:24.250 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:24.251 | HD Request # 76 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:24.251 | Historical data download thread signaled to stop. 2024-04-29 17:39:24.251 | HD Request # 76 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:24.251 | HD Request # 76 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:24.251 | HD Request # 76 | Completion time: 1s. 2024-04-29 17:39:24.251 | HD Request # 76 | Intraday data download complete for ESM24-CME. Unique request ID: 76 2024-04-29 17:39:24.251 | Removing historical data download ID 76. 2024-04-29 17:39:24.251 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:24.251 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:24.251 | HD Request # 76 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:24.251 | 2024-04-29 17:39:24.251 | No download requests in the queue to start downloads for. 2024-04-29 17:39:24.304 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:24.305 | Socket (7) | Closed. 2024-04-29 17:39:26.033 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:26.033 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:26.033 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:26.033 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:26.033 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:26.086 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:26.086 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:26.086 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:26.086 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:26.256 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:26.256 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:26.256 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:26.256 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:26.256 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:26.256 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:26.256 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:26.256 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:26.256 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:26.256 | Triggering next historical data download in queue. 2024-04-29 17:39:26.256 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:26.256 | HD Request # 77 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:26.256 | HD Request # 77 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:26.256 | HD Request # 77 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:26.256 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:26.256 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:26.256 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:26.308 | HD Request # 77 | Sending historical data logon request message. 2024-04-29 17:39:26.308 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:26.308 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:26.308 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:26.308 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:26.308 | DTC Client socket (6) | Closed. 2024-04-29 17:39:26.309 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:26.309 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:26.309 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:26.475 | HD Request # 77 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:26.529 | Socket (7) | CloseSocket call. 2024-04-29 17:39:26.529 | HD Request # 77 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:26.529 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:26.529 | Historical data download thread signaled to stop. 2024-04-29 17:39:26.529 | HD Request # 77 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:26.529 | HD Request # 77 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:26.529 | HD Request # 77 | Completion time: 0s. 2024-04-29 17:39:26.529 | HD Request # 77 | Intraday data download complete for ESM24-CME. Unique request ID: 77 2024-04-29 17:39:26.529 | Removing historical data download ID 77. 2024-04-29 17:39:26.529 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:26.529 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:26.529 | HD Request # 77 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:26.529 | 2024-04-29 17:39:26.529 | No download requests in the queue to start downloads for. 2024-04-29 17:39:26.583 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:26.583 | Socket (7) | Closed. 2024-04-29 17:39:28.309 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:28.309 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:28.309 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:28.309 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:28.309 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:28.362 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:28.362 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:28.362 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:28.362 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:28.525 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:28.525 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:28.525 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:28.525 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:28.525 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:28.525 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:28.525 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:28.525 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:28.525 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:28.525 | Triggering next historical data download in queue. 2024-04-29 17:39:28.525 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:28.525 | HD Request # 78 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:28.526 | HD Request # 78 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:28.526 | HD Request # 78 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:28.526 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:28.526 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:28.526 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:28.578 | HD Request # 78 | Sending historical data logon request message. 2024-04-29 17:39:28.578 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:28.578 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:28.578 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:28.578 | DTC Client socket (6) | Closed. 2024-04-29 17:39:28.579 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:28.579 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:28.579 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:28.579 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:28.746 | HD Request # 78 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:28.799 | Socket (7) | CloseSocket call. 2024-04-29 17:39:28.799 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:28.799 | HD Request # 78 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:28.799 | Historical data download thread signaled to stop. 2024-04-29 17:39:28.799 | HD Request # 78 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:28.799 | HD Request # 78 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:28.799 | HD Request # 78 | Completion time: 0s. 2024-04-29 17:39:28.799 | HD Request # 78 | Intraday data download complete for ESM24-CME. Unique request ID: 78 2024-04-29 17:39:28.799 | Removing historical data download ID 78. 2024-04-29 17:39:28.799 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:28.799 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:28.799 | HD Request # 78 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:28.799 | 2024-04-29 17:39:28.799 | No download requests in the queue to start downloads for. 2024-04-29 17:39:28.854 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:28.854 | Socket (7) | Closed. 2024-04-29 17:39:30.571 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:30.571 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:30.573 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:30.573 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:30.573 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:30.629 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:30.629 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:30.629 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:30.629 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:30.798 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:30.798 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:30.798 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:30.798 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:30.798 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:30.798 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:30.798 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:30.798 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:30.798 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:30.798 | Triggering next historical data download in queue. 2024-04-29 17:39:30.798 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:30.798 | HD Request # 79 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:30.798 | HD Request # 79 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:30.798 | HD Request # 79 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:30.798 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:30.798 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:30.798 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:30.851 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:30.851 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:30.851 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:30.851 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:30.851 | DTC Client socket (6) | Closed. 2024-04-29 17:39:30.851 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:30.851 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:30.851 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:30.853 | HD Request # 79 | Sending historical data logon request message. 2024-04-29 17:39:31.019 | HD Request # 79 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:31.075 | Socket (7) | CloseSocket call. 2024-04-29 17:39:31.075 | HD Request # 79 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:31.075 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:31.075 | Historical data download thread signaled to stop. 2024-04-29 17:39:31.075 | HD Request # 79 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:31.075 | HD Request # 79 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:31.075 | HD Request # 79 | Completion time: 1s. 2024-04-29 17:39:31.075 | HD Request # 79 | Intraday data download complete for ESM24-CME. Unique request ID: 79 2024-04-29 17:39:31.075 | Removing historical data download ID 79. 2024-04-29 17:39:31.075 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:31.075 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:31.075 | HD Request # 79 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:31.075 | 2024-04-29 17:39:31.075 | No download requests in the queue to start downloads for. 2024-04-29 17:39:31.129 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:31.129 | Socket (7) | Closed. 2024-04-29 17:39:32.842 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:32.842 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:32.843 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:32.843 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:32.843 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:32.895 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:32.895 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:32.895 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:32.895 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:33.059 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:33.059 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:33.059 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:33.059 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:33.059 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:33.059 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:33.059 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:33.059 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:33.059 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:33.059 | Triggering next historical data download in queue. 2024-04-29 17:39:33.059 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:33.059 | HD Request # 80 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:33.059 | HD Request # 80 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:33.059 | HD Request # 80 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:33.059 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:33.059 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:33.059 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:33.115 | HD Request # 80 | Sending historical data logon request message. 2024-04-29 17:39:33.116 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:33.116 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:33.116 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:33.116 | DTC Client socket (6) | Closed. 2024-04-29 17:39:33.116 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:33.116 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:33.116 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:33.116 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:33.281 | HD Request # 80 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:33.333 | Socket (7) | CloseSocket call. 2024-04-29 17:39:33.333 | HD Request # 80 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:33.333 | Historical data download thread signaled to stop. 2024-04-29 17:39:33.333 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:33.333 | HD Request # 80 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:33.334 | HD Request # 80 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:33.334 | HD Request # 80 | Completion time: 0s. 2024-04-29 17:39:33.334 | HD Request # 80 | Intraday data download complete for ESM24-CME. Unique request ID: 80 2024-04-29 17:39:33.334 | Removing historical data download ID 80. 2024-04-29 17:39:33.334 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:33.334 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:33.334 | HD Request # 80 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:33.334 | 2024-04-29 17:39:33.334 | No download requests in the queue to start downloads for. 2024-04-29 17:39:33.388 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:33.388 | Socket (7) | Closed. 2024-04-29 17:39:35.113 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:35.113 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:35.117 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:35.117 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:35.117 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:35.171 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:35.171 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:35.171 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:35.171 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:35.334 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:35.334 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:35.334 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:35.334 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:35.334 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:35.334 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:35.334 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:35.334 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:35.334 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:35.334 | Triggering next historical data download in queue. 2024-04-29 17:39:35.334 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:35.334 | HD Request # 81 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:35.334 | HD Request # 81 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:35.334 | HD Request # 81 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:35.334 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:35.334 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:35.334 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:35.387 | HD Request # 81 | Sending historical data logon request message. 2024-04-29 17:39:35.387 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:35.387 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:35.387 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:35.387 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:35.387 | DTC Client socket (6) | Closed. 2024-04-29 17:39:35.387 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:35.387 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:35.387 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:35.551 | HD Request # 81 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:35.604 | Socket (7) | CloseSocket call. 2024-04-29 17:39:35.604 | HD Request # 81 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:35.605 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:35.605 | Historical data download thread signaled to stop. 2024-04-29 17:39:35.605 | HD Request # 81 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:35.605 | HD Request # 81 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:35.605 | HD Request # 81 | Completion time: 0s. 2024-04-29 17:39:35.605 | HD Request # 81 | Intraday data download complete for ESM24-CME. Unique request ID: 81 2024-04-29 17:39:35.605 | Removing historical data download ID 81. 2024-04-29 17:39:35.605 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:35.605 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:35.605 | HD Request # 81 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:35.605 | 2024-04-29 17:39:35.605 | No download requests in the queue to start downloads for. 2024-04-29 17:39:35.660 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:35.660 | Socket (7) | Closed. 2024-04-29 17:39:37.386 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:37.386 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:37.386 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:37.387 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:37.387 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:37.442 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:37.442 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:37.442 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:37.442 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:37.604 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:37.604 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:37.604 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:37.604 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:37.604 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:37.604 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:37.604 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:37.604 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:37.604 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:37.604 | Triggering next historical data download in queue. 2024-04-29 17:39:37.604 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:37.604 | HD Request # 82 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:37.604 | HD Request # 82 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:37.604 | HD Request # 82 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:37.604 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:37.604 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:37.604 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:37.658 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:37.658 | HD Request # 82 | Sending historical data logon request message. 2024-04-29 17:39:37.658 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:37.658 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:37.658 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:37.658 | DTC Client socket (6) | Closed. 2024-04-29 17:39:37.658 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:37.658 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:37.658 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:37.826 | HD Request # 82 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:37.880 | Socket (7) | CloseSocket call. 2024-04-29 17:39:37.880 | HD Request # 82 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:37.880 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:37.880 | Historical data download thread signaled to stop. 2024-04-29 17:39:37.880 | HD Request # 82 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:37.880 | HD Request # 82 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:37.880 | HD Request # 82 | Completion time: 0s. 2024-04-29 17:39:37.880 | HD Request # 82 | Intraday data download complete for ESM24-CME. Unique request ID: 82 2024-04-29 17:39:37.880 | Removing historical data download ID 82. 2024-04-29 17:39:37.880 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:37.880 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:37.880 | HD Request # 82 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:37.880 | 2024-04-29 17:39:37.880 | No download requests in the queue to start downloads for. 2024-04-29 17:39:37.936 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:37.936 | Socket (7) | Closed. 2024-04-29 17:39:39.655 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:39.655 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:39.655 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:39.655 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:39.655 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:39.707 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:39.707 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:39.707 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:39.707 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:39.870 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:39.870 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:39.870 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:39.870 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:39.870 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:39.870 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:39.870 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:39.870 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:39.870 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:39.870 | Triggering next historical data download in queue. 2024-04-29 17:39:39.870 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:39.870 | HD Request # 83 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:39.870 | HD Request # 83 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:39.870 | HD Request # 83 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:39.870 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:39.870 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:39.870 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:39.923 | HD Request # 83 | Sending historical data logon request message. 2024-04-29 17:39:39.924 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:39.924 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:39.924 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:39.924 | DTC Client socket (6) | Closed. 2024-04-29 17:39:39.924 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:39.924 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:39.924 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:39.924 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:40.085 | HD Request # 83 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:40.138 | Socket (7) | CloseSocket call. 2024-04-29 17:39:40.138 | HD Request # 83 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:40.138 | Historical data download thread signaled to stop. 2024-04-29 17:39:40.138 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:40.138 | HD Request # 83 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:40.138 | HD Request # 83 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:40.138 | HD Request # 83 | Completion time: 1s. 2024-04-29 17:39:40.138 | HD Request # 83 | Intraday data download complete for ESM24-CME. Unique request ID: 83 2024-04-29 17:39:40.138 | Removing historical data download ID 83. 2024-04-29 17:39:40.138 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:40.138 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:40.138 | HD Request # 83 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:40.138 | 2024-04-29 17:39:40.138 | No download requests in the queue to start downloads for. 2024-04-29 17:39:40.191 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:40.191 | Socket (7) | Closed. 2024-04-29 17:39:41.928 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:41.928 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:41.929 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:41.929 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:41.929 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:41.983 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:41.983 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:41.983 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:41.983 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:42.152 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:42.152 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:42.152 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:42.152 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:42.152 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:42.152 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:42.152 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:42.152 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:42.152 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:42.152 | Triggering next historical data download in queue. 2024-04-29 17:39:42.152 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:42.152 | HD Request # 84 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:42.153 | HD Request # 84 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:42.153 | HD Request # 84 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:42.153 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:42.153 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:42.153 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:42.205 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:42.205 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:42.205 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:42.205 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:42.205 | DTC Client socket (6) | Closed. 2024-04-29 17:39:42.206 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:42.206 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:42.206 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:42.208 | HD Request # 84 | Sending historical data logon request message. 2024-04-29 17:39:42.375 | HD Request # 84 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:42.429 | Socket (7) | CloseSocket call. 2024-04-29 17:39:42.429 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:42.429 | HD Request # 84 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:42.429 | Historical data download thread signaled to stop. 2024-04-29 17:39:42.429 | HD Request # 84 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:42.429 | HD Request # 84 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:42.429 | HD Request # 84 | Completion time: 0s. 2024-04-29 17:39:42.429 | HD Request # 84 | Intraday data download complete for ESM24-CME. Unique request ID: 84 2024-04-29 17:39:42.429 | Removing historical data download ID 84. 2024-04-29 17:39:42.429 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:42.429 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:42.429 | HD Request # 84 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:42.429 | 2024-04-29 17:39:42.429 | No download requests in the queue to start downloads for. 2024-04-29 17:39:42.483 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:42.484 | Socket (7) | Closed. 2024-04-29 17:39:44.204 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:44.204 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:44.205 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:44.205 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:44.205 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:44.258 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:44.258 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:44.258 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:44.258 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:44.428 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:44.428 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:44.428 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:44.428 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:44.428 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:44.428 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:44.428 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:44.428 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:44.428 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:44.428 | Triggering next historical data download in queue. 2024-04-29 17:39:44.428 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:44.428 | HD Request # 85 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:44.428 | HD Request # 85 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:44.428 | HD Request # 85 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:44.428 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:44.428 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:44.428 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:44.482 | HD Request # 85 | Sending historical data logon request message. 2024-04-29 17:39:44.482 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:44.482 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:44.482 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:44.482 | DTC Client socket (6) | Closed. 2024-04-29 17:39:44.483 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:44.483 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:44.483 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:44.483 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:44.649 | HD Request # 85 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:44.702 | Socket (7) | CloseSocket call. 2024-04-29 17:39:44.702 | HD Request # 85 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:44.702 | Historical data download thread signaled to stop. 2024-04-29 17:39:44.702 | HD Request # 85 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:44.702 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:44.702 | HD Request # 85 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:44.702 | HD Request # 85 | Completion time: 0s. 2024-04-29 17:39:44.702 | HD Request # 85 | Intraday data download complete for ESM24-CME. Unique request ID: 85 2024-04-29 17:39:44.702 | Removing historical data download ID 85. 2024-04-29 17:39:44.702 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:44.702 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:44.702 | HD Request # 85 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:44.702 | 2024-04-29 17:39:44.702 | No download requests in the queue to start downloads for. 2024-04-29 17:39:44.759 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:44.759 | Socket (7) | Closed. 2024-04-29 17:39:46.463 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:46.463 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:46.463 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:46.463 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:46.463 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:46.517 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:46.517 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:46.517 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:46.517 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:46.683 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:46.683 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:46.683 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:46.683 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:46.683 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:46.683 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:46.683 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:46.683 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:46.683 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:46.683 | Triggering next historical data download in queue. 2024-04-29 17:39:46.683 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:46.683 | HD Request # 86 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:46.683 | HD Request # 86 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:46.683 | HD Request # 86 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:46.683 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:46.683 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:46.683 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:46.737 | HD Request # 86 | Sending historical data logon request message. 2024-04-29 17:39:46.738 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:46.738 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:46.738 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:46.738 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:46.738 | DTC Client socket (6) | Closed. 2024-04-29 17:39:46.738 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:46.738 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:46.738 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:46.905 | HD Request # 86 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:46.958 | Socket (7) | CloseSocket call. 2024-04-29 17:39:46.958 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:46.958 | HD Request # 86 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:46.958 | Historical data download thread signaled to stop. 2024-04-29 17:39:46.958 | HD Request # 86 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:46.958 | HD Request # 86 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:46.958 | HD Request # 86 | Completion time: 0s. 2024-04-29 17:39:46.958 | HD Request # 86 | Intraday data download complete for ESM24-CME. Unique request ID: 86 2024-04-29 17:39:46.958 | Removing historical data download ID 86. 2024-04-29 17:39:46.958 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:46.958 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:46.958 | HD Request # 86 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:46.958 | 2024-04-29 17:39:46.958 | No download requests in the queue to start downloads for. 2024-04-29 17:39:47.014 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:47.014 | Socket (7) | Closed. 2024-04-29 17:39:48.736 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:48.736 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:48.737 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:48.737 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:48.737 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:48.790 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:48.790 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:48.790 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:48.790 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:48.957 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:48.957 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:48.957 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:48.957 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:48.957 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:48.957 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:48.957 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:48.957 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:48.957 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:48.957 | Triggering next historical data download in queue. 2024-04-29 17:39:48.957 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:48.957 | HD Request # 87 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:48.958 | HD Request # 87 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:48.958 | HD Request # 87 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:48.958 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:48.958 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:48.958 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:49.012 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:49.012 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:49.012 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:49.012 | HD Request # 87 | Sending historical data logon request message. 2024-04-29 17:39:49.012 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:49.012 | DTC Client socket (6) | Closed. 2024-04-29 17:39:49.013 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:49.013 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:49.013 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:49.175 | HD Request # 87 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:49.229 | Socket (7) | CloseSocket call. 2024-04-29 17:39:49.229 | HD Request # 87 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:49.229 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:49.229 | Historical data download thread signaled to stop. 2024-04-29 17:39:49.229 | HD Request # 87 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:49.229 | HD Request # 87 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:49.229 | HD Request # 87 | Completion time: 1s. 2024-04-29 17:39:49.229 | HD Request # 87 | Intraday data download complete for ESM24-CME. Unique request ID: 87 2024-04-29 17:39:49.229 | Removing historical data download ID 87. 2024-04-29 17:39:49.229 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:49.229 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:49.229 | HD Request # 87 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:49.229 | 2024-04-29 17:39:49.229 | No download requests in the queue to start downloads for. 2024-04-29 17:39:49.284 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:49.284 | Socket (7) | Closed. 2024-04-29 17:39:51.008 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:51.008 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:51.010 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:51.010 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:51.010 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:51.065 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:51.065 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:51.065 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:51.065 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:51.228 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:51.228 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:51.228 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:51.228 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:51.228 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:51.228 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:51.228 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:51.228 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:51.228 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:51.228 | Triggering next historical data download in queue. 2024-04-29 17:39:51.228 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:51.228 | HD Request # 88 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:51.228 | HD Request # 88 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:51.228 | HD Request # 88 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:51.228 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:51.228 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:51.228 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:51.281 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:51.281 | HD Request # 88 | Sending historical data logon request message. 2024-04-29 17:39:51.281 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:51.281 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:51.281 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:51.281 | DTC Client socket (6) | Closed. 2024-04-29 17:39:51.281 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:51.281 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:51.281 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:51.447 | HD Request # 88 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:51.502 | Socket (7) | CloseSocket call. 2024-04-29 17:39:51.502 | HD Request # 88 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:51.502 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:51.502 | Historical data download thread signaled to stop. 2024-04-29 17:39:51.502 | HD Request # 88 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:51.502 | HD Request # 88 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:51.502 | HD Request # 88 | Completion time: 0s. 2024-04-29 17:39:51.502 | HD Request # 88 | Intraday data download complete for ESM24-CME. Unique request ID: 88 2024-04-29 17:39:51.502 | Removing historical data download ID 88. 2024-04-29 17:39:51.502 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:51.502 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:51.502 | HD Request # 88 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:51.502 | 2024-04-29 17:39:51.502 | No download requests in the queue to start downloads for. 2024-04-29 17:39:51.554 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:51.554 | Socket (7) | Closed. 2024-04-29 17:39:53.277 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:53.277 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:53.277 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:53.277 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:53.277 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:53.332 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:53.332 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:53.332 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:53.332 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:53.497 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:53.497 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:53.497 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:53.497 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:53.497 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:53.497 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:53.497 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:53.497 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:53.497 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:53.497 | Triggering next historical data download in queue. 2024-04-29 17:39:53.497 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:53.497 | HD Request # 89 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:53.497 | HD Request # 89 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:53.497 | HD Request # 89 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:53.497 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:53.497 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:53.497 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:53.554 | HD Request # 89 | Sending historical data logon request message. 2024-04-29 17:39:53.554 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:53.554 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:53.554 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:53.554 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:53.554 | DTC Client socket (6) | Closed. 2024-04-29 17:39:53.554 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:53.554 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:53.554 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:53.720 | HD Request # 89 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:53.774 | Socket (7) | CloseSocket call. 2024-04-29 17:39:53.774 | HD Request # 89 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:53.774 | Historical data download thread signaled to stop. 2024-04-29 17:39:53.774 | HD Request # 89 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:53.774 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:53.774 | HD Request # 89 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:53.774 | HD Request # 89 | Completion time: 0s. 2024-04-29 17:39:53.774 | HD Request # 89 | Intraday data download complete for ESM24-CME. Unique request ID: 89 2024-04-29 17:39:53.774 | Removing historical data download ID 89. 2024-04-29 17:39:53.774 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:53.774 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:53.774 | HD Request # 89 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:53.774 | 2024-04-29 17:39:53.774 | No download requests in the queue to start downloads for. 2024-04-29 17:39:53.829 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:53.829 | Socket (7) | Closed. 2024-04-29 17:39:55.546 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:55.546 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:55.546 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:55.546 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:55.546 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:55.599 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:55.599 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:55.599 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:55.599 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:55.774 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:55.774 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:55.774 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:55.774 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:55.774 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:55.774 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:55.774 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:55.774 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:55.774 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:55.774 | Triggering next historical data download in queue. 2024-04-29 17:39:55.774 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:55.774 | HD Request # 90 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:55.775 | HD Request # 90 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:55.775 | HD Request # 90 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:55.775 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:55.775 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:55.775 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:55.829 | HD Request # 90 | Sending historical data logon request message. 2024-04-29 17:39:55.830 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:55.830 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:55.830 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:55.830 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:55.830 | DTC Client socket (6) | Closed. 2024-04-29 17:39:55.830 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:55.830 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:55.830 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:55.991 | HD Request # 90 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:56.044 | Socket (7) | CloseSocket call. 2024-04-29 17:39:56.044 | HD Request # 90 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:56.044 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:56.044 | Historical data download thread signaled to stop. 2024-04-29 17:39:56.044 | HD Request # 90 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:56.044 | HD Request # 90 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:56.044 | HD Request # 90 | Completion time: 1s. 2024-04-29 17:39:56.044 | HD Request # 90 | Intraday data download complete for ESM24-CME. Unique request ID: 90 2024-04-29 17:39:56.044 | Removing historical data download ID 90. 2024-04-29 17:39:56.044 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:56.044 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:56.044 | HD Request # 90 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:56.044 | 2024-04-29 17:39:56.044 | No download requests in the queue to start downloads for. 2024-04-29 17:39:56.097 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:56.097 | Socket (7) | Closed. 2024-04-29 17:39:57.830 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:39:57.830 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:39:57.831 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:57.832 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:39:57.832 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:57.885 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:39:57.885 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:39:57.885 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:39:57.885 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:39:58.050 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:39:58.050 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:39:58.050 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:39:58.050 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:39:58.050 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:39:58.050 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:39:58.050 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:39:58.050 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:39:58.050 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:39:58.050 | Triggering next historical data download in queue. 2024-04-29 17:39:58.050 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:39:58.050 | HD Request # 91 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:39:58.051 | HD Request # 91 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:58.051 | HD Request # 91 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:39:58.051 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:39:58.051 | Socket (7) | New receive buffer size: 0 2024-04-29 17:39:58.051 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:39:58.102 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:39:58.102 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:39:58.102 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:39:58.102 | DTC Client socket (6) | Closed. 2024-04-29 17:39:58.103 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:39:58.103 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:39:58.103 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:39:58.103 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:39:58.104 | HD Request # 91 | Sending historical data logon request message. 2024-04-29 17:39:58.280 | HD Request # 91 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:39:58.337 | Socket (7) | CloseSocket call. 2024-04-29 17:39:58.337 | HD Request # 91 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:39:58.337 | Historical data download thread signaled to stop. 2024-04-29 17:39:58.337 | HD Request # 91 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:39:58.337 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:39:58.337 | HD Request # 91 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:39:58.337 | HD Request # 91 | Completion time: 0s. 2024-04-29 17:39:58.337 | HD Request # 91 | Intraday data download complete for ESM24-CME. Unique request ID: 91 2024-04-29 17:39:58.337 | Removing historical data download ID 91. 2024-04-29 17:39:58.337 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:39:58.337 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:39:58.337 | HD Request # 91 | Enabling Intraday chart updating for symbol. 2024-04-29 17:39:58.337 | 2024-04-29 17:39:58.337 | No download requests in the queue to start downloads for. 2024-04-29 17:39:58.391 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:39:58.391 | Socket (7) | Closed. 2024-04-29 17:40:00.105 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:00.105 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:00.105 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:00.105 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:00.105 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:00.159 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:00.159 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:00.159 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:00.159 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:00.330 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:00.330 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:00.330 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:00.330 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:00.330 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:00.330 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:00.330 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:00.330 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:00.330 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:00.330 | Triggering next historical data download in queue. 2024-04-29 17:40:00.330 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:00.330 | HD Request # 92 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:00.330 | HD Request # 92 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:00.330 | HD Request # 92 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:00.330 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:00.330 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:00.330 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:00.384 | HD Request # 92 | Sending historical data logon request message. 2024-04-29 17:40:00.386 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:00.386 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:00.387 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:00.387 | DTC Client socket (6) | Closed. 2024-04-29 17:40:00.387 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:00.387 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:00.387 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:00.387 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:00.550 | HD Request # 92 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:00.605 | Socket (7) | CloseSocket call. 2024-04-29 17:40:00.605 | HD Request # 92 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:00.605 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:00.605 | Historical data download thread signaled to stop. 2024-04-29 17:40:00.605 | HD Request # 92 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:00.605 | HD Request # 92 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:00.605 | HD Request # 92 | Completion time: 0s. 2024-04-29 17:40:00.605 | HD Request # 92 | Intraday data download complete for ESM24-CME. Unique request ID: 92 2024-04-29 17:40:00.605 | Removing historical data download ID 92. 2024-04-29 17:40:00.605 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:00.605 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:00.605 | HD Request # 92 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:00.605 | 2024-04-29 17:40:00.605 | No download requests in the queue to start downloads for. 2024-04-29 17:40:00.658 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:00.658 | Socket (7) | Closed. 2024-04-29 17:40:02.392 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:02.392 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:02.393 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:02.393 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:02.393 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:02.446 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:02.446 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:02.446 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:02.446 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:02.610 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:02.610 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:02.610 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:02.610 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:02.610 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:02.610 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:02.610 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:02.610 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:02.610 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:02.610 | Triggering next historical data download in queue. 2024-04-29 17:40:02.610 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:02.610 | HD Request # 93 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:02.610 | HD Request # 93 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:02.610 | HD Request # 93 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:02.610 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:02.610 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:02.610 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:02.662 | HD Request # 93 | Sending historical data logon request message. 2024-04-29 17:40:02.663 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:02.663 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:02.663 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:02.663 | DTC Client socket (6) | Closed. 2024-04-29 17:40:02.663 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:02.663 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:02.663 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:02.663 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:02.831 | HD Request # 93 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:02.884 | Socket (7) | CloseSocket call. 2024-04-29 17:40:02.884 | HD Request # 93 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:02.884 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:02.884 | Historical data download thread signaled to stop. 2024-04-29 17:40:02.884 | HD Request # 93 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:02.884 | HD Request # 93 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:02.885 | HD Request # 93 | Completion time: 0s. 2024-04-29 17:40:02.885 | HD Request # 93 | Intraday data download complete for ESM24-CME. Unique request ID: 93 2024-04-29 17:40:02.885 | Removing historical data download ID 93. 2024-04-29 17:40:02.885 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:02.885 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:02.885 | HD Request # 93 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:02.885 | 2024-04-29 17:40:02.885 | No download requests in the queue to start downloads for. 2024-04-29 17:40:02.939 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:02.939 | Socket (7) | Closed. 