Date/Time: Fri, 10 May 2024 19:16:28 +0000
Alerts
View Count: 962
[2024-02-26 18:14:35] |
John - SC Support - Posts: 31533 |
With regards to the delta of 418, please get us that chart and tell us the date and time when you see that value and the Time Zone setting for the chart (if it is set to Use Global Time Zone, then we need to know your Global Time Zone). Refer to the following for how to get us a chart: Support Board Posting Information: Providing Chartbook with Only a Single Chart With regards to performance, refer to the following: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-27 14:53:23] |
coachted - Posts: 286 |
So I literally made a copy of the dom chart i have, which is running very very slow.... using the "duplicated chart chartbook" function and saved the new chartbook as " DOM TEST". I then opened a new instance and opened the "DOM TEST" in the new instance....this way all settings are exactly the same...and yet the delta still is completely different...I have included a video here for your review..it includes a look at the chart settings...which are identical...the studies are identical...you will also notice the difference in perfomrance...I am running a 16 core 13th gen intel i7 13700k processor with 64 k of memory with an ssd drive....more than suggested by SC and I have terrible perfomance...I am also including a picture of my perfomance tab from task manager.
Private File Screenshot 2024-02-27 095131.png / V - Attached On 2024-02-27 14:53:18 UTC - Size: 46.42 KB - 35 views |
[2024-02-27 15:45:16] |
attached please find a copy of the dom i called dom test.... the dom on the right is opened in a seperate instance....you can see here at the high of the day the total volume traded is missing in the dom also you can see the total volume, the gold numbers is different than the dom on the left....which is opened in my primary chartbook...this goes on for many instances down the dom...this was a new high first time up there since 930 am and the chart time session is 9:30 - 16:59:59 on both charts....the same scenario happens at the low of the day....the delat does not make snese on the2nd instance dom...note the current bid and current ask...the last two colums match the total current volume matches...the second colum from the left...in gold...but notice the delta the first column...is completely wrong
Date Time Of Last Edit: 2024-02-27 16:03:05
Screenshot 2024-02-27 104037.png / V - Attached On 2024-02-27 15:44:54 UTC - Size: 342.68 KB - 37 views DOM TEST.Cht - Attached On 2024-02-27 15:45:47 UTC - Size: 5.34 KB - 42 views Screenshot 2024-02-27 110027.png / V - Attached On 2024-02-27 16:02:58 UTC - Size: 287.34 KB - 34 views |
[2024-02-27 15:47:57] |
attached is my main chartbook just incase you need it
NQ.Cht - Attached On 2024-02-27 15:47:43 UTC - Size: 156.21 KB - 104 views |
[2024-02-27 16:06:59] |
I just opened a 3rd instance and loaded the same DOM Test chartbook and it matches the DOM in my main chartbook...this is bizarre.
Date Time Of Last Edit: 2024-02-27 16:10:10
Screenshot 2024-02-27 110642.png / V - Attached On 2024-02-27 16:06:52 UTC - Size: 393.34 KB - 35 views |
[2024-02-27 17:26:56] |
We need to deal with one issue at a time. Right now, let's deal with the delta that you state is incorrect. We assume the DOM TEST.cht is the chartbook that shows this issue. We need to know the exact date and time when that value showed in your DOM.
[2024-03-22 20:43:43] |
Is there a way to color the volume in the numbers bars like i have in the Volume profile...please see attached,,,the numbers bars is a ask vol bid vol diff...i cant figure out the text coloring method...
Screenshot 2024-03-22 164017.png / V - Attached On 2024-03-22 20:42:02 UTC - Size: 80.55 KB - 33 views |
[2024-03-22 23:03:47] |
Exactly which coloring option are you using. We need the exact name.
[2024-04-04 18:32:52] |
I have an alert going off constiantly but when i look in the alert manager there is nothing to tell me where the alert is coming from can you please advise
[2024-04-04 21:32:11] |
There are multiple pages on the "Alert Manager". Open the Alert Manager by selecting "Window >> Alert Manager" which will default to showing you the "Log" page, which is where any Study alert is shown. There are also tabs for "Symbol Alert" and "Time Alert". Be sure to check these to see if the alert you are getting is related to one of these. Refer to the following: Alerts Manager For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-22 22:50:03] |
I am thinking about trying a funded trader account with TOpstep and have a few questions.....Can i use my current Edge pro account and then copy the trades to the tryout accounts? oOr do I have to have a Sim Account copy trades to the tryout accounts...Id like to still trade live in my Edge pro account and copy those trades into the tryout accounts is this possible?
[2024-04-23 14:33:54] |
The answer to all the questions is "No", you can not do this with our built-in tools. The "Order Allocation to Trade Accounts" only works with accounts that are available under a single login. So you can not copy trades from your live account to a TopStep account. What you can do, is if you have multiple TopStep accounts that are accessible under a single login, then you can copy the trades between those accounts. Refer to the information for our "Order Allocation to Trade Accounts" at the following link: Order Allocation to Trade Accounts We have seen posts that there is a third party that has a tool that can copy trades between services. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-23 15:02:40] |
can i switch my data for my real account to rithmic and would that permit me to trade a live account and copy to topstep tryout account?
[2024-04-23 16:08:24] |
This has nothing to do with the data. We do not have a way to copy trades between different connections. When using Sierra Chart, a single installation is connected to a single trading service. If you have multiple trading accounts under that trading service, then you can copy the trades between those accounts. But if the accounts are at different brokerages, or require different logins, then you can not have a single Sierra Chart connected to those accounts, therefore the trade copying does not work in this case. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-23 18:39:19] |
I found this from a 3rd party service "It has been explained numerous times, It doesn’t matter what accounts you have or which trading service you use. The concept is explained on this page. You can setup a transmitter from one SC installation and a receiver study on a chart from another SC installation running a different trade service configuration. There is a video on this page and there is the study documentation inside SC. That should be enough to get started." So my question is do I have to install Sierra charts again, ie have 2 versions of SC open and set one version to Rithmic and one version to Teton? |
[2024-04-23 19:33:16] |
We can only answer from our perspective, which is that you need to have two installations of Sierra Chart in order to trade two different accounts. Where one installation is connected to your Teton account and the other installation is connected to your Rithmic account. We can not speak for how the 3rd party software works. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-24 22:46:56] |
Below please find my message log from my connection with Rithmic, I have noticed keeps stating "2024-04-24 22:45:45.538 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds." Can you please advise why it keeps dosconnecting. 2024-04-24 22:38:30.302 | Trade activity files set size: 4 2024-04-24 22:38:30.341 | Reading Internal Order ID file. 2024-04-24 22:38:30.355 | Reading Trade Orders file. 2024-04-24 22:38:30.356 | Reading Trade Positions file. 2024-04-24 22:38:30.356 | Reading Trade Account Data files. 2024-04-24 22:38:30.358 | Software version: 2629 64-bit 2024-04-24 22:38:30.358 | Primary Thread ID: 14664 2024-04-24 22:38:30.358 | Usage end date: 2024-05-16 2024-04-24 22:38:30.358 | Enabled for: Advanced Features 2. 2024-04-24 22:38:30.358 | Enabled for: Sierra Chart Historical Data Service. 2024-04-24 22:38:30.358 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-04-24 22:38:30.358 | Enabled for: Delayed Denali Exchange Data Feed. 2024-04-24 22:38:30.358 | Enabled for exchange2: CME (Trading Account Required) 2024-04-24 22:38:30.358 | Enabled for exchange2: CBOT (Trading Account Required) 2024-04-24 22:38:30.358 | Enabled for exchange2: COMEX (Trading Account Required) 2024-04-24 22:38:30.358 | Enabled for exchange2: NYMEX (Trading Account Required) 2024-04-24 22:38:30.358 | Enabled for exchange2: NASDAQ Global Indexes 2024-04-24 22:38:30.358 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-04-24 22:38:30.358 | Current selected Data/Trading service: Rithmic Direct - DTC 2024-04-24 22:38:30.358 | Custom symbol settings values: enabled 2024-04-24 22:38:30.358 | Chart Update Interval: 400 2024-04-24 22:38:30.358 | Intraday Data Storage Time Unit: 0 2024-04-24 22:38:30.358 | Time Zone: +00:00:00 (UTC+00) 2024-04-24 22:38:30.358 | 2024-04-24 22:38:30 Local computer time in UTC 2024-04-24 22:38:30.358 | 2024-04-24 22:38:30 Local computer time in SC Time Zone 2024-04-24 22:38:30.358 | 2024-04-24 22:38:29 Server time in UTC 2024-04-24 22:38:30.358 | Local computer UTC time and Server UTC time difference: 1 seconds. 2024-04-24 22:38:30.358 | Program path: C:\SierraChart2\ 2024-04-24 22:38:30.358 | Data Files path: C:\SierraChart2\Data\ 2024-04-24 22:38:30.358 | OS Version Number: 10.0 2024-04-24 22:38:30.358 | Locale Setting: C 2024-04-24 22:38:30.359 | DLLs: OrderFlowLabs.com.free_64.dll, OrderFlowLabs.com.free_ARM64.dll, Smaug_SC_Library_64.dll, sst_FreeBundle_64.dll, SST_LocalCopier_64.dll, UserContributedStudies_64.dll 2024-04-24 22:38:30.359 | Allowed protected custom studies: OrderFlowLabs.com FREE, Smaug_SC_Library, SST_FreeBundle, SST_LocalCopier 2024-04-24 22:38:30.359 | Crash reporter started: true 2024-04-24 22:38:30.359 | 2024-04-24 22:38:30.373 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. 2024-04-24 22:38:30.416 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:38:30.416 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0 2024-04-24 22:38:30.416 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 38.79.0.89. 2024-04-24 22:38:30.420 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2024-04-24 22:38:30.485 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2024-04-24 22:38:30.485 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2024-04-24 22:38:30.592 | Received 5 login tokens. 2024-04-24 22:38:30.708 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | Number times message added: 1 2024-04-24 22:38:30.711 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | CloseSocket call. 2024-04-24 22:38:30.711 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:38:30.711 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Closed. 2024-04-24 22:38:30.989 | Symbol settings MD5 received. Request ID: 1. 2024-04-24 22:38:30.989 | Requested symbol settings for service code rithmic_v2.trading. Request ID: 2. 2024-04-24 22:38:31.741 | Symbol settings received. Request ID: 2. 2024-04-24 22:38:32.863 | Requested user files to download. 2024-04-24 22:38:33.301 | Downloading user file: 63779 2024-04-24 22:38:33.999 | File has been written to: C:\SierraChart2\Data\SST_LocalCopier_64.dll. File Size: 1298432 bytes. 2024-04-24 22:38:34.016 | User files to download complete 2024-04-24 22:38:34.868 | 2024-04-24 22:38:34.869 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:38:34.870 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508 2024-04-24 22:38:35.724 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-04-24 22:38:35.724 | DTC Client socket (1) | New receive buffer size: 0 2024-04-24 22:38:35.724 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-04-24 22:38:35.779 | Rithmic Direct - DTC | Network connection to server complete. 2024-04-24 22:38:35.779 | Rithmic Direct - DTC | Starting socket receive thread. 2024-04-24 22:38:35.779 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-04-24 22:38:35.779 | Rithmic Direct - DTC | Sending logon request message. 2024-04-24 22:38:35.944 | Rithmic Direct - DTC | Received logon response. 2024-04-24 22:38:35.944 | Rithmic Direct - DTC | Server Name: . 2024-04-24 22:38:35.944 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:38:35.944 | Rithmic Direct - DTC | Successfully connected. 2024-04-24 22:38:35.944 | Rithmic Direct - DTC | Trading is supported. 2024-04-24 22:38:35.944 | Rithmic Direct - DTC | Order cancel and replace is supported. 2024-04-24 22:38:35.944 | Rithmic Direct - DTC | OCO Orders supported. 2024-04-24 22:38:35.944 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2024-04-24 22:38:35.944 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2024-04-24 22:38:35.944 | Rithmic Direct - DTC | Connected to server complete. 2024-04-24 22:38:35.945 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-04-24 22:38:38.082 | Files to Open on Startup | Opening file: ExampleChartbook.cht 2024-04-24 22:38:38.098 | XAUUSD 1 Min #1 | Reloading chart. 2024-04-24 22:38:38.109 | XAUUSD Daily #2 | Reloading chart. 2024-04-24 22:38:38.123 | US30 1 Min #3 | Reloading chart. 2024-04-24 22:38:38.146 | USOil 1 Min #4 | Reloading chart. 2024-04-24 22:38:38.158 | ESM24-CME 1 Min #5 | Reloading chart. 2024-04-24 22:38:38.173 | SPX500 Daily #6 | Reloading chart. 2024-04-24 22:38:38.186 | EURUSD Daily #7 | Reloading chart. 2024-04-24 22:38:38.200 | EURUSD 5 Min #8 | Reloading chart. 2024-04-24 22:38:38.226 | ESM24-CME #9 | Reloading chart. 2024-04-24 22:38:38.380 | ESM24-CME 1 Min #10 | Reloading chart. 