2024-04-29 17:40:04.653 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:04.653 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:04.653 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:04.653 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:04.653 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:04.708 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:04.708 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:04.708 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:04.708 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:04.891 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:04.891 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:04.891 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:04.891 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:04.891 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:04.891 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:04.891 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:04.891 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:04.891 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:04.891 | Triggering next historical data download in queue. 2024-04-29 17:40:04.891 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:04.891 | HD Request # 94 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:04.892 | HD Request # 94 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:04.892 | HD Request # 94 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:04.892 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:04.892 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:04.892 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:04.945 | HD Request # 94 | Sending historical data logon request message. 2024-04-29 17:40:04.947 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:04.947 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:04.947 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:04.947 | DTC Client socket (6) | Closed. 2024-04-29 17:40:04.947 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:04.947 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:04.947 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:04.947 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:05.114 | HD Request # 94 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:05.170 | Socket (7) | CloseSocket call. 2024-04-29 17:40:05.170 | HD Request # 94 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:05.170 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:05.170 | Historical data download thread signaled to stop. 2024-04-29 17:40:05.170 | HD Request # 94 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:05.170 | HD Request # 94 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:05.170 | HD Request # 94 | Completion time: 1s. 2024-04-29 17:40:05.170 | HD Request # 94 | Intraday data download complete for ESM24-CME. Unique request ID: 94 2024-04-29 17:40:05.170 | Removing historical data download ID 94. 2024-04-29 17:40:05.170 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:05.170 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:05.170 | HD Request # 94 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:05.170 | 2024-04-29 17:40:05.170 | No download requests in the queue to start downloads for. 2024-04-29 17:40:05.225 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:05.225 | Socket (7) | Closed. 2024-04-29 17:40:06.943 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:06.943 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:06.943 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:06.943 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:06.943 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:06.997 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:06.997 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:06.997 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:06.997 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:07.173 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:07.173 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:07.173 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:07.173 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:07.173 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:07.173 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:07.173 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:07.173 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:07.173 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:07.173 | Triggering next historical data download in queue. 2024-04-29 17:40:07.173 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:07.173 | HD Request # 95 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:07.173 | HD Request # 95 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:07.173 | HD Request # 95 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:07.173 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:07.173 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:07.173 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:07.228 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:07.228 | HD Request # 95 | Sending historical data logon request message. 2024-04-29 17:40:07.229 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:07.229 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:07.229 | DTC Client socket (6) | Closed. 2024-04-29 17:40:07.229 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:07.230 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:07.230 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:07.230 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:07.396 | HD Request # 95 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:07.449 | Socket (7) | CloseSocket call. 2024-04-29 17:40:07.449 | HD Request # 95 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:07.449 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:07.449 | Historical data download thread signaled to stop. 2024-04-29 17:40:07.449 | HD Request # 95 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:07.449 | HD Request # 95 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:07.449 | HD Request # 95 | Completion time: 0s. 2024-04-29 17:40:07.449 | HD Request # 95 | Intraday data download complete for ESM24-CME. Unique request ID: 95 2024-04-29 17:40:07.449 | Removing historical data download ID 95. 2024-04-29 17:40:07.449 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:07.449 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:07.449 | HD Request # 95 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:07.449 | 2024-04-29 17:40:07.449 | No download requests in the queue to start downloads for. 2024-04-29 17:40:07.505 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:07.505 | Socket (7) | Closed. 2024-04-29 17:40:09.226 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:09.226 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:09.227 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:09.227 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:09.227 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:09.280 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:09.280 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:09.280 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:09.280 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:09.445 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:09.445 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:09.445 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:09.445 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:09.445 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:09.445 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:09.445 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:09.445 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:09.445 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:09.445 | Triggering next historical data download in queue. 2024-04-29 17:40:09.445 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:09.445 | HD Request # 96 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:09.445 | HD Request # 96 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:09.445 | HD Request # 96 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:09.445 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:09.446 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:09.446 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:09.498 | HD Request # 96 | Sending historical data logon request message. 2024-04-29 17:40:09.499 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:09.499 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:09.499 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:09.499 | DTC Client socket (6) | Closed. 2024-04-29 17:40:09.499 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:09.499 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:09.499 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:09.499 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:09.662 | HD Request # 96 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:09.717 | Socket (7) | CloseSocket call. 2024-04-29 17:40:09.717 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:09.717 | HD Request # 96 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:09.717 | Historical data download thread signaled to stop. 2024-04-29 17:40:09.717 | HD Request # 96 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:09.718 | HD Request # 96 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:09.718 | HD Request # 96 | Completion time: 0s. 2024-04-29 17:40:09.718 | HD Request # 96 | Intraday data download complete for ESM24-CME. Unique request ID: 96 2024-04-29 17:40:09.718 | Removing historical data download ID 96. 2024-04-29 17:40:09.718 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:09.718 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:09.718 | HD Request # 96 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:09.718 | 2024-04-29 17:40:09.718 | No download requests in the queue to start downloads for. 2024-04-29 17:40:09.775 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:09.775 | Socket (7) | Closed. 2024-04-29 17:40:11.500 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:11.500 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:11.500 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:11.500 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:11.500 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:11.553 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:11.553 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:11.553 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:11.553 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:11.721 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:11.721 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:11.721 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:11.721 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:11.721 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:11.721 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:11.721 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:11.721 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:11.721 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:11.721 | Triggering next historical data download in queue. 2024-04-29 17:40:11.721 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:11.722 | HD Request # 97 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:11.722 | HD Request # 97 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:11.722 | HD Request # 97 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:11.722 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:11.722 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:11.722 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:11.776 | HD Request # 97 | Sending historical data logon request message. 2024-04-29 17:40:11.776 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:11.776 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:11.776 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:11.776 | DTC Client socket (6) | Closed. 2024-04-29 17:40:11.776 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:11.777 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:11.777 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:11.777 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:11.937 | HD Request # 97 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:11.992 | Socket (7) | CloseSocket call. 2024-04-29 17:40:11.992 | HD Request # 97 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:11.992 | Historical data download thread signaled to stop. 2024-04-29 17:40:11.992 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:11.992 | HD Request # 97 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:11.992 | HD Request # 97 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:11.992 | HD Request # 97 | Completion time: 0s. 2024-04-29 17:40:11.992 | HD Request # 97 | Intraday data download complete for ESM24-CME. Unique request ID: 97 2024-04-29 17:40:11.992 | Removing historical data download ID 97. 2024-04-29 17:40:11.992 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:11.992 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:11.992 | HD Request # 97 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:11.992 | 2024-04-29 17:40:11.992 | No download requests in the queue to start downloads for. 2024-04-29 17:40:12.046 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:12.046 | Socket (7) | Closed. 2024-04-29 17:40:13.776 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:13.776 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:13.776 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:13.776 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:13.776 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:13.832 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:13.832 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:13.832 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:13.832 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:14.000 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:14.000 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:14.000 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:14.000 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:14.000 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:14.000 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:14.000 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:14.000 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:14.000 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:14.000 | Triggering next historical data download in queue. 2024-04-29 17:40:14.000 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:14.000 | HD Request # 98 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:14.001 | HD Request # 98 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:14.001 | HD Request # 98 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:14.001 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:14.001 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:14.001 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:14.054 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:14.054 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:14.054 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:14.054 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:14.054 | DTC Client socket (6) | Closed. 2024-04-29 17:40:14.055 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:14.055 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:14.055 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:14.055 | HD Request # 98 | Sending historical data logon request message. 2024-04-29 17:40:14.225 | HD Request # 98 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:14.277 | Socket (7) | CloseSocket call. 2024-04-29 17:40:14.277 | HD Request # 98 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:14.277 | Historical data download thread signaled to stop. 2024-04-29 17:40:14.277 | HD Request # 98 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:14.277 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:14.277 | HD Request # 98 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:14.277 | HD Request # 98 | Completion time: 0s. 2024-04-29 17:40:14.277 | HD Request # 98 | Intraday data download complete for ESM24-CME. Unique request ID: 98 2024-04-29 17:40:14.277 | Removing historical data download ID 98. 2024-04-29 17:40:14.277 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:14.277 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:14.277 | HD Request # 98 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:14.277 | 2024-04-29 17:40:14.277 | No download requests in the queue to start downloads for. 2024-04-29 17:40:14.332 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:14.332 | Socket (7) | Closed. 2024-04-29 17:40:16.059 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:16.059 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:16.059 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:16.060 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:16.060 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:16.113 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:16.113 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:16.113 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:16.113 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:16.279 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:16.279 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:16.279 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:16.279 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:16.279 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:16.279 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:16.279 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:16.279 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:16.279 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:16.279 | Triggering next historical data download in queue. 2024-04-29 17:40:16.279 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:16.279 | HD Request # 99 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:16.279 | HD Request # 99 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:16.279 | HD Request # 99 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:16.279 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:16.279 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:16.279 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:16.332 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:16.332 | HD Request # 99 | Sending historical data logon request message. 2024-04-29 17:40:16.332 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:16.332 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:16.333 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:16.333 | DTC Client socket (6) | Closed. 2024-04-29 17:40:16.333 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:16.333 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:16.333 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:16.499 | HD Request # 99 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:16.552 | Socket (7) | CloseSocket call. 2024-04-29 17:40:16.552 | HD Request # 99 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:16.552 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:16.552 | Historical data download thread signaled to stop. 2024-04-29 17:40:16.552 | HD Request # 99 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:16.552 | HD Request # 99 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:16.552 | HD Request # 99 | Completion time: 0s. 2024-04-29 17:40:16.552 | HD Request # 99 | Intraday data download complete for ESM24-CME. Unique request ID: 99 2024-04-29 17:40:16.552 | Removing historical data download ID 99. 2024-04-29 17:40:16.552 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:16.552 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:16.552 | HD Request # 99 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:16.552 | 2024-04-29 17:40:16.552 | No download requests in the queue to start downloads for. 2024-04-29 17:40:16.605 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:16.605 | Socket (7) | Closed. 2024-04-29 17:40:18.325 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:18.325 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:18.326 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:18.326 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:18.326 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:18.380 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:18.380 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:18.380 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:18.380 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:18.547 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:18.547 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:18.547 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:18.547 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:18.547 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:18.547 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:18.547 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:18.547 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:18.547 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:18.547 | Triggering next historical data download in queue. 2024-04-29 17:40:18.547 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:18.547 | HD Request # 100 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:18.547 | HD Request # 100 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:18.547 | HD Request # 100 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:18.547 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:18.547 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:18.547 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:18.601 | HD Request # 100 | Sending historical data logon request message. 2024-04-29 17:40:18.601 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:18.601 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:18.601 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:18.601 | DTC Client socket (6) | Closed. 2024-04-29 17:40:18.601 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:18.601 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:18.601 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:18.601 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:18.772 | HD Request # 100 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:18.827 | Socket (7) | CloseSocket call. 2024-04-29 17:40:18.827 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:18.827 | HD Request # 100 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:18.827 | Historical data download thread signaled to stop. 2024-04-29 17:40:18.827 | HD Request # 100 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:18.827 | HD Request # 100 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:18.827 | HD Request # 100 | Completion time: 0s. 2024-04-29 17:40:18.827 | HD Request # 100 | Intraday data download complete for ESM24-CME. Unique request ID: 100 2024-04-29 17:40:18.827 | Removing historical data download ID 100. 2024-04-29 17:40:18.827 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:18.827 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:18.827 | HD Request # 100 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:18.827 | 2024-04-29 17:40:18.827 | No download requests in the queue to start downloads for. 2024-04-29 17:40:18.880 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:18.880 | Socket (7) | Closed. 2024-04-29 17:40:20.592 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:20.592 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:20.592 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:20.592 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:20.592 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:20.646 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:20.646 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:20.646 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:20.646 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:20.815 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:20.815 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:20.815 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:20.815 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:20.815 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:20.815 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:20.815 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:20.815 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:20.815 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:20.815 | Triggering next historical data download in queue. 2024-04-29 17:40:20.815 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:20.815 | HD Request # 101 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:20.815 | HD Request # 101 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:20.815 | HD Request # 101 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:20.815 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:20.815 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:20.815 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:20.869 | HD Request # 101 | Sending historical data logon request message. 2024-04-29 17:40:20.869 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:20.869 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:20.869 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:20.869 | DTC Client socket (6) | Closed. 2024-04-29 17:40:20.869 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:20.870 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:20.870 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:20.870 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:21.041 | HD Request # 101 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:21.096 | Socket (7) | CloseSocket call. 2024-04-29 17:40:21.096 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:21.096 | HD Request # 101 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:21.096 | Historical data download thread signaled to stop. 2024-04-29 17:40:21.096 | HD Request # 101 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:21.096 | HD Request # 101 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:21.096 | HD Request # 101 | Completion time: 1s. 2024-04-29 17:40:21.096 | HD Request # 101 | Intraday data download complete for ESM24-CME. Unique request ID: 101 2024-04-29 17:40:21.096 | Removing historical data download ID 101. 2024-04-29 17:40:21.096 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:21.096 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:21.096 | HD Request # 101 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:21.096 | 2024-04-29 17:40:21.096 | No download requests in the queue to start downloads for. 2024-04-29 17:40:21.152 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:21.152 | Socket (7) | Closed. 2024-04-29 17:40:22.861 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:22.861 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:22.863 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:22.863 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:22.863 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:22.919 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:22.919 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:22.919 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:22.919 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:23.083 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:23.083 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:23.083 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:23.083 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:23.083 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:23.083 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:23.083 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:23.083 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:23.083 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:23.083 | Triggering next historical data download in queue. 2024-04-29 17:40:23.083 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:23.083 | HD Request # 102 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:23.083 | HD Request # 102 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:23.083 | HD Request # 102 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:23.083 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:23.083 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:23.083 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:23.137 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:23.137 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:23.137 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:23.137 | DTC Client socket (6) | Closed. 2024-04-29 17:40:23.137 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:23.138 | HD Request # 102 | Sending historical data logon request message. 2024-04-29 17:40:23.138 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:23.138 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:23.138 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:23.304 | HD Request # 102 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:23.357 | Socket (7) | CloseSocket call. 2024-04-29 17:40:23.357 | HD Request # 102 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:23.357 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:23.357 | Historical data download thread signaled to stop. 2024-04-29 17:40:23.357 | HD Request # 102 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:23.357 | HD Request # 102 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:23.357 | HD Request # 102 | Completion time: 0s. 2024-04-29 17:40:23.357 | HD Request # 102 | Intraday data download complete for ESM24-CME. Unique request ID: 102 2024-04-29 17:40:23.357 | Removing historical data download ID 102. 2024-04-29 17:40:23.357 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:23.357 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:23.357 | HD Request # 102 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:23.357 | 2024-04-29 17:40:23.357 | No download requests in the queue to start downloads for. 2024-04-29 17:40:23.410 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:23.410 | Socket (7) | Closed. 2024-04-29 17:40:25.140 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:25.140 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:25.140 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:25.140 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:25.140 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:25.193 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:25.193 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:25.193 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:25.193 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:25.357 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:25.357 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:25.357 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:25.357 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:25.357 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:25.357 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:25.357 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:25.357 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:25.357 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:25.357 | Triggering next historical data download in queue. 2024-04-29 17:40:25.357 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:25.357 | HD Request # 103 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:25.357 | HD Request # 103 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:25.357 | HD Request # 103 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:25.357 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:25.357 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:25.357 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:25.410 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:25.410 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:25.410 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:25.410 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:25.410 | DTC Client socket (6) | Closed. 2024-04-29 17:40:25.410 | HD Request # 103 | Sending historical data logon request message. 2024-04-29 17:40:25.410 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:25.410 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:25.410 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:25.573 | HD Request # 103 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:25.627 | Socket (7) | CloseSocket call. 2024-04-29 17:40:25.627 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:25.628 | HD Request # 103 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:25.628 | Historical data download thread signaled to stop. 2024-04-29 17:40:25.628 | HD Request # 103 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:25.628 | HD Request # 103 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:25.628 | HD Request # 103 | Completion time: 0s. 2024-04-29 17:40:25.628 | HD Request # 103 | Intraday data download complete for ESM24-CME. Unique request ID: 103 2024-04-29 17:40:25.628 | Removing historical data download ID 103. 2024-04-29 17:40:25.628 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:25.628 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:25.628 | HD Request # 103 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:25.628 | 2024-04-29 17:40:25.628 | No download requests in the queue to start downloads for. 2024-04-29 17:40:25.681 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:25.681 | Socket (7) | Closed. 2024-04-29 17:40:27.387 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:27.387 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:27.388 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:27.388 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:27.388 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:27.443 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:27.443 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:27.443 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:27.443 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:27.607 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:27.607 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:27.607 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:27.607 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:27.607 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:27.607 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:27.607 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:27.607 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:27.607 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:27.607 | Triggering next historical data download in queue. 2024-04-29 17:40:27.607 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:27.607 | HD Request # 104 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:27.607 | HD Request # 104 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:27.607 | HD Request # 104 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:27.607 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:27.607 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:27.607 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:27.659 | HD Request # 104 | Sending historical data logon request message. 2024-04-29 17:40:27.660 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:27.660 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:27.660 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:27.660 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:27.660 | DTC Client socket (6) | Closed. 2024-04-29 17:40:27.660 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:27.660 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:27.660 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:27.825 | HD Request # 104 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:27.878 | Socket (7) | CloseSocket call. 2024-04-29 17:40:27.878 | HD Request # 104 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:27.878 | Historical data download thread signaled to stop. 2024-04-29 17:40:27.878 | HD Request # 104 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:27.878 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:27.879 | HD Request # 104 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:27.879 | HD Request # 104 | Completion time: 0s. 2024-04-29 17:40:27.879 | HD Request # 104 | Intraday data download complete for ESM24-CME. Unique request ID: 104 2024-04-29 17:40:27.879 | Removing historical data download ID 104. 2024-04-29 17:40:27.879 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:27.879 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:27.879 | HD Request # 104 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:27.879 | 2024-04-29 17:40:27.879 | No download requests in the queue to start downloads for. 2024-04-29 17:40:27.933 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:27.933 | Socket (7) | Closed. 2024-04-29 17:40:29.659 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:29.659 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:29.659 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:29.659 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:29.659 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:29.712 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:29.712 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:29.712 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:29.712 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:29.874 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:29.874 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:29.874 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:29.874 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:29.874 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:29.874 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:29.874 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:29.874 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:29.874 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:29.874 | Triggering next historical data download in queue. 2024-04-29 17:40:29.874 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:29.875 | HD Request # 105 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:29.875 | HD Request # 105 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:29.875 | HD Request # 105 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:29.875 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:29.875 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:29.875 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:29.927 | HD Request # 105 | Sending historical data logon request message. 2024-04-29 17:40:29.930 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:29.930 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:29.930 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:29.930 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:29.931 | DTC Client socket (6) | Closed. 2024-04-29 17:40:29.931 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:29.931 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:29.931 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:30.093 | HD Request # 105 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:30.146 | Socket (7) | CloseSocket call. 2024-04-29 17:40:30.146 | HD Request # 105 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:30.146 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:30.146 | Historical data download thread signaled to stop. 2024-04-29 17:40:30.146 | HD Request # 105 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:30.146 | HD Request # 105 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:30.146 | HD Request # 105 | Completion time: 1s. 2024-04-29 17:40:30.146 | HD Request # 105 | Intraday data download complete for ESM24-CME. Unique request ID: 105 2024-04-29 17:40:30.146 | Removing historical data download ID 105. 2024-04-29 17:40:30.146 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:30.146 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:30.146 | HD Request # 105 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:30.146 | 2024-04-29 17:40:30.146 | No download requests in the queue to start downloads for. 2024-04-29 17:40:30.200 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:30.201 | Socket (7) | Closed. 2024-04-29 17:40:31.941 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:31.941 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:31.942 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:31.942 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:31.942 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:31.997 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:31.997 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:31.997 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:31.997 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:32.164 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:32.164 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:32.164 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:32.164 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:32.164 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:32.164 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:32.164 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:32.164 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:32.164 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:32.164 | Triggering next historical data download in queue. 2024-04-29 17:40:32.164 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:32.164 | HD Request # 106 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:32.164 | HD Request # 106 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:32.164 | HD Request # 106 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:32.164 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:32.164 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:32.164 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:32.217 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:32.217 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:32.218 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:32.219 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:32.219 | HD Request # 106 | Sending historical data logon request message. 2024-04-29 17:40:32.219 | DTC Client socket (6) | Closed. 2024-04-29 17:40:32.219 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:32.219 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:32.219 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:32.395 | HD Request # 106 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:32.451 | Socket (7) | CloseSocket call. 2024-04-29 17:40:32.451 | HD Request # 106 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:32.451 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:32.451 | Historical data download thread signaled to stop. 2024-04-29 17:40:32.451 | HD Request # 106 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:32.451 | HD Request # 106 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:32.451 | HD Request # 106 | Completion time: 0s. 2024-04-29 17:40:32.451 | HD Request # 106 | Intraday data download complete for ESM24-CME. Unique request ID: 106 2024-04-29 17:40:32.451 | Removing historical data download ID 106. 2024-04-29 17:40:32.451 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:32.451 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:32.451 | HD Request # 106 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:32.451 | 2024-04-29 17:40:32.451 | No download requests in the queue to start downloads for. 2024-04-29 17:40:32.505 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:32.505 | Socket (7) | Closed. 2024-04-29 17:40:34.202 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:34.202 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:34.202 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:34.202 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:34.202 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:34.257 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:34.257 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:34.257 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:34.257 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:34.420 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:34.420 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:34.420 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:34.420 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:34.420 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:34.420 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:34.420 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:34.420 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:34.420 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:34.420 | Triggering next historical data download in queue. 2024-04-29 17:40:34.420 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:34.420 | HD Request # 107 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:34.421 | HD Request # 107 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:34.421 | HD Request # 107 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:34.421 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:34.421 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:34.421 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:34.474 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:34.474 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:34.474 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:34.474 | HD Request # 107 | Sending historical data logon request message. 2024-04-29 17:40:34.474 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:34.474 | DTC Client socket (6) | Closed. 2024-04-29 17:40:34.474 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:34.474 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:34.474 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:34.637 | HD Request # 107 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:34.689 | Socket (7) | CloseSocket call. 2024-04-29 17:40:34.689 | HD Request # 107 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:34.689 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:34.689 | Historical data download thread signaled to stop. 2024-04-29 17:40:34.689 | HD Request # 107 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:34.689 | HD Request # 107 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:34.689 | HD Request # 107 | Completion time: 0s. 2024-04-29 17:40:34.689 | HD Request # 107 | Intraday data download complete for ESM24-CME. Unique request ID: 107 2024-04-29 17:40:34.689 | Removing historical data download ID 107. 2024-04-29 17:40:34.689 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:34.689 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:34.689 | HD Request # 107 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:34.689 | 2024-04-29 17:40:34.689 | No download requests in the queue to start downloads for. 2024-04-29 17:40:34.742 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:34.742 | Socket (7) | Closed. 2024-04-29 17:40:36.475 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:36.475 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:36.478 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:36.478 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:36.478 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:36.531 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:36.531 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:36.531 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:36.531 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:36.694 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:36.694 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:36.694 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:36.694 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:36.694 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:36.694 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:36.694 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:36.694 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:36.694 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:36.694 | Triggering next historical data download in queue. 2024-04-29 17:40:36.694 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:36.694 | HD Request # 108 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:36.694 | HD Request # 108 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:36.695 | HD Request # 108 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:36.695 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:36.695 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:36.695 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:36.748 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:36.748 | HD Request # 108 | Sending historical data logon request message. 2024-04-29 17:40:36.748 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:36.748 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:36.749 | DTC Client socket (6) | Closed. 2024-04-29 17:40:36.749 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:36.749 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:36.749 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:36.749 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:36.910 | HD Request # 108 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:36.964 | Socket (7) | CloseSocket call. 2024-04-29 17:40:36.964 | HD Request # 108 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:36.964 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:36.964 | Historical data download thread signaled to stop. 2024-04-29 17:40:36.964 | HD Request # 108 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:36.964 | HD Request # 108 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:36.964 | HD Request # 108 | Completion time: 0s. 2024-04-29 17:40:36.964 | HD Request # 108 | Intraday data download complete for ESM24-CME. Unique request ID: 108 2024-04-29 17:40:36.964 | Removing historical data download ID 108. 2024-04-29 17:40:36.964 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:36.964 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:36.964 | HD Request # 108 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:36.964 | 2024-04-29 17:40:36.964 | No download requests in the queue to start downloads for. 2024-04-29 17:40:37.021 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:37.021 | Socket (7) | Closed. 2024-04-29 17:40:38.760 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:38.760 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:38.760 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:38.760 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:38.760 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:38.815 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:38.815 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:38.815 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:38.815 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:38.981 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:38.981 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:38.981 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:38.981 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:38.981 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:38.981 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:38.981 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:38.981 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:38.981 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:38.981 | Triggering next historical data download in queue. 2024-04-29 17:40:38.981 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:38.981 | HD Request # 109 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:38.981 | HD Request # 109 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:38.981 | HD Request # 109 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:38.982 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:38.982 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:38.982 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:39.036 | HD Request # 109 | Sending historical data logon request message. 2024-04-29 17:40:39.037 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:39.037 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:39.037 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:39.038 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:39.038 | DTC Client socket (6) | Closed. 2024-04-29 17:40:39.039 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:39.039 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:39.039 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:39.203 | HD Request # 109 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:39.255 | Socket (7) | CloseSocket call. 2024-04-29 17:40:39.255 | HD Request # 109 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:39.255 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:39.255 | Historical data download thread signaled to stop. 2024-04-29 17:40:39.255 | HD Request # 109 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:39.255 | HD Request # 109 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:39.255 | HD Request # 109 | Completion time: 1s. 2024-04-29 17:40:39.255 | HD Request # 109 | Intraday data download complete for ESM24-CME. Unique request ID: 109 2024-04-29 17:40:39.255 | Removing historical data download ID 109. 2024-04-29 17:40:39.255 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:39.255 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:39.255 | HD Request # 109 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:39.255 | 2024-04-29 17:40:39.255 | No download requests in the queue to start downloads for. 2024-04-29 17:40:39.310 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:39.310 | Socket (7) | Closed. 2024-04-29 17:40:41.026 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:41.026 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:41.027 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:41.027 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:41.027 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:41.082 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:41.082 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:41.082 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:41.082 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:41.252 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:41.252 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:41.252 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:41.252 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:41.252 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:41.252 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:41.252 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:41.252 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:41.252 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:41.252 | Triggering next historical data download in queue. 2024-04-29 17:40:41.252 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:41.252 | HD Request # 110 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:41.252 | HD Request # 110 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:41.252 | HD Request # 110 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:41.252 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:41.252 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:41.252 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:41.304 | HD Request # 110 | Sending historical data logon request message. 2024-04-29 17:40:41.304 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:41.305 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:41.305 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:41.305 | DTC Client socket (6) | Closed. 2024-04-29 17:40:41.305 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:41.305 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:41.305 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:41.305 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:41.469 | HD Request # 110 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:41.523 | Socket (7) | CloseSocket call. 2024-04-29 17:40:41.523 | HD Request # 110 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:41.523 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:41.523 | Historical data download thread signaled to stop. 2024-04-29 17:40:41.523 | HD Request # 110 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:41.523 | HD Request # 110 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:41.523 | HD Request # 110 | Completion time: 0s. 2024-04-29 17:40:41.523 | HD Request # 110 | Intraday data download complete for ESM24-CME. Unique request ID: 110 2024-04-29 17:40:41.523 | Removing historical data download ID 110. 2024-04-29 17:40:41.523 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:41.523 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:41.523 | HD Request # 110 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:41.523 | 2024-04-29 17:40:41.523 | No download requests in the queue to start downloads for. 2024-04-29 17:40:41.577 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:41.577 | Socket (7) | Closed. 2024-04-29 17:40:43.291 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:43.291 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:43.292 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:43.292 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:43.292 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:43.347 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:43.347 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:43.347 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:43.347 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:43.511 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:43.511 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:43.511 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:43.511 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:43.511 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:43.511 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:43.511 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:43.511 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:43.511 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:43.511 | Triggering next historical data download in queue. 2024-04-29 17:40:43.511 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:43.511 | HD Request # 111 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:43.511 | HD Request # 111 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:43.511 | HD Request # 111 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:43.511 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:43.512 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:43.512 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:43.564 | HD Request # 111 | Sending historical data logon request message. 2024-04-29 17:40:43.565 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:43.565 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:43.565 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:43.565 | DTC Client socket (6) | Closed. 2024-04-29 17:40:43.565 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:43.565 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:43.565 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:43.565 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:43.729 | HD Request # 111 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:43.784 | Socket (7) | CloseSocket call. 2024-04-29 17:40:43.784 | HD Request # 111 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:43.784 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:43.784 | Historical data download thread signaled to stop. 2024-04-29 17:40:43.784 | HD Request # 111 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:43.784 | HD Request # 111 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:43.784 | HD Request # 111 | Completion time: 0s. 2024-04-29 17:40:43.784 | HD Request # 111 | Intraday data download complete for ESM24-CME. Unique request ID: 111 2024-04-29 17:40:43.784 | Removing historical data download ID 111. 2024-04-29 17:40:43.784 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:43.784 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:43.784 | HD Request # 111 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:43.784 | 2024-04-29 17:40:43.784 | No download requests in the queue to start downloads for. 2024-04-29 17:40:43.837 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:43.837 | Socket (7) | Closed. 2024-04-29 17:40:45.557 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:45.557 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:45.557 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:45.557 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:45.557 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:45.612 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:45.612 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:45.612 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:45.612 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:45.775 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:45.775 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:45.775 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:45.775 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:45.775 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:45.775 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:45.775 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:45.775 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:45.775 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:45.775 | Triggering next historical data download in queue. 2024-04-29 17:40:45.775 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:45.775 | HD Request # 112 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:45.776 | HD Request # 112 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:45.776 | HD Request # 112 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:45.776 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:45.776 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:45.776 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:45.833 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:45.833 | HD Request # 112 | Sending historical data logon request message. 2024-04-29 17:40:45.833 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:45.833 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:45.833 | DTC Client socket (6) | Closed. 2024-04-29 17:40:45.833 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:45.833 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:45.833 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:45.833 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:46.000 | HD Request # 112 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:46.052 | Socket (7) | CloseSocket call. 2024-04-29 17:40:46.052 | HD Request # 112 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:46.052 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:46.052 | Historical data download thread signaled to stop. 2024-04-29 17:40:46.052 | HD Request # 112 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:46.052 | HD Request # 112 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:46.052 | HD Request # 112 | Completion time: 1s. 2024-04-29 17:40:46.052 | HD Request # 112 | Intraday data download complete for ESM24-CME. Unique request ID: 112 2024-04-29 17:40:46.052 | Removing historical data download ID 112. 2024-04-29 17:40:46.052 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:46.052 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:46.052 | HD Request # 112 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:46.052 | 2024-04-29 17:40:46.052 | No download requests in the queue to start downloads for. 2024-04-29 17:40:46.107 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:46.107 | Socket (7) | Closed. 2024-04-29 17:40:47.825 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:47.825 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:47.826 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:47.826 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:47.826 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:47.879 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:47.879 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:47.879 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:47.879 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:48.041 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:48.041 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:48.041 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:48.041 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:48.041 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:48.041 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:48.041 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:48.042 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:48.042 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:48.042 | Triggering next historical data download in queue. 2024-04-29 17:40:48.042 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:48.042 | HD Request # 113 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:48.042 | HD Request # 113 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:48.042 | HD Request # 113 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:48.042 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:48.042 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:48.042 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:48.094 | HD Request # 113 | Sending historical data logon request message. 2024-04-29 17:40:48.094 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:48.095 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:48.095 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:48.095 | DTC Client socket (6) | Closed. 2024-04-29 17:40:48.095 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:48.095 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:48.095 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:48.095 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:48.259 | HD Request # 113 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:48.310 | Socket (7) | CloseSocket call. 2024-04-29 17:40:48.310 | HD Request # 113 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:48.310 | Historical data download thread signaled to stop. 2024-04-29 17:40:48.310 | HD Request # 113 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:48.310 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:48.310 | HD Request # 113 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:48.310 | HD Request # 113 | Completion time: 0s. 2024-04-29 17:40:48.310 | HD Request # 113 | Intraday data download complete for ESM24-CME. Unique request ID: 113 2024-04-29 17:40:48.310 | Removing historical data download ID 113. 2024-04-29 17:40:48.310 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:48.310 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:48.310 | HD Request # 113 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:48.310 | 2024-04-29 17:40:48.310 | No download requests in the queue to start downloads for. 2024-04-29 17:40:48.364 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:48.364 | Socket (7) | Closed. 2024-04-29 17:40:50.090 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:50.090 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:50.091 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:50.091 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:50.091 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:50.143 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:50.143 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:50.143 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:50.143 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:50.318 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:50.318 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:50.318 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:50.318 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:50.318 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:50.318 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:50.318 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:50.318 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:50.318 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:50.318 | Triggering next historical data download in queue. 2024-04-29 17:40:50.318 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:50.318 | HD Request # 114 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:50.318 | HD Request # 114 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:50.318 | HD Request # 114 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:50.318 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:50.318 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:50.318 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:50.370 | HD Request # 114 | Sending historical data logon request message. 2024-04-29 17:40:50.372 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:50.372 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:50.372 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:50.372 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:50.372 | DTC Client socket (6) | Closed. 2024-04-29 17:40:50.373 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:50.373 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:50.373 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:50.536 | HD Request # 114 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:50.589 | Socket (7) | CloseSocket call. 2024-04-29 17:40:50.589 | HD Request # 114 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:50.589 | Historical data download thread signaled to stop. 2024-04-29 17:40:50.589 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:50.589 | HD Request # 114 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:50.589 | HD Request # 114 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:50.589 | HD Request # 114 | Completion time: 0s. 2024-04-29 17:40:50.589 | HD Request # 114 | Intraday data download complete for ESM24-CME. Unique request ID: 114 2024-04-29 17:40:50.589 | Removing historical data download ID 114. 2024-04-29 17:40:50.589 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:50.589 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:50.589 | HD Request # 114 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:50.589 | 2024-04-29 17:40:50.589 | No download requests in the queue to start downloads for. 2024-04-29 17:40:50.646 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:50.646 | Socket (7) | Closed. 2024-04-29 17:40:52.357 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:52.357 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:52.359 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:52.359 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:52.359 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:52.415 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:52.415 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:52.415 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:52.415 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:52.586 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:52.586 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:52.586 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:52.586 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:52.586 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:52.586 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:52.586 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:52.586 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:52.586 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:52.586 | Triggering next historical data download in queue. 2024-04-29 17:40:52.586 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:52.586 | HD Request # 115 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:52.587 | HD Request # 115 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:52.587 | HD Request # 115 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:52.587 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:52.587 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:52.587 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:52.640 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:52.640 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:52.640 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:52.640 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:52.640 | DTC Client socket (6) | Closed. 2024-04-29 17:40:52.640 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:52.640 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:52.640 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:52.641 | HD Request # 115 | Sending historical data logon request message. 2024-04-29 17:40:52.813 | HD Request # 115 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:52.869 | Socket (7) | CloseSocket call. 2024-04-29 17:40:52.869 | HD Request # 115 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:52.869 | Historical data download thread signaled to stop. 2024-04-29 17:40:52.869 | HD Request # 115 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:52.870 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:52.870 | HD Request # 115 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:52.870 | HD Request # 115 | Completion time: 0s. 2024-04-29 17:40:52.870 | HD Request # 115 | Intraday data download complete for ESM24-CME. Unique request ID: 115 2024-04-29 17:40:52.870 | Removing historical data download ID 115. 2024-04-29 17:40:52.870 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:52.870 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:52.870 | HD Request # 115 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:52.870 | 2024-04-29 17:40:52.870 | No download requests in the queue to start downloads for. 2024-04-29 17:40:52.927 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:52.927 | Socket (7) | Closed. 2024-04-29 17:40:54.636 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:54.636 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:54.637 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:54.637 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:54.637 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:54.692 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:54.692 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:54.692 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:54.692 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:54.858 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:54.858 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:54.858 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:54.858 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:54.858 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:54.858 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:54.858 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:54.858 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:54.858 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:54.858 | Triggering next historical data download in queue. 2024-04-29 17:40:54.858 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:54.858 | HD Request # 116 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:54.859 | HD Request # 116 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:54.859 | HD Request # 116 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:54.859 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:54.859 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:54.859 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:54.910 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:54.910 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:54.911 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:54.911 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:54.911 | DTC Client socket (6) | Closed. 2024-04-29 17:40:54.911 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:54.911 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:54.911 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:54.914 | HD Request # 116 | Sending historical data logon request message. 2024-04-29 17:40:55.079 | HD Request # 116 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:55.132 | Socket (7) | CloseSocket call. 2024-04-29 17:40:55.132 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:55.132 | HD Request # 116 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:55.132 | Historical data download thread signaled to stop. 2024-04-29 17:40:55.132 | HD Request # 116 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:55.132 | HD Request # 116 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:55.132 | HD Request # 116 | Completion time: 1s. 2024-04-29 17:40:55.132 | HD Request # 116 | Intraday data download complete for ESM24-CME. Unique request ID: 116 2024-04-29 17:40:55.132 | Removing historical data download ID 116. 2024-04-29 17:40:55.132 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:55.132 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:55.132 | HD Request # 116 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:55.132 | 2024-04-29 17:40:55.132 | No download requests in the queue to start downloads for. 2024-04-29 17:40:55.187 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:55.187 | Socket (7) | Closed. 2024-04-29 17:40:56.902 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:56.902 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:56.902 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:56.903 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:56.903 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:56.957 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:56.957 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:56.957 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:56.957 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:57.120 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:57.120 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:57.120 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:57.120 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:57.120 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:57.120 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:57.120 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:57.120 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:57.120 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:57.120 | Triggering next historical data download in queue. 2024-04-29 17:40:57.120 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:57.120 | HD Request # 117 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:57.120 | HD Request # 117 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:57.120 | HD Request # 117 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:57.120 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:57.120 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:57.120 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:57.175 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:57.175 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:57.175 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:57.175 | DTC Client socket (6) | Closed. 2024-04-29 17:40:57.175 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:57.175 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:57.175 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:57.175 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:57.175 | HD Request # 117 | Sending historical data logon request message. 2024-04-29 17:40:57.345 | HD Request # 117 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:57.399 | Socket (7) | CloseSocket call. 2024-04-29 17:40:57.399 | HD Request # 117 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:57.399 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:57.399 | Historical data download thread signaled to stop. 2024-04-29 17:40:57.399 | HD Request # 117 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:57.399 | HD Request # 117 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:57.399 | HD Request # 117 | Completion time: 0s. 2024-04-29 17:40:57.399 | HD Request # 117 | Intraday data download complete for ESM24-CME. Unique request ID: 117 2024-04-29 17:40:57.399 | Removing historical data download ID 117. 2024-04-29 17:40:57.399 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:57.399 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:57.399 | HD Request # 117 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:57.399 | 2024-04-29 17:40:57.399 | No download requests in the queue to start downloads for. 2024-04-29 17:40:57.453 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:57.453 | Socket (7) | Closed. 2024-04-29 17:40:59.181 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:40:59.181 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:40:59.182 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:59.182 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:40:59.182 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:59.234 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:40:59.234 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:40:59.234 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:40:59.234 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:40:59.399 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:40:59.399 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:40:59.399 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:40:59.399 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:40:59.399 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:40:59.399 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:40:59.399 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:40:59.399 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:40:59.399 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:40:59.399 | Triggering next historical data download in queue. 2024-04-29 17:40:59.399 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:40:59.399 | HD Request # 118 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:40:59.399 | HD Request # 118 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:59.400 | HD Request # 118 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:40:59.400 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:40:59.400 | Socket (7) | New receive buffer size: 0 2024-04-29 17:40:59.400 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:40:59.455 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:40:59.455 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:40:59.456 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:40:59.456 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:40:59.456 | DTC Client socket (6) | Closed. 2024-04-29 17:40:59.457 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:40:59.457 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:40:59.457 | HD Request # 118 | Sending historical data logon request message. 2024-04-29 17:40:59.457 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:40:59.625 | HD Request # 118 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:40:59.680 | Socket (7) | CloseSocket call. 2024-04-29 17:40:59.680 | HD Request # 118 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:40:59.680 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:40:59.680 | Historical data download thread signaled to stop. 2024-04-29 17:40:59.680 | HD Request # 118 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:40:59.680 | HD Request # 118 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:40:59.680 | HD Request # 118 | Completion time: 0s. 2024-04-29 17:40:59.680 | HD Request # 118 | Intraday data download complete for ESM24-CME. Unique request ID: 118 2024-04-29 17:40:59.680 | Removing historical data download ID 118. 2024-04-29 17:40:59.680 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:40:59.680 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:40:59.680 | HD Request # 118 | Enabling Intraday chart updating for symbol. 2024-04-29 17:40:59.680 | 2024-04-29 17:40:59.680 | No download requests in the queue to start downloads for. 2024-04-29 17:40:59.734 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:40:59.734 | Socket (7) | Closed. 2024-04-29 17:41:01.187 | ESM4.CME[M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 2024-03-31 22:00:00 2024-04-29 17:41:01.452 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:01.452 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:01.453 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:01.453 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:01.453 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:01.506 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:01.506 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:01.506 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:01.506 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:01.671 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:01.671 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:01.671 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:01.671 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:01.671 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:01.671 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:01.671 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:01.671 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:01.671 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:01.671 | Triggering next historical data download in queue. 2024-04-29 17:41:01.671 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:01.671 | HD Request # 119 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:01.671 | HD Request # 119 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:01.671 | HD Request # 119 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:01.671 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:01.672 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:01.672 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:01.725 | HD Request # 119 | Sending historical data logon request message. 2024-04-29 17:41:01.727 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:01.727 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:01.727 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:01.727 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:01.728 | DTC Client socket (6) | Closed. 2024-04-29 17:41:01.728 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:01.728 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:01.728 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:01.888 | HD Request # 119 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:01.943 | Socket (7) | CloseSocket call. 2024-04-29 17:41:01.943 | HD Request # 119 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:01.943 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:01.943 | Historical data download thread signaled to stop. 2024-04-29 17:41:01.943 | HD Request # 119 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:01.943 | HD Request # 119 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:01.943 | HD Request # 119 | Completion time: 0s. 2024-04-29 17:41:01.943 | HD Request # 119 | Intraday data download complete for ESM24-CME. Unique request ID: 119 2024-04-29 17:41:01.943 | Removing historical data download ID 119. 2024-04-29 17:41:01.943 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:01.943 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:01.943 | HD Request # 119 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:01.943 | 2024-04-29 17:41:01.943 | No download requests in the queue to start downloads for. 2024-04-29 17:41:01.998 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:01.998 | Socket (7) | Closed. 2024-04-29 17:41:03.736 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:03.736 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:03.737 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:03.737 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:03.737 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:03.790 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:03.790 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:03.790 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:03.790 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:03.961 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:03.961 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:03.961 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:03.961 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:03.961 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:03.961 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:03.961 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:03.961 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:03.961 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:03.961 | Triggering next historical data download in queue. 2024-04-29 17:41:03.961 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:03.961 | HD Request # 120 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:03.961 | HD Request # 120 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:03.961 | HD Request # 120 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:03.961 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:03.961 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:03.961 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:04.014 | HD Request # 120 | Sending historical data logon request message. 2024-04-29 17:41:04.014 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:04.014 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:04.014 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:04.014 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:04.014 | DTC Client socket (6) | Closed. 2024-04-29 17:41:04.015 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:04.015 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:04.015 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:04.177 | HD Request # 120 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:04.232 | Socket (7) | CloseSocket call. 2024-04-29 17:41:04.232 | HD Request # 120 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:04.232 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:04.232 | Historical data download thread signaled to stop. 2024-04-29 17:41:04.232 | HD Request # 120 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:04.232 | HD Request # 120 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:04.232 | HD Request # 120 | Completion time: 1s. 2024-04-29 17:41:04.232 | HD Request # 120 | Intraday data download complete for ESM24-CME. Unique request ID: 120 2024-04-29 17:41:04.232 | Removing historical data download ID 120. 2024-04-29 17:41:04.232 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:04.232 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:04.232 | HD Request # 120 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:04.232 | 2024-04-29 17:41:04.232 | No download requests in the queue to start downloads for. 2024-04-29 17:41:04.286 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:04.286 | Socket (7) | Closed. 2024-04-29 17:41:06.006 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:06.006 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:06.007 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:06.008 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:06.008 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:06.062 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:06.062 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:06.062 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:06.062 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:06.229 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:06.229 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:06.229 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:06.229 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:06.229 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:06.229 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:06.229 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:06.229 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:06.229 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:06.229 | Triggering next historical data download in queue. 2024-04-29 17:41:06.229 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:06.229 | HD Request # 121 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:06.229 | HD Request # 121 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:06.229 | HD Request # 121 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:06.229 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:06.229 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:06.229 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:06.284 | HD Request # 121 | Sending historical data logon request message. 2024-04-29 17:41:06.285 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:06.285 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:06.285 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:06.285 | DTC Client socket (6) | Closed. 2024-04-29 17:41:06.285 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:06.285 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:06.285 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:06.285 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:06.445 | HD Request # 121 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:06.498 | Socket (7) | CloseSocket call. 2024-04-29 17:41:06.498 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:06.498 | HD Request # 121 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:06.498 | Historical data download thread signaled to stop. 2024-04-29 17:41:06.498 | HD Request # 121 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:06.499 | HD Request # 121 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:06.499 | HD Request # 121 | Completion time: 0s. 2024-04-29 17:41:06.499 | HD Request # 121 | Intraday data download complete for ESM24-CME. Unique request ID: 121 2024-04-29 17:41:06.499 | Removing historical data download ID 121. 2024-04-29 17:41:06.499 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:06.499 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:06.499 | HD Request # 121 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:06.499 | 2024-04-29 17:41:06.499 | No download requests in the queue to start downloads for. 2024-04-29 17:41:06.553 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:06.553 | Socket (7) | Closed. 2024-04-29 17:41:08.264 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:08.265 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:08.265 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:08.265 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:08.265 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:08.319 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:08.319 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:08.319 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:08.319 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:08.487 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:08.487 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:08.487 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:08.487 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:08.487 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:08.487 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:08.487 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:08.487 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:08.487 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:08.487 | Triggering next historical data download in queue. 2024-04-29 17:41:08.487 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:08.488 | HD Request # 122 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:08.488 | HD Request # 122 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:08.488 | HD Request # 122 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:08.488 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:08.488 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:08.488 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:08.542 | HD Request # 122 | Sending historical data logon request message. 2024-04-29 17:41:08.543 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:08.544 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:08.544 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:08.544 | DTC Client socket (6) | Closed. 2024-04-29 17:41:08.544 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:08.545 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:08.545 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:08.545 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:08.713 | HD Request # 122 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:08.768 | Socket (7) | CloseSocket call. 2024-04-29 17:41:08.769 | HD Request # 122 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:08.769 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:08.769 | Historical data download thread signaled to stop. 2024-04-29 17:41:08.769 | HD Request # 122 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:08.769 | HD Request # 122 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:08.769 | HD Request # 122 | Completion time: 0s. 2024-04-29 17:41:08.769 | HD Request # 122 | Intraday data download complete for ESM24-CME. Unique request ID: 122 2024-04-29 17:41:08.769 | Removing historical data download ID 122. 2024-04-29 17:41:08.769 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:08.769 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:08.769 | HD Request # 122 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:08.769 | 2024-04-29 17:41:08.769 | No download requests in the queue to start downloads for. 2024-04-29 17:41:08.821 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:08.822 | Socket (7) | Closed. 2024-04-29 17:41:10.549 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:10.549 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:10.550 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:10.550 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:10.550 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:10.603 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:10.603 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:10.603 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:10.603 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:10.770 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:10.770 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:10.770 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:10.770 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:10.770 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:10.770 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:10.770 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:10.770 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:10.770 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:10.770 | Triggering next historical data download in queue. 2024-04-29 17:41:10.770 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:10.770 | HD Request # 123 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:10.770 | HD Request # 123 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:10.771 | HD Request # 123 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:10.771 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:10.771 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:10.771 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:10.825 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:10.826 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:10.826 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:10.826 | HD Request # 123 | Sending historical data logon request message. 2024-04-29 17:41:10.826 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:10.826 | DTC Client socket (6) | Closed. 2024-04-29 17:41:10.826 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:10.826 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:10.826 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:10.991 | HD Request # 123 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:11.044 | Socket (7) | CloseSocket call. 2024-04-29 17:41:11.044 | HD Request # 123 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:11.044 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:11.044 | Historical data download thread signaled to stop. 2024-04-29 17:41:11.044 | HD Request # 123 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:11.044 | HD Request # 123 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:11.044 | HD Request # 123 | Completion time: 1s. 2024-04-29 17:41:11.044 | HD Request # 123 | Intraday data download complete for ESM24-CME. Unique request ID: 123 2024-04-29 17:41:11.044 | Removing historical data download ID 123. 2024-04-29 17:41:11.044 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:11.044 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:11.044 | HD Request # 123 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:11.044 | 2024-04-29 17:41:11.044 | No download requests in the queue to start downloads for. 2024-04-29 17:41:11.097 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:11.098 | Socket (7) | Closed. 2024-04-29 17:41:12.810 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:12.810 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:12.810 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:12.810 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:12.810 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:12.863 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:12.863 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:12.863 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:12.863 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:13.027 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:13.027 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:13.027 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:13.027 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:13.027 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:13.027 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:13.027 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:13.027 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:13.027 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:13.027 | Triggering next historical data download in queue. 2024-04-29 17:41:13.027 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:13.027 | HD Request # 124 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:13.027 | HD Request # 124 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:13.027 | HD Request # 124 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:13.027 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:13.027 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:13.027 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:13.081 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:13.081 | HD Request # 124 | Sending historical data logon request message. 2024-04-29 17:41:13.081 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:13.081 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:13.081 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:13.081 | DTC Client socket (6) | Closed. 2024-04-29 17:41:13.081 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:13.081 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:13.081 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:13.242 | HD Request # 124 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:13.294 | Socket (7) | CloseSocket call. 2024-04-29 17:41:13.294 | HD Request # 124 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:13.294 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:13.294 | Historical data download thread signaled to stop. 2024-04-29 17:41:13.294 | HD Request # 124 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:13.294 | HD Request # 124 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:13.294 | HD Request # 124 | Completion time: 0s. 2024-04-29 17:41:13.294 | HD Request # 124 | Intraday data download complete for ESM24-CME. Unique request ID: 124 2024-04-29 17:41:13.294 | Removing historical data download ID 124. 2024-04-29 17:41:13.294 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:13.294 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:13.294 | HD Request # 124 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:13.294 | 2024-04-29 17:41:13.294 | No download requests in the queue to start downloads for. 2024-04-29 17:41:13.349 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:13.349 | Socket (7) | Closed. 2024-04-29 17:41:15.078 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:15.078 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:15.078 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:15.078 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:15.078 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:15.133 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:15.133 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:15.133 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:15.133 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:15.297 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:15.297 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:15.297 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:15.297 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:15.297 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:15.297 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:15.297 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:15.297 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:15.297 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:15.297 | Triggering next historical data download in queue. 2024-04-29 17:41:15.297 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:15.297 | HD Request # 125 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:15.297 | HD Request # 125 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:15.297 | HD Request # 125 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:15.297 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:15.297 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:15.297 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:15.352 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:15.352 | HD Request # 125 | Sending historical data logon request message. 2024-04-29 17:41:15.365 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:15.365 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:15.365 | DTC Client socket (6) | Closed. 2024-04-29 17:41:15.367 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:15.368 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:15.368 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:15.369 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:15.517 | HD Request # 125 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:15.571 | Socket (7) | CloseSocket call. 2024-04-29 17:41:15.571 | HD Request # 125 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:15.571 | Historical data download thread signaled to stop. 2024-04-29 17:41:15.571 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:15.571 | HD Request # 125 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:15.572 | HD Request # 125 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:15.572 | HD Request # 125 | Completion time: 0s. 2024-04-29 17:41:15.572 | HD Request # 125 | Intraday data download complete for ESM24-CME. Unique request ID: 125 2024-04-29 17:41:15.572 | Removing historical data download ID 125. 2024-04-29 17:41:15.572 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:15.572 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:15.572 | HD Request # 125 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:15.572 | 2024-04-29 17:41:15.572 | No download requests in the queue to start downloads for. 2024-04-29 17:41:15.628 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:15.628 | Socket (7) | Closed. 2024-04-29 17:41:17.377 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:17.377 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:17.378 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:17.378 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:17.378 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:17.431 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:17.431 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:17.431 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:17.431 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:17.596 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:17.596 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:17.596 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:17.596 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:17.596 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:17.596 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:17.596 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:17.596 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:17.596 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:17.596 | Triggering next historical data download in queue. 2024-04-29 17:41:17.596 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:17.596 | HD Request # 126 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:17.596 | HD Request # 126 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:17.596 | HD Request # 126 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:17.596 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:17.596 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:17.596 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:17.649 | HD Request # 126 | Sending historical data logon request message. 2024-04-29 17:41:17.650 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:17.650 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:17.650 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:17.650 | DTC Client socket (6) | Closed. 2024-04-29 17:41:17.650 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:17.650 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:17.650 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:17.651 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:17.817 | HD Request # 126 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:17.870 | Socket (7) | CloseSocket call. 2024-04-29 17:41:17.870 | HD Request # 126 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:17.870 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:17.870 | Historical data download thread signaled to stop. 2024-04-29 17:41:17.870 | HD Request # 126 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:17.871 | HD Request # 126 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:17.871 | HD Request # 126 | Completion time: 0s. 2024-04-29 17:41:17.871 | HD Request # 126 | Intraday data download complete for ESM24-CME. Unique request ID: 126 2024-04-29 17:41:17.871 | Removing historical data download ID 126. 2024-04-29 17:41:17.871 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:17.871 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:17.871 | HD Request # 126 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:17.871 | 2024-04-29 17:41:17.871 | No download requests in the queue to start downloads for. 2024-04-29 17:41:17.924 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:17.924 | Socket (7) | Closed. 2024-04-29 17:41:19.660 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:19.660 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:19.660 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:19.660 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:19.660 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:19.713 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:19.713 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:19.713 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:19.713 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:19.877 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:19.877 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:19.877 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:19.877 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:19.877 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:19.877 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:19.877 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:19.877 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:19.877 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:19.877 | Triggering next historical data download in queue. 2024-04-29 17:41:19.877 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:19.877 | HD Request # 127 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:19.878 | HD Request # 127 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:19.879 | HD Request # 127 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:19.879 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:19.879 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:19.879 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:19.932 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:19.932 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:19.932 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:19.932 | DTC Client socket (6) | Closed. 2024-04-29 17:41:19.932 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:19.933 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:19.933 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:19.933 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:19.933 | HD Request # 127 | Sending historical data logon request message. 2024-04-29 17:41:20.100 | HD Request # 127 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:20.152 | Socket (7) | CloseSocket call. 2024-04-29 17:41:20.152 | HD Request # 127 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:20.152 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:20.152 | Historical data download thread signaled to stop. 2024-04-29 17:41:20.152 | HD Request # 127 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:20.152 | HD Request # 127 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:20.152 | HD Request # 127 | Completion time: 1s. 2024-04-29 17:41:20.152 | HD Request # 127 | Intraday data download complete for ESM24-CME. Unique request ID: 127 2024-04-29 17:41:20.152 | Removing historical data download ID 127. 2024-04-29 17:41:20.152 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:20.152 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:20.152 | HD Request # 127 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:20.152 | 2024-04-29 17:41:20.152 | No download requests in the queue to start downloads for. 2024-04-29 17:41:20.207 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:20.207 | Socket (7) | Closed. 2024-04-29 17:41:21.930 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:21.930 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:21.931 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:21.931 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:21.931 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:21.984 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:21.984 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:21.984 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:21.984 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:22.147 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:22.147 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:22.147 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:22.147 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:22.147 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:22.147 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:22.147 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:22.147 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:22.147 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:22.147 | Triggering next historical data download in queue. 2024-04-29 17:41:22.147 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:22.147 | HD Request # 128 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:22.148 | HD Request # 128 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:22.148 | HD Request # 128 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:22.148 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:22.148 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:22.148 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:22.204 | HD Request # 128 | Sending historical data logon request message. 2024-04-29 17:41:22.204 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:22.204 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:22.205 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:22.205 | DTC Client socket (6) | Closed. 2024-04-29 17:41:22.205 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:22.205 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:22.205 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:22.205 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:22.368 | HD Request # 128 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:22.422 | Socket (7) | CloseSocket call. 2024-04-29 17:41:22.422 | HD Request # 128 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:22.422 | Historical data download thread signaled to stop. 2024-04-29 17:41:22.422 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:22.422 | HD Request # 128 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:22.422 | HD Request # 128 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:22.422 | HD Request # 128 | Completion time: 0s. 2024-04-29 17:41:22.422 | HD Request # 128 | Intraday data download complete for ESM24-CME. Unique request ID: 128 2024-04-29 17:41:22.422 | Removing historical data download ID 128. 