2024-04-24 22:38:38.392 | AAPL-NQTV 5 Min #11 | Reloading chart. 2024-04-24 22:38:38.404 | SPY 1 Min #12 | Reloading chart. 2024-04-24 22:38:38.543 | ESM24-CME #13 | Reloading chart. 2024-04-24 22:38:38.544 | ESM24-CME #13 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-04-24 22:38:38.555 | ESM24-CME #13 | Chart data loading complete. 2024-04-24 22:38:38.587 | XAUUSD Daily #2 | Chart data loading complete. 2024-04-24 22:38:38.590 | USOil 1 Min #4 | Chart data loading complete. 2024-04-24 22:38:38.591 | SPX500 Daily #6 | Chart data loading complete. 2024-04-24 22:38:38.592 | EURUSD Daily #7 | Chart data loading complete. 2024-04-24 22:38:38.594 | ESM24-CME 1 Min #5 | Chart data loading complete. 2024-04-24 22:38:38.596 | US30 1 Min #3 | Chart data loading complete. 2024-04-24 22:38:38.597 | XAUUSD 1 Min #1 | Chart data loading complete. 2024-04-24 22:38:38.615 | ESM24-CME #9 | Chart data loading complete. 2024-04-24 22:38:38.616 | EURUSD 5 Min #8 | Chart data loading complete. 2024-04-24 22:38:38.618 | ESM24-CME 1 Min #10 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-04-24 22:38:38.619 | ESM24-CME 1 Min #10 | Chart data loading complete. 2024-04-24 22:38:38.620 | AAPL-NQTV 5 Min #11 | Chart data loading complete. 2024-04-24 22:38:38.621 | SPY 1 Min #12 | Chart data loading complete. 2024-04-24 22:38:38.653 | Starting DelayedDownloadMonitoringTimer 2024-04-24 22:38:38.653 | Starting HDTimeoutTimer 2024-04-24 22:38:38.653 | Added historical Daily data request for XAUUSD to the queue. 2024-04-24 22:38:38.654 | Triggering next historical data download in queue. 2024-04-24 22:38:38.654 | Using Bid/Ask average for last trade price for XAUUSD 2024-04-24 22:38:38.654 | Using symbol data fast lookup vector 2024-04-24 22:38:38.654 | SC Data with Depth | Starting real-time market data updates for: XAUUSD. ID: 1 Service code: fxcm 2024-04-24 22:38:38.656 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 2024-04-24 22:38:38.658 | SC Data with Depth | Requesting security definition data for: XAUUSD. ID: 1 2024-04-24 22:38:38.659 | HD Request # 1 | Downloading Historical Daily chart data for XAUUSD. Starting date: 2024-04-22. Service: fxcm 2024-04-24 22:38:38.659 | HD Request # 1 | Using server: ds12.sierracharts.com port 10149 2024-04-24 22:38:38.660 | Added historical Intraday data request for XAUUSD to the queue. 2024-04-24 22:38:38.660 | Intraday data recording state for symbol XAUUSD is set to download 'Pending'. 2024-04-24 22:38:38.660 | Triggering next historical data download in queue. 2024-04-24 22:38:38.662 | Using Bid/Ask average for last trade price for US30 2024-04-24 22:38:38.662 | SC Data with Depth | Starting real-time market data updates for: US30. ID: 2 Service code: fxcm 2024-04-24 22:38:38.662 | SC Data with Depth | Requesting security definition data for: US30. ID: 2 2024-04-24 22:38:38.662 | Added historical Intraday data request for US30 to the queue. 2024-04-24 22:38:38.662 | Intraday data recording state for symbol US30 is set to download 'Pending'. 2024-04-24 22:38:38.662 | Triggering next historical data download in queue. 2024-04-24 22:38:38.662 | Rithmic Direct - DTC | Starting real-time market data updates for: ESM24-CME. ID: 3 2024-04-24 22:38:38.664 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:38:38.665 | Rithmic Direct - DTC | Requesting security definition data for: ESM24-CME. ID: 3 2024-04-24 22:38:38.666 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:38:38.666 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:38:38.666 | Triggering next historical data download in queue. 2024-04-24 22:38:38.673 | Using Bid/Ask average for last trade price for USOil 2024-04-24 22:38:38.673 | SC Data with Depth | Starting real-time market data updates for: USOil. ID: 4 Service code: fxcm 2024-04-24 22:38:38.673 | SC Data with Depth | Requesting security definition data for: USOil. ID: 4 2024-04-24 22:38:38.673 | Added historical Intraday data request for USOil to the queue. 2024-04-24 22:38:38.673 | Intraday data recording state for symbol USOil is set to download 'Pending'. 2024-04-24 22:38:38.673 | Triggering next historical data download in queue. 2024-04-24 22:38:38.673 | Added historical Daily data request for SPX500 to the queue. 2024-04-24 22:38:38.673 | Triggering next historical data download in queue. 2024-04-24 22:38:38.673 | Using Bid/Ask average for last trade price for SPX500 2024-04-24 22:38:38.673 | SC Data with Depth | Starting real-time market data updates for: SPX500. ID: 5 Service code: fxcm 2024-04-24 22:38:38.673 | SC Data with Depth | Requesting security definition data for: SPX500. ID: 5 2024-04-24 22:38:38.674 | Added historical Daily data request for EURUSD to the queue. 2024-04-24 22:38:38.674 | Triggering next historical data download in queue. 2024-04-24 22:38:38.674 | Using Bid/Ask average for last trade price for EURUSD 2024-04-24 22:38:38.674 | SC Data with Depth | Starting real-time market data updates for: EURUSD. ID: 6 Service code: fxcm 2024-04-24 22:38:38.674 | SC Data with Depth | Requesting security definition data for: EURUSD. ID: 6 2024-04-24 22:38:38.674 | Added historical Intraday data request for EURUSD to the queue. 2024-04-24 22:38:38.674 | Intraday data recording state for symbol EURUSD is set to download 'Pending'. 2024-04-24 22:38:38.674 | Triggering next historical data download in queue. 2024-04-24 22:38:38.676 | DTC Client socket (2) | Creating socket. 2024-04-24 22:38:38.676 | DTC Client socket (2) | New receive buffer size: 0 2024-04-24 22:38:38.676 | DTC Client socket (2) | Connecting to IP: 38.103.112.181. 2024-04-24 22:38:38.676 | Socket (3) | Creating socket. 2024-04-24 22:38:38.676 | Socket (3) | New receive buffer size: 0 2024-04-24 22:38:38.676 | Socket (3) | Connecting to IP: 38.103.112.181. 2024-04-24 22:38:38.676 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:38:38.676 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:38:38.676 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:38:38.716 | SC Data with Depth | Network connection to server complete. 2024-04-24 22:38:38.716 | SC Data with Depth | Starting socket receive thread. 2024-04-24 22:38:38.716 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2024-04-24 22:38:38.730 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:38:38.730 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:38:38.730 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:38:38.730 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:38:38.767 | SC Data with Depth | Setting DTC encoding to Binary VLS 2024-04-24 22:38:38.767 | SC Data with Depth | Sending logon request message. 2024-04-24 22:38:38.770 | HD Request # 1 | Setting DTC encoding to Binary VLS 2024-04-24 22:38:38.770 | HD Request # 1 | Sending historical data logon request message. 2024-04-24 22:38:38.785 | Mapping AAPL-NQTV to AAPL-NQTV. Service code: nasdaq_exchange.data 2024-04-24 22:38:38.785 | Delayed Data Feed | Starting real-time market data updates for: AAPL-NQTV (AAPL-NQTV). ID: 7 Service code: nasdaq_exchange.data 2024-04-24 22:38:38.787 | Delayed Data Feed | Connecting to the server ds31.sierracharts.com. Port 10043 2024-04-24 22:38:38.789 | Delayed Data Feed | Requesting security definition data for: AAPL-NQTV (AAPL-NQTV). ID: 7 2024-04-24 22:38:38.789 | Added historical Intraday data request for AAPL-NQTV to the queue. 2024-04-24 22:38:38.789 | Intraday data recording state for symbol AAPL-NQTV is set to download 'Pending'. 2024-04-24 22:38:38.789 | Triggering next historical data download in queue. 2024-04-24 22:38:38.801 | Mapping SPY to SPY. Service code: us_equities_utp_cta_exchange.data 2024-04-24 22:38:38.801 | Delayed Data Feed | Starting real-time market data updates for: SPY (SPY). ID: 8 Service code: us_equities_utp_cta_exchange.data 2024-04-24 22:38:38.802 | Delayed Data Feed | Connecting to the server ds3.sierracharts.com. Port 10043 2024-04-24 22:38:38.804 | Delayed Data Feed | Requesting security definition data for: SPY (SPY). ID: 8 2024-04-24 22:38:38.804 | Added historical Intraday data request for SPY to the queue. 2024-04-24 22:38:38.804 | Intraday data recording state for symbol SPY is set to download 'Pending'. 2024-04-24 22:38:38.804 | Triggering next historical data download in queue. 2024-04-24 22:38:38.812 | DTC Client socket (5) | Creating socket. 2024-04-24 22:38:38.812 | DTC Client socket (5) | New receive buffer size: 0 2024-04-24 22:38:38.812 | DTC Client socket (5) | Connecting to IP: 38.103.112.189. 2024-04-24 22:38:38.837 | DTC Client socket (6) | Creating socket. 2024-04-24 22:38:38.837 | DTC Client socket (6) | New receive buffer size: 0 2024-04-24 22:38:38.837 | DTC Client socket (6) | Connecting to IP: 38.103.112.199. 2024-04-24 22:38:38.853 | Delayed Data Feed | Network connection to server complete. 2024-04-24 22:38:38.853 | Delayed Data Feed | Starting socket receive thread. 2024-04-24 22:38:38.853 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-04-24 22:38:38.878 | Delayed Data Feed | Network connection to server complete. 2024-04-24 22:38:38.878 | Delayed Data Feed | Starting socket receive thread. 2024-04-24 22:38:38.878 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-04-24 22:38:38.895 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:38:38.895 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:38:38.895 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:38:38.895 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:38:38.895 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:38:38.895 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:38:38.895 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:38:38.895 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:38:38.928 | Delayed Data Feed | Setting DTC encoding to Binary VLS 2024-04-24 22:38:38.928 | Delayed Data Feed | Sending logon request message. 2024-04-24 22:38:38.951 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:38:38.952 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:38:38.952 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:38:38.952 | DTC Client socket (4) | Closed. 2024-04-24 22:38:38.952 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:38:38.952 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:38:38.952 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:38:38.952 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:38:38.953 | Delayed Data Feed | Setting DTC encoding to Binary VLS 2024-04-24 22:38:38.953 | Delayed Data Feed | Sending logon request message. 2024-04-24 22:38:39.046 | HD Request # 1 | Requesting historical Daily data starting at 2024-04-22. 2024-04-24 22:38:39.087 | HD Request # 1 | Decompressing data. 2024-04-24 22:38:39.131 | HD Request # 1 | Receiving historical Daily data for XAUUSD starting at 2024-04-22. 2024-04-24 22:38:39.131 | HD Request # 1 | Writing historical Daily data to the file XAUUSD.dly. 2024-04-24 22:38:39.143 | SC Data with Depth | Received logon response. 2024-04-24 22:38:39.143 | SC Data with Depth | Server Name: SC Realtime Server. 2024-04-24 22:38:39.143 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:38:39.143 | SC Data with Depth | Successfully connected. 2024-04-24 22:38:39.143 | SC Data with Depth | Trading is not supported. 2024-04-24 22:38:39.143 | SC Data with Depth | MarketDepthIsSupported: 1 2024-04-24 22:38:39.143 | SC Data with Depth | Restarting real-time data updates for symbol: EURUSD 2024-04-24 22:38:39.143 | SC Data with Depth | Restarting real-time data updates for symbol: SPX500 2024-04-24 22:38:39.143 | SC Data with Depth | Restarting real-time data updates for symbol: US30 2024-04-24 22:38:39.143 | SC Data with Depth | Restarting real-time data updates for symbol: USOil 2024-04-24 22:38:39.143 | SC Data with Depth | Restarting real-time data updates for symbol: XAUUSD 2024-04-24 22:38:39.169 | Socket (3) | CloseSocket call. 2024-04-24 22:38:39.169 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-04-24 22:38:39.170 | Historical data download thread signaled to stop. 2024-04-24 22:38:39.170 | HD Request # 1 | Received 4 Daily data records from 2024-04-22 00:00:00 to 2024-04-25 00:00:00 (4.0 days) and wrote 4 records for XAUUSD 2024-04-24 22:38:39.170 | HD Request # 1 | Completion time: 1s. 2024-04-24 22:38:39.170 | HD Request # 1 | Daily data download complete for XAUUSD. Unique request ID: 1 2024-04-24 22:38:39.170 | Removing historical data download ID 1. 2024-04-24 22:38:39.170 | 2024-04-24 22:38:39.170 | Triggering next historical data download in queue. 2024-04-24 22:38:39.170 | Delaying start of download for XAUUSD. 2024-04-24 22:38:39.213 | Socket (3) | Socket gracefully closed by remote side. 2024-04-24 22:38:39.213 | Socket (3) | Closed. 2024-04-24 22:38:39.270 | SC Data with Depth | Received security definition for symbol EURUSD 2024-04-24 22:38:39.270 | SC Data with Depth | Received security definition for symbol SPX500 2024-04-24 22:38:39.270 | SC Data with Depth | Received security definition for symbol US30 2024-04-24 22:38:39.270 | SC Data with Depth | Received security definition for symbol USOil 2024-04-24 22:38:39.270 | SC Data with Depth | Received security definition for symbol XAUUSD 2024-04-24 22:38:39.287 | Delayed Data Feed | Received logon response. 2024-04-24 22:38:39.287 | Delayed Data Feed | Server Name: SC Realtime Server. 2024-04-24 22:38:39.287 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:38:39.287 | Delayed Data Feed | Successfully connected. 2024-04-24 22:38:39.287 | Delayed Data Feed | Trading is not supported. 2024-04-24 22:38:39.287 | Delayed Data Feed | MarketDepthIsSupported: 1 2024-04-24 22:38:39.287 | Delayed Data Feed | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV 2024-04-24 22:38:39.317 | XAUUSD[M] Daily #2 | Reloading chart. 