2024-04-29 17:41:22.422 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:22.422 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:22.422 | HD Request # 128 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:22.422 | 2024-04-29 17:41:22.422 | No download requests in the queue to start downloads for. 2024-04-29 17:41:22.477 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:22.477 | Socket (7) | Closed. 2024-04-29 17:41:24.185 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:24.185 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:24.190 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:24.190 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:24.190 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:24.244 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:24.244 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:24.244 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:24.244 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:24.409 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:24.409 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:24.409 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:24.409 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:24.409 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:24.409 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:24.409 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:24.409 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:24.409 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:24.409 | Triggering next historical data download in queue. 2024-04-29 17:41:24.409 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:24.409 | HD Request # 129 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:24.409 | HD Request # 129 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:24.409 | HD Request # 129 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:24.410 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:24.410 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:24.410 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:24.463 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:24.463 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:24.463 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:24.463 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:24.463 | DTC Client socket (6) | Closed. 2024-04-29 17:41:24.463 | HD Request # 129 | Sending historical data logon request message. 2024-04-29 17:41:24.463 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:24.463 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:24.463 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:24.629 | HD Request # 129 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:24.682 | Socket (7) | CloseSocket call. 2024-04-29 17:41:24.682 | HD Request # 129 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:24.682 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:24.682 | Historical data download thread signaled to stop. 2024-04-29 17:41:24.682 | HD Request # 129 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:24.682 | HD Request # 129 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:24.682 | HD Request # 129 | Completion time: 0s. 2024-04-29 17:41:24.682 | HD Request # 129 | Intraday data download complete for ESM24-CME. Unique request ID: 129 2024-04-29 17:41:24.682 | Removing historical data download ID 129. 2024-04-29 17:41:24.682 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:24.682 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:24.682 | HD Request # 129 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:24.682 | 2024-04-29 17:41:24.682 | No download requests in the queue to start downloads for. 2024-04-29 17:41:24.736 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:24.737 | Socket (7) | Closed. 2024-04-29 17:41:26.452 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:26.452 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:26.453 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:26.453 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:26.453 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:26.507 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:26.507 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:26.507 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:26.507 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:26.672 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:26.672 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:26.672 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:26.672 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:26.672 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:26.672 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:26.672 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:26.672 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:26.672 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:26.672 | Triggering next historical data download in queue. 2024-04-29 17:41:26.672 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:26.672 | HD Request # 130 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:26.673 | HD Request # 130 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:26.673 | HD Request # 130 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:26.673 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:26.673 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:26.673 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:26.726 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:26.726 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:26.726 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:26.727 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:26.727 | DTC Client socket (6) | Closed. 2024-04-29 17:41:26.728 | HD Request # 130 | Sending historical data logon request message. 2024-04-29 17:41:26.728 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:26.728 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:26.728 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:26.898 | HD Request # 130 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:26.954 | Socket (7) | CloseSocket call. 2024-04-29 17:41:26.954 | HD Request # 130 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:26.954 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:26.954 | Historical data download thread signaled to stop. 2024-04-29 17:41:26.954 | HD Request # 130 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:26.955 | HD Request # 130 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:26.955 | HD Request # 130 | Completion time: 0s. 2024-04-29 17:41:26.955 | HD Request # 130 | Intraday data download complete for ESM24-CME. Unique request ID: 130 2024-04-29 17:41:26.955 | Removing historical data download ID 130. 2024-04-29 17:41:26.955 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:26.955 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:26.955 | HD Request # 130 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:26.955 | 2024-04-29 17:41:26.955 | No download requests in the queue to start downloads for. 2024-04-29 17:41:27.009 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:27.009 | Socket (7) | Closed. 2024-04-29 17:41:28.724 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:28.724 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:28.724 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:28.725 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:28.725 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:28.778 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:28.778 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:28.778 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:28.778 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:28.946 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:28.946 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:28.946 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:28.946 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:28.946 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:28.946 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:28.946 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:28.946 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:28.946 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:28.946 | Triggering next historical data download in queue. 2024-04-29 17:41:28.946 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:28.946 | HD Request # 131 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:28.947 | HD Request # 131 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:28.947 | HD Request # 131 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:28.947 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:28.947 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:28.947 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:29.000 | HD Request # 131 | Sending historical data logon request message. 2024-04-29 17:41:29.000 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:29.000 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:29.000 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:29.000 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:29.000 | DTC Client socket (6) | Closed. 2024-04-29 17:41:29.001 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:29.001 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:29.001 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:29.167 | HD Request # 131 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:29.221 | Socket (7) | CloseSocket call. 2024-04-29 17:41:29.221 | HD Request # 131 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:29.221 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:29.221 | Historical data download thread signaled to stop. 2024-04-29 17:41:29.221 | HD Request # 131 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:29.221 | HD Request # 131 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:29.221 | HD Request # 131 | Completion time: 1s. 2024-04-29 17:41:29.221 | HD Request # 131 | Intraday data download complete for ESM24-CME. Unique request ID: 131 2024-04-29 17:41:29.221 | Removing historical data download ID 131. 2024-04-29 17:41:29.221 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:29.221 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:29.221 | HD Request # 131 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:29.221 | 2024-04-29 17:41:29.221 | No download requests in the queue to start downloads for. 2024-04-29 17:41:29.275 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:29.275 | Socket (7) | Closed. 2024-04-29 17:41:30.980 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:30.981 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:30.981 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:30.982 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:30.982 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:31.034 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:31.034 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:31.034 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:31.034 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:31.197 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:31.197 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:31.197 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:31.197 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:31.197 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:31.197 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:31.197 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:31.197 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:31.197 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:31.197 | Triggering next historical data download in queue. 2024-04-29 17:41:31.197 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:31.197 | HD Request # 132 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:31.197 | HD Request # 132 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:31.197 | HD Request # 132 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:31.197 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:31.197 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:31.197 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:31.250 | HD Request # 132 | Sending historical data logon request message. 2024-04-29 17:41:31.251 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:31.251 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:31.251 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:31.251 | DTC Client socket (6) | Closed. 2024-04-29 17:41:31.251 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:31.251 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:31.251 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:31.251 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:31.416 | HD Request # 132 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:31.469 | Socket (7) | CloseSocket call. 2024-04-29 17:41:31.469 | HD Request # 132 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:31.469 | Historical data download thread signaled to stop. 2024-04-29 17:41:31.469 | HD Request # 132 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:31.469 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:31.469 | HD Request # 132 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:31.469 | HD Request # 132 | Completion time: 0s. 2024-04-29 17:41:31.469 | HD Request # 132 | Intraday data download complete for ESM24-CME. Unique request ID: 132 2024-04-29 17:41:31.469 | Removing historical data download ID 132. 2024-04-29 17:41:31.469 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:31.469 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:31.469 | HD Request # 132 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:31.469 | 2024-04-29 17:41:31.469 | No download requests in the queue to start downloads for. 2024-04-29 17:41:31.523 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:31.523 | Socket (7) | Closed. 2024-04-29 17:41:33.253 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:33.253 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:33.254 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:33.254 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:33.254 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:33.307 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:33.307 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:33.307 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:33.307 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:33.475 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:33.475 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:33.475 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:33.475 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:33.475 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:33.475 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:33.475 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:33.475 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:33.475 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:33.475 | Triggering next historical data download in queue. 2024-04-29 17:41:33.475 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:33.475 | HD Request # 133 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:33.475 | HD Request # 133 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:33.475 | HD Request # 133 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:33.475 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:33.476 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:33.476 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:33.529 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:33.530 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:33.530 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:33.530 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:33.530 | DTC Client socket (6) | Closed. 2024-04-29 17:41:33.530 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:33.530 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:33.530 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:33.533 | HD Request # 133 | Sending historical data logon request message. 2024-04-29 17:41:33.707 | HD Request # 133 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:33.761 | Socket (7) | CloseSocket call. 2024-04-29 17:41:33.761 | HD Request # 133 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:33.761 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:33.761 | Historical data download thread signaled to stop. 2024-04-29 17:41:33.761 | HD Request # 133 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:33.761 | HD Request # 133 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:33.761 | HD Request # 133 | Completion time: 0s. 2024-04-29 17:41:33.761 | HD Request # 133 | Intraday data download complete for ESM24-CME. Unique request ID: 133 2024-04-29 17:41:33.761 | Removing historical data download ID 133. 2024-04-29 17:41:33.761 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:33.761 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:33.761 | HD Request # 133 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:33.761 | 2024-04-29 17:41:33.761 | No download requests in the queue to start downloads for. 2024-04-29 17:41:33.817 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:33.817 | Socket (7) | Closed. 2024-04-29 17:41:35.509 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:35.509 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:35.509 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:35.509 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:35.510 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:35.563 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:35.563 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:35.563 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:35.563 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:35.731 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:35.731 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:35.731 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:35.731 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:35.731 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:35.731 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:35.731 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:35.731 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:35.731 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:35.731 | Triggering next historical data download in queue. 2024-04-29 17:41:35.731 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:35.731 | HD Request # 134 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:35.731 | HD Request # 134 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:35.731 | HD Request # 134 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:35.731 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:35.731 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:35.731 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:35.784 | HD Request # 134 | Sending historical data logon request message. 2024-04-29 17:41:35.785 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:35.785 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:35.785 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:35.785 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:35.785 | DTC Client socket (6) | Closed. 2024-04-29 17:41:35.785 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:35.785 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:35.785 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:35.948 | HD Request # 134 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:36.002 | Socket (7) | CloseSocket call. 2024-04-29 17:41:36.002 | HD Request # 134 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:36.002 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:36.002 | Historical data download thread signaled to stop. 2024-04-29 17:41:36.002 | HD Request # 134 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:36.002 | HD Request # 134 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:36.002 | HD Request # 134 | Completion time: 1s. 2024-04-29 17:41:36.002 | HD Request # 134 | Intraday data download complete for ESM24-CME. Unique request ID: 134 2024-04-29 17:41:36.003 | Removing historical data download ID 134. 2024-04-29 17:41:36.003 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:36.003 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:36.003 | HD Request # 134 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:36.003 | 2024-04-29 17:41:36.003 | No download requests in the queue to start downloads for. 2024-04-29 17:41:36.057 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:36.057 | Socket (7) | Closed. 2024-04-29 17:41:37.774 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:37.774 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:37.775 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:37.775 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:37.775 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:37.830 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:37.830 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:37.830 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:37.830 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:37.994 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:37.994 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:37.994 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:37.994 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:37.994 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:37.994 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:37.994 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:37.994 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:37.994 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:37.994 | Triggering next historical data download in queue. 2024-04-29 17:41:37.994 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:37.994 | HD Request # 135 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:37.994 | HD Request # 135 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:37.994 | HD Request # 135 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:37.994 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:37.994 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:37.994 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:38.048 | HD Request # 135 | Sending historical data logon request message. 2024-04-29 17:41:38.050 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:38.050 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:38.050 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:38.050 | DTC Client socket (6) | Closed. 2024-04-29 17:41:38.051 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:38.051 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:38.051 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:38.051 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:38.216 | HD Request # 135 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:38.269 | Socket (7) | CloseSocket call. 2024-04-29 17:41:38.269 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:38.269 | HD Request # 135 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:38.269 | Historical data download thread signaled to stop. 2024-04-29 17:41:38.269 | HD Request # 135 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:38.269 | HD Request # 135 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:38.269 | HD Request # 135 | Completion time: 1s. 2024-04-29 17:41:38.269 | HD Request # 135 | Intraday data download complete for ESM24-CME. Unique request ID: 135 2024-04-29 17:41:38.269 | Removing historical data download ID 135. 2024-04-29 17:41:38.269 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:38.269 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:38.269 | HD Request # 135 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:38.269 | 2024-04-29 17:41:38.269 | No download requests in the queue to start downloads for. 2024-04-29 17:41:38.323 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:38.323 | Socket (7) | Closed. 2024-04-29 17:41:40.041 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:40.041 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:40.043 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:40.043 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:40.043 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:40.097 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:40.097 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:40.097 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:40.097 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:40.261 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:40.261 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:40.261 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:40.261 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:40.261 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:40.261 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:40.261 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:40.261 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:40.261 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:40.261 | Triggering next historical data download in queue. 2024-04-29 17:41:40.261 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:40.261 | HD Request # 136 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:40.262 | HD Request # 136 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:40.262 | HD Request # 136 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:40.262 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:40.262 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:40.262 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:40.319 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:40.319 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:40.319 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:40.319 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:40.319 | DTC Client socket (6) | Closed. 2024-04-29 17:41:40.320 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:40.320 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:40.320 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:40.321 | HD Request # 136 | Sending historical data logon request message. 2024-04-29 17:41:40.501 | HD Request # 136 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:40.553 | Socket (7) | CloseSocket call. 2024-04-29 17:41:40.553 | HD Request # 136 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:40.553 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:40.553 | Historical data download thread signaled to stop. 2024-04-29 17:41:40.553 | HD Request # 136 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:40.554 | HD Request # 136 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:40.554 | HD Request # 136 | Completion time: 0s. 2024-04-29 17:41:40.554 | HD Request # 136 | Intraday data download complete for ESM24-CME. Unique request ID: 136 2024-04-29 17:41:40.554 | Removing historical data download ID 136. 2024-04-29 17:41:40.554 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:40.554 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:40.554 | HD Request # 136 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:40.554 | 2024-04-29 17:41:40.554 | No download requests in the queue to start downloads for. 2024-04-29 17:41:40.612 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:40.612 | Socket (7) | Closed. 2024-04-29 17:41:42.316 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:42.316 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:42.317 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:42.317 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:42.317 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:42.372 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:42.372 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:42.372 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:42.372 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:42.815 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:42.815 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:42.815 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:42.815 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:42.815 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:42.815 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:42.815 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:42.815 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:42.815 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:42.815 | Triggering next historical data download in queue. 2024-04-29 17:41:42.815 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:42.815 | HD Request # 137 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:42.815 | HD Request # 137 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:42.815 | HD Request # 137 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:42.815 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:42.815 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:42.815 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:42.870 | HD Request # 137 | Sending historical data logon request message. 2024-04-29 17:41:42.870 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:42.870 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:42.871 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:42.871 | DTC Client socket (6) | Closed. 2024-04-29 17:41:42.871 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:42.871 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:42.871 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:42.871 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:43.045 | HD Request # 137 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:43.104 | Socket (7) | CloseSocket call. 2024-04-29 17:41:43.104 | HD Request # 137 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:43.104 | Historical data download thread signaled to stop. 2024-04-29 17:41:43.104 | HD Request # 137 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:43.104 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:43.105 | HD Request # 137 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:43.105 | HD Request # 137 | Completion time: 1s. 2024-04-29 17:41:43.105 | HD Request # 137 | Intraday data download complete for ESM24-CME. Unique request ID: 137 2024-04-29 17:41:43.105 | Removing historical data download ID 137. 2024-04-29 17:41:43.105 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:43.105 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:43.105 | HD Request # 137 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:43.105 | 2024-04-29 17:41:43.105 | No download requests in the queue to start downloads for. 2024-04-29 17:41:43.162 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:43.162 | Socket (7) | Closed. 2024-04-29 17:41:44.853 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:44.853 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:44.853 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:44.853 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:44.853 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:44.914 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:44.914 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:44.914 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:44.914 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:45.111 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:45.111 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:45.111 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:45.111 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:45.111 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:45.111 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:45.111 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:45.111 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:45.111 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:45.111 | Triggering next historical data download in queue. 2024-04-29 17:41:45.111 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:45.111 | HD Request # 138 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:45.111 | HD Request # 138 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:45.111 | HD Request # 138 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:45.111 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:45.111 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:45.111 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:45.169 | HD Request # 138 | Sending historical data logon request message. 2024-04-29 17:41:45.169 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:45.169 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:45.169 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:45.169 | DTC Client socket (6) | Closed. 2024-04-29 17:41:45.169 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:45.170 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:45.170 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:45.170 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:45.348 | HD Request # 138 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:45.405 | Socket (7) | CloseSocket call. 2024-04-29 17:41:45.405 | HD Request # 138 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:45.405 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:45.405 | Historical data download thread signaled to stop. 2024-04-29 17:41:45.405 | HD Request # 138 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:45.405 | HD Request # 138 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:45.405 | HD Request # 138 | Completion time: 0s. 2024-04-29 17:41:45.405 | HD Request # 138 | Intraday data download complete for ESM24-CME. Unique request ID: 138 2024-04-29 17:41:45.405 | Removing historical data download ID 138. 2024-04-29 17:41:45.405 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:45.405 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:45.405 | HD Request # 138 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:45.405 | 2024-04-29 17:41:45.405 | No download requests in the queue to start downloads for. 2024-04-29 17:41:45.477 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:45.477 | Socket (7) | Closed. 2024-04-29 17:41:47.157 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:47.157 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:47.158 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:47.158 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:47.158 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:47.210 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:47.210 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:47.210 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:47.210 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:47.370 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:47.370 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:47.370 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:47.370 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:47.370 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:47.370 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:47.370 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:47.370 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:47.370 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:47.370 | Triggering next historical data download in queue. 2024-04-29 17:41:47.370 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:47.371 | HD Request # 139 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:47.371 | HD Request # 139 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:47.371 | HD Request # 139 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:47.371 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:47.371 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:47.371 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:47.424 | HD Request # 139 | Sending historical data logon request message. 2024-04-29 17:41:47.424 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:47.424 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:47.425 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:47.425 | DTC Client socket (6) | Closed. 2024-04-29 17:41:47.425 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:47.425 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:47.425 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:47.425 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:47.601 | HD Request # 139 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:47.656 | Socket (7) | CloseSocket call. 2024-04-29 17:41:47.656 | HD Request # 139 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:47.656 | Historical data download thread signaled to stop. 2024-04-29 17:41:47.656 | HD Request # 139 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:47.656 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:47.656 | HD Request # 139 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:47.656 | HD Request # 139 | Completion time: 0s. 2024-04-29 17:41:47.656 | HD Request # 139 | Intraday data download complete for ESM24-CME. Unique request ID: 139 2024-04-29 17:41:47.656 | Removing historical data download ID 139. 2024-04-29 17:41:47.656 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:47.656 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:47.656 | HD Request # 139 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:47.656 | 2024-04-29 17:41:47.656 | No download requests in the queue to start downloads for. 2024-04-29 17:41:47.713 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:47.713 | Socket (7) | Closed. 2024-04-29 17:41:49.427 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:49.427 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:49.428 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:49.428 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:49.428 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:49.483 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:49.483 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:49.483 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:49.483 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:49.648 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:49.648 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:49.648 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:49.648 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:49.648 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:49.648 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:49.648 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:49.648 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:49.648 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:49.648 | Triggering next historical data download in queue. 2024-04-29 17:41:49.648 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:49.648 | HD Request # 140 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:49.648 | HD Request # 140 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:49.648 | HD Request # 140 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:49.649 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:49.649 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:49.649 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:49.703 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:49.704 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:49.704 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:49.704 | DTC Client socket (6) | Closed. 2024-04-29 17:41:49.704 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:49.704 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:49.704 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:49.704 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:49.709 | HD Request # 140 | Sending historical data logon request message. 2024-04-29 17:41:49.890 | HD Request # 140 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:49.947 | Socket (7) | CloseSocket call. 2024-04-29 17:41:49.947 | HD Request # 140 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:49.947 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:49.947 | Historical data download thread signaled to stop. 2024-04-29 17:41:49.947 | HD Request # 140 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:49.947 | HD Request # 140 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:49.947 | HD Request # 140 | Completion time: 0s. 2024-04-29 17:41:49.947 | HD Request # 140 | Intraday data download complete for ESM24-CME. Unique request ID: 140 2024-04-29 17:41:49.947 | Removing historical data download ID 140. 2024-04-29 17:41:49.947 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:49.947 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:49.947 | HD Request # 140 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:49.947 | 2024-04-29 17:41:49.947 | No download requests in the queue to start downloads for. 2024-04-29 17:41:50.006 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:50.006 | Socket (7) | Closed. 2024-04-29 17:41:51.267 | ESM4.CME 1 Min #1 | Reloading chart. 2024-04-29 17:41:51.710 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:51.710 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:51.711 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:51.711 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:51.711 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:51.763 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:51.763 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:51.763 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:51.763 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:51.823 | ESM4.CME[M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 2024-03-31 18:00:00 2024-04-29 17:41:51.823 | Chart: ESM4.CME[M] 1 Min #1 | Study: LTC: Trade Receiver Study V2 | Loading Rx study -- v2.1.52 -- * 2024-04-29 17:41:51.826 | ESM4.CME[M] 1 Min #1 | Chart data loading complete. 2024-04-29 17:41:51.970 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:51.970 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:51.970 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:51.970 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:51.970 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:51.970 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:51.970 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:51.970 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:51.970 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:51.970 | Triggering next historical data download in queue. 2024-04-29 17:41:51.970 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:51.970 | HD Request # 141 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:51.970 | HD Request # 141 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:51.970 | HD Request # 141 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:51.970 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:51.970 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:51.970 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:52.024 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:52.024 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:52.024 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:52.024 | HD Request # 141 | Sending historical data logon request message. 2024-04-29 17:41:52.024 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:52.024 | DTC Client socket (6) | Closed. 2024-04-29 17:41:52.025 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:52.025 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:52.025 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:52.191 | HD Request # 141 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:52.244 | Socket (7) | CloseSocket call. 2024-04-29 17:41:52.244 | HD Request # 141 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:52.244 | Historical data download thread signaled to stop. 2024-04-29 17:41:52.244 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:52.244 | HD Request # 141 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:52.244 | HD Request # 141 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:52.244 | HD Request # 141 | Completion time: 1s. 2024-04-29 17:41:52.244 | HD Request # 141 | Intraday data download complete for ESM24-CME. Unique request ID: 141 2024-04-29 17:41:52.244 | Removing historical data download ID 141. 2024-04-29 17:41:52.244 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:52.244 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:52.244 | HD Request # 141 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:52.244 | 2024-04-29 17:41:52.244 | No download requests in the queue to start downloads for. 2024-04-29 17:41:52.298 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:52.298 | Socket (7) | Closed. 2024-04-29 17:41:52.476 | Chart: ESM4.CME[M] 1 Min #1 | Study: LTC: Trade Receiver Study V2 | This study will not proceed. Only one RX study for a combination of tag, trading account and symbol can be used. Chartbook Chartbook2.Cht, Chart 1 and study id 1 on this SC instance is already loaded with a RX study using the same Tag: ESTopStep. Decide which study you want to use. When you are on SIM mode, make sure to check you are running the RX studies on seperate accounts. * 2024-04-29 17:41:54.012 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:54.012 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:54.013 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:54.013 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:54.014 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:54.068 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:54.068 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:54.068 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:54.068 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:54.235 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:54.235 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:54.235 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:54.235 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:54.235 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:54.235 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:54.235 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:54.235 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:54.235 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:54.235 | Triggering next historical data download in queue. 2024-04-29 17:41:54.235 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:54.235 | HD Request # 142 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:54.235 | HD Request # 142 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:54.235 | HD Request # 142 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:54.235 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:54.235 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:54.235 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:54.288 | HD Request # 142 | Sending historical data logon request message. 2024-04-29 17:41:54.289 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:54.289 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:54.289 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:54.289 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:54.289 | DTC Client socket (6) | Closed. 2024-04-29 17:41:54.289 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:54.289 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:54.289 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:54.456 | HD Request # 142 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:54.510 | Socket (7) | CloseSocket call. 2024-04-29 17:41:54.510 | HD Request # 142 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:54.510 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:54.510 | Historical data download thread signaled to stop. 2024-04-29 17:41:54.510 | HD Request # 142 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:54.510 | HD Request # 142 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:54.510 | HD Request # 142 | Completion time: 0s. 2024-04-29 17:41:54.510 | HD Request # 142 | Intraday data download complete for ESM24-CME. Unique request ID: 142 2024-04-29 17:41:54.510 | Removing historical data download ID 142. 2024-04-29 17:41:54.510 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:54.510 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:54.510 | HD Request # 142 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:54.510 | 2024-04-29 17:41:54.510 | No download requests in the queue to start downloads for. 2024-04-29 17:41:54.564 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:54.564 | Socket (7) | Closed. 2024-04-29 17:41:56.305 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:56.305 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:56.305 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:56.305 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:56.305 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:56.359 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:56.359 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:56.359 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:56.359 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:56.524 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:56.524 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:56.524 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:56.524 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:56.524 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:56.524 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:56.524 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:56.524 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:56.524 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:56.524 | Triggering next historical data download in queue. 2024-04-29 17:41:56.524 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:56.524 | HD Request # 143 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:56.524 | HD Request # 143 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:56.524 | HD Request # 143 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:56.525 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:56.525 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:56.525 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:56.577 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:56.578 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:56.578 | HD Request # 143 | Sending historical data logon request message. 2024-04-29 17:41:56.578 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:56.578 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:56.578 | DTC Client socket (6) | Closed. 2024-04-29 17:41:56.578 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:56.578 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:56.578 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:56.745 | HD Request # 143 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:56.799 | Socket (7) | CloseSocket call. 2024-04-29 17:41:56.799 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:56.799 | HD Request # 143 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:56.799 | Historical data download thread signaled to stop. 2024-04-29 17:41:56.799 | HD Request # 143 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:56.800 | HD Request # 143 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:56.800 | HD Request # 143 | Completion time: 0s. 2024-04-29 17:41:56.800 | HD Request # 143 | Intraday data download complete for ESM24-CME. Unique request ID: 143 2024-04-29 17:41:56.800 | Removing historical data download ID 143. 2024-04-29 17:41:56.800 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:56.800 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:56.800 | HD Request # 143 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:56.800 | 2024-04-29 17:41:56.800 | No download requests in the queue to start downloads for. 2024-04-29 17:41:56.852 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:56.852 | Socket (7) | Closed. 2024-04-29 17:41:58.563 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:41:58.563 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:41:58.563 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:58.563 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:41:58.563 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:58.620 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:41:58.620 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:41:58.620 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:41:58.620 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:41:58.783 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:41:58.783 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:41:58.783 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:41:58.783 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:41:58.783 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:41:58.783 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:41:58.783 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:41:58.783 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:41:58.783 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:41:58.783 | Triggering next historical data download in queue. 2024-04-29 17:41:58.783 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:41:58.783 | HD Request # 144 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:41:58.783 | HD Request # 144 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:58.783 | HD Request # 144 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:41:58.783 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:41:58.783 | Socket (7) | New receive buffer size: 0 2024-04-29 17:41:58.783 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:41:58.838 | HD Request # 144 | Sending historical data logon request message. 2024-04-29 17:41:58.839 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:41:58.839 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:41:58.839 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:41:58.839 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:41:58.839 | DTC Client socket (6) | Closed. 2024-04-29 17:41:58.840 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:41:58.840 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:41:58.840 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:41:59.005 | HD Request # 144 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:41:59.058 | Socket (7) | CloseSocket call. 2024-04-29 17:41:59.058 | HD Request # 144 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:41:59.058 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:41:59.058 | Historical data download thread signaled to stop. 2024-04-29 17:41:59.058 | HD Request # 144 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:41:59.059 | HD Request # 144 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:41:59.059 | HD Request # 144 | Completion time: 1s. 2024-04-29 17:41:59.059 | HD Request # 144 | Intraday data download complete for ESM24-CME. Unique request ID: 144 2024-04-29 17:41:59.059 | Removing historical data download ID 144. 2024-04-29 17:41:59.059 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:41:59.059 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:41:59.059 | HD Request # 144 | Enabling Intraday chart updating for symbol. 2024-04-29 17:41:59.059 | 2024-04-29 17:41:59.059 | No download requests in the queue to start downloads for. 2024-04-29 17:41:59.113 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:41:59.113 | Socket (7) | Closed. 2024-04-29 17:42:00.823 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:00.823 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:00.823 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:00.824 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:00.824 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:00.876 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:00.876 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:00.876 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:00.876 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:01.039 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:01.039 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:01.039 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:01.039 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:01.039 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:01.039 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:01.039 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:01.039 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:01.039 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:01.039 | Triggering next historical data download in queue. 2024-04-29 17:42:01.039 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:01.039 | HD Request # 145 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:01.039 | HD Request # 145 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:01.039 | HD Request # 145 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:01.039 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:01.039 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:01.039 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:01.092 | HD Request # 145 | Sending historical data logon request message. 2024-04-29 17:42:01.107 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:01.107 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:01.107 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:01.107 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:01.107 | DTC Client socket (6) | Closed. 2024-04-29 17:42:01.108 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:01.108 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:01.108 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:01.268 | HD Request # 145 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:01.326 | Socket (7) | CloseSocket call. 2024-04-29 17:42:01.326 | HD Request # 145 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:01.326 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:01.326 | Historical data download thread signaled to stop. 2024-04-29 17:42:01.326 | HD Request # 145 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:01.327 | HD Request # 145 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:01.327 | HD Request # 145 | Completion time: 0s. 2024-04-29 17:42:01.327 | HD Request # 145 | Intraday data download complete for ESM24-CME. Unique request ID: 145 2024-04-29 17:42:01.327 | Removing historical data download ID 145. 2024-04-29 17:42:01.327 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:01.327 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:01.327 | HD Request # 145 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:01.327 | 2024-04-29 17:42:01.327 | No download requests in the queue to start downloads for. 2024-04-29 17:42:01.379 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:01.379 | Socket (7) | Closed. 