2024-04-24 22:38:39.326 | Delayed Data Feed | Received logon response. 2024-04-24 22:38:39.326 | Delayed Data Feed | Server Name: SC Realtime Server. 2024-04-24 22:38:39.326 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:38:39.326 | Delayed Data Feed | Successfully connected. 2024-04-24 22:38:39.326 | Delayed Data Feed | Trading is not supported. 2024-04-24 22:38:39.326 | Delayed Data Feed | MarketDepthIsSupported: 1 2024-04-24 22:38:39.326 | Delayed Data Feed | Restarting real-time data updates for symbol: SPY -> SPY 2024-04-24 22:38:39.358 | XAUUSD[M] Daily #2 | Chart data loading complete. 2024-04-24 22:38:39.432 | Delayed Data Feed | Received security definition for symbol AAPL-NQTV 2024-04-24 22:38:39.451 | Delayed Data Feed | Received security definition for symbol SPY 2024-04-24 22:38:40.952 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:38:40.952 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:38:40.952 | Requesting market depth updates for: ESM24-CME if supported. NumLevels=1400 2024-04-24 22:38:40.952 | Separate subscription for market depth updates not supported. ESM24-CME 2024-04-24 22:38:40.952 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2024-04-24 22:38:40.953 | DTC Client socket (3) | New receive buffer size: 0 2024-04-24 22:38:40.953 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2024-04-24 22:38:41.007 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:38:41.007 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:38:41.007 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:38:41.007 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:38:41.171 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:38:41.171 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:38:41.171 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:38:41.171 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:38:41.171 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:38:41.171 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:38:41.171 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:38:41.171 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME. Market Depth data restarted. 2024-04-24 22:38:41.225 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-04-24 22:38:41.225 | DTC Client socket (3) | CloseSocket call. 2024-04-24 22:38:41.225 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:38:41.225 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:38:41.225 | DTC Client socket (3) | Closed. 2024-04-24 22:38:41.225 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:38:41.225 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:38:41.225 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:38:43.219 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:38:43.219 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:38:43.224 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2024-04-24 22:38:43.225 | DTC Client socket (3) | New receive buffer size: 0 2024-04-24 22:38:43.225 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2024-04-24 22:38:43.278 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:38:43.278 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:38:43.278 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:38:43.278 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:38:43.443 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:38:43.443 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:38:43.443 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:38:43.443 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:38:43.443 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:38:43.443 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:38:43.443 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:38:43.443 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME. Market Depth data restarted. 2024-04-24 22:38:43.498 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-04-24 22:38:43.498 | DTC Client socket (3) | CloseSocket call. 2024-04-24 22:38:43.498 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:38:43.498 | DTC Client socket (3) | Closed. 2024-04-24 22:38:43.498 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:38:43.498 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:38:43.498 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:38:43.498 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:38:44.642 | HD Request # 2 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm 2024-04-24 22:38:44.643 | HD Request # 2 | Download start date-time: 2024-04-24 16:44:27.000000. File last date-time: 2024-04-24 16:44:27.516000 2024-04-24 22:38:44.643 | HD Request # 2 | Using server: ds13-2.sierracharts.com port 10150 2024-04-24 22:38:44.668 | Socket (3) | Creating socket. 2024-04-24 22:38:44.668 | Socket (3) | New receive buffer size: 0 2024-04-24 22:38:44.668 | Socket (3) | Connecting to IP: 38.142.170.156. 2024-04-24 22:38:44.840 | HD Request # 2 | Setting DTC encoding to Binary VLS 2024-04-24 22:38:44.840 | HD Request # 2 | Sending historical data logon request message. 2024-04-24 22:38:44.979 | HD Request # 2 | Requesting Intraday data. Start date-time: 2024-04-24 16:44:27. Record interval: 0. Symbol: XAUUSD 2024-04-24 22:38:45.052 | HD Request # 2 | Decompressing data. 2024-04-24 22:38:45.278 | HD Request # 2 | Receiving Intraday data for XAUUSD starting at 2024-04-24 16:44:27.074000 2024-04-24 22:38:45.472 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:38:45.472 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:38:45.473 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:38:45.473 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:38:45.473 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:38:45.487 | HD Request # 2 | Timestamp of first Intraday data file record written: 2024-04-24 16:44:29.979000. 2024-04-24 22:38:45.528 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:38:45.528 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:38:45.528 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:38:45.528 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:38:45.630 | Socket (3) | CloseSocket call. 2024-04-24 22:38:45.630 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-04-24 22:38:45.630 | Historical data download thread signaled to stop. 2024-04-24 22:38:45.630 | HD Request # 2 | Received 58750 Intraday data records from 2024-04-24 16:44:27.074000 to 2024-04-24 22:38:41.832000 (5.9 hours. Delay: 3.8 seconds) and wrote 58747 records for XAUUSD 2024-04-24 22:38:45.630 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2024-04-24 22:38:41.832000 2024-04-24 22:38:45.631 | Added 1 Time and Sales records to Intraday data file for XAUUSD after download. 2024-04-24 22:38:45.631 | HD Request # 2 | Completion time: 1s. 2024-04-24 22:38:45.631 | HD Request # 2 | Intraday data download complete for XAUUSD. Unique request ID: 2 2024-04-24 22:38:45.631 | Removing historical data download ID 2. 2024-04-24 22:38:45.631 | Real-time Intraday chart data file updates started for XAUUSD 2024-04-24 22:38:45.631 | Intraday chart data file opened for XAUUSD 2024-04-24 22:38:45.631 | HD Request # 2 | Enabling Intraday chart updating for symbol. 2024-04-24 22:38:45.631 | 2024-04-24 22:38:45.631 | Triggering next historical data download in queue. 2024-04-24 22:38:45.631 | HD Request # 3 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm 2024-04-24 22:38:45.631 | HD Request # 3 | Download start date-time: 2024-04-24 16:44:28.000000. File last date-time: 2024-04-24 16:44:28.181000 2024-04-24 22:38:45.631 | HD Request # 3 | Using server: ds4.sierracharts.com port 10149 2024-04-24 22:38:45.650 | Socket (7) | Creating socket. 2024-04-24 22:38:45.650 | Socket (7) | New receive buffer size: 0 2024-04-24 22:38:45.650 | Socket (7) | Connecting to IP: 38.103.112.200. 2024-04-24 22:38:45.696 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:38:45.696 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:38:45.696 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:38:45.696 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:38:45.696 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:38:45.696 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:38:45.696 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:38:45.696 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME. Market Depth data restarted. 2024-04-24 22:38:45.706 | Socket (3) | Socket gracefully closed by remote side. 2024-04-24 22:38:45.706 | Socket (3) | Closed. 2024-04-24 22:38:45.739 | HD Request # 3 | Setting DTC encoding to Binary VLS 2024-04-24 22:38:45.739 | HD Request # 3 | Sending historical data logon request message. 2024-04-24 22:38:45.750 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:38:45.750 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:38:45.750 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:38:45.750 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:38:45.750 | DTC Client socket (4) | Closed. 2024-04-24 22:38:45.751 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:38:45.751 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:38:45.751 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:38:46.022 | HD Request # 3 | Requesting Intraday data. Start date-time: 2024-04-24 16:44:28. Record interval: 0. Symbol: US30 2024-04-24 22:38:46.065 | HD Request # 3 | Decompressing data. 2024-04-24 22:38:46.167 | HD Request # 3 | Receiving Intraday data for US30 starting at 2024-04-24 16:44:28.181000 2024-04-24 22:38:46.329 | HD Request # 3 | Timestamp of first Intraday data file record written: 2024-04-24 16:44:28.997000. 2024-04-24 22:38:46.576 | Socket (7) | CloseSocket call. 2024-04-24 22:38:46.576 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:38:46.576 | Historical data download thread signaled to stop. 2024-04-24 22:38:46.576 | HD Request # 3 | Received 131189 Intraday data records from 2024-04-24 16:44:28.181000 to 2024-04-24 22:38:44.868000 (5.9 hours. Delay: 1.7 seconds) and wrote 131188 records for US30 2024-04-24 22:38:46.576 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2024-04-24 22:38:44.868000 2024-04-24 22:38:46.576 | Added 4 Time and Sales records to Intraday data file for US30 after download. 2024-04-24 22:38:46.576 | HD Request # 3 | Completion time: 1s. 2024-04-24 22:38:46.576 | HD Request # 3 | Intraday data download complete for US30. Unique request ID: 3 2024-04-24 22:38:46.576 | Removing historical data download ID 3. 2024-04-24 22:38:46.576 | Real-time Intraday chart data file updates started for US30 2024-04-24 22:38:46.576 | Intraday chart data file opened for US30 2024-04-24 22:38:46.576 | HD Request # 3 | Enabling Intraday chart updating for symbol. 2024-04-24 22:38:46.576 | 2024-04-24 22:38:46.576 | Triggering next historical data download in queue. 2024-04-24 22:38:46.576 | Delaying start of download for ESM24-CME. 2024-04-24 22:38:46.617 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:38:46.617 | Socket (7) | Closed. 2024-04-24 22:38:47.739 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:38:47.739 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:38:47.739 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2024-04-24 22:38:47.740 | DTC Client socket (3) | New receive buffer size: 0 2024-04-24 22:38:47.740 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2024-04-24 22:38:47.792 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:38:47.792 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:38:47.792 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:38:47.792 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:38:47.963 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:38:47.963 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:38:47.963 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:38:47.963 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:38:47.963 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:38:47.963 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:38:47.963 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:38:47.963 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME. Market Depth data restarted. 2024-04-24 22:38:48.016 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-04-24 22:38:48.016 | DTC Client socket (3) | CloseSocket call. 2024-04-24 22:38:48.016 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:38:48.016 | DTC Client socket (3) | Closed. 2024-04-24 22:38:48.016 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:38:48.016 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:38:48.016 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:38:48.016 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:38:49.413 | ESM4.CME/MESM4.CME [CBV] #2 | Reloading chart. 2024-04-24 22:38:49.416 | Added historical Intraday data request for ESM4.CME to the queue. 2024-04-24 22:38:49.416 | Triggering next historical data download in queue. 2024-04-24 22:38:49.417 | ESM4.CME/MESM4.CME [CBV] #2 | Performing continuous chart historical Daily data download for symbol ESM4.CME starting at last date in file. 2024-04-24 22:38:49.417 | Starting DelayedDownloadMonitoringTimer 2024-04-24 22:38:49.417 | Starting HDTimeoutTimer 2024-04-24 22:38:49.417 | Added historical Daily data request for ESM4.CME to the queue. 2024-04-24 22:38:49.418 | Triggering next historical data download in queue. 2024-04-24 22:38:49.428 | ESM4.CME/MESM4.CME [CBV] #2 | Waiting for historical downloads to complete with the IDs: 11, 12, 2024-04-24 22:38:49.431 | Mapping ESM4.CME to ESM24. Service code: cme 2024-04-24 22:38:49.432 | HD Request # 4 | Downloading Historical Daily chart data for ESM4.CME. Starting date: 2024-04-19. Service: rithmic.trading 2024-04-24 22:38:49.789 | HD Request # 4 | Requesting historical Daily data for ESM24 starting at 2024-04-18. SC External HD service. 