2024-04-29 17:42:03.118 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:03.118 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:03.118 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:03.118 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:03.118 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:03.173 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:03.173 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:03.173 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:03.173 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:03.340 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:03.340 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:03.340 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:03.340 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:03.340 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:03.340 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:03.340 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:03.340 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:03.340 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:03.340 | Triggering next historical data download in queue. 2024-04-29 17:42:03.340 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:03.340 | HD Request # 146 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:03.340 | HD Request # 146 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:03.340 | HD Request # 146 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:03.340 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:03.341 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:03.341 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:03.393 | HD Request # 146 | Sending historical data logon request message. 2024-04-29 17:42:03.394 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:03.394 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:03.394 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:03.394 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:03.394 | DTC Client socket (6) | Closed. 2024-04-29 17:42:03.395 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:03.395 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:03.395 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:03.562 | HD Request # 146 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:03.615 | Socket (7) | CloseSocket call. 2024-04-29 17:42:03.615 | HD Request # 146 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:03.615 | Historical data download thread signaled to stop. 2024-04-29 17:42:03.615 | HD Request # 146 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:03.615 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:03.615 | HD Request # 146 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:03.615 | HD Request # 146 | Completion time: 0s. 2024-04-29 17:42:03.615 | HD Request # 146 | Intraday data download complete for ESM24-CME. Unique request ID: 146 2024-04-29 17:42:03.615 | Removing historical data download ID 146. 2024-04-29 17:42:03.615 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:03.615 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:03.615 | HD Request # 146 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:03.615 | 2024-04-29 17:42:03.615 | No download requests in the queue to start downloads for. 2024-04-29 17:42:03.669 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:03.669 | Socket (7) | Closed. 2024-04-29 17:42:05.385 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:05.385 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:05.386 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:05.386 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:05.386 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:05.439 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:05.439 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:05.439 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:05.439 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:05.604 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:05.604 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:05.604 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:05.604 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:05.604 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:05.604 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:05.604 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:05.604 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:05.604 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:05.604 | Triggering next historical data download in queue. 2024-04-29 17:42:05.604 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:05.604 | HD Request # 147 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:05.605 | HD Request # 147 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:05.605 | HD Request # 147 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:05.605 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:05.605 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:05.605 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:05.659 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:05.659 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:05.659 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:05.659 | DTC Client socket (6) | Closed. 2024-04-29 17:42:05.659 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:05.661 | HD Request # 147 | Sending historical data logon request message. 2024-04-29 17:42:05.661 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:05.661 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:05.661 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:05.826 | HD Request # 147 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:05.880 | Socket (7) | CloseSocket call. 2024-04-29 17:42:05.880 | HD Request # 147 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:05.880 | Historical data download thread signaled to stop. 2024-04-29 17:42:05.880 | HD Request # 147 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:05.881 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:05.881 | HD Request # 147 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:05.881 | HD Request # 147 | Completion time: 0s. 2024-04-29 17:42:05.881 | HD Request # 147 | Intraday data download complete for ESM24-CME. Unique request ID: 147 2024-04-29 17:42:05.881 | Removing historical data download ID 147. 2024-04-29 17:42:05.881 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:05.881 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:05.881 | HD Request # 147 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:05.881 | 2024-04-29 17:42:05.881 | No download requests in the queue to start downloads for. 2024-04-29 17:42:05.935 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:05.935 | Socket (7) | Closed. 2024-04-29 17:42:07.653 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:07.653 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:07.653 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:07.653 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:07.653 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:07.707 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:07.707 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:07.707 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:07.707 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:07.873 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:07.873 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:07.873 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:07.873 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:07.873 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:07.873 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:07.873 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:07.873 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:07.873 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:07.873 | Triggering next historical data download in queue. 2024-04-29 17:42:07.873 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:07.873 | HD Request # 148 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:07.873 | HD Request # 148 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:07.873 | HD Request # 148 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:07.873 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:07.873 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:07.873 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:07.927 | HD Request # 148 | Sending historical data logon request message. 2024-04-29 17:42:07.927 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:07.927 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:07.927 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:07.927 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:07.927 | DTC Client socket (6) | Closed. 2024-04-29 17:42:07.928 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:07.928 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:07.928 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:08.092 | HD Request # 148 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:08.144 | Socket (7) | CloseSocket call. 2024-04-29 17:42:08.144 | HD Request # 148 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:08.144 | Historical data download thread signaled to stop. 2024-04-29 17:42:08.144 | HD Request # 148 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:08.144 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:08.144 | HD Request # 148 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:08.144 | HD Request # 148 | Completion time: 1s. 2024-04-29 17:42:08.144 | HD Request # 148 | Intraday data download complete for ESM24-CME. Unique request ID: 148 2024-04-29 17:42:08.144 | Removing historical data download ID 148. 2024-04-29 17:42:08.144 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:08.144 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:08.144 | HD Request # 148 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:08.144 | 2024-04-29 17:42:08.144 | No download requests in the queue to start downloads for. 2024-04-29 17:42:08.198 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:08.198 | Socket (7) | Closed. 2024-04-29 17:42:09.916 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:09.916 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:09.918 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:09.918 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:09.918 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:09.972 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:09.972 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:09.972 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:09.972 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:10.138 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:10.138 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:10.138 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:10.138 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:10.138 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:10.138 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:10.138 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:10.138 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:10.138 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:10.138 | Triggering next historical data download in queue. 2024-04-29 17:42:10.138 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:10.138 | HD Request # 149 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:10.138 | HD Request # 149 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:10.138 | HD Request # 149 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:10.138 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:10.138 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:10.138 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:10.192 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:10.192 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:10.192 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:10.192 | DTC Client socket (6) | Closed. 2024-04-29 17:42:10.192 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:10.193 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:10.193 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:10.193 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:10.193 | HD Request # 149 | Sending historical data logon request message. 2024-04-29 17:42:10.353 | HD Request # 149 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:10.407 | Socket (7) | CloseSocket call. 2024-04-29 17:42:10.407 | HD Request # 149 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:10.407 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:10.407 | Historical data download thread signaled to stop. 2024-04-29 17:42:10.407 | HD Request # 149 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:10.407 | HD Request # 149 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:10.407 | HD Request # 149 | Completion time: 0s. 2024-04-29 17:42:10.407 | HD Request # 149 | Intraday data download complete for ESM24-CME. Unique request ID: 149 2024-04-29 17:42:10.407 | Removing historical data download ID 149. 2024-04-29 17:42:10.407 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:10.407 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:10.407 | HD Request # 149 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:10.407 | 2024-04-29 17:42:10.407 | No download requests in the queue to start downloads for. 2024-04-29 17:42:10.461 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:10.461 | Socket (7) | Closed. 2024-04-29 17:42:12.189 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:12.189 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:12.190 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:12.190 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:12.190 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:12.245 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:12.245 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:12.245 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:12.245 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:12.413 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:12.413 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:12.413 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:12.413 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:12.413 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:12.413 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:12.413 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:12.413 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:12.413 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:12.413 | Triggering next historical data download in queue. 2024-04-29 17:42:12.413 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:12.413 | HD Request # 150 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:12.414 | HD Request # 150 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:12.414 | HD Request # 150 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:12.414 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:12.415 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:12.415 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:12.467 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:12.467 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:12.467 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:12.467 | DTC Client socket (6) | Closed. 2024-04-29 17:42:12.467 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:12.468 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:12.468 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:12.468 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:12.468 | HD Request # 150 | Sending historical data logon request message. 2024-04-29 17:42:12.636 | HD Request # 150 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:12.691 | Socket (7) | CloseSocket call. 2024-04-29 17:42:12.691 | HD Request # 150 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:12.691 | Historical data download thread signaled to stop. 2024-04-29 17:42:12.691 | HD Request # 150 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:12.691 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:12.692 | HD Request # 150 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:12.692 | HD Request # 150 | Completion time: 0s. 2024-04-29 17:42:12.692 | HD Request # 150 | Intraday data download complete for ESM24-CME. Unique request ID: 150 2024-04-29 17:42:12.692 | Removing historical data download ID 150. 2024-04-29 17:42:12.692 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:12.692 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:12.692 | HD Request # 150 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:12.692 | 2024-04-29 17:42:12.692 | No download requests in the queue to start downloads for. 2024-04-29 17:42:12.746 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:12.746 | Socket (7) | Closed. 2024-04-29 17:42:13.962 | Chart: ESM4.CME[M] 1 Min #1 | Study: LTC: Trade Receiver Study V2 | Rx Study was successfully removed from this chart. * 2024-04-29 17:42:14.448 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:14.448 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:14.448 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:14.448 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:14.448 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:14.503 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:14.503 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:14.503 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:14.503 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:14.667 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:14.667 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:14.667 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:14.667 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:14.667 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:14.667 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:14.667 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:14.667 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:14.667 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:14.667 | Triggering next historical data download in queue. 2024-04-29 17:42:14.667 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:14.667 | HD Request # 151 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:14.667 | HD Request # 151 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:14.667 | HD Request # 151 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:14.667 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:14.667 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:14.667 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:14.722 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:14.722 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:14.722 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:14.722 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:14.722 | DTC Client socket (6) | Closed. 2024-04-29 17:42:14.723 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:14.723 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:14.723 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:14.723 | HD Request # 151 | Sending historical data logon request message. 2024-04-29 17:42:14.890 | HD Request # 151 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:14.944 | Socket (7) | CloseSocket call. 2024-04-29 17:42:14.944 | HD Request # 151 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:14.944 | Historical data download thread signaled to stop. 2024-04-29 17:42:14.944 | HD Request # 151 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:14.944 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:14.944 | HD Request # 151 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:14.944 | HD Request # 151 | Completion time: 0s. 2024-04-29 17:42:14.944 | HD Request # 151 | Intraday data download complete for ESM24-CME. Unique request ID: 151 2024-04-29 17:42:14.944 | Removing historical data download ID 151. 2024-04-29 17:42:14.944 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:14.944 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:14.944 | HD Request # 151 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:14.944 | 2024-04-29 17:42:14.944 | No download requests in the queue to start downloads for. 2024-04-29 17:42:14.999 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:14.999 | Socket (7) | Closed. 2024-04-29 17:42:16.717 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:16.717 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:16.717 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:16.717 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:16.717 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:16.770 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:16.770 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:16.770 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:16.770 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:16.936 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:16.936 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:16.936 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:16.936 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:16.936 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:16.936 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:16.936 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:16.936 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:16.936 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:16.936 | Triggering next historical data download in queue. 2024-04-29 17:42:16.936 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:16.936 | HD Request # 152 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:16.936 | HD Request # 152 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:16.936 | HD Request # 152 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:16.936 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:16.936 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:16.936 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:16.989 | HD Request # 152 | Sending historical data logon request message. 2024-04-29 17:42:16.989 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:16.990 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:16.990 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:16.990 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:16.990 | DTC Client socket (6) | Closed. 2024-04-29 17:42:16.991 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:16.991 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:16.991 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:17.150 | HD Request # 152 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:17.203 | Socket (7) | CloseSocket call. 2024-04-29 17:42:17.203 | HD Request # 152 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:17.203 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:17.203 | Historical data download thread signaled to stop. 2024-04-29 17:42:17.203 | HD Request # 152 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:17.203 | HD Request # 152 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:17.203 | HD Request # 152 | Completion time: 1s. 2024-04-29 17:42:17.203 | HD Request # 152 | Intraday data download complete for ESM24-CME. Unique request ID: 152 2024-04-29 17:42:17.203 | Removing historical data download ID 152. 2024-04-29 17:42:17.203 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:17.203 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:17.203 | HD Request # 152 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:17.203 | 2024-04-29 17:42:17.203 | No download requests in the queue to start downloads for. 2024-04-29 17:42:17.258 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:17.258 | Socket (7) | Closed. 2024-04-29 17:42:18.988 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:18.988 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:18.988 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:18.989 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:18.989 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:19.042 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:19.042 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:19.042 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:19.042 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:19.206 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:19.206 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:19.206 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:19.206 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:19.206 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:19.206 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:19.206 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:19.206 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:19.206 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:19.206 | Triggering next historical data download in queue. 2024-04-29 17:42:19.206 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:19.206 | HD Request # 153 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:19.206 | HD Request # 153 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:19.206 | HD Request # 153 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:19.206 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:19.207 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:19.207 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:19.260 | HD Request # 153 | Sending historical data logon request message. 2024-04-29 17:42:19.260 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:19.260 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:19.260 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:19.260 | DTC Client socket (6) | Closed. 2024-04-29 17:42:19.260 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:19.260 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:19.260 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:19.260 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:19.424 | HD Request # 153 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:19.478 | Socket (7) | CloseSocket call. 2024-04-29 17:42:19.478 | HD Request # 153 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:19.478 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:19.478 | Historical data download thread signaled to stop. 2024-04-29 17:42:19.478 | HD Request # 153 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:19.479 | HD Request # 153 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:19.479 | HD Request # 153 | Completion time: 0s. 2024-04-29 17:42:19.479 | HD Request # 153 | Intraday data download complete for ESM24-CME. Unique request ID: 153 2024-04-29 17:42:19.479 | Removing historical data download ID 153. 2024-04-29 17:42:19.479 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:19.479 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:19.479 | HD Request # 153 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:19.479 | 2024-04-29 17:42:19.479 | No download requests in the queue to start downloads for. 2024-04-29 17:42:19.532 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:19.532 | Socket (7) | Closed. 2024-04-29 17:42:21.221 | ESM4.CME 1 Min #1 | Reloading chart. 2024-04-29 17:42:21.246 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:21.246 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:21.246 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:21.246 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:21.246 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:21.300 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:21.300 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:21.300 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:21.300 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:21.461 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:21.461 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:21.461 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:21.461 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:21.461 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:21.461 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:21.461 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:21.461 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:21.461 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:21.461 | Triggering next historical data download in queue. 2024-04-29 17:42:21.461 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:21.461 | HD Request # 154 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:21.461 | HD Request # 154 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:21.461 | HD Request # 154 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:21.461 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:21.461 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:21.461 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:21.514 | HD Request # 154 | Sending historical data logon request message. 2024-04-29 17:42:21.514 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:21.514 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:21.514 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:21.514 | DTC Client socket (6) | Closed. 2024-04-29 17:42:21.514 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:21.515 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:21.515 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:21.515 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:21.677 | HD Request # 154 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:21.730 | Socket (7) | CloseSocket call. 2024-04-29 17:42:21.730 | HD Request # 154 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:21.730 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:21.730 | Historical data download thread signaled to stop. 2024-04-29 17:42:21.730 | HD Request # 154 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:21.730 | HD Request # 154 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:21.730 | HD Request # 154 | Completion time: 0s. 2024-04-29 17:42:21.730 | HD Request # 154 | Intraday data download complete for ESM24-CME. Unique request ID: 154 2024-04-29 17:42:21.730 | Removing historical data download ID 154. 2024-04-29 17:42:21.730 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:21.730 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:21.730 | HD Request # 154 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:21.730 | 2024-04-29 17:42:21.730 | No download requests in the queue to start downloads for. 2024-04-29 17:42:21.779 | ESM4.CME[M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 2024-03-31 18:00:00 2024-04-29 17:42:21.780 | Chart: ESM4.CME[M] 1 Min #1 | Study: LTC: Trade Receiver Study V2 | Loading Rx study -- v2.1.52 -- * 2024-04-29 17:42:21.783 | ESM4.CME[M] 1 Min #1 | Chart data loading complete. 2024-04-29 17:42:21.783 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:21.783 | Socket (7) | Closed. 2024-04-29 17:42:23.521 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:23.521 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:23.521 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:23.521 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:23.521 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:23.575 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:23.575 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:23.575 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:23.575 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:23.739 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:23.739 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:23.739 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:23.739 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:23.739 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:23.739 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:23.739 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:23.739 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:23.739 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:23.739 | Triggering next historical data download in queue. 2024-04-29 17:42:23.739 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:23.739 | HD Request # 155 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:23.739 | HD Request # 155 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:23.739 | HD Request # 155 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:23.739 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:23.739 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:23.739 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:23.792 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:23.792 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:23.792 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:23.792 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:23.792 | DTC Client socket (6) | Closed. 2024-04-29 17:42:23.793 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:23.793 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:23.793 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:23.801 | HD Request # 155 | Sending historical data logon request message. 2024-04-29 17:42:23.983 | HD Request # 155 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:24.048 | Socket (7) | CloseSocket call. 2024-04-29 17:42:24.048 | HD Request # 155 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:24.048 | Historical data download thread signaled to stop. 2024-04-29 17:42:24.048 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:24.048 | HD Request # 155 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:24.048 | HD Request # 155 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:24.048 | HD Request # 155 | Completion time: 1s. 2024-04-29 17:42:24.048 | HD Request # 155 | Intraday data download complete for ESM24-CME. Unique request ID: 155 2024-04-29 17:42:24.048 | Removing historical data download ID 155. 2024-04-29 17:42:24.048 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:24.048 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:24.048 | HD Request # 155 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:24.048 | 2024-04-29 17:42:24.048 | No download requests in the queue to start downloads for. 2024-04-29 17:42:24.113 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:24.113 | Socket (7) | Closed. 2024-04-29 17:42:25.779 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:25.779 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:25.780 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:25.780 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:25.780 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:25.834 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:25.834 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:25.834 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:25.834 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:26.001 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:26.001 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:26.001 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:26.001 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:26.001 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:26.001 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:26.001 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:26.001 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:26.001 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:26.001 | Triggering next historical data download in queue. 2024-04-29 17:42:26.001 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:26.002 | HD Request # 156 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:26.002 | HD Request # 156 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:26.002 | HD Request # 156 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:26.002 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:26.002 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:26.002 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:26.056 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:26.056 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:26.056 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:26.056 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:26.056 | DTC Client socket (6) | Closed. 2024-04-29 17:42:26.056 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:26.056 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:26.056 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:26.056 | HD Request # 156 | Sending historical data logon request message. 2024-04-29 17:42:26.221 | HD Request # 156 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:26.276 | Socket (7) | CloseSocket call. 2024-04-29 17:42:26.276 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:26.276 | HD Request # 156 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:26.276 | Historical data download thread signaled to stop. 2024-04-29 17:42:26.276 | HD Request # 156 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:26.276 | HD Request # 156 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:26.276 | HD Request # 156 | Completion time: 0s. 2024-04-29 17:42:26.276 | HD Request # 156 | Intraday data download complete for ESM24-CME. Unique request ID: 156 2024-04-29 17:42:26.276 | Removing historical data download ID 156. 2024-04-29 17:42:26.276 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:26.276 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:26.276 | HD Request # 156 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:26.276 | 2024-04-29 17:42:26.276 | No download requests in the queue to start downloads for. 2024-04-29 17:42:26.329 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:26.329 | Socket (7) | Closed. 2024-04-29 17:42:28.053 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:28.053 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:28.054 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:28.054 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:28.054 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:28.108 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:28.108 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:28.108 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:28.108 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:28.276 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:28.276 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:28.276 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:28.276 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:28.276 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:28.276 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:28.276 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:28.276 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:28.276 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:28.276 | Triggering next historical data download in queue. 2024-04-29 17:42:28.276 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:28.276 | HD Request # 157 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:28.276 | HD Request # 157 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:28.276 | HD Request # 157 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:28.276 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:28.276 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:28.276 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:28.329 | HD Request # 157 | Sending historical data logon request message. 2024-04-29 17:42:28.330 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:28.330 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:28.330 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:28.330 | DTC Client socket (6) | Closed. 2024-04-29 17:42:28.330 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:28.330 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:28.330 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:28.330 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:28.497 | HD Request # 157 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:28.550 | Socket (7) | CloseSocket call. 2024-04-29 17:42:28.550 | HD Request # 157 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:28.550 | Historical data download thread signaled to stop. 2024-04-29 17:42:28.551 | HD Request # 157 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:28.551 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:28.551 | HD Request # 157 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:28.551 | HD Request # 157 | Completion time: 0s. 2024-04-29 17:42:28.551 | HD Request # 157 | Intraday data download complete for ESM24-CME. Unique request ID: 157 2024-04-29 17:42:28.551 | Removing historical data download ID 157. 2024-04-29 17:42:28.551 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:28.551 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:28.551 | HD Request # 157 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:28.551 | 2024-04-29 17:42:28.551 | No download requests in the queue to start downloads for. 2024-04-29 17:42:28.605 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:28.605 | Socket (7) | Closed. 2024-04-29 17:42:30.312 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:30.312 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:30.312 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:30.312 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:30.312 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:30.365 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:30.365 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:30.365 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:30.365 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:30.531 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:30.531 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:30.531 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:30.531 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:30.531 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:30.531 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:30.531 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:30.531 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:30.531 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:30.531 | Triggering next historical data download in queue. 2024-04-29 17:42:30.531 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:30.531 | HD Request # 158 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:30.531 | HD Request # 158 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:30.531 | HD Request # 158 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:30.531 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:30.531 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:30.531 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:30.584 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:30.584 | HD Request # 158 | Sending historical data logon request message. 2024-04-29 17:42:30.584 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:30.584 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:30.585 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:30.585 | DTC Client socket (6) | Closed. 2024-04-29 17:42:30.585 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:30.585 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:30.585 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:30.751 | HD Request # 158 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:30.807 | Socket (7) | CloseSocket call. 2024-04-29 17:42:30.807 | HD Request # 158 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:30.807 | Historical data download thread signaled to stop. 2024-04-29 17:42:30.807 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:30.807 | HD Request # 158 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:30.807 | HD Request # 158 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:30.807 | HD Request # 158 | Completion time: 0s. 2024-04-29 17:42:30.807 | HD Request # 158 | Intraday data download complete for ESM24-CME. Unique request ID: 158 2024-04-29 17:42:30.807 | Removing historical data download ID 158. 2024-04-29 17:42:30.807 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:30.807 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:30.807 | HD Request # 158 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:30.807 | 2024-04-29 17:42:30.807 | No download requests in the queue to start downloads for. 2024-04-29 17:42:30.862 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:30.862 | Socket (7) | Closed. 2024-04-29 17:42:32.583 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:32.583 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:32.583 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:32.583 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:32.583 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:32.638 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:32.638 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:32.638 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:32.638 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:32.805 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:32.805 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:32.805 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:32.805 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:32.805 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:32.805 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:32.805 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:32.805 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:32.805 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:32.805 | Triggering next historical data download in queue. 2024-04-29 17:42:32.805 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:32.805 | HD Request # 159 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:32.805 | HD Request # 159 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:32.805 | HD Request # 159 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:32.805 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:32.806 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:32.806 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:32.858 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:32.858 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:32.858 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:32.858 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:32.858 | DTC Client socket (6) | Closed. 2024-04-29 17:42:32.859 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:32.859 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:32.859 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:32.860 | HD Request # 159 | Sending historical data logon request message. 2024-04-29 17:42:33.023 | HD Request # 159 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:33.077 | Socket (7) | CloseSocket call. 2024-04-29 17:42:33.077 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:33.077 | HD Request # 159 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:33.077 | Historical data download thread signaled to stop. 2024-04-29 17:42:33.077 | HD Request # 159 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:33.077 | HD Request # 159 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:33.077 | HD Request # 159 | Completion time: 1s. 2024-04-29 17:42:33.077 | HD Request # 159 | Intraday data download complete for ESM24-CME. Unique request ID: 159 2024-04-29 17:42:33.077 | Removing historical data download ID 159. 2024-04-29 17:42:33.077 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:33.077 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:33.077 | HD Request # 159 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:33.077 | 2024-04-29 17:42:33.077 | No download requests in the queue to start downloads for. 2024-04-29 17:42:33.131 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:33.132 | Socket (7) | Closed. 2024-04-29 17:42:34.839 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:34.839 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:34.840 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:34.840 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:34.840 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:34.893 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:34.893 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:34.893 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:34.893 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:35.064 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:35.064 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:35.064 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:35.064 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:35.064 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:35.064 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:35.064 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:35.064 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:35.064 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:35.064 | Triggering next historical data download in queue. 2024-04-29 17:42:35.064 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:35.064 | HD Request # 160 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:35.064 | HD Request # 160 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:35.064 | HD Request # 160 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:35.064 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:35.064 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:35.064 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:35.117 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:35.117 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:35.117 | DTC Client socket (6) | Write in progress. Shutdown being delayed. PendingSize=0 2024-04-29 17:42:35.117 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:35.117 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:35.117 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:35.117 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:35.118 | HD Request # 160 | Sending historical data logon request message. 2024-04-29 17:42:35.171 | DTC Client socket (6) | Write has completed. Shutdown being performed. 2024-04-29 17:42:35.171 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:35.171 | DTC Client socket (6) | Closed. 2024-04-29 17:42:35.281 | HD Request # 160 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:35.334 | Socket (7) | CloseSocket call. 2024-04-29 17:42:35.334 | HD Request # 160 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:35.334 | Historical data download thread signaled to stop. 2024-04-29 17:42:35.334 | HD Request # 160 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:35.334 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:35.334 | HD Request # 160 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:35.334 | HD Request # 160 | Completion time: 0s. 2024-04-29 17:42:35.334 | HD Request # 160 | Intraday data download complete for ESM24-CME. Unique request ID: 160 2024-04-29 17:42:35.334 | Removing historical data download ID 160. 2024-04-29 17:42:35.334 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:35.334 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:35.334 | HD Request # 160 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:35.334 | 2024-04-29 17:42:35.334 | No download requests in the queue to start downloads for. 2024-04-29 17:42:35.390 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:35.390 | Socket (7) | Closed. 2024-04-29 17:42:37.109 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:37.109 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:37.109 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:37.109 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:37.109 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:37.163 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:37.163 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:37.163 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:37.163 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:37.327 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:37.327 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:37.327 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:37.327 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:37.327 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:37.327 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:37.327 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:37.327 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:37.327 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:37.327 | Triggering next historical data download in queue. 2024-04-29 17:42:37.327 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:37.327 | HD Request # 161 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:37.328 | HD Request # 161 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:37.328 | HD Request # 161 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:37.328 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:37.328 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:37.328 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:37.381 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:37.381 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:37.381 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:37.381 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:37.382 | DTC Client socket (6) | Closed. 2024-04-29 17:42:37.382 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:37.382 | HD Request # 161 | Sending historical data logon request message. 2024-04-29 17:42:37.382 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:37.382 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:37.552 | HD Request # 161 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:37.606 | Socket (7) | CloseSocket call. 2024-04-29 17:42:37.606 | HD Request # 161 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:37.606 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:37.606 | Historical data download thread signaled to stop. 2024-04-29 17:42:37.606 | HD Request # 161 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:37.607 | HD Request # 161 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:37.607 | HD Request # 161 | Completion time: 0s. 2024-04-29 17:42:37.607 | HD Request # 161 | Intraday data download complete for ESM24-CME. Unique request ID: 161 2024-04-29 17:42:37.607 | Removing historical data download ID 161. 2024-04-29 17:42:37.607 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:37.607 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:37.607 | HD Request # 161 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:37.607 | 2024-04-29 17:42:37.607 | No download requests in the queue to start downloads for. 2024-04-29 17:42:37.661 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:37.661 | Socket (7) | Closed. 2024-04-29 17:42:39.382 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:39.382 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:39.383 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:39.383 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:39.383 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:39.437 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:39.437 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:39.437 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:39.437 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:39.603 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:39.603 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:39.603 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:39.603 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:39.603 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:39.603 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:39.603 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:39.603 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:39.603 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:39.603 | Triggering next historical data download in queue. 2024-04-29 17:42:39.603 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:39.603 | HD Request # 162 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:39.604 | HD Request # 162 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:39.604 | HD Request # 162 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:39.604 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:39.604 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:39.604 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:39.658 | HD Request # 162 | Sending historical data logon request message. 2024-04-29 17:42:39.659 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:39.659 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:39.659 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:39.659 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:39.659 | DTC Client socket (6) | Closed. 2024-04-29 17:42:39.659 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:39.659 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:39.659 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:39.841 | HD Request # 162 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:39.897 | Socket (7) | CloseSocket call. 2024-04-29 17:42:39.897 | HD Request # 162 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:39.897 | Historical data download thread signaled to stop. 2024-04-29 17:42:39.897 | HD Request # 162 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:39.897 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:39.897 | HD Request # 162 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:39.897 | HD Request # 162 | Completion time: 0s. 2024-04-29 17:42:39.897 | HD Request # 162 | Intraday data download complete for ESM24-CME. Unique request ID: 162 2024-04-29 17:42:39.897 | Removing historical data download ID 162. 2024-04-29 17:42:39.897 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:39.897 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:39.897 | HD Request # 162 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:39.897 | 2024-04-29 17:42:39.897 | No download requests in the queue to start downloads for. 2024-04-29 17:42:39.950 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:39.950 | Socket (7) | Closed. 