2024-04-24 22:38:49.947 | HD Request # 4 | Receiving historical Daily data for ESM4.CME starting at 2024-04-19. 2024-04-24 22:38:49.947 | HD Request # 4 | Writing historical Daily data to the file ESM4.CME.dly. 2024-04-24 22:38:49.950 | HD Request # 4 | Bytes received: 304 2024-04-24 22:38:49.950 | HD Request # 4 | Received 5 Daily data records from 2024-04-19 00:00:00 to 2024-04-24 00:00:00 (6.0 days) and wrote 4 records for ESM4.CME 2024-04-24 22:38:49.950 | HD Request # 4 | Completion time: 0s. 2024-04-24 22:38:49.950 | HD Request # 4 | Daily data download complete for ESM4.CME. Unique request ID: 12 2024-04-24 22:38:49.950 | Removing historical data download ID 12. 2024-04-24 22:38:49.950 | 2024-04-24 22:38:49.950 | No download requests in the queue to start downloads for. 2024-04-24 22:38:50.009 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:38:50.009 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:38:50.010 | DTC Client socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:38:50.010 | DTC Client socket (7) | New receive buffer size: 0 2024-04-24 22:38:50.010 | DTC Client socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:38:50.064 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:38:50.064 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:38:50.065 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:38:50.065 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:38:50.227 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:38:50.227 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:38:50.227 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:38:50.227 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:38:50.227 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:38:50.227 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:38:50.227 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:38:50.227 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME. Market Depth data restarted. 2024-04-24 22:38:50.280 | DTC Client socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:38:50.280 | DTC Client socket (7) | CloseSocket call. 2024-04-24 22:38:50.280 | DTC Client socket (7) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:38:50.280 | DTC Client socket (7) | Closed. 2024-04-24 22:38:50.281 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:38:50.281 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:38:50.281 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:38:50.281 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:38:50.432 | Opened cached Intraday file: C:\SierraChart2\Data\US30.scid. Thread ID: 2020 2024-04-24 22:38:50.948 | Unsubscribed from market depth data for ESM24-CME 2024-04-24 22:38:50.948 | Denali Data Feed | Starting real-time market data updates for: ESM4.CME (ESM24). ID: 9 Service code: cme 2024-04-24 22:38:50.950 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048 2024-04-24 22:38:50.953 | Denali Data Feed | Requesting security definition data for: ESM4.CME (ESM24). ID: 9 2024-04-24 22:38:50.953 | Requesting market depth updates for: ESM4.CME if supported. NumLevels=100 2024-04-24 22:38:50.971 | DTC Client socket (3) | Creating socket. 2024-04-24 22:38:50.971 | DTC Client socket (3) | New receive buffer size: 0 2024-04-24 22:38:50.971 | DTC Client socket (3) | Connecting to IP: 38.103.112.188. 2024-04-24 22:38:51.013 | Denali Data Feed | Network connection to server complete. 2024-04-24 22:38:51.013 | Denali Data Feed | Starting socket receive thread. 2024-04-24 22:38:51.013 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-04-24 22:38:51.068 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-04-24 22:38:51.068 | Denali Data Feed | Sending logon request message. 2024-04-24 22:38:51.630 | Denali Data Feed | Received logon response. 2024-04-24 22:38:51.630 | Denali Data Feed | Server Name: SC Realtime Server. 2024-04-24 22:38:51.630 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:38:51.630 | Denali Data Feed | Successfully connected. 2024-04-24 22:38:51.630 | Denali Data Feed | Trading is not supported. 2024-04-24 22:38:51.630 | Denali Data Feed | MarketDepthIsSupported: 1 2024-04-24 22:38:51.630 | Denali Data Feed | Restarting real-time data updates for symbol: ESM4.CME -> ESM24. Market Depth data restarted. 2024-04-24 22:38:51.754 | Denali Data Feed | Clearing market depth for ESM4.CME 2024-04-24 22:38:51.754 | Denali Data Feed | Received security definition for symbol ESM4.CME 2024-04-24 22:38:52.277 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:38:52.277 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:38:52.278 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:38:52.278 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:38:52.278 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:38:52.331 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:38:52.331 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:38:52.331 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:38:52.331 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:38:52.495 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:38:52.495 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:38:52.495 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:38:52.495 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:38:52.495 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:38:52.495 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:38:52.495 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:38:52.495 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:38:52.550 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:38:52.550 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:38:52.550 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:38:52.550 | DTC Client socket (4) | Closed. 2024-04-24 22:38:52.550 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:38:52.550 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:38:52.550 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:38:52.551 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:38:54.681 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:38:54.681 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:38:54.682 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:38:54.682 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:38:54.682 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:38:54.736 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:38:54.736 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:38:54.736 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:38:54.737 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:38:54.870 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:38:54.870 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (7) | New receive buffer size: 0 2024-04-24 22:38:54.870 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (7) | Connecting to IP: 38.79.0.89. 2024-04-24 22:38:54.901 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:38:54.901 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:38:54.901 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:38:54.901 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:38:54.901 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:38:54.901 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:38:54.901 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:38:54.901 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:38:54.955 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:38:54.955 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:38:54.955 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:38:54.955 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:38:54.955 | DTC Client socket (4) | Closed. 2024-04-24 22:38:54.956 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:38:54.956 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:38:54.956 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:38:55.169 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (7) | Socket gracefully closed by remote side. | Number times message added: 1 2024-04-24 22:38:55.170 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (7) | CloseSocket call. 2024-04-24 22:38:55.170 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (7) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:38:55.171 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (7) | Closed. 2024-04-24 22:38:55.449 | Opened cached Intraday file: C:\SierraChart2\Data\XAUUSD.scid. Thread ID: 2020 2024-04-24 22:38:56.952 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:38:56.952 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:38:56.952 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:38:56.952 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:38:56.952 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:38:57.007 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:38:57.007 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:38:57.007 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:38:57.008 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:38:57.175 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:38:57.175 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:38:57.175 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:38:57.175 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:38:57.175 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:38:57.175 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:38:57.175 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:38:57.175 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:38:57.229 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:38:57.229 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:38:57.229 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:38:57.229 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:38:57.229 | DTC Client socket (4) | Closed. 2024-04-24 22:38:57.231 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:38:57.231 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:38:57.231 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:38:59.206 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:38:59.206 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:38:59.208 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:38:59.208 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:38:59.208 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:38:59.263 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:38:59.263 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:38:59.263 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:38:59.263 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:38:59.432 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:38:59.432 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:38:59.432 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:38:59.432 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:38:59.432 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:38:59.432 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:38:59.432 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:38:59.432 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:38:59.488 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:38:59.490 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:38:59.490 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:38:59.490 | DTC Client socket (4) | Closed. 2024-04-24 22:38:59.491 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:38:59.492 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:38:59.492 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:38:59.492 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:01.492 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:01.492 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:01.493 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:01.493 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:01.493 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:01.551 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:01.551 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:01.551 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:01.551 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:01.719 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:01.719 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:01.719 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:01.719 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:01.719 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:01.719 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:01.719 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:01.719 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:01.775 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:01.775 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:01.775 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:01.775 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:01.775 | DTC Client socket (4) | Closed. 2024-04-24 22:39:01.776 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:01.776 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:01.776 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:03.778 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:03.778 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:03.779 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:03.779 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:03.779 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:03.833 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:03.833 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:03.833 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:03.833 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:03.999 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:03.999 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:03.999 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:03.999 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:03.999 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:03.999 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:03.999 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:03.999 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:04.055 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:04.055 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:04.055 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:04.055 | DTC Client socket (4) | Closed. 