2024-04-29 17:42:41.635 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:41.635 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:41.639 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:41.639 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:41.639 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:41.693 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:41.693 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:41.693 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:41.693 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:41.855 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:41.855 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:41.855 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:41.855 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:41.855 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:41.855 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:41.855 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:41.855 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:41.855 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:41.855 | Triggering next historical data download in queue. 2024-04-29 17:42:41.855 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:41.855 | HD Request # 163 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:41.855 | HD Request # 163 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:41.855 | HD Request # 163 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:41.855 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:41.856 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:41.856 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:41.908 | HD Request # 163 | Sending historical data logon request message. 2024-04-29 17:42:41.909 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:41.909 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:41.909 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:41.909 | DTC Client socket (6) | Closed. 2024-04-29 17:42:41.909 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:41.909 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:41.909 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:41.909 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:42.072 | HD Request # 163 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:42.125 | Socket (7) | CloseSocket call. 2024-04-29 17:42:42.125 | HD Request # 163 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:42.125 | Historical data download thread signaled to stop. 2024-04-29 17:42:42.125 | HD Request # 163 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:42.125 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:42.125 | HD Request # 163 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:42.125 | HD Request # 163 | Completion time: 1s. 2024-04-29 17:42:42.125 | HD Request # 163 | Intraday data download complete for ESM24-CME. Unique request ID: 163 2024-04-29 17:42:42.125 | Removing historical data download ID 163. 2024-04-29 17:42:42.125 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:42.125 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:42.125 | HD Request # 163 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:42.125 | 2024-04-29 17:42:42.125 | No download requests in the queue to start downloads for. 2024-04-29 17:42:42.178 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:42.178 | Socket (7) | Closed. 2024-04-29 17:42:43.905 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:43.905 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:43.905 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:43.905 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:43.905 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:43.959 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:43.959 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:43.959 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:43.959 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:44.124 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:44.124 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:44.124 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:44.124 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:44.124 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:44.124 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:44.124 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:44.124 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:44.124 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:44.124 | Triggering next historical data download in queue. 2024-04-29 17:42:44.124 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:44.124 | HD Request # 164 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:44.124 | HD Request # 164 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:44.125 | HD Request # 164 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:44.125 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:44.125 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:44.125 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:44.177 | HD Request # 164 | Sending historical data logon request message. 2024-04-29 17:42:44.178 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:44.178 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:44.178 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:44.178 | DTC Client socket (6) | Closed. 2024-04-29 17:42:44.178 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:44.178 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:44.178 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:44.178 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:44.345 | HD Request # 164 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:44.399 | Socket (7) | CloseSocket call. 2024-04-29 17:42:44.399 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:44.401 | HD Request # 164 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:44.401 | Historical data download thread signaled to stop. 2024-04-29 17:42:44.401 | HD Request # 164 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:44.401 | HD Request # 164 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:44.401 | HD Request # 164 | Completion time: 0s. 2024-04-29 17:42:44.401 | HD Request # 164 | Intraday data download complete for ESM24-CME. Unique request ID: 164 2024-04-29 17:42:44.401 | Removing historical data download ID 164. 2024-04-29 17:42:44.401 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:44.401 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:44.401 | HD Request # 164 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:44.401 | 2024-04-29 17:42:44.401 | No download requests in the queue to start downloads for. 2024-04-29 17:42:44.453 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:44.454 | Socket (7) | Closed. 2024-04-29 17:42:46.174 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:46.174 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:46.174 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:46.174 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:46.174 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:46.227 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:46.227 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:46.227 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:46.227 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:46.392 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:46.392 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:46.392 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:46.392 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:46.392 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:46.392 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:46.392 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:46.392 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:46.392 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:46.392 | Triggering next historical data download in queue. 2024-04-29 17:42:46.392 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:46.392 | HD Request # 165 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:46.392 | HD Request # 165 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:46.392 | HD Request # 165 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:46.392 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:46.392 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:46.392 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:46.446 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:46.446 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:46.446 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:46.446 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:46.446 | DTC Client socket (6) | Closed. 2024-04-29 17:42:46.446 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:46.446 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:46.446 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:46.446 | HD Request # 165 | Sending historical data logon request message. 2024-04-29 17:42:46.612 | HD Request # 165 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:46.666 | Socket (7) | CloseSocket call. 2024-04-29 17:42:46.666 | HD Request # 165 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:46.666 | Historical data download thread signaled to stop. 2024-04-29 17:42:46.666 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:46.666 | HD Request # 165 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:46.666 | HD Request # 165 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:46.666 | HD Request # 165 | Completion time: 0s. 2024-04-29 17:42:46.666 | HD Request # 165 | Intraday data download complete for ESM24-CME. Unique request ID: 165 2024-04-29 17:42:46.666 | Removing historical data download ID 165. 2024-04-29 17:42:46.666 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:46.666 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:46.666 | HD Request # 165 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:46.666 | 2024-04-29 17:42:46.666 | No download requests in the queue to start downloads for. 2024-04-29 17:42:46.720 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:46.720 | Socket (7) | Closed. 2024-04-29 17:42:48.444 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:48.444 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:48.444 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:48.445 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:48.445 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:48.499 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:48.499 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:48.499 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:48.499 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:48.666 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:48.666 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:48.666 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:48.666 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:48.666 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:48.666 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:48.666 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:48.666 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:48.666 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:48.666 | Triggering next historical data download in queue. 2024-04-29 17:42:48.666 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:48.666 | HD Request # 166 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:48.666 | HD Request # 166 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:48.666 | HD Request # 166 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:48.666 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:48.666 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:48.666 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:48.720 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:48.720 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:48.720 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:48.721 | HD Request # 166 | Sending historical data logon request message. 2024-04-29 17:42:48.721 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:48.721 | DTC Client socket (6) | Closed. 2024-04-29 17:42:48.721 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:48.721 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:48.721 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:48.889 | HD Request # 166 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:48.941 | Socket (7) | CloseSocket call. 2024-04-29 17:42:48.941 | HD Request # 166 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:48.941 | Historical data download thread signaled to stop. 2024-04-29 17:42:48.941 | HD Request # 166 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:48.941 | HD Request # 166 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:48.941 | HD Request # 166 | Completion time: 0s. 2024-04-29 17:42:48.941 | HD Request # 166 | Intraday data download complete for ESM24-CME. Unique request ID: 166 2024-04-29 17:42:48.941 | Removing historical data download ID 166. 2024-04-29 17:42:48.941 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:48.941 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:48.941 | HD Request # 166 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:48.941 | 2024-04-29 17:42:48.941 | No download requests in the queue to start downloads for. 2024-04-29 17:42:48.941 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:48.994 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:48.994 | Socket (7) | Closed. 2024-04-29 17:42:50.698 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:50.698 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:50.698 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:50.698 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:50.698 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:50.754 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:50.754 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:50.754 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:50.754 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:50.923 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:50.923 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:50.923 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:50.923 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:50.923 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:50.923 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:50.923 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:50.923 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:50.923 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:50.923 | Triggering next historical data download in queue. 2024-04-29 17:42:50.923 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:50.923 | HD Request # 167 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:50.924 | HD Request # 167 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:50.924 | HD Request # 167 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:50.924 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:50.924 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:50.924 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:50.978 | HD Request # 167 | Sending historical data logon request message. 2024-04-29 17:42:50.980 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:50.980 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:50.980 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:50.980 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:50.980 | DTC Client socket (6) | Closed. 2024-04-29 17:42:50.980 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:50.980 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:50.980 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:51.144 | HD Request # 167 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:51.197 | Socket (7) | CloseSocket call. 2024-04-29 17:42:51.197 | HD Request # 167 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:51.197 | Historical data download thread signaled to stop. 2024-04-29 17:42:51.197 | HD Request # 167 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:51.197 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:51.197 | HD Request # 167 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:51.197 | HD Request # 167 | Completion time: 1s. 2024-04-29 17:42:51.197 | HD Request # 167 | Intraday data download complete for ESM24-CME. Unique request ID: 167 2024-04-29 17:42:51.197 | Removing historical data download ID 167. 2024-04-29 17:42:51.197 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:51.197 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:51.197 | HD Request # 167 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:51.197 | 2024-04-29 17:42:51.197 | No download requests in the queue to start downloads for. 2024-04-29 17:42:51.250 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:51.250 | Socket (7) | Closed. 2024-04-29 17:42:52.985 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:52.985 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:52.986 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:52.986 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:52.986 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:53.041 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:53.041 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:53.041 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:53.041 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:53.215 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:53.215 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:53.215 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:53.215 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:53.215 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:53.215 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:53.215 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:53.215 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:53.215 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:53.215 | Triggering next historical data download in queue. 2024-04-29 17:42:53.215 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:53.215 | HD Request # 168 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:53.215 | HD Request # 168 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:53.215 | HD Request # 168 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:53.215 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:53.215 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:53.215 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:53.268 | HD Request # 168 | Sending historical data logon request message. 2024-04-29 17:42:53.269 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:53.269 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:53.269 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:53.269 | DTC Client socket (6) | Closed. 2024-04-29 17:42:53.269 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:53.269 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:53.269 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:53.269 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:53.437 | HD Request # 168 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:53.491 | Socket (7) | CloseSocket call. 2024-04-29 17:42:53.491 | HD Request # 168 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:53.491 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:53.491 | Historical data download thread signaled to stop. 2024-04-29 17:42:53.491 | HD Request # 168 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:53.491 | HD Request # 168 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:53.491 | HD Request # 168 | Completion time: 0s. 2024-04-29 17:42:53.491 | HD Request # 168 | Intraday data download complete for ESM24-CME. Unique request ID: 168 2024-04-29 17:42:53.491 | Removing historical data download ID 168. 2024-04-29 17:42:53.491 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:53.491 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:53.491 | HD Request # 168 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:53.491 | 2024-04-29 17:42:53.491 | No download requests in the queue to start downloads for. 2024-04-29 17:42:53.546 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:53.546 | Socket (7) | Closed. 2024-04-29 17:42:55.271 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:55.271 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:55.271 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:55.271 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:55.271 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:55.330 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:55.330 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:55.330 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:55.330 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:55.500 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:55.500 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:55.500 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:55.500 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:55.500 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:55.500 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:55.500 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:55.500 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:55.500 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:55.500 | Triggering next historical data download in queue. 2024-04-29 17:42:55.500 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:55.500 | HD Request # 169 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:55.500 | HD Request # 169 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:55.500 | HD Request # 169 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:55.500 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:55.500 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:55.500 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:55.554 | HD Request # 169 | Sending historical data logon request message. 2024-04-29 17:42:55.555 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:55.557 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:55.557 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:55.557 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:55.557 | DTC Client socket (6) | Closed. 2024-04-29 17:42:55.557 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:55.557 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:55.557 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:55.718 | HD Request # 169 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:55.771 | Socket (7) | CloseSocket call. 2024-04-29 17:42:55.771 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:55.773 | HD Request # 169 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:55.773 | Historical data download thread signaled to stop. 2024-04-29 17:42:55.773 | HD Request # 169 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:55.773 | HD Request # 169 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:55.773 | HD Request # 169 | Completion time: 0s. 2024-04-29 17:42:55.773 | HD Request # 169 | Intraday data download complete for ESM24-CME. Unique request ID: 169 2024-04-29 17:42:55.773 | Removing historical data download ID 169. 2024-04-29 17:42:55.773 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:55.773 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:55.773 | HD Request # 169 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:55.773 | 2024-04-29 17:42:55.773 | No download requests in the queue to start downloads for. 2024-04-29 17:42:55.825 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:55.825 | Socket (7) | Closed. 2024-04-29 17:42:57.541 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:57.541 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:57.543 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:57.543 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:57.543 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:57.598 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:57.598 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:57.598 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:57.598 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:42:57.766 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:42:57.766 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:42:57.766 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:42:57.766 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:42:57.766 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:42:57.766 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:42:57.766 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:42:57.766 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:42:57.766 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:42:57.766 | Triggering next historical data download in queue. 2024-04-29 17:42:57.766 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:42:57.766 | HD Request # 170 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:42:57.767 | HD Request # 170 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:57.767 | HD Request # 170 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:42:57.767 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:57.767 | Socket (7) | New receive buffer size: 0 2024-04-29 17:42:57.767 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:57.820 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:42:57.820 | HD Request # 170 | Sending historical data logon request message. 2024-04-29 17:42:57.820 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:42:57.820 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:42:57.820 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:42:57.820 | DTC Client socket (6) | Closed. 2024-04-29 17:42:57.820 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:42:57.820 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:42:57.820 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:42:57.986 | HD Request # 170 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:42:58.038 | Socket (7) | CloseSocket call. 2024-04-29 17:42:58.038 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:42:58.038 | HD Request # 170 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:42:58.038 | Historical data download thread signaled to stop. 2024-04-29 17:42:58.038 | HD Request # 170 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:42:58.038 | HD Request # 170 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:42:58.038 | HD Request # 170 | Completion time: 1s. 2024-04-29 17:42:58.038 | HD Request # 170 | Intraday data download complete for ESM24-CME. Unique request ID: 170 2024-04-29 17:42:58.038 | Removing historical data download ID 170. 2024-04-29 17:42:58.038 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:42:58.038 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:42:58.038 | HD Request # 170 | Enabling Intraday chart updating for symbol. 2024-04-29 17:42:58.038 | 2024-04-29 17:42:58.038 | No download requests in the queue to start downloads for. 2024-04-29 17:42:58.093 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:42:58.093 | Socket (7) | Closed. 2024-04-29 17:42:59.810 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:42:59.810 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:42:59.811 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:42:59.811 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:42:59.811 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:42:59.863 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:42:59.863 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:42:59.863 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:42:59.863 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:00.024 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:00.024 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:00.024 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:00.024 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:00.024 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:00.024 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:00.024 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:00.024 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:00.024 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:00.024 | Triggering next historical data download in queue. 2024-04-29 17:43:00.024 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:00.025 | HD Request # 171 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:00.025 | HD Request # 171 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:00.025 | HD Request # 171 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:00.025 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:00.025 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:00.025 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:00.078 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:00.078 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:00.079 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:00.079 | HD Request # 171 | Sending historical data logon request message. 2024-04-29 17:43:00.079 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:00.079 | DTC Client socket (6) | Closed. 2024-04-29 17:43:00.079 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:00.079 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:00.079 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:00.241 | HD Request # 171 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:00.294 | Socket (7) | CloseSocket call. 2024-04-29 17:43:00.294 | HD Request # 171 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:00.294 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:00.294 | Historical data download thread signaled to stop. 2024-04-29 17:43:00.294 | HD Request # 171 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:00.294 | HD Request # 171 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:00.294 | HD Request # 171 | Completion time: 0s. 2024-04-29 17:43:00.294 | HD Request # 171 | Intraday data download complete for ESM24-CME. Unique request ID: 171 2024-04-29 17:43:00.294 | Removing historical data download ID 171. 2024-04-29 17:43:00.294 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:00.294 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:00.294 | HD Request # 171 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:00.294 | 2024-04-29 17:43:00.294 | No download requests in the queue to start downloads for. 2024-04-29 17:43:00.349 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:00.350 | Socket (7) | Closed. 2024-04-29 17:43:02.078 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:02.078 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:02.078 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:02.078 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:02.078 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:02.131 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:02.131 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:02.132 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:02.132 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:02.298 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:02.298 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:02.298 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:02.298 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:02.298 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:02.298 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:02.298 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:02.298 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:02.298 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:02.298 | Triggering next historical data download in queue. 2024-04-29 17:43:02.298 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:02.298 | HD Request # 172 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:02.298 | HD Request # 172 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:02.298 | HD Request # 172 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:02.299 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:02.299 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:02.299 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:02.352 | HD Request # 172 | Sending historical data logon request message. 2024-04-29 17:43:02.352 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:02.352 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:02.352 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:02.352 | DTC Client socket (6) | Closed. 2024-04-29 17:43:02.352 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:02.353 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:02.353 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:02.353 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:02.520 | HD Request # 172 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:02.574 | Socket (7) | CloseSocket call. 2024-04-29 17:43:02.574 | HD Request # 172 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:02.574 | Historical data download thread signaled to stop. 2024-04-29 17:43:02.574 | HD Request # 172 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:02.574 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:02.574 | HD Request # 172 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:02.574 | HD Request # 172 | Completion time: 0s. 2024-04-29 17:43:02.574 | HD Request # 172 | Intraday data download complete for ESM24-CME. Unique request ID: 172 2024-04-29 17:43:02.574 | Removing historical data download ID 172. 2024-04-29 17:43:02.574 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:02.574 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:02.574 | HD Request # 172 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:02.574 | 2024-04-29 17:43:02.574 | No download requests in the queue to start downloads for. 2024-04-29 17:43:02.627 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:02.627 | Socket (7) | Closed. 2024-04-29 17:43:04.348 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:04.348 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:04.348 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:04.348 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:04.348 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:04.402 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:04.402 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:04.402 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:04.402 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:04.566 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:04.566 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:04.566 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:04.566 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:04.566 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:04.566 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:04.566 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:04.566 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:04.566 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:04.566 | Triggering next historical data download in queue. 2024-04-29 17:43:04.566 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:04.566 | HD Request # 173 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:04.566 | HD Request # 173 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:04.566 | HD Request # 173 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:04.566 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:04.566 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:04.566 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:04.618 | HD Request # 173 | Sending historical data logon request message. 2024-04-29 17:43:04.621 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:04.621 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:04.621 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:04.621 | DTC Client socket (6) | Closed. 2024-04-29 17:43:04.622 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:04.622 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:04.622 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:04.622 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:04.781 | HD Request # 173 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:04.836 | Socket (7) | CloseSocket call. 2024-04-29 17:43:04.836 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:04.836 | HD Request # 173 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:04.836 | Historical data download thread signaled to stop. 2024-04-29 17:43:04.836 | HD Request # 173 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:04.836 | HD Request # 173 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:04.836 | HD Request # 173 | Completion time: 0s. 2024-04-29 17:43:04.836 | HD Request # 173 | Intraday data download complete for ESM24-CME. Unique request ID: 173 2024-04-29 17:43:04.836 | Removing historical data download ID 173. 2024-04-29 17:43:04.836 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:04.836 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:04.836 | HD Request # 173 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:04.836 | 2024-04-29 17:43:04.836 | No download requests in the queue to start downloads for. 2024-04-29 17:43:04.891 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:04.891 | Socket (7) | Closed. 2024-04-29 17:43:06.604 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:06.604 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:06.605 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:06.605 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:06.605 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:06.661 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:06.661 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:06.661 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:06.661 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:06.830 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:06.830 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:06.830 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:06.830 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:06.830 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:06.830 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:06.830 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:06.830 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:06.830 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:06.830 | Triggering next historical data download in queue. 2024-04-29 17:43:06.830 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:06.830 | HD Request # 174 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:06.830 | HD Request # 174 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:06.830 | HD Request # 174 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:06.830 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:06.831 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:06.831 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:06.884 | HD Request # 174 | Sending historical data logon request message. 2024-04-29 17:43:06.885 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:06.885 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:06.885 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:06.885 | DTC Client socket (6) | Closed. 2024-04-29 17:43:06.885 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:06.885 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:06.885 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:06.885 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:07.048 | HD Request # 174 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:07.102 | Socket (7) | CloseSocket call. 2024-04-29 17:43:07.102 | HD Request # 174 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:07.102 | Historical data download thread signaled to stop. 2024-04-29 17:43:07.102 | HD Request # 174 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:07.102 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:07.102 | HD Request # 174 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:07.102 | HD Request # 174 | Completion time: 1s. 2024-04-29 17:43:07.102 | HD Request # 174 | Intraday data download complete for ESM24-CME. Unique request ID: 174 2024-04-29 17:43:07.102 | Removing historical data download ID 174. 2024-04-29 17:43:07.102 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:07.102 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:07.102 | HD Request # 174 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:07.102 | 2024-04-29 17:43:07.102 | No download requests in the queue to start downloads for. 2024-04-29 17:43:07.156 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:07.156 | Socket (7) | Closed. 2024-04-29 17:43:08.878 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:08.878 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:08.879 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:08.879 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:08.879 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:08.931 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:08.931 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:08.931 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:08.931 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:09.098 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:09.098 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:09.098 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:09.098 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:09.098 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:09.098 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:09.098 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:09.098 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:09.098 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:09.098 | Triggering next historical data download in queue. 2024-04-29 17:43:09.098 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:09.098 | HD Request # 175 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:09.099 | HD Request # 175 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:09.099 | HD Request # 175 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:09.099 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:09.099 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:09.099 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:09.152 | HD Request # 175 | Sending historical data logon request message. 2024-04-29 17:43:09.153 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:09.153 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:09.153 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:09.153 | DTC Client socket (6) | Closed. 2024-04-29 17:43:09.153 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:09.153 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:09.153 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:09.153 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:09.317 | HD Request # 175 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:09.370 | Socket (7) | CloseSocket call. 2024-04-29 17:43:09.370 | HD Request # 175 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:09.370 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:09.370 | Historical data download thread signaled to stop. 2024-04-29 17:43:09.370 | HD Request # 175 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:09.370 | HD Request # 175 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:09.370 | HD Request # 175 | Completion time: 0s. 2024-04-29 17:43:09.370 | HD Request # 175 | Intraday data download complete for ESM24-CME. Unique request ID: 175 2024-04-29 17:43:09.370 | Removing historical data download ID 175. 2024-04-29 17:43:09.370 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:09.370 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:09.370 | HD Request # 175 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:09.370 | 2024-04-29 17:43:09.370 | No download requests in the queue to start downloads for. 2024-04-29 17:43:09.425 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:09.425 | Socket (7) | Closed. 2024-04-29 17:43:11.136 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:11.136 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:11.136 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:11.136 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:11.136 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:11.192 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:11.192 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:11.193 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:11.193 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:11.363 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:11.363 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:11.363 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:11.363 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:11.363 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:11.363 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:11.363 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:11.363 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:11.363 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:11.363 | Triggering next historical data download in queue. 2024-04-29 17:43:11.363 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:11.363 | HD Request # 176 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:11.363 | HD Request # 176 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:11.363 | HD Request # 176 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:11.363 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:11.364 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:11.364 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:11.417 | HD Request # 176 | Sending historical data logon request message. 2024-04-29 17:43:11.417 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:11.417 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:11.417 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:11.417 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:11.417 | DTC Client socket (6) | Closed. 2024-04-29 17:43:11.418 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:11.418 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:11.418 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:11.587 | HD Request # 176 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:11.641 | Socket (7) | CloseSocket call. 2024-04-29 17:43:11.641 | HD Request # 176 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:11.641 | Historical data download thread signaled to stop. 2024-04-29 17:43:11.641 | HD Request # 176 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:11.641 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:11.641 | HD Request # 176 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:11.641 | HD Request # 176 | Completion time: 0s. 2024-04-29 17:43:11.641 | HD Request # 176 | Intraday data download complete for ESM24-CME. Unique request ID: 176 2024-04-29 17:43:11.641 | Removing historical data download ID 176. 2024-04-29 17:43:11.641 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:11.641 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:11.641 | HD Request # 176 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:11.641 | 2024-04-29 17:43:11.641 | No download requests in the queue to start downloads for. 2024-04-29 17:43:11.694 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:11.694 | Socket (7) | Closed. 2024-04-29 17:43:13.426 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:13.426 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:13.427 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:13.427 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:13.427 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:13.482 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:13.482 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:13.482 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:13.482 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:13.645 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:13.645 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:13.645 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:13.645 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:13.645 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:13.645 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:13.645 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:13.645 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:13.645 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:13.645 | Triggering next historical data download in queue. 2024-04-29 17:43:13.645 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:13.645 | HD Request # 177 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:13.645 | HD Request # 177 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:13.645 | HD Request # 177 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:13.645 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:13.645 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:13.645 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:13.698 | HD Request # 177 | Sending historical data logon request message. 2024-04-29 17:43:13.698 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:13.698 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:13.698 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:13.699 | DTC Client socket (6) | Closed. 2024-04-29 17:43:13.699 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:13.699 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:13.699 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:13.699 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:13.866 | HD Request # 177 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:13.920 | Socket (7) | CloseSocket call. 2024-04-29 17:43:13.920 | HD Request # 177 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:13.920 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:13.920 | Historical data download thread signaled to stop. 2024-04-29 17:43:13.920 | HD Request # 177 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:13.920 | HD Request # 177 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:13.920 | HD Request # 177 | Completion time: 0s. 2024-04-29 17:43:13.920 | HD Request # 177 | Intraday data download complete for ESM24-CME. Unique request ID: 177 2024-04-29 17:43:13.920 | Removing historical data download ID 177. 2024-04-29 17:43:13.920 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:13.920 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:13.920 | HD Request # 177 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:13.920 | 2024-04-29 17:43:13.920 | No download requests in the queue to start downloads for. 2024-04-29 17:43:13.975 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:13.975 | Socket (7) | Closed. 2024-04-29 17:43:15.687 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:15.687 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:15.688 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:15.688 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:15.688 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:15.743 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:15.743 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:15.743 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:15.743 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:15.912 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:15.912 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:15.912 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:15.912 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:15.912 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:15.912 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:15.912 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:15.912 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:15.912 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:15.912 | Triggering next historical data download in queue. 2024-04-29 17:43:15.912 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:15.912 | HD Request # 178 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:15.913 | HD Request # 178 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:15.913 | HD Request # 178 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:15.913 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:15.913 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:15.913 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:15.965 | HD Request # 178 | Sending historical data logon request message. 2024-04-29 17:43:15.966 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:15.966 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:15.966 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:15.966 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:15.966 | DTC Client socket (6) | Closed. 2024-04-29 17:43:15.966 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:15.966 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:15.966 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:16.128 | HD Request # 178 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:16.182 | Socket (7) | CloseSocket call. 2024-04-29 17:43:16.182 | HD Request # 178 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:16.182 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:16.182 | Historical data download thread signaled to stop. 2024-04-29 17:43:16.182 | HD Request # 178 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:16.182 | HD Request # 178 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:16.182 | HD Request # 178 | Completion time: 1s. 2024-04-29 17:43:16.182 | HD Request # 178 | Intraday data download complete for ESM24-CME. Unique request ID: 178 2024-04-29 17:43:16.182 | Removing historical data download ID 178. 2024-04-29 17:43:16.182 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:16.182 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:16.182 | HD Request # 178 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:16.182 | 2024-04-29 17:43:16.182 | No download requests in the queue to start downloads for. 2024-04-29 17:43:16.236 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:16.236 | Socket (7) | Closed. 2024-04-29 17:43:17.947 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:17.947 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:17.948 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:17.949 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:17.949 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:18.002 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:18.002 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:18.002 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:18.002 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:18.171 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:18.171 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:18.171 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:18.171 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:18.171 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:18.171 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:18.171 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:18.171 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:18.171 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:18.171 | Triggering next historical data download in queue. 2024-04-29 17:43:18.171 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:18.171 | HD Request # 179 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:18.171 | HD Request # 179 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:18.172 | HD Request # 179 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:18.172 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:18.172 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:18.172 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:18.224 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:18.225 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:18.225 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:18.225 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:18.225 | DTC Client socket (6) | Closed. 2024-04-29 17:43:18.225 | HD Request # 179 | Sending historical data logon request message. 2024-04-29 17:43:18.225 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:18.225 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:18.225 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:18.389 | HD Request # 179 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:18.442 | Socket (7) | CloseSocket call. 2024-04-29 17:43:18.442 | HD Request # 179 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:18.442 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:18.442 | Historical data download thread signaled to stop. 2024-04-29 17:43:18.442 | HD Request # 179 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:18.442 | HD Request # 179 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:18.442 | HD Request # 179 | Completion time: 0s. 2024-04-29 17:43:18.442 | HD Request # 179 | Intraday data download complete for ESM24-CME. Unique request ID: 179 2024-04-29 17:43:18.442 | Removing historical data download ID 179. 2024-04-29 17:43:18.442 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:18.442 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:18.442 | HD Request # 179 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:18.442 | 2024-04-29 17:43:18.442 | No download requests in the queue to start downloads for. 2024-04-29 17:43:18.496 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:18.496 | Socket (7) | Closed. 2024-04-29 17:43:20.222 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:20.222 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:20.222 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:20.222 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:20.222 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:20.278 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:20.278 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:20.278 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:20.278 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:20.443 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:20.443 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:20.443 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:20.443 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:20.443 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:20.443 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:20.443 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:20.443 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:20.443 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:20.443 | Triggering next historical data download in queue. 2024-04-29 17:43:20.443 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:20.443 | HD Request # 180 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:20.443 | HD Request # 180 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:20.443 | HD Request # 180 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:20.443 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:20.443 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:20.443 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:20.497 | HD Request # 180 | Sending historical data logon request message. 