2024-04-24 22:39:04.055 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:04.055 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:04.055 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:04.055 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:06.034 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:06.034 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:06.035 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:06.035 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:06.035 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:06.090 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:06.090 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:06.090 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:06.090 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:06.256 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:06.256 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:06.256 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:06.256 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:06.256 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:06.256 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:06.256 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:06.256 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:06.312 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:06.312 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:06.312 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:06.312 | DTC Client socket (4) | Closed. 2024-04-24 22:39:06.313 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:06.313 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:06.313 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:06.313 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:08.305 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:08.305 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:08.306 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:08.306 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:08.306 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:08.360 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:08.360 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:08.360 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:08.360 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:08.535 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:08.535 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:08.535 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:08.535 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:08.535 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:08.535 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:08.535 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:08.535 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:08.591 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:08.591 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:08.592 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:08.592 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:08.592 | DTC Client socket (4) | Closed. 2024-04-24 22:39:08.593 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:08.593 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:08.593 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:09.654 | HD Request # 5 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:39:09.654 | HD Request # 5 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:09.655 | HD Request # 5 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:39:09.655 | Socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:09.655 | Socket (4) | New receive buffer size: 0 2024-04-24 22:39:09.655 | Socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:09.711 | HD Request # 5 | Sending historical data logon request message. 2024-04-24 22:39:09.879 | HD Request # 5 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:39:09.931 | Socket (4) | CloseSocket call. 2024-04-24 22:39:09.931 | HD Request # 5 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:39:09.931 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:09.931 | Historical data download thread signaled to stop. 2024-04-24 22:39:09.931 | HD Request # 5 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:39:09.931 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:09.931 | HD Request # 5 | Completion time: 0s. 2024-04-24 22:39:09.931 | HD Request # 5 | Intraday data download complete for ESM24-CME. Unique request ID: 4 2024-04-24 22:39:09.931 | Removing historical data download ID 4. 2024-04-24 22:39:09.931 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:39:09.931 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:39:09.931 | HD Request # 5 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:09.931 | 2024-04-24 22:39:09.931 | Triggering next historical data download in queue. 2024-04-24 22:39:09.931 | HD Request # 6 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm 2024-04-24 22:39:09.931 | HD Request # 6 | Download start date-time: 2024-04-24 16:44:27.000000. File last date-time: 2024-04-24 16:44:27.258000 2024-04-24 22:39:09.932 | HD Request # 6 | Using server: ds12.sierracharts.com port 10149 2024-04-24 22:39:09.932 | Socket (7) | Creating socket. 2024-04-24 22:39:09.932 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:09.932 | Socket (7) | Connecting to IP: 38.103.112.181. 2024-04-24 22:39:09.986 | Socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:09.986 | Socket (4) | Closed. 2024-04-24 22:39:10.020 | HD Request # 6 | Setting DTC encoding to Binary VLS 2024-04-24 22:39:10.020 | HD Request # 6 | Sending historical data logon request message. 2024-04-24 22:39:10.302 | HD Request # 6 | Requesting Intraday data. Start date-time: 2024-04-24 16:44:27. Record interval: 0. Symbol: USOil 2024-04-24 22:39:10.348 | HD Request # 6 | Decompressing data. 2024-04-24 22:39:10.493 | HD Request # 6 | Receiving Intraday data for USOil starting at 2024-04-24 16:44:27.258000 2024-04-24 22:39:10.593 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:10.593 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:10.594 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:10.594 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:10.594 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:10.619 | Socket (7) | CloseSocket call. 2024-04-24 22:39:10.619 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:10.619 | Historical data download thread signaled to stop. 2024-04-24 22:39:10.619 | HD Request # 6 | Timestamp of first Intraday data file record written: 2024-04-24 16:44:29.477000. 2024-04-24 22:39:10.619 | HD Request # 6 | Received 9863 Intraday data records from 2024-04-24 16:44:27.258000 to 2024-04-24 22:38:40.757000 (5.9 hours. Delay: 29.9 seconds) and wrote 9862 records for USOil 2024-04-24 22:39:10.620 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2024-04-24 22:38:40.757000 2024-04-24 22:39:10.620 | HD Request # 6 | Completion time: 1s. 2024-04-24 22:39:10.620 | HD Request # 6 | Intraday data download complete for USOil. Unique request ID: 5 2024-04-24 22:39:10.620 | Removing historical data download ID 5. 2024-04-24 22:39:10.620 | Real-time Intraday chart data file updates started for USOil 2024-04-24 22:39:10.620 | Intraday chart data file opened for USOil 2024-04-24 22:39:10.620 | HD Request # 6 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:10.620 | 2024-04-24 22:39:10.620 | Triggering next historical data download in queue. 2024-04-24 22:39:10.620 | HD Request # 7 | Downloading Historical Daily chart data for SPX500. Starting date: 2024-04-22. Service: fxcm 2024-04-24 22:39:10.620 | HD Request # 7 | Using server: ds13-2.sierracharts.com port 10150 2024-04-24 22:39:10.620 | Socket (8) | Creating socket. 2024-04-24 22:39:10.620 | Socket (8) | New receive buffer size: 0 2024-04-24 22:39:10.620 | Socket (8) | Connecting to IP: 38.142.170.156. 2024-04-24 22:39:10.648 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:10.648 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:10.648 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:10.648 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:10.658 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:10.658 | Socket (7) | Closed. 2024-04-24 22:39:10.819 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:10.819 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:10.819 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:10.819 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:10.819 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:10.819 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:10.819 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:10.819 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:39:10.819 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:39:10.819 | Triggering next historical data download in queue. 2024-04-24 22:39:10.819 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:10.819 | HD Request # 7 | Setting DTC encoding to Binary VLS 2024-04-24 22:39:10.819 | HD Request # 7 | Sending historical data logon request message. 2024-04-24 22:39:10.872 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:10.872 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:10.872 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:10.872 | DTC Client socket (4) | Closed. 2024-04-24 22:39:10.872 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:10.872 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:10.872 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:10.872 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:10.922 | HD Request # 7 | Requesting historical Daily data starting at 2024-04-22. 2024-04-24 22:39:10.995 | HD Request # 7 | Decompressing data. 2024-04-24 22:39:11.051 | HD Request # 7 | Receiving historical Daily data for SPX500 starting at 2024-04-22. 2024-04-24 22:39:11.052 | HD Request # 7 | Writing historical Daily data to the file SPX500.dly. 2024-04-24 22:39:11.077 | Socket (8) | CloseSocket call. 2024-04-24 22:39:11.077 | Socket (8) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:11.077 | Historical data download thread signaled to stop. 2024-04-24 22:39:11.077 | HD Request # 7 | Received 4 Daily data records from 2024-04-22 00:00:00 to 2024-04-25 00:00:00 (4.0 days) and wrote 4 records for SPX500 2024-04-24 22:39:11.077 | HD Request # 7 | Completion time: 1s. 2024-04-24 22:39:11.077 | HD Request # 7 | Daily data download complete for SPX500. Unique request ID: 6 2024-04-24 22:39:11.077 | Removing historical data download ID 6. 2024-04-24 22:39:11.077 | 2024-04-24 22:39:11.077 | Triggering next historical data download in queue. 2024-04-24 22:39:11.077 | HD Request # 8 | Downloading Historical Daily chart data for EURUSD. Starting date: 2024-04-22. Service: fxcm 2024-04-24 22:39:11.078 | HD Request # 8 | Using server: ds4.sierracharts.com port 10149 2024-04-24 22:39:11.078 | Socket (4) | Creating socket. 2024-04-24 22:39:11.078 | Socket (4) | New receive buffer size: 0 2024-04-24 22:39:11.078 | Socket (4) | Connecting to IP: 38.103.112.200. 2024-04-24 22:39:11.152 | Socket (8) | Socket gracefully closed by remote side. 2024-04-24 22:39:11.152 | Socket (8) | Closed. 2024-04-24 22:39:11.175 | HD Request # 8 | Setting DTC encoding to Binary VLS 2024-04-24 22:39:11.175 | HD Request # 8 | Sending historical data logon request message. 2024-04-24 22:39:11.216 | HD Request # 8 | Requesting historical Daily data starting at 2024-04-22. 2024-04-24 22:39:11.257 | HD Request # 8 | Decompressing data. 2024-04-24 22:39:11.283 | HD Request # 8 | Receiving historical Daily data for EURUSD starting at 2024-04-22. 2024-04-24 22:39:11.284 | HD Request # 8 | Writing historical Daily data to the file EURUSD.dly. 2024-04-24 22:39:11.311 | Socket (4) | CloseSocket call. 2024-04-24 22:39:11.311 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:11.311 | Historical data download thread signaled to stop. 2024-04-24 22:39:11.311 | HD Request # 8 | Received 4 Daily data records from 2024-04-22 00:00:00 to 2024-04-25 00:00:00 (4.0 days) and wrote 4 records for EURUSD 2024-04-24 22:39:11.311 | HD Request # 8 | Completion time: 0s. 2024-04-24 22:39:11.311 | HD Request # 8 | Daily data download complete for EURUSD. Unique request ID: 7 2024-04-24 22:39:11.311 | Removing historical data download ID 7. 2024-04-24 22:39:11.311 | 2024-04-24 22:39:11.311 | Triggering next historical data download in queue. 2024-04-24 22:39:11.311 | HD Request # 9 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm 2024-04-24 22:39:11.311 | HD Request # 9 | Download start date-time: 2024-04-24 16:44:27.000000. File last date-time: 2024-04-24 16:44:27.498000 2024-04-24 22:39:11.311 | HD Request # 9 | Using server: ds12.sierracharts.com port 10150 2024-04-24 22:39:11.312 | Socket (7) | Creating socket. 2024-04-24 22:39:11.312 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:11.312 | Socket (7) | Connecting to IP: 38.103.112.181. 2024-04-24 22:39:11.350 | Socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:11.350 | Socket (4) | Closed. 