2024-04-29 17:43:20.497 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:20.497 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:20.497 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:20.497 | DTC Client socket (6) | Closed. 2024-04-29 17:43:20.497 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:20.498 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:20.498 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:20.498 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:20.663 | HD Request # 180 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:20.718 | Socket (7) | CloseSocket call. 2024-04-29 17:43:20.718 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:20.718 | HD Request # 180 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:20.719 | Historical data download thread signaled to stop. 2024-04-29 17:43:20.719 | HD Request # 180 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:20.719 | HD Request # 180 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:20.719 | HD Request # 180 | Completion time: 0s. 2024-04-29 17:43:20.719 | HD Request # 180 | Intraday data download complete for ESM24-CME. Unique request ID: 180 2024-04-29 17:43:20.719 | Removing historical data download ID 180. 2024-04-29 17:43:20.719 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:20.719 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:20.719 | HD Request # 180 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:20.719 | 2024-04-29 17:43:20.719 | No download requests in the queue to start downloads for. 2024-04-29 17:43:20.771 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:20.771 | Socket (7) | Closed. 2024-04-29 17:43:22.504 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:22.504 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:22.505 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:22.505 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:22.505 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:22.560 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:22.560 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:22.560 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:22.560 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:22.728 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:22.728 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:22.728 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:22.728 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:22.728 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:22.728 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:22.728 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:22.728 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:22.728 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:22.728 | Triggering next historical data download in queue. 2024-04-29 17:43:22.728 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:22.728 | HD Request # 181 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:22.728 | HD Request # 181 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:22.728 | HD Request # 181 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:22.728 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:22.728 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:22.728 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:22.780 | HD Request # 181 | Sending historical data logon request message. 2024-04-29 17:43:22.782 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:22.782 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:22.782 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:22.782 | DTC Client socket (6) | Closed. 2024-04-29 17:43:22.782 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:22.782 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:22.782 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:22.782 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:22.948 | HD Request # 181 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:23.001 | Socket (7) | CloseSocket call. 2024-04-29 17:43:23.001 | HD Request # 181 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:23.001 | Historical data download thread signaled to stop. 2024-04-29 17:43:23.001 | HD Request # 181 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:23.001 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:23.001 | HD Request # 181 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:23.001 | HD Request # 181 | Completion time: 1s. 2024-04-29 17:43:23.001 | HD Request # 181 | Intraday data download complete for ESM24-CME. Unique request ID: 181 2024-04-29 17:43:23.001 | Removing historical data download ID 181. 2024-04-29 17:43:23.001 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:23.001 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:23.001 | HD Request # 181 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:23.001 | 2024-04-29 17:43:23.001 | No download requests in the queue to start downloads for. 2024-04-29 17:43:23.056 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:23.056 | Socket (7) | Closed. 2024-04-29 17:43:24.767 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:24.767 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:24.768 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:24.768 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:24.768 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:24.822 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:24.822 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:24.822 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:24.822 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:24.987 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:24.987 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:24.987 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:24.987 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:24.987 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:24.987 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:24.987 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:24.987 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:24.987 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:24.987 | Triggering next historical data download in queue. 2024-04-29 17:43:24.987 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:24.987 | HD Request # 182 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:24.987 | HD Request # 182 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:24.987 | HD Request # 182 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:24.987 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:24.987 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:24.987 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:25.040 | HD Request # 182 | Sending historical data logon request message. 2024-04-29 17:43:25.041 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:25.041 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:25.041 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:25.041 | DTC Client socket (6) | Closed. 2024-04-29 17:43:25.041 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:25.041 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:25.041 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:25.041 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:25.205 | HD Request # 182 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:25.258 | Socket (7) | CloseSocket call. 2024-04-29 17:43:25.258 | HD Request # 182 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:25.258 | Historical data download thread signaled to stop. 2024-04-29 17:43:25.258 | HD Request # 182 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:25.258 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:25.258 | HD Request # 182 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:25.258 | HD Request # 182 | Completion time: 1s. 2024-04-29 17:43:25.258 | HD Request # 182 | Intraday data download complete for ESM24-CME. Unique request ID: 182 2024-04-29 17:43:25.258 | Removing historical data download ID 182. 2024-04-29 17:43:25.258 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:25.258 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:25.258 | HD Request # 182 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:25.258 | 2024-04-29 17:43:25.258 | No download requests in the queue to start downloads for. 2024-04-29 17:43:25.312 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:25.312 | Socket (7) | Closed. 2024-04-29 17:43:27.025 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:27.025 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:27.027 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:27.027 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:27.027 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:27.079 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:27.079 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:27.079 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:27.079 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:27.245 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:27.245 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:27.245 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:27.245 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:27.245 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:27.245 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:27.245 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:27.245 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:27.245 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:27.245 | Triggering next historical data download in queue. 2024-04-29 17:43:27.245 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:27.245 | HD Request # 183 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:27.245 | HD Request # 183 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:27.245 | HD Request # 183 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:27.245 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:27.245 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:27.245 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:27.300 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:27.300 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:27.300 | HD Request # 183 | Sending historical data logon request message. 2024-04-29 17:43:27.300 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:27.300 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:27.300 | DTC Client socket (6) | Closed. 2024-04-29 17:43:27.300 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:27.300 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:27.300 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:27.464 | HD Request # 183 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:27.517 | Socket (7) | CloseSocket call. 2024-04-29 17:43:27.517 | HD Request # 183 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:27.517 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:27.517 | Historical data download thread signaled to stop. 2024-04-29 17:43:27.517 | HD Request # 183 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:27.518 | HD Request # 183 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:27.518 | HD Request # 183 | Completion time: 0s. 2024-04-29 17:43:27.518 | HD Request # 183 | Intraday data download complete for ESM24-CME. Unique request ID: 183 2024-04-29 17:43:27.518 | Removing historical data download ID 183. 2024-04-29 17:43:27.518 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:27.518 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:27.518 | HD Request # 183 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:27.518 | 2024-04-29 17:43:27.518 | No download requests in the queue to start downloads for. 2024-04-29 17:43:27.572 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:27.572 | Socket (7) | Closed. 2024-04-29 17:43:29.296 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:29.296 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:29.296 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:29.296 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:29.296 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:29.355 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:29.355 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:29.355 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:29.355 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:29.524 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:29.524 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:29.524 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:29.524 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:29.524 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:29.524 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:29.524 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:29.524 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:29.524 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:29.524 | Triggering next historical data download in queue. 2024-04-29 17:43:29.524 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:29.524 | HD Request # 184 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:29.524 | HD Request # 184 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:29.524 | HD Request # 184 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:29.524 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:29.524 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:29.524 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:29.577 | HD Request # 184 | Sending historical data logon request message. 2024-04-29 17:43:29.577 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:29.577 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:29.577 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:29.577 | DTC Client socket (6) | Closed. 2024-04-29 17:43:29.577 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:29.578 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:29.578 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:29.578 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:29.745 | HD Request # 184 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:29.798 | Socket (7) | CloseSocket call. 2024-04-29 17:43:29.798 | HD Request # 184 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:29.798 | Historical data download thread signaled to stop. 2024-04-29 17:43:29.798 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:29.798 | HD Request # 184 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:29.798 | HD Request # 184 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:29.798 | HD Request # 184 | Completion time: 0s. 2024-04-29 17:43:29.798 | HD Request # 184 | Intraday data download complete for ESM24-CME. Unique request ID: 184 2024-04-29 17:43:29.798 | Removing historical data download ID 184. 2024-04-29 17:43:29.798 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:29.798 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:29.798 | HD Request # 184 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:29.798 | 2024-04-29 17:43:29.798 | No download requests in the queue to start downloads for. 2024-04-29 17:43:29.853 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:29.853 | Socket (7) | Closed. 2024-04-29 17:43:31.582 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:31.582 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:31.582 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:31.583 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:31.583 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:31.638 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:31.638 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:31.638 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:31.638 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:31.818 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:31.818 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:31.818 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:31.818 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:31.818 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:31.818 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:31.818 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:31.818 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:31.818 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:31.818 | Triggering next historical data download in queue. 2024-04-29 17:43:31.818 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:31.819 | HD Request # 185 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:31.819 | HD Request # 185 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:31.819 | HD Request # 185 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:31.819 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:31.819 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:31.819 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:31.872 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:31.872 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:31.872 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:31.872 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:31.872 | DTC Client socket (6) | Closed. 2024-04-29 17:43:31.872 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:31.872 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:31.872 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:31.873 | HD Request # 185 | Sending historical data logon request message. 2024-04-29 17:43:32.040 | HD Request # 185 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:32.094 | Socket (7) | CloseSocket call. 2024-04-29 17:43:32.094 | HD Request # 185 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:32.094 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:32.094 | Historical data download thread signaled to stop. 2024-04-29 17:43:32.094 | HD Request # 185 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:32.094 | HD Request # 185 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:32.094 | HD Request # 185 | Completion time: 1s. 2024-04-29 17:43:32.094 | HD Request # 185 | Intraday data download complete for ESM24-CME. Unique request ID: 185 2024-04-29 17:43:32.094 | Removing historical data download ID 185. 2024-04-29 17:43:32.094 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:32.094 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:32.094 | HD Request # 185 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:32.094 | 2024-04-29 17:43:32.094 | No download requests in the queue to start downloads for. 2024-04-29 17:43:32.146 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:32.146 | Socket (7) | Closed. 2024-04-29 17:43:33.853 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:33.853 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:33.854 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:33.854 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:33.854 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:33.908 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:33.908 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:33.908 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:33.908 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:34.073 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:34.073 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:34.073 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:34.073 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:34.073 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:34.073 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:34.073 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:34.073 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:34.073 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:34.073 | Triggering next historical data download in queue. 2024-04-29 17:43:34.073 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:34.073 | HD Request # 186 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:34.073 | HD Request # 186 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:34.073 | HD Request # 186 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:34.073 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:34.073 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:34.073 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:34.126 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:34.126 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:34.126 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:34.127 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:34.127 | DTC Client socket (6) | Closed. 2024-04-29 17:43:34.127 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:34.127 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:34.127 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:34.127 | HD Request # 186 | Sending historical data logon request message. 2024-04-29 17:43:34.292 | HD Request # 186 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:34.344 | Socket (7) | CloseSocket call. 2024-04-29 17:43:34.344 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:34.344 | HD Request # 186 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:34.344 | Historical data download thread signaled to stop. 2024-04-29 17:43:34.344 | HD Request # 186 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:34.344 | HD Request # 186 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:34.344 | HD Request # 186 | Completion time: 0s. 2024-04-29 17:43:34.344 | HD Request # 186 | Intraday data download complete for ESM24-CME. Unique request ID: 186 2024-04-29 17:43:34.344 | Removing historical data download ID 186. 2024-04-29 17:43:34.344 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:34.344 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:34.344 | HD Request # 186 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:34.344 | 2024-04-29 17:43:34.344 | No download requests in the queue to start downloads for. 2024-04-29 17:43:34.399 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:34.399 | Socket (7) | Closed. 2024-04-29 17:43:36.125 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:36.125 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:36.125 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:36.125 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:36.125 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:36.178 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:36.178 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:36.178 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:36.178 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:36.341 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:36.341 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:36.341 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:36.341 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:36.341 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:36.341 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:36.341 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:36.341 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:36.341 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:36.341 | Triggering next historical data download in queue. 2024-04-29 17:43:36.341 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:36.341 | HD Request # 187 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:36.342 | HD Request # 187 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:36.342 | HD Request # 187 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:36.342 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:36.342 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:36.342 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:36.394 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:36.394 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:36.394 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:36.394 | HD Request # 187 | Sending historical data logon request message. 2024-04-29 17:43:36.394 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:36.394 | DTC Client socket (6) | Closed. 2024-04-29 17:43:36.395 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:36.395 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:36.395 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:36.558 | HD Request # 187 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:36.611 | Socket (7) | CloseSocket call. 2024-04-29 17:43:36.611 | HD Request # 187 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:36.611 | Historical data download thread signaled to stop. 2024-04-29 17:43:36.611 | HD Request # 187 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:36.611 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:36.611 | HD Request # 187 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:36.611 | HD Request # 187 | Completion time: 0s. 2024-04-29 17:43:36.611 | HD Request # 187 | Intraday data download complete for ESM24-CME. Unique request ID: 187 2024-04-29 17:43:36.611 | Removing historical data download ID 187. 2024-04-29 17:43:36.611 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:36.611 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:36.611 | HD Request # 187 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:36.611 | 2024-04-29 17:43:36.611 | No download requests in the queue to start downloads for. 2024-04-29 17:43:36.664 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:36.664 | Socket (7) | Closed. 2024-04-29 17:43:38.397 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:38.397 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:38.397 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:38.397 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:38.397 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:38.455 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:38.455 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:38.455 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:38.455 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:38.627 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:38.627 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:38.627 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:38.627 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:38.627 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:38.627 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:38.627 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:38.627 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:38.627 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:38.627 | Triggering next historical data download in queue. 2024-04-29 17:43:38.627 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:38.627 | HD Request # 188 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:38.627 | HD Request # 188 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:38.627 | HD Request # 188 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:38.627 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:38.627 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:38.627 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:38.681 | HD Request # 188 | Sending historical data logon request message. 2024-04-29 17:43:38.683 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:38.683 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:38.683 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:38.683 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:38.683 | DTC Client socket (6) | Closed. 2024-04-29 17:43:38.684 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:38.684 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:38.684 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:38.845 | HD Request # 188 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:38.898 | Socket (7) | CloseSocket call. 2024-04-29 17:43:38.898 | HD Request # 188 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:38.898 | Historical data download thread signaled to stop. 2024-04-29 17:43:38.898 | HD Request # 188 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:38.898 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:38.898 | HD Request # 188 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:38.898 | HD Request # 188 | Completion time: 0s. 2024-04-29 17:43:38.898 | HD Request # 188 | Intraday data download complete for ESM24-CME. Unique request ID: 188 2024-04-29 17:43:38.898 | Removing historical data download ID 188. 2024-04-29 17:43:38.898 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:38.898 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:38.898 | HD Request # 188 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:38.898 | 2024-04-29 17:43:38.898 | No download requests in the queue to start downloads for. 2024-04-29 17:43:38.951 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:38.951 | Socket (7) | Closed. 2024-04-29 17:43:40.676 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:40.676 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:40.676 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:40.676 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:40.676 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:40.741 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:40.741 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:40.741 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:40.741 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:40.927 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:40.927 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:40.927 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:40.927 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:40.927 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:40.927 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:40.927 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:40.927 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:40.927 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:40.927 | Triggering next historical data download in queue. 2024-04-29 17:43:40.927 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:40.927 | HD Request # 189 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:40.927 | HD Request # 189 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:40.927 | HD Request # 189 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:40.927 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:40.927 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:40.927 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:40.985 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:40.985 | HD Request # 189 | Sending historical data logon request message. 2024-04-29 17:43:40.985 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:40.985 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:40.985 | DTC Client socket (6) | Closed. 2024-04-29 17:43:40.986 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:40.986 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:40.986 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:40.986 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:41.154 | HD Request # 189 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:41.208 | Socket (7) | CloseSocket call. 2024-04-29 17:43:41.208 | HD Request # 189 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:41.208 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:41.208 | Historical data download thread signaled to stop. 2024-04-29 17:43:41.208 | HD Request # 189 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:41.208 | HD Request # 189 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:41.208 | HD Request # 189 | Completion time: 1s. 2024-04-29 17:43:41.208 | HD Request # 189 | Intraday data download complete for ESM24-CME. Unique request ID: 189 2024-04-29 17:43:41.208 | Removing historical data download ID 189. 2024-04-29 17:43:41.209 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:41.209 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:41.209 | HD Request # 189 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:41.209 | 2024-04-29 17:43:41.209 | No download requests in the queue to start downloads for. 2024-04-29 17:43:41.263 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:41.263 | Socket (7) | Closed. 2024-04-29 17:43:42.978 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:42.978 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:42.980 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:42.980 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:42.980 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:43.035 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:43.035 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:43.035 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:43.035 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:43.200 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:43.200 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:43.200 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:43.200 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:43.200 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:43.200 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:43.200 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:43.200 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:43.200 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:43.200 | Triggering next historical data download in queue. 2024-04-29 17:43:43.200 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:43.201 | HD Request # 190 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:43.201 | HD Request # 190 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:43.201 | HD Request # 190 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:43.201 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:43.201 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:43.201 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:43.256 | HD Request # 190 | Sending historical data logon request message. 2024-04-29 17:43:43.256 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:43.256 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:43.256 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:43.256 | DTC Client socket (6) | Closed. 2024-04-29 17:43:43.256 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:43.257 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:43.257 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:43.257 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:43.419 | HD Request # 190 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:43.473 | Socket (7) | CloseSocket call. 2024-04-29 17:43:43.473 | HD Request # 190 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:43.473 | Historical data download thread signaled to stop. 2024-04-29 17:43:43.473 | HD Request # 190 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:43.473 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:43.473 | HD Request # 190 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:43.473 | HD Request # 190 | Completion time: 0s. 2024-04-29 17:43:43.473 | HD Request # 190 | Intraday data download complete for ESM24-CME. Unique request ID: 190 2024-04-29 17:43:43.473 | Removing historical data download ID 190. 2024-04-29 17:43:43.473 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:43.473 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:43.473 | HD Request # 190 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:43.473 | 2024-04-29 17:43:43.473 | No download requests in the queue to start downloads for. 2024-04-29 17:43:43.528 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:43.528 | Socket (7) | Closed. 2024-04-29 17:43:45.257 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:45.257 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:45.257 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:45.257 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:45.257 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:45.312 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:45.312 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:45.312 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:45.312 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:45.481 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:45.481 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:45.481 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:45.481 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:45.481 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:45.481 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:45.481 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:45.481 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:45.481 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:45.481 | Triggering next historical data download in queue. 2024-04-29 17:43:45.481 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:45.481 | HD Request # 191 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:45.481 | HD Request # 191 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:45.481 | HD Request # 191 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:45.481 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:45.481 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:45.481 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:45.536 | HD Request # 191 | Sending historical data logon request message. 2024-04-29 17:43:45.537 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:45.537 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:45.537 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:45.537 | DTC Client socket (6) | Closed. 2024-04-29 17:43:45.537 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:45.538 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:45.538 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:45.538 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:45.703 | HD Request # 191 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:45.757 | Socket (7) | CloseSocket call. 2024-04-29 17:43:45.757 | HD Request # 191 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:45.757 | Historical data download thread signaled to stop. 2024-04-29 17:43:45.757 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:45.757 | HD Request # 191 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:45.757 | HD Request # 191 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:45.757 | HD Request # 191 | Completion time: 0s. 2024-04-29 17:43:45.757 | HD Request # 191 | Intraday data download complete for ESM24-CME. Unique request ID: 191 2024-04-29 17:43:45.757 | Removing historical data download ID 191. 2024-04-29 17:43:45.757 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:45.757 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:45.757 | HD Request # 191 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:45.757 | 2024-04-29 17:43:45.757 | No download requests in the queue to start downloads for. 2024-04-29 17:43:45.819 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:45.819 | Socket (7) | Closed. 2024-04-29 17:43:47.529 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:47.529 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:47.529 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:47.529 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:47.529 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:47.585 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:47.585 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:47.585 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:47.585 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:47.753 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:47.753 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:47.753 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:47.753 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:47.753 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:47.753 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:47.753 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:47.753 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:47.753 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:47.753 | Triggering next historical data download in queue. 2024-04-29 17:43:47.753 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:47.753 | HD Request # 192 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:47.754 | HD Request # 192 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:47.754 | HD Request # 192 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:47.754 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:47.754 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:47.754 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:47.806 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:47.806 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:47.806 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:47.806 | DTC Client socket (6) | Closed. 2024-04-29 17:43:47.806 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:47.806 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:47.806 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:47.806 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:47.807 | HD Request # 192 | Sending historical data logon request message. 2024-04-29 17:43:47.970 | HD Request # 192 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:48.024 | Socket (7) | CloseSocket call. 2024-04-29 17:43:48.024 | HD Request # 192 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:48.024 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:48.024 | Historical data download thread signaled to stop. 2024-04-29 17:43:48.024 | HD Request # 192 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:48.024 | HD Request # 192 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:48.024 | HD Request # 192 | Completion time: 1s. 2024-04-29 17:43:48.024 | HD Request # 192 | Intraday data download complete for ESM24-CME. Unique request ID: 192 2024-04-29 17:43:48.024 | Removing historical data download ID 192. 2024-04-29 17:43:48.025 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:48.025 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:48.025 | HD Request # 192 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:48.025 | 2024-04-29 17:43:48.025 | No download requests in the queue to start downloads for. 2024-04-29 17:43:48.083 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:48.083 | Socket (7) | Closed. 2024-04-29 17:43:49.795 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:49.795 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:49.796 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:49.796 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:49.796 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:49.850 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:49.850 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:49.850 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:49.850 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:50.024 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:50.024 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:50.024 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:50.024 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:50.024 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:50.024 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:50.024 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:50.025 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:50.025 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:50.025 | Triggering next historical data download in queue. 2024-04-29 17:43:50.025 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:50.025 | HD Request # 193 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:50.025 | HD Request # 193 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:50.025 | HD Request # 193 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:50.025 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:50.025 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:50.025 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:50.082 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:50.082 | HD Request # 193 | Sending historical data logon request message. 2024-04-29 17:43:50.082 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:50.082 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:50.082 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:50.082 | DTC Client socket (6) | Closed. 2024-04-29 17:43:50.083 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:50.083 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:50.083 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:50.248 | HD Request # 193 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:50.304 | Socket (7) | CloseSocket call. 2024-04-29 17:43:50.304 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:50.304 | HD Request # 193 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:50.305 | Historical data download thread signaled to stop. 2024-04-29 17:43:50.305 | HD Request # 193 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:50.305 | HD Request # 193 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:50.305 | HD Request # 193 | Completion time: 0s. 2024-04-29 17:43:50.305 | HD Request # 193 | Intraday data download complete for ESM24-CME. Unique request ID: 193 2024-04-29 17:43:50.305 | Removing historical data download ID 193. 2024-04-29 17:43:50.305 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:50.305 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:50.305 | HD Request # 193 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:50.305 | 2024-04-29 17:43:50.305 | No download requests in the queue to start downloads for. 2024-04-29 17:43:50.368 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:50.368 | Socket (7) | Closed. 2024-04-29 17:43:52.086 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:52.086 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:52.087 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:52.087 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:52.087 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:52.140 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:52.140 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:52.140 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:52.140 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:52.304 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:52.304 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:52.304 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:52.304 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:52.304 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:52.304 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:52.304 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:52.304 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:52.304 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:52.304 | Triggering next historical data download in queue. 2024-04-29 17:43:52.304 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:52.304 | HD Request # 194 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:52.304 | HD Request # 194 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:52.304 | HD Request # 194 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:52.304 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:52.304 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:52.304 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:52.358 | HD Request # 194 | Sending historical data logon request message. 2024-04-29 17:43:52.358 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:52.358 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:52.358 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:52.358 | DTC Client socket (6) | Closed. 2024-04-29 17:43:52.359 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:52.359 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:52.359 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:52.359 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:52.523 | HD Request # 194 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:52.575 | Socket (7) | CloseSocket call. 2024-04-29 17:43:52.575 | HD Request # 194 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:52.575 | Historical data download thread signaled to stop. 2024-04-29 17:43:52.575 | HD Request # 194 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:52.575 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:52.575 | HD Request # 194 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:52.575 | HD Request # 194 | Completion time: 0s. 2024-04-29 17:43:52.575 | HD Request # 194 | Intraday data download complete for ESM24-CME. Unique request ID: 194 2024-04-29 17:43:52.575 | Removing historical data download ID 194. 2024-04-29 17:43:52.575 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:52.575 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:52.575 | HD Request # 194 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:52.575 | 2024-04-29 17:43:52.575 | No download requests in the queue to start downloads for. 2024-04-29 17:43:52.628 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:52.628 | Socket (7) | Closed. 2024-04-29 17:43:54.359 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:54.359 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:54.360 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:54.360 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:54.360 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:54.412 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:54.412 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:54.412 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:54.412 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:54.576 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:54.576 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:54.576 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:54.576 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:54.576 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:54.576 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:54.576 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:54.576 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:54.576 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:54.576 | Triggering next historical data download in queue. 2024-04-29 17:43:54.576 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:54.576 | HD Request # 195 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:54.577 | HD Request # 195 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:54.577 | HD Request # 195 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:54.577 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:54.577 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:54.577 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:54.630 | HD Request # 195 | Sending historical data logon request message. 2024-04-29 17:43:54.631 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:54.631 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:54.631 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:54.631 | DTC Client socket (6) | Closed. 2024-04-29 17:43:54.631 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:54.631 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:54.631 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:54.631 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:54.793 | HD Request # 195 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:54.846 | Socket (7) | CloseSocket call. 2024-04-29 17:43:54.846 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:54.847 | HD Request # 195 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:54.847 | Historical data download thread signaled to stop. 2024-04-29 17:43:54.847 | HD Request # 195 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:54.848 | HD Request # 195 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:54.848 | HD Request # 195 | Completion time: 0s. 2024-04-29 17:43:54.848 | HD Request # 195 | Intraday data download complete for ESM24-CME. Unique request ID: 195 2024-04-29 17:43:54.848 | Removing historical data download ID 195. 2024-04-29 17:43:54.848 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:54.848 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:54.848 | HD Request # 195 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:54.848 | 2024-04-29 17:43:54.848 | No download requests in the queue to start downloads for. 2024-04-29 17:43:54.898 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:54.898 | Socket (7) | Closed. 2024-04-29 17:43:56.628 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:56.628 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:56.628 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:56.628 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:56.628 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:56.680 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:56.680 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:56.680 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:56.680 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:56.845 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:56.845 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:56.845 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:56.845 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:56.845 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:56.845 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:56.845 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:56.845 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:56.845 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:56.845 | Triggering next historical data download in queue. 2024-04-29 17:43:56.845 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:56.845 | HD Request # 196 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:56.845 | HD Request # 196 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:56.845 | HD Request # 196 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:56.845 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:56.845 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:56.845 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:56.897 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:56.897 | HD Request # 196 | Sending historical data logon request message. 2024-04-29 17:43:56.898 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:56.898 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:56.898 | DTC Client socket (6) | Closed. 2024-04-29 17:43:56.898 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:56.898 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:56.898 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:56.898 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:57.061 | HD Request # 196 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:57.114 | Socket (7) | CloseSocket call. 2024-04-29 17:43:57.114 | HD Request # 196 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:57.114 | Historical data download thread signaled to stop. 2024-04-29 17:43:57.114 | HD Request # 196 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:57.114 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:57.114 | HD Request # 196 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:57.114 | HD Request # 196 | Completion time: 1s. 2024-04-29 17:43:57.114 | HD Request # 196 | Intraday data download complete for ESM24-CME. Unique request ID: 196 2024-04-29 17:43:57.114 | Removing historical data download ID 196. 2024-04-29 17:43:57.114 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:57.114 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:57.114 | HD Request # 196 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:57.114 | 2024-04-29 17:43:57.114 | No download requests in the queue to start downloads for. 2024-04-29 17:43:57.168 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:57.168 | Socket (7) | Closed. 2024-04-29 17:43:58.898 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:43:58.898 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:43:58.901 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:58.901 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:43:58.901 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:58.955 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:43:58.955 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:43:58.955 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:43:58.955 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:43:59.120 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:43:59.120 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:43:59.120 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:43:59.120 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:43:59.120 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:43:59.120 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:43:59.120 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:43:59.120 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:43:59.120 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:43:59.120 | Triggering next historical data download in queue. 2024-04-29 17:43:59.120 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:43:59.121 | HD Request # 197 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:43:59.121 | HD Request # 197 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:59.121 | HD Request # 197 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:43:59.121 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:43:59.121 | Socket (7) | New receive buffer size: 0 2024-04-29 17:43:59.121 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:43:59.173 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:43:59.173 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:43:59.173 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:43:59.173 | DTC Client socket (6) | Closed. 2024-04-29 17:43:59.173 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:43:59.174 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:43:59.174 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:43:59.174 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:43:59.174 | HD Request # 197 | Sending historical data logon request message. 2024-04-29 17:43:59.339 | HD Request # 197 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:43:59.392 | Socket (7) | CloseSocket call. 2024-04-29 17:43:59.392 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:43:59.392 | HD Request # 197 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:43:59.392 | Historical data download thread signaled to stop. 2024-04-29 17:43:59.392 | HD Request # 197 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:43:59.393 | HD Request # 197 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:43:59.393 | HD Request # 197 | Completion time: 0s. 2024-04-29 17:43:59.393 | HD Request # 197 | Intraday data download complete for ESM24-CME. Unique request ID: 197 2024-04-29 17:43:59.393 | Removing historical data download ID 197. 