2024-04-24 22:39:11.408 | HD Request # 9 | Setting DTC encoding to Binary VLS 2024-04-24 22:39:11.408 | HD Request # 9 | Sending historical data logon request message. 2024-04-24 22:39:11.685 | HD Request # 9 | Requesting Intraday data. Start date-time: 2024-04-24 16:44:27. Record interval: 0. Symbol: EURUSD 2024-04-24 22:39:11.731 | HD Request # 9 | Decompressing data. 2024-04-24 22:39:11.877 | HD Request # 9 | Receiving Intraday data for EURUSD starting at 2024-04-24 16:44:27.258000 2024-04-24 22:39:12.010 | Socket (7) | CloseSocket call. 2024-04-24 22:39:12.010 | Historical data download thread signaled to stop. 2024-04-24 22:39:12.010 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:12.010 | HD Request # 9 | Timestamp of first Intraday data file record written: 2024-04-24 16:44:30.155000. 2024-04-24 22:39:12.011 | HD Request # 9 | Received 25216 Intraday data records from 2024-04-24 16:44:27.258000 to 2024-04-24 22:39:05.770000 (5.9 hours. Delay: 6.2 seconds) and wrote 25214 records for EURUSD 2024-04-24 22:39:12.011 | HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2024-04-24 22:39:05.770000 2024-04-24 22:39:12.011 | Added 3 Time and Sales records to Intraday data file for EURUSD after download. 2024-04-24 22:39:12.011 | HD Request # 9 | Completion time: 1s. 2024-04-24 22:39:12.011 | HD Request # 9 | Intraday data download complete for EURUSD. Unique request ID: 8 2024-04-24 22:39:12.011 | Removing historical data download ID 8. 2024-04-24 22:39:12.011 | Real-time Intraday chart data file updates started for EURUSD 2024-04-24 22:39:12.011 | Intraday chart data file opened for EURUSD 2024-04-24 22:39:12.011 | HD Request # 9 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:12.011 | 2024-04-24 22:39:12.011 | Triggering next historical data download in queue. 2024-04-24 22:39:12.011 | HD Request # 10 | Downloading Intraday chart data for AAPL-NQTV to the file AAPL-NQTV.scid. Service: nasdaq_exchange.data 2024-04-24 22:39:12.011 | HD Request # 10 | Download start date-time: 2024-04-24 16:29:24.000000. File last date-time: 2024-04-24 16:29:24.915000 2024-04-24 22:39:12.012 | HD Request # 10 | Using server: ds3.sierracharts.com port 10149 2024-04-24 22:39:12.012 | Socket (4) | Creating socket. 2024-04-24 22:39:12.012 | Socket (4) | New receive buffer size: 0 2024-04-24 22:39:12.012 | Socket (4) | Connecting to IP: 38.103.112.199. 2024-04-24 22:39:12.053 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:12.053 | Socket (7) | Closed. 2024-04-24 22:39:12.101 | HD Request # 10 | Setting DTC encoding to Binary VLS 2024-04-24 22:39:12.101 | HD Request # 10 | Sending historical data logon request message. 2024-04-24 22:39:12.387 | HD Request # 10 | Requesting Intraday data. Start date-time: 2024-04-24 16:29:24. Record interval: 0. Symbol: AAPL-NQTV 2024-04-24 22:39:12.431 | HD Request # 10 | Decompressing data. 2024-04-24 22:39:12.565 | HD Request # 10 | Receiving Intraday data for AAPL-NQTV starting at 2024-04-24 16:29:24.915000 2024-04-24 22:39:12.721 | HD Request # 10 | Timestamp of first Intraday data file record written: 2024-04-24 16:29:29.350000. 2024-04-24 22:39:12.802 | Socket (4) | CloseSocket call. 2024-04-24 22:39:12.803 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:12.803 | Historical data download thread signaled to stop. 2024-04-24 22:39:12.803 | HD Request # 10 | Received 64033 Intraday data records from 2024-04-24 16:29:24.915000 to 2024-04-24 22:23:55.771000 (5.9 hours. Delay: 15.3 minutes) and wrote 64032 records for AAPL-NQTV 2024-04-24 22:39:12.803 | HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2024-04-24 22:23:55.771000 2024-04-24 22:39:12.804 | Added 2 Time and Sales records to Intraday data file for AAPL-NQTV after download. 2024-04-24 22:39:12.804 | HD Request # 10 | Completion time: 0s. 2024-04-24 22:39:12.804 | HD Request # 10 | Intraday data download complete for AAPL-NQTV. Unique request ID: 9 2024-04-24 22:39:12.804 | Removing historical data download ID 9. 2024-04-24 22:39:12.804 | Real-time Intraday chart data file updates started for AAPL-NQTV 2024-04-24 22:39:12.804 | Intraday chart data file opened for AAPL-NQTV 2024-04-24 22:39:12.804 | HD Request # 10 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:12.804 | 2024-04-24 22:39:12.804 | Triggering next historical data download in queue. 2024-04-24 22:39:12.804 | HD Request # 11 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: us_equities_utp_cta_exchange.data 2024-04-24 22:39:12.804 | HD Request # 11 | Download start date-time: 2024-04-24 16:29:27.000000. File last date-time: 2024-04-24 16:29:27.673000 2024-04-24 22:39:12.804 | HD Request # 11 | Using server: ds30.sierracharts.com port 10150 2024-04-24 22:39:12.826 | Socket (7) | Creating socket. 2024-04-24 22:39:12.826 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:12.826 | Socket (7) | Connecting to IP: 38.103.112.195. 2024-04-24 22:39:12.844 | Socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:12.844 | Socket (4) | Closed. 2024-04-24 22:39:12.848 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:12.848 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:12.848 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:12.849 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:12.849 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:12.903 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:12.903 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:12.904 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:12.904 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:12.915 | HD Request # 11 | Setting DTC encoding to Binary VLS 2024-04-24 22:39:12.915 | HD Request # 11 | Sending historical data logon request message. 2024-04-24 22:39:13.066 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:13.066 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:13.066 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:13.066 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:13.066 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:13.066 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:13.066 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:13.066 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:13.124 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:13.124 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:13.124 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:13.124 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:13.124 | DTC Client socket (4) | Closed. 2024-04-24 22:39:13.125 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:13.125 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:13.125 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:13.208 | HD Request # 11 | Requesting Intraday data. Start date-time: 2024-04-24 16:29:27. Record interval: 0. Symbol: SPY 2024-04-24 22:39:13.251 | HD Request # 11 | Decompressing data. 2024-04-24 22:39:13.359 | HD Request # 11 | Receiving Intraday data for SPY starting at 2024-04-24 16:29:27.012000 2024-04-24 22:39:13.514 | HD Request # 11 | Timestamp of first Intraday data file record written: 2024-04-24 16:29:28.407000. 2024-04-24 22:39:13.904 | Socket (7) | CloseSocket call. 2024-04-24 22:39:13.904 | Historical data download thread signaled to stop. 2024-04-24 22:39:13.905 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:13.905 | HD Request # 11 | Received 226566 Intraday data records from 2024-04-24 16:29:27.012000 to 2024-04-24 22:24:10.734000 (5.9 hours. Delay: 15.1 minutes) and wrote 113209 records for SPY 2024-04-24 22:39:13.905 | HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2024-04-24 22:24:10.722000 2024-04-24 22:39:13.905 | HD Request # 11 | Completion time: 1s. 2024-04-24 22:39:13.905 | HD Request # 11 | Intraday data download complete for SPY. Unique request ID: 10 2024-04-24 22:39:13.905 | Removing historical data download ID 10. 2024-04-24 22:39:13.905 | Real-time Intraday chart data file updates started for SPY 2024-04-24 22:39:13.905 | Intraday chart data file opened for SPY 2024-04-24 22:39:13.905 | HD Request # 11 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:13.905 | 2024-04-24 22:39:13.905 | Triggering next historical data download in queue. 2024-04-24 22:39:13.906 | HD Request # 12 | Downloading Intraday chart data for ESM4.CME to the file ESM4.CME.scid. Service: cme 2024-04-24 22:39:13.906 | HD Request # 12 | Download start date-time: 2024-04-24 20:59:59.000000. File last date-time: 2024-04-24 20:59:59.758000 2024-04-24 22:39:13.906 | HD Request # 12 | Using server: ds13.sierracharts.com port 10149 2024-04-24 22:39:13.926 | Socket (4) | Creating socket. 2024-04-24 22:39:13.926 | Socket (4) | New receive buffer size: 0 2024-04-24 22:39:13.926 | Socket (4) | Connecting to IP: 38.142.170.155. 2024-04-24 22:39:13.946 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:13.946 | Socket (7) | Closed. 2024-04-24 22:39:14.147 | HD Request # 12 | Setting DTC encoding to Binary VLS 2024-04-24 22:39:14.147 | HD Request # 12 | Sending historical data logon request message. 2024-04-24 22:39:14.292 | HD Request # 12 | Requesting Intraday data. Start date-time: 2024-04-24 20:59:59. Record interval: 0. Symbol: ESM24 2024-04-24 22:39:14.363 | HD Request # 12 | Decompressing data. 2024-04-24 22:39:14.524 | HD Request # 12 | Receiving Intraday data for ESM4.CME starting at 2024-04-24 20:59:59.040000 2024-04-24 22:39:14.618 | Socket (4) | CloseSocket call. 2024-04-24 22:39:14.618 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:14.618 | Historical data download thread signaled to stop. 2024-04-24 22:39:14.618 | HD Request # 12 | Timestamp of first Intraday data file record written: 2024-04-24 22:00:00.000000. 2024-04-24 22:39:14.618 | HD Request # 12 | Received 7529 Intraday data records from 2024-04-24 20:59:59.040000 to 2024-04-24 22:39:09.419000 (99.2 minutes. Delay: 5.2 seconds) and wrote 7525 records for ESM4.CME 2024-04-24 22:39:14.618 | HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2024-04-24 22:39:09.419000 2024-04-24 22:39:14.618 | Added 6 Time and Sales records to Intraday data file for ESM4.CME after download. 2024-04-24 22:39:14.618 | HD Request # 12 | Completion time: 1s. 2024-04-24 22:39:14.618 | HD Request # 12 | Intraday data download complete for ESM4.CME. Unique request ID: 11 2024-04-24 22:39:14.618 | Removing historical data download ID 11. 2024-04-24 22:39:14.618 | Real-time Intraday chart data file updates started for ESM4.CME 2024-04-24 22:39:14.618 | Intraday chart data file opened for ESM4.CME 2024-04-24 22:39:14.618 | HD Request # 12 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:14.619 | 2024-04-24 22:39:14.619 | Triggering next historical data download in queue. 2024-04-24 22:39:14.619 | HD Request # 13 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:39:14.619 | HD Request # 13 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:14.619 | HD Request # 13 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:39:14.619 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:14.619 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:14.619 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:14.671 | HD Request # 13 | Sending historical data logon request message. 2024-04-24 22:39:14.707 | Socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:14.707 | Socket (4) | Closed. 2024-04-24 22:39:14.840 | HD Request # 13 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:39:14.895 | Socket (7) | CloseSocket call. 2024-04-24 22:39:14.895 | HD Request # 13 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:39:14.895 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:14.895 | Historical data download thread signaled to stop. 2024-04-24 22:39:14.895 | HD Request # 13 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:39:14.896 | HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:14.896 | HD Request # 13 | Completion time: 0s. 2024-04-24 22:39:14.896 | HD Request # 13 | Intraday data download complete for ESM24-CME. Unique request ID: 13 2024-04-24 22:39:14.896 | Removing historical data download ID 13. 2024-04-24 22:39:14.896 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:39:14.896 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:39:14.896 | HD Request # 13 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:14.896 | 2024-04-24 22:39:14.896 | No download requests in the queue to start downloads for. 2024-04-24 22:39:14.950 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:14.950 | Socket (7) | Closed. 2024-04-24 22:39:14.993 | ESM4.CME/MESM4.CME [CBV] #2 | Download is complete for all contract months in chart. Proceeding with data load. 2024-04-24 22:39:14.994 | ESM4.CME/MESM4.CME [CBV] #2 | Reloading chart. 2024-04-24 22:39:15.006 | ESM4.CME/MESM4.CME [CBV] #2 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-04-24 22:39:15.016 | ESM4.CME/MESM4.CME [CBV] #2 | Chart data loading complete. 2024-04-24 22:39:15.117 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:15.117 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:15.121 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:15.122 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:15.122 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:15.178 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:15.178 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:15.179 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:15.179 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:15.341 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:15.341 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:15.341 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:15.341 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:15.341 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:15.341 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:15.341 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:15.342 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:39:15.342 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:39:15.342 | Triggering next historical data download in queue. 2024-04-24 22:39:15.342 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:15.342 | HD Request # 14 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:39:15.342 | HD Request # 14 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:15.342 | HD Request # 14 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:39:15.342 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:15.342 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:15.342 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:15.394 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:15.394 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:15.394 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:15.394 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:15.394 | DTC Client socket (4) | Closed. 2024-04-24 22:39:15.394 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:15.394 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:15.394 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:15.394 | HD Request # 14 | Sending historical data logon request message. 2024-04-24 22:39:15.400 | ESM4.CME/MESM4.CME [CBV] #2 | Reloading chart. 2024-04-24 22:39:15.419 | ESM4.CME/MESM4.CME [CBV] #2 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-04-24 22:39:15.420 | ESM4.CME/MESM4.CME [CBV] #2 | Chart data loading complete. 2024-04-24 22:39:15.493 | Opened cached Intraday file: C:\SierraChart2\Data\USOil.scid. Thread ID: 2020 2024-04-24 22:39:15.493 | Opened cached Intraday file: C:\SierraChart2\Data\EURUSD.scid. Thread ID: 2020 2024-04-24 22:39:15.563 | HD Request # 14 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:39:15.617 | Socket (7) | CloseSocket call. 2024-04-24 22:39:15.617 | HD Request # 14 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:39:15.617 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:15.617 | Historical data download thread signaled to stop. 2024-04-24 22:39:15.617 | HD Request # 14 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:39:15.617 | HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:15.617 | HD Request # 14 | Completion time: 0s. 2024-04-24 22:39:15.617 | HD Request # 14 | Intraday data download complete for ESM24-CME. Unique request ID: 14 2024-04-24 22:39:15.617 | Removing historical data download ID 14. 2024-04-24 22:39:15.617 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:39:15.617 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:39:15.617 | HD Request # 14 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:15.617 | 2024-04-24 22:39:15.617 | No download requests in the queue to start downloads for. 2024-04-24 22:39:15.674 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:15.674 | Socket (7) | Closed. 2024-04-24 22:39:15.746 | Opened cached Intraday file: C:\SierraChart2\Data\AAPL-NQTV.scid. Thread ID: 2356 2024-04-24 22:39:15.806 | Mapping MESM4.CME to MESM24. Service code: cme 2024-04-24 22:39:15.806 | Denali Data Feed | Starting real-time market data updates for: MESM4.CME (MESM24). ID: 10 Service code: cme 2024-04-24 22:39:15.806 | Denali Data Feed | Requesting security definition data for: MESM4.CME (MESM24). ID: 10 2024-04-24 22:39:15.948 | Denali Data Feed | Received security definition for symbol MESM4.CME 2024-04-24 22:39:17.386 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:17.386 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:17.387 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:17.387 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:17.387 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:17.442 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:17.442 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:17.442 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:17.442 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:17.604 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:17.604 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:17.604 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:17.604 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:17.604 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:17.604 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:17.604 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:17.604 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:39:17.604 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:39:17.604 | Triggering next historical data download in queue. 2024-04-24 22:39:17.604 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:17.604 | HD Request # 15 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:39:17.605 | HD Request # 15 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:17.606 | HD Request # 15 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:39:17.606 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:17.606 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:17.606 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:17.658 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:17.658 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:17.658 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:17.658 | DTC Client socket (4) | Closed. 2024-04-24 22:39:17.659 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:17.659 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:17.659 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:17.659 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:17.661 | HD Request # 15 | Sending historical data logon request message. 2024-04-24 22:39:17.827 | HD Request # 15 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:39:17.887 | Socket (7) | CloseSocket call. 2024-04-24 22:39:17.887 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:17.887 | HD Request # 15 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:39:17.887 | Historical data download thread signaled to stop. 2024-04-24 22:39:17.887 | HD Request # 15 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:39:17.888 | HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:17.888 | HD Request # 15 | Completion time: 0s. 2024-04-24 22:39:17.888 | HD Request # 15 | Intraday data download complete for ESM24-CME. Unique request ID: 15 2024-04-24 22:39:17.888 | Removing historical data download ID 15. 2024-04-24 22:39:17.888 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:39:17.888 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:39:17.888 | HD Request # 15 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:17.888 | 2024-04-24 22:39:17.888 | No download requests in the queue to start downloads for. 2024-04-24 22:39:17.942 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:17.942 | Socket (7) | Closed. 2024-04-24 22:39:19.643 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:19.643 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:19.644 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:19.644 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:19.644 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:19.700 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:19.700 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:19.700 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:19.700 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:19.866 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:19.866 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:19.866 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:19.866 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:19.866 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:19.866 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:19.866 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:19.867 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:39:19.867 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:39:19.867 | Triggering next historical data download in queue. 2024-04-24 22:39:19.867 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:19.867 | HD Request # 16 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:39:19.867 | HD Request # 16 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:19.867 | HD Request # 16 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:39:19.867 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:19.867 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:19.867 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:19.921 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:19.922 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:19.922 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:19.922 | HD Request # 16 | Sending historical data logon request message. 2024-04-24 22:39:19.922 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:19.922 | DTC Client socket (4) | Closed. 2024-04-24 22:39:19.922 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:19.922 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:19.922 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:20.085 | HD Request # 16 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:39:20.137 | Socket (7) | CloseSocket call. 2024-04-24 22:39:20.137 | HD Request # 16 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:39:20.137 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:20.137 | Historical data download thread signaled to stop. 2024-04-24 22:39:20.137 | HD Request # 16 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:39:20.137 | HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:20.137 | HD Request # 16 | Completion time: 1s. 2024-04-24 22:39:20.137 | HD Request # 16 | Intraday data download complete for ESM24-CME. Unique request ID: 16 2024-04-24 22:39:20.137 | Removing historical data download ID 16. 2024-04-24 22:39:20.137 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:39:20.137 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:39:20.137 | HD Request # 16 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:20.137 | 2024-04-24 22:39:20.137 | No download requests in the queue to start downloads for. 2024-04-24 22:39:20.192 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:20.192 | Socket (7) | Closed. 2024-04-24 22:39:20.520 | Opened cached Intraday file: C:\SierraChart2\Data\ESM4.CME.scid. Thread ID: 2020 2024-04-24 22:39:20.945 | Unsubscribed from market depth data for ESM4.CME 2024-04-24 22:39:21.875 | ESM4.CME/MESM4.CME [CBV] #2 | Reloading chart. 2024-04-24 22:39:21.894 | ESM4.CME/MESM4.CME [CBV] #2 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-04-24 22:39:21.901 | ESM4.CME/MESM4.CME [CBV] #2 | Chart data loading complete. 2024-04-24 22:39:21.915 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:21.915 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:21.916 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:21.916 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:21.916 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:21.971 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:21.971 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:21.971 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:21.971 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:22.137 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:22.137 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:22.137 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:22.137 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:22.137 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:22.137 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:22.137 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:22.137 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:39:22.137 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:39:22.137 | Triggering next historical data download in queue. 2024-04-24 22:39:22.137 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:22.137 | HD Request # 17 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:39:22.138 | HD Request # 17 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:22.138 | HD Request # 17 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:39:22.138 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:22.139 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:22.139 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:22.192 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:22.192 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:22.192 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:22.192 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:22.192 | DTC Client socket (4) | Closed. 2024-04-24 22:39:22.193 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:22.193 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:22.193 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:22.194 | HD Request # 17 | Sending historical data logon request message. 2024-04-24 22:39:22.363 | HD Request # 17 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:39:22.417 | Socket (7) | CloseSocket call. 2024-04-24 22:39:22.417 | HD Request # 17 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:39:22.417 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:22.417 | Historical data download thread signaled to stop. 2024-04-24 22:39:22.417 | HD Request # 17 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:39:22.417 | HD Request # 17 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:22.417 | HD Request # 17 | Completion time: 0s. 2024-04-24 22:39:22.417 | HD Request # 17 | Intraday data download complete for ESM24-CME. Unique request ID: 17 2024-04-24 22:39:22.417 | Removing historical data download ID 17. 