2024-04-29 17:43:59.393 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:43:59.393 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:43:59.393 | HD Request # 197 | Enabling Intraday chart updating for symbol. 2024-04-29 17:43:59.393 | 2024-04-29 17:43:59.393 | No download requests in the queue to start downloads for. 2024-04-29 17:43:59.447 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:43:59.447 | Socket (7) | Closed. 2024-04-29 17:44:01.152 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:44:01.152 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:44:01.153 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:01.153 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:44:01.153 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:01.205 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:44:01.205 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:44:01.205 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:44:01.205 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:44:01.369 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:44:01.369 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:44:01.369 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:44:01.369 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:44:01.369 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:44:01.369 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:44:01.369 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:44:01.369 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:44:01.369 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:44:01.369 | Triggering next historical data download in queue. 2024-04-29 17:44:01.369 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:44:01.369 | HD Request # 198 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:44:01.369 | HD Request # 198 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:01.369 | HD Request # 198 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:44:01.369 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:01.369 | Socket (7) | New receive buffer size: 0 2024-04-29 17:44:01.369 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:01.422 | HD Request # 198 | Sending historical data logon request message. 2024-04-29 17:44:01.422 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:44:01.422 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:44:01.422 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:44:01.422 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:44:01.422 | DTC Client socket (6) | Closed. 2024-04-29 17:44:01.423 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:44:01.423 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:44:01.423 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:44:01.591 | HD Request # 198 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:44:01.646 | Socket (7) | CloseSocket call. 2024-04-29 17:44:01.646 | HD Request # 198 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:44:01.646 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:44:01.646 | Historical data download thread signaled to stop. 2024-04-29 17:44:01.646 | HD Request # 198 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:44:01.647 | HD Request # 198 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:01.647 | HD Request # 198 | Completion time: 0s. 2024-04-29 17:44:01.647 | HD Request # 198 | Intraday data download complete for ESM24-CME. Unique request ID: 198 2024-04-29 17:44:01.647 | Removing historical data download ID 198. 2024-04-29 17:44:01.647 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:44:01.647 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:44:01.647 | HD Request # 198 | Enabling Intraday chart updating for symbol. 2024-04-29 17:44:01.647 | 2024-04-29 17:44:01.647 | No download requests in the queue to start downloads for. 2024-04-29 17:44:01.701 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:44:01.701 | Socket (7) | Closed. 2024-04-29 17:44:03.422 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:44:03.422 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:44:03.423 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:03.423 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:44:03.423 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:03.476 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:44:03.476 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:44:03.476 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:44:03.476 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:44:03.644 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:44:03.644 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:44:03.644 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:44:03.644 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:44:03.644 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:44:03.644 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:44:03.644 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:44:03.644 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:44:03.644 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:44:03.644 | Triggering next historical data download in queue. 2024-04-29 17:44:03.644 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:44:03.644 | HD Request # 199 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:44:03.644 | HD Request # 199 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:03.644 | HD Request # 199 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:44:03.644 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:03.644 | Socket (7) | New receive buffer size: 0 2024-04-29 17:44:03.644 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:03.696 | HD Request # 199 | Sending historical data logon request message. 2024-04-29 17:44:03.698 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:44:03.698 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:44:03.698 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:44:03.698 | DTC Client socket (6) | Closed. 2024-04-29 17:44:03.698 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:44:03.698 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:44:03.698 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:44:03.698 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:44:03.867 | HD Request # 199 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:44:03.919 | Socket (7) | CloseSocket call. 2024-04-29 17:44:03.919 | HD Request # 199 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:44:03.919 | Historical data download thread signaled to stop. 2024-04-29 17:44:03.919 | HD Request # 199 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:44:03.919 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:44:03.919 | HD Request # 199 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:03.919 | HD Request # 199 | Completion time: 0s. 2024-04-29 17:44:03.919 | HD Request # 199 | Intraday data download complete for ESM24-CME. Unique request ID: 199 2024-04-29 17:44:03.919 | Removing historical data download ID 199. 2024-04-29 17:44:03.919 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:44:03.919 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:44:03.919 | HD Request # 199 | Enabling Intraday chart updating for symbol. 2024-04-29 17:44:03.919 | 2024-04-29 17:44:03.919 | No download requests in the queue to start downloads for. 2024-04-29 17:44:03.972 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:44:03.972 | Socket (7) | Closed. 2024-04-29 17:44:05.693 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:44:05.693 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:44:05.694 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:05.694 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:44:05.694 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:05.746 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:44:05.746 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:44:05.746 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:44:05.746 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:44:05.910 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:44:05.910 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:44:05.910 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:44:05.910 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:44:05.910 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:44:05.910 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:44:05.910 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:44:05.910 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:44:05.910 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:44:05.910 | Triggering next historical data download in queue. 2024-04-29 17:44:05.910 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:44:05.910 | HD Request # 200 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:44:05.910 | HD Request # 200 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:05.910 | HD Request # 200 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:44:05.910 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:05.910 | Socket (7) | New receive buffer size: 0 2024-04-29 17:44:05.910 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:05.964 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:44:05.964 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:44:05.964 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:44:05.965 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:44:05.965 | DTC Client socket (6) | Closed. 2024-04-29 17:44:05.966 | HD Request # 200 | Sending historical data logon request message. 2024-04-29 17:44:05.966 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:44:05.966 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:44:05.966 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:44:06.132 | HD Request # 200 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:44:06.185 | Socket (7) | CloseSocket call. 2024-04-29 17:44:06.185 | HD Request # 200 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:44:06.185 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:44:06.185 | Historical data download thread signaled to stop. 2024-04-29 17:44:06.185 | HD Request # 200 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:44:06.186 | HD Request # 200 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:06.186 | HD Request # 200 | Completion time: 1s. 2024-04-29 17:44:06.186 | HD Request # 200 | Intraday data download complete for ESM24-CME. Unique request ID: 200 2024-04-29 17:44:06.186 | Removing historical data download ID 200. 2024-04-29 17:44:06.186 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:44:06.186 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:44:06.186 | HD Request # 200 | Enabling Intraday chart updating for symbol. 2024-04-29 17:44:06.186 | 2024-04-29 17:44:06.186 | No download requests in the queue to start downloads for. 2024-04-29 17:44:06.239 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:44:06.239 | Socket (7) | Closed. 2024-04-29 17:44:07.948 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:44:07.948 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:44:07.949 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:07.949 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:44:07.949 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:08.003 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:44:08.003 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:44:08.003 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:44:08.003 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:44:08.166 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:44:08.166 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:44:08.166 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:44:08.166 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:44:08.166 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:44:08.166 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:44:08.166 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:44:08.166 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:44:08.166 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:44:08.166 | Triggering next historical data download in queue. 2024-04-29 17:44:08.166 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:44:08.166 | HD Request # 201 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:44:08.166 | HD Request # 201 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:08.166 | HD Request # 201 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:44:08.166 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:08.166 | Socket (7) | New receive buffer size: 0 2024-04-29 17:44:08.166 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:08.219 | HD Request # 201 | Sending historical data logon request message. 2024-04-29 17:44:08.219 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:44:08.219 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:44:08.219 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:44:08.219 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:44:08.219 | DTC Client socket (6) | Closed. 2024-04-29 17:44:08.220 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:44:08.220 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:44:08.220 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:44:08.381 | HD Request # 201 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:44:08.436 | Socket (7) | CloseSocket call. 2024-04-29 17:44:08.436 | HD Request # 201 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:44:08.436 | Historical data download thread signaled to stop. 2024-04-29 17:44:08.436 | HD Request # 201 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:44:08.436 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:44:08.436 | HD Request # 201 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:08.436 | HD Request # 201 | Completion time: 0s. 2024-04-29 17:44:08.436 | HD Request # 201 | Intraday data download complete for ESM24-CME. Unique request ID: 201 2024-04-29 17:44:08.436 | Removing historical data download ID 201. 2024-04-29 17:44:08.436 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:44:08.436 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:44:08.436 | HD Request # 201 | Enabling Intraday chart updating for symbol. 2024-04-29 17:44:08.436 | 2024-04-29 17:44:08.436 | No download requests in the queue to start downloads for. 2024-04-29 17:44:08.492 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:44:08.492 | Socket (7) | Closed. 2024-04-29 17:44:10.219 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:44:10.219 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:44:10.219 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:10.219 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:44:10.219 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:10.272 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:44:10.272 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:44:10.272 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:44:10.272 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:44:10.441 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:44:10.441 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:44:10.441 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:44:10.441 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:44:10.441 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:44:10.441 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:44:10.441 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:44:10.441 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:44:10.441 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:44:10.441 | Triggering next historical data download in queue. 2024-04-29 17:44:10.441 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:44:10.441 | HD Request # 202 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:44:10.441 | HD Request # 202 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:10.441 | HD Request # 202 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:44:10.441 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:10.442 | Socket (7) | New receive buffer size: 0 2024-04-29 17:44:10.442 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:10.498 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:44:10.498 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:44:10.498 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:44:10.498 | HD Request # 202 | Sending historical data logon request message. 2024-04-29 17:44:10.498 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:44:10.498 | DTC Client socket (6) | Closed. 2024-04-29 17:44:10.498 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:44:10.498 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:44:10.498 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:44:10.665 | HD Request # 202 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:44:10.719 | Socket (7) | CloseSocket call. 2024-04-29 17:44:10.719 | HD Request # 202 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:44:10.719 | Historical data download thread signaled to stop. 2024-04-29 17:44:10.719 | HD Request # 202 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:44:10.719 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:44:10.719 | HD Request # 202 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:10.719 | HD Request # 202 | Completion time: 0s. 2024-04-29 17:44:10.719 | HD Request # 202 | Intraday data download complete for ESM24-CME. Unique request ID: 202 2024-04-29 17:44:10.719 | Removing historical data download ID 202. 2024-04-29 17:44:10.719 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:44:10.719 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:44:10.719 | HD Request # 202 | Enabling Intraday chart updating for symbol. 2024-04-29 17:44:10.719 | 2024-04-29 17:44:10.719 | No download requests in the queue to start downloads for. 2024-04-29 17:44:10.772 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:44:10.772 | Socket (7) | Closed. 2024-04-29 17:44:11.932 | The message log has been sent to support. * 2024-04-29 17:44:11.935 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:11.935 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (6) | New receive buffer size: 0 2024-04-29 17:44:11.935 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (6) | Connecting to IP: 38.142.170.158. 2024-04-29 17:44:12.488 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:44:12.488 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:44:12.489 | DTC Client socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:12.489 | DTC Client socket (7) | New receive buffer size: 0 2024-04-29 17:44:12.489 | DTC Client socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:12.542 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:44:12.542 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:44:12.542 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:44:12.542 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:44:12.703 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:44:12.703 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:44:12.703 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:44:12.703 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:44:12.703 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:44:12.703 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:44:12.703 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:44:12.703 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:44:12.703 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:44:12.703 | Triggering next historical data download in queue. 2024-04-29 17:44:12.703 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:44:12.703 | HD Request # 203 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:44:12.703 | HD Request # 203 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:12.703 | HD Request # 203 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:44:12.704 | Socket (8) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:12.704 | Socket (8) | New receive buffer size: 0 2024-04-29 17:44:12.704 | Socket (8) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:12.757 | DTC Client socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:44:12.757 | DTC Client socket (7) | CloseSocket call. 2024-04-29 17:44:12.757 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:44:12.757 | DTC Client socket (7) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:44:12.757 | DTC Client socket (7) | Closed. 2024-04-29 17:44:12.757 | HD Request # 203 | Sending historical data logon request message. 2024-04-29 17:44:12.757 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:44:12.757 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:44:12.757 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:44:12.821 | The Message Log was sent. Result: Message Log received. * 2024-04-29 17:44:12.920 | HD Request # 203 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:44:12.976 | Socket (8) | CloseSocket call. 2024-04-29 17:44:12.976 | Socket (8) | Shutdown started. Waiting for graceful close. 2024-04-29 17:44:12.978 | HD Request # 203 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:44:12.978 | Historical data download thread signaled to stop. 2024-04-29 17:44:12.978 | HD Request # 203 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:44:12.978 | HD Request # 203 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:12.978 | HD Request # 203 | Completion time: 0s. 2024-04-29 17:44:12.978 | HD Request # 203 | Intraday data download complete for ESM24-CME. Unique request ID: 203 2024-04-29 17:44:12.978 | Removing historical data download ID 203. 2024-04-29 17:44:12.978 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:44:12.978 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:44:12.978 | HD Request # 203 | Enabling Intraday chart updating for symbol. 2024-04-29 17:44:12.978 | 2024-04-29 17:44:12.978 | No download requests in the queue to start downloads for. 2024-04-29 17:44:13.030 | Socket (8) | Socket gracefully closed by remote side. 2024-04-29 17:44:13.030 | Socket (8) | Closed. 2024-04-29 17:44:13.069 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (6) | CloseSocket call. 2024-04-29 17:44:13.069 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (6) | Shutdown started. Waiting for graceful close. 2024-04-29 17:44:13.133 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (6) | Socket gracefully closed by remote side. 2024-04-29 17:44:13.133 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (6) | Closed. 2024-04-29 17:44:14.760 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:44:14.760 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:44:14.760 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:14.760 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:44:14.760 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:14.815 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:44:14.815 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:44:14.815 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:44:14.815 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:44:14.979 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:44:14.979 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:44:14.979 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:44:14.979 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:44:14.979 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:44:14.979 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:44:14.979 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:44:14.979 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:44:14.979 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:44:14.979 | Triggering next historical data download in queue. 2024-04-29 17:44:14.979 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:44:14.979 | HD Request # 204 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:44:14.979 | HD Request # 204 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:14.979 | HD Request # 204 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:44:14.979 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:14.979 | Socket (7) | New receive buffer size: 0 2024-04-29 17:44:14.979 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:15.034 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:44:15.034 | HD Request # 204 | Sending historical data logon request message. 2024-04-29 17:44:15.034 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:44:15.034 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:44:15.034 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:44:15.034 | DTC Client socket (6) | Closed. 2024-04-29 17:44:15.034 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:44:15.034 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:44:15.034 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:44:15.198 | HD Request # 204 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:44:15.253 | Socket (7) | CloseSocket call. 2024-04-29 17:44:15.253 | HD Request # 204 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:44:15.253 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:44:15.253 | Historical data download thread signaled to stop. 2024-04-29 17:44:15.253 | HD Request # 204 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:44:15.253 | HD Request # 204 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:15.253 | HD Request # 204 | Completion time: 1s. 2024-04-29 17:44:15.253 | HD Request # 204 | Intraday data download complete for ESM24-CME. Unique request ID: 204 2024-04-29 17:44:15.253 | Removing historical data download ID 204. 2024-04-29 17:44:15.253 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:44:15.253 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:44:15.253 | HD Request # 204 | Enabling Intraday chart updating for symbol. 2024-04-29 17:44:15.253 | 2024-04-29 17:44:15.253 | No download requests in the queue to start downloads for. 2024-04-29 17:44:15.307 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:44:15.307 | Socket (7) | Closed. 2024-04-29 17:44:17.037 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:44:17.037 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:44:17.038 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:17.038 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:44:17.038 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:17.093 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:44:17.093 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:44:17.093 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:44:17.093 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:44:17.258 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:44:17.258 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:44:17.258 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:44:17.258 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:44:17.258 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:44:17.258 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:44:17.258 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:44:17.258 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:44:17.258 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:44:17.258 | Triggering next historical data download in queue. 2024-04-29 17:44:17.258 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:44:17.258 | HD Request # 205 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:44:17.258 | HD Request # 205 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:17.258 | HD Request # 205 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:44:17.258 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:17.258 | Socket (7) | New receive buffer size: 0 2024-04-29 17:44:17.258 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:17.311 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:44:17.311 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:44:17.311 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:44:17.311 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:44:17.311 | DTC Client socket (6) | Closed. 2024-04-29 17:44:17.311 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:44:17.311 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:44:17.311 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:44:17.312 | HD Request # 205 | Sending historical data logon request message. 2024-04-29 17:44:17.474 | HD Request # 205 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:44:17.526 | Socket (7) | CloseSocket call. 2024-04-29 17:44:17.526 | HD Request # 205 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:44:17.526 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:44:17.526 | Historical data download thread signaled to stop. 2024-04-29 17:44:17.526 | HD Request # 205 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:44:17.526 | HD Request # 205 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:17.526 | HD Request # 205 | Completion time: 0s. 2024-04-29 17:44:17.526 | HD Request # 205 | Intraday data download complete for ESM24-CME. Unique request ID: 205 2024-04-29 17:44:17.526 | Removing historical data download ID 205. 2024-04-29 17:44:17.526 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:44:17.526 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:44:17.526 | HD Request # 205 | Enabling Intraday chart updating for symbol. 2024-04-29 17:44:17.526 | 2024-04-29 17:44:17.526 | No download requests in the queue to start downloads for. 2024-04-29 17:44:17.582 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:44:17.582 | Socket (7) | Closed. 2024-04-29 17:44:19.318 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:44:19.318 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:44:19.319 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:19.319 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:44:19.319 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:19.373 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:44:19.373 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:44:19.373 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:44:19.373 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:44:19.539 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:44:19.539 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:44:19.539 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:44:19.539 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:44:19.539 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:44:19.539 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:44:19.539 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:44:19.539 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:44:19.539 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:44:19.539 | Triggering next historical data download in queue. 2024-04-29 17:44:19.539 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:44:19.539 | HD Request # 206 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:44:19.539 | HD Request # 206 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:19.539 | HD Request # 206 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:44:19.539 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:19.539 | Socket (7) | New receive buffer size: 0 2024-04-29 17:44:19.540 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:19.593 | HD Request # 206 | Sending historical data logon request message. 2024-04-29 17:44:19.594 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:44:19.594 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:44:19.594 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:44:19.594 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:44:19.594 | DTC Client socket (6) | Closed. 2024-04-29 17:44:19.594 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:44:19.594 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:44:19.594 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:44:19.756 | HD Request # 206 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:44:19.808 | Socket (7) | CloseSocket call. 2024-04-29 17:44:19.809 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:44:19.809 | HD Request # 206 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:44:19.809 | Historical data download thread signaled to stop. 2024-04-29 17:44:19.809 | HD Request # 206 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:44:19.809 | HD Request # 206 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:19.809 | HD Request # 206 | Completion time: 0s. 2024-04-29 17:44:19.809 | HD Request # 206 | Intraday data download complete for ESM24-CME. Unique request ID: 206 2024-04-29 17:44:19.809 | Removing historical data download ID 206. 2024-04-29 17:44:19.809 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:44:19.809 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:44:19.809 | HD Request # 206 | Enabling Intraday chart updating for symbol. 2024-04-29 17:44:19.809 | 2024-04-29 17:44:19.809 | No download requests in the queue to start downloads for. 2024-04-29 17:44:19.862 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:44:19.862 | Socket (7) | Closed. 2024-04-29 17:44:21.574 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:44:21.574 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:44:21.574 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:21.574 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:44:21.574 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:21.627 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:44:21.627 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:44:21.627 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:44:21.627 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:44:21.795 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:44:21.795 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:44:21.795 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:44:21.795 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:44:21.795 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:44:21.795 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:44:21.795 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:44:21.795 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:44:21.795 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:44:21.795 | Triggering next historical data download in queue. 2024-04-29 17:44:21.795 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:44:21.795 | HD Request # 207 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:44:21.795 | HD Request # 207 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:21.795 | HD Request # 207 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:44:21.796 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:21.796 | Socket (7) | New receive buffer size: 0 2024-04-29 17:44:21.796 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:21.851 | HD Request # 207 | Sending historical data logon request message. 2024-04-29 17:44:21.852 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:44:21.852 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:44:21.853 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:44:21.853 | DTC Client socket (6) | Closed. 2024-04-29 17:44:21.854 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:44:21.855 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:44:21.855 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:44:21.855 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:44:22.016 | HD Request # 207 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:44:22.070 | Socket (7) | CloseSocket call. 2024-04-29 17:44:22.070 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:44:22.070 | HD Request # 207 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:44:22.070 | Historical data download thread signaled to stop. 2024-04-29 17:44:22.070 | HD Request # 207 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:44:22.071 | HD Request # 207 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:22.071 | HD Request # 207 | Completion time: 1s. 2024-04-29 17:44:22.071 | HD Request # 207 | Intraday data download complete for ESM24-CME. Unique request ID: 207 2024-04-29 17:44:22.071 | Removing historical data download ID 207. 2024-04-29 17:44:22.071 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:44:22.071 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:44:22.071 | HD Request # 207 | Enabling Intraday chart updating for symbol. 2024-04-29 17:44:22.071 | 2024-04-29 17:44:22.071 | No download requests in the queue to start downloads for. 2024-04-29 17:44:22.125 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:44:22.125 | Socket (7) | Closed. 2024-04-29 17:44:23.848 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:44:23.848 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:44:23.848 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:23.848 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:44:23.848 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:23.902 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:44:23.902 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:44:23.903 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:44:23.903 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:44:24.067 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:44:24.067 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:44:24.067 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:44:24.067 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:44:24.067 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:44:24.067 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:44:24.067 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:44:24.067 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:44:24.067 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:44:24.067 | Triggering next historical data download in queue. 2024-04-29 17:44:24.067 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:44:24.068 | HD Request # 208 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:44:24.068 | HD Request # 208 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:24.068 | HD Request # 208 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:44:24.068 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:24.069 | Socket (7) | New receive buffer size: 0 2024-04-29 17:44:24.069 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:24.122 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:44:24.122 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:44:24.122 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:44:24.122 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:44:24.122 | DTC Client socket (6) | Closed. 2024-04-29 17:44:24.122 | HD Request # 208 | Sending historical data logon request message. 2024-04-29 17:44:24.122 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:44:24.122 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:44:24.122 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:44:24.288 | HD Request # 208 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:44:24.339 | Socket (7) | CloseSocket call. 2024-04-29 17:44:24.339 | HD Request # 208 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:44:24.339 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:44:24.339 | Historical data download thread signaled to stop. 2024-04-29 17:44:24.339 | HD Request # 208 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:44:24.339 | HD Request # 208 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:24.339 | HD Request # 208 | Completion time: 0s. 2024-04-29 17:44:24.339 | HD Request # 208 | Intraday data download complete for ESM24-CME. Unique request ID: 208 2024-04-29 17:44:24.339 | Removing historical data download ID 208. 2024-04-29 17:44:24.339 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:44:24.339 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:44:24.339 | HD Request # 208 | Enabling Intraday chart updating for symbol. 2024-04-29 17:44:24.339 | 2024-04-29 17:44:24.339 | No download requests in the queue to start downloads for. 2024-04-29 17:44:24.394 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:44:24.394 | Socket (7) | Closed. 2024-04-29 17:44:26.110 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:44:26.110 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:44:26.110 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:26.110 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:44:26.110 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:26.164 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:44:26.164 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:44:26.164 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:44:26.164 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:44:26.331 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:44:26.331 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:44:26.331 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:44:26.331 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:44:26.331 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:44:26.331 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:44:26.331 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:44:26.332 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:44:26.332 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:44:26.332 | Triggering next historical data download in queue. 2024-04-29 17:44:26.332 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:44:26.332 | HD Request # 209 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:44:26.332 | HD Request # 209 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:26.332 | HD Request # 209 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:44:26.332 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:26.332 | Socket (7) | New receive buffer size: 0 2024-04-29 17:44:26.332 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:26.388 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:44:26.388 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:44:26.388 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:44:26.388 | HD Request # 209 | Sending historical data logon request message. 2024-04-29 17:44:26.388 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:44:26.388 | DTC Client socket (6) | Closed. 2024-04-29 17:44:26.389 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:44:26.389 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:44:26.389 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:44:26.556 | HD Request # 209 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:44:26.610 | Socket (7) | CloseSocket call. 2024-04-29 17:44:26.610 | HD Request # 209 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:44:26.610 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:44:26.610 | Historical data download thread signaled to stop. 2024-04-29 17:44:26.610 | HD Request # 209 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:44:26.611 | HD Request # 209 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:26.611 | HD Request # 209 | Completion time: 0s. 2024-04-29 17:44:26.611 | HD Request # 209 | Intraday data download complete for ESM24-CME. Unique request ID: 209 2024-04-29 17:44:26.611 | Removing historical data download ID 209. 2024-04-29 17:44:26.611 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:44:26.611 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:44:26.611 | HD Request # 209 | Enabling Intraday chart updating for symbol. 2024-04-29 17:44:26.611 | 2024-04-29 17:44:26.611 | No download requests in the queue to start downloads for. 2024-04-29 17:44:26.666 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:44:26.666 | Socket (7) | Closed. 2024-04-29 17:44:28.383 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:44:28.383 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:44:28.383 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:28.383 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:44:28.383 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:28.440 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:44:28.440 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:44:28.440 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:44:28.440 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:44:28.609 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:44:28.609 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:44:28.609 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:44:28.609 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:44:28.609 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:44:28.609 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:44:28.609 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:44:28.609 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:44:28.609 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:44:28.609 | Triggering next historical data download in queue. 2024-04-29 17:44:28.609 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:44:28.609 | HD Request # 210 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:44:28.609 | HD Request # 210 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:28.609 | HD Request # 210 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:44:28.609 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:28.609 | Socket (7) | New receive buffer size: 0 2024-04-29 17:44:28.609 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:28.663 | HD Request # 210 | Sending historical data logon request message. 2024-04-29 17:44:28.664 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:44:28.664 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:44:28.664 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:44:28.664 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:44:28.664 | DTC Client socket (6) | Closed. 2024-04-29 17:44:28.665 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:44:28.665 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:44:28.665 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:44:28.832 | HD Request # 210 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:44:28.884 | Socket (7) | CloseSocket call. 2024-04-29 17:44:28.884 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:44:28.884 | HD Request # 210 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:44:28.885 | Historical data download thread signaled to stop. 2024-04-29 17:44:28.885 | HD Request # 210 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:44:28.885 | HD Request # 210 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:28.885 | HD Request # 210 | Completion time: 0s. 2024-04-29 17:44:28.885 | HD Request # 210 | Intraday data download complete for ESM24-CME. Unique request ID: 210 2024-04-29 17:44:28.885 | Removing historical data download ID 210. 2024-04-29 17:44:28.885 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:44:28.885 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:44:28.885 | HD Request # 210 | Enabling Intraday chart updating for symbol. 2024-04-29 17:44:28.885 | 2024-04-29 17:44:28.885 | No download requests in the queue to start downloads for. 2024-04-29 17:44:28.939 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:44:28.939 | Socket (7) | Closed. 2024-04-29 17:44:30.655 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:44:30.655 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:44:30.656 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:30.656 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:44:30.656 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:30.709 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:44:30.709 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:44:30.709 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:44:30.709 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:44:30.874 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:44:30.874 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:44:30.874 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:44:30.874 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:44:30.874 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:44:30.874 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:44:30.874 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:44:30.874 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:44:30.874 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:44:30.874 | Triggering next historical data download in queue. 2024-04-29 17:44:30.874 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:44:30.874 | HD Request # 211 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:44:30.874 | HD Request # 211 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:30.874 | HD Request # 211 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:44:30.874 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:30.874 | Socket (7) | New receive buffer size: 0 2024-04-29 17:44:30.874 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:30.927 | HD Request # 211 | Sending historical data logon request message. 2024-04-29 17:44:30.927 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:44:30.927 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:44:30.927 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:44:30.927 | DTC Client socket (6) | Closed. 2024-04-29 17:44:30.927 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:44:30.928 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:44:30.928 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:44:30.928 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:44:31.093 | HD Request # 211 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:44:31.147 | Socket (7) | CloseSocket call. 2024-04-29 17:44:31.147 | HD Request # 211 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:44:31.147 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:44:31.147 | Historical data download thread signaled to stop. 2024-04-29 17:44:31.147 | HD Request # 211 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:44:31.147 | HD Request # 211 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:31.147 | HD Request # 211 | Completion time: 1s. 2024-04-29 17:44:31.147 | HD Request # 211 | Intraday data download complete for ESM24-CME. Unique request ID: 211 2024-04-29 17:44:31.147 | Removing historical data download ID 211. 2024-04-29 17:44:31.147 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:44:31.147 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:44:31.147 | HD Request # 211 | Enabling Intraday chart updating for symbol. 2024-04-29 17:44:31.147 | 2024-04-29 17:44:31.147 | No download requests in the queue to start downloads for. 2024-04-29 17:44:31.203 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:44:31.203 | Socket (7) | Closed. 2024-04-29 17:44:32.926 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:44:32.926 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:44:32.927 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:32.927 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:44:32.927 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:32.982 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:44:32.982 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:44:32.982 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:44:32.982 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:44:33.148 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:44:33.148 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:44:33.148 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:44:33.148 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:44:33.148 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:44:33.148 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:44:33.148 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:44:33.148 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:44:33.148 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:44:33.148 | Triggering next historical data download in queue. 2024-04-29 17:44:33.148 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:44:33.148 | HD Request # 212 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:44:33.148 | HD Request # 212 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:33.148 | HD Request # 212 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:44:33.148 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:33.148 | Socket (7) | New receive buffer size: 0 2024-04-29 17:44:33.148 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:33.203 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:44:33.203 | HD Request # 212 | Sending historical data logon request message. 2024-04-29 17:44:33.203 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:44:33.203 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:44:33.203 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:44:33.203 | DTC Client socket (6) | Closed. 2024-04-29 17:44:33.203 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:44:33.203 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:44:33.203 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:44:33.366 | HD Request # 212 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:44:33.419 | Socket (7) | CloseSocket call. 2024-04-29 17:44:33.419 | HD Request # 212 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:44:33.419 | Historical data download thread signaled to stop. 2024-04-29 17:44:33.419 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:44:33.419 | HD Request # 212 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:44:33.419 | HD Request # 212 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:33.419 | HD Request # 212 | Completion time: 0s. 2024-04-29 17:44:33.419 | HD Request # 212 | Intraday data download complete for ESM24-CME. Unique request ID: 212 2024-04-29 17:44:33.419 | Removing historical data download ID 212. 2024-04-29 17:44:33.419 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:44:33.419 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:44:33.419 | HD Request # 212 | Enabling Intraday chart updating for symbol. 2024-04-29 17:44:33.419 | 2024-04-29 17:44:33.419 | No download requests in the queue to start downloads for. 2024-04-29 17:44:33.472 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:44:33.472 | Socket (7) | Closed. 2024-04-29 17:44:35.185 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-29 17:44:35.186 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-29 17:44:35.186 | DTC Client socket (6) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:35.186 | DTC Client socket (6) | New receive buffer size: 0 2024-04-29 17:44:35.186 | DTC Client socket (6) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:35.241 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-29 17:44:35.241 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-29 17:44:35.241 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-29 17:44:35.241 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-29 17:44:35.404 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-29 17:44:35.404 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-29 17:44:35.404 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-29 17:44:35.404 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-29 17:44:35.404 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-29 17:44:35.404 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-29 17:44:35.404 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-29 17:44:35.405 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-29 17:44:35.405 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-29 17:44:35.405 | Triggering next historical data download in queue. 2024-04-29 17:44:35.405 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-29 17:44:35.405 | HD Request # 213 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-29 17:44:35.405 | HD Request # 213 | Download start date-time: 2024-04-26 00:19:36.000000. File last date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:35.405 | HD Request # 213 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-29 17:44:35.405 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-29 17:44:35.405 | Socket (7) | New receive buffer size: 0 2024-04-29 17:44:35.405 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-29 17:44:35.459 | HD Request # 213 | Sending historical data logon request message. 2024-04-29 17:44:35.460 | DTC Client socket (6) | Socket gracefully closed by remote side. 2024-04-29 17:44:35.460 | DTC Client socket (6) | CloseSocket call. 2024-04-29 17:44:35.460 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-29 17:44:35.460 | DTC Client socket (6) | Closed. 2024-04-29 17:44:35.460 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-29 17:44:35.461 | DTC Client socket (0) | CloseSocket call. 2024-04-29 17:44:35.461 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-29 17:44:35.461 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-29 17:44:35.622 | HD Request # 213 | Requesting Intraday data. Start date-time: 2024-04-26 00:19:36. Record interval: 0. Symbol: ESM24-CME 2024-04-29 17:44:35.676 | Socket (7) | CloseSocket call. 2024-04-29 17:44:35.676 | HD Request # 213 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-29 17:44:35.676 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-29 17:44:35.676 | Historical data download thread signaled to stop. 2024-04-29 17:44:35.676 | HD Request # 213 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-29 17:44:35.677 | HD Request # 213 | Add time&sales data | Remembered last file record date-time: 2024-04-26 00:19:36.101004 2024-04-29 17:44:35.677 | HD Request # 213 | Completion time: 0s. 2024-04-29 17:44:35.677 | HD Request # 213 | Intraday data download complete for ESM24-CME. Unique request ID: 213 2024-04-29 17:44:35.677 | Removing historical data download ID 213. 2024-04-29 17:44:35.677 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-29 17:44:35.677 | Intraday chart data file opened for ESM24-CME 2024-04-29 17:44:35.677 | HD Request # 213 | Enabling Intraday chart updating for symbol. 2024-04-29 17:44:35.677 | 2024-04-29 17:44:35.677 | No download requests in the queue to start downloads for. 2024-04-29 17:44:35.733 | Socket (7) | Socket gracefully closed by remote side. 2024-04-29 17:44:35.733 | Socket (7) | Closed. |
[2024-04-29 18:37:21] |
John - SC Support - Posts: 31509 |
We do not know why, but Rithmic keeps disconnecting. The only thing we can suggest is to try a different server and see if that works better for you.
[2024-04-30 01:40:16] |
coachted - Posts: 286 |
is there a way to automatically combine trades in the trades widow...for exampple in the attached file the last 2 trades were the same exact trade at the same exact time....i know i scaled out but this is essentially one trade...
Screenshot 2024-04-29 213937.png / V - Attached On 2024-04-30 01:39:55 UTC - Size: 42.27 KB - 10 views |
[2024-04-30 15:06:59] |
There is not a way to combine trades as you are asking. The notation of BP (Begin Position) and EP (End Position) give you the information of the fact that these trades were opened and closed together.