2024-04-24 22:39:22.417 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:39:22.417 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:39:22.417 | HD Request # 17 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:22.417 | 2024-04-24 22:39:22.417 | No download requests in the queue to start downloads for. 2024-04-24 22:39:22.471 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:22.471 | Socket (7) | Closed. 2024-04-24 22:39:24.192 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:24.192 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:24.192 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:24.192 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:24.192 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:24.247 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:24.248 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:24.248 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:24.248 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:24.412 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:24.412 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:24.412 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:24.412 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:24.412 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:24.412 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:24.412 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:24.412 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:39:24.412 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:39:24.412 | Triggering next historical data download in queue. 2024-04-24 22:39:24.412 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:24.412 | HD Request # 18 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:39:24.412 | HD Request # 18 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:24.412 | HD Request # 18 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:39:24.412 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:24.412 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:24.412 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:24.465 | HD Request # 18 | Sending historical data logon request message. 2024-04-24 22:39:24.466 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:24.466 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:24.466 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:24.466 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:24.466 | DTC Client socket (4) | Closed. 2024-04-24 22:39:24.466 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:24.466 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:24.466 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:24.633 | HD Request # 18 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:39:24.688 | Socket (7) | CloseSocket call. 2024-04-24 22:39:24.688 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:24.688 | HD Request # 18 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:39:24.689 | Historical data download thread signaled to stop. 2024-04-24 22:39:24.689 | HD Request # 18 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:39:24.689 | HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:24.689 | HD Request # 18 | Completion time: 0s. 2024-04-24 22:39:24.689 | HD Request # 18 | Intraday data download complete for ESM24-CME. Unique request ID: 18 2024-04-24 22:39:24.689 | Removing historical data download ID 18. 2024-04-24 22:39:24.689 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:39:24.689 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:39:24.689 | HD Request # 18 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:24.689 | 2024-04-24 22:39:24.689 | No download requests in the queue to start downloads for. 2024-04-24 22:39:24.742 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:24.742 | Socket (7) | Closed. 2024-04-24 22:39:25.945 | Requesting market depth updates for: ESM4.CME if supported. NumLevels=100 2024-04-24 22:39:26.081 | Denali Data Feed | Clearing market depth for ESM4.CME 2024-04-24 22:39:26.461 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:26.461 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:26.462 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:26.462 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:26.462 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:26.518 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:26.518 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:26.518 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:26.518 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:26.689 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:26.689 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:26.689 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:26.689 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:26.689 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:26.689 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:26.689 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:26.689 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:39:26.689 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:39:26.689 | Triggering next historical data download in queue. 2024-04-24 22:39:26.689 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:26.689 | HD Request # 19 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:39:26.690 | HD Request # 19 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:26.690 | HD Request # 19 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:39:26.690 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:26.690 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:26.690 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:26.744 | HD Request # 19 | Sending historical data logon request message. 2024-04-24 22:39:26.744 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:26.744 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:26.744 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:26.744 | DTC Client socket (4) | Closed. 2024-04-24 22:39:26.744 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:26.745 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:26.745 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:26.745 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:26.909 | HD Request # 19 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:39:26.962 | Socket (7) | CloseSocket call. 2024-04-24 22:39:26.962 | HD Request # 19 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:39:26.962 | Historical data download thread signaled to stop. 2024-04-24 22:39:26.962 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:26.962 | HD Request # 19 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:39:26.962 | HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:26.962 | HD Request # 19 | Completion time: 0s. 2024-04-24 22:39:26.962 | HD Request # 19 | Intraday data download complete for ESM24-CME. Unique request ID: 19 2024-04-24 22:39:26.962 | Removing historical data download ID 19. 2024-04-24 22:39:26.962 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:39:26.962 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:39:26.962 | HD Request # 19 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:26.962 | 2024-04-24 22:39:26.962 | No download requests in the queue to start downloads for. 2024-04-24 22:39:27.016 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:27.016 | Socket (7) | Closed. 2024-04-24 22:39:28.750 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:28.750 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:28.751 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:28.752 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:28.752 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:28.806 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:28.806 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:28.806 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:28.806 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:28.974 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:28.974 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:28.974 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:28.974 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:28.974 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:28.974 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:28.974 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:28.974 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:39:28.974 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:39:28.974 | Triggering next historical data download in queue. 2024-04-24 22:39:28.974 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:28.974 | HD Request # 20 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:39:28.975 | HD Request # 20 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:28.975 | HD Request # 20 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:39:28.975 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:28.975 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:28.975 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:29.028 | HD Request # 20 | Sending historical data logon request message. 2024-04-24 22:39:29.028 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:29.028 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:29.028 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:29.028 | DTC Client socket (4) | Closed. 2024-04-24 22:39:29.028 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:29.029 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:29.029 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:29.029 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:29.190 | HD Request # 20 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:39:29.244 | Socket (7) | CloseSocket call. 2024-04-24 22:39:29.244 | HD Request # 20 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:39:29.244 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:29.244 | Historical data download thread signaled to stop. 2024-04-24 22:39:29.244 | HD Request # 20 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:39:29.244 | HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:29.244 | HD Request # 20 | Completion time: 1s. 2024-04-24 22:39:29.244 | HD Request # 20 | Intraday data download complete for ESM24-CME. Unique request ID: 20 2024-04-24 22:39:29.244 | Removing historical data download ID 20. 2024-04-24 22:39:29.244 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:39:29.244 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:39:29.244 | HD Request # 20 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:29.244 | 2024-04-24 22:39:29.244 | No download requests in the queue to start downloads for. 2024-04-24 22:39:29.298 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:29.298 | Socket (7) | Closed. 2024-04-24 22:39:31.006 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:31.006 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:31.008 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:31.008 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:31.008 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:31.064 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:31.064 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:31.064 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:31.064 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:31.228 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:31.228 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:31.228 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:31.228 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:31.228 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:31.228 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:31.228 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:31.228 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:39:31.228 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:39:31.228 | Triggering next historical data download in queue. 2024-04-24 22:39:31.228 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:31.228 | HD Request # 21 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:39:31.229 | HD Request # 21 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:31.229 | HD Request # 21 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:39:31.229 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:31.229 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:31.229 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:31.282 | HD Request # 21 | Sending historical data logon request message. 2024-04-24 22:39:31.283 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:31.283 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:31.283 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:31.283 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:31.283 | DTC Client socket (4) | Closed. 2024-04-24 22:39:31.284 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:31.284 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:31.284 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:31.445 | HD Request # 21 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:39:31.498 | Socket (7) | CloseSocket call. 2024-04-24 22:39:31.499 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:31.507 | HD Request # 21 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:39:31.507 | Historical data download thread signaled to stop. 2024-04-24 22:39:31.507 | HD Request # 21 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:39:31.507 | HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:31.507 | HD Request # 21 | Completion time: 0s. 2024-04-24 22:39:31.507 | HD Request # 21 | Intraday data download complete for ESM24-CME. Unique request ID: 21 2024-04-24 22:39:31.507 | Removing historical data download ID 21. 2024-04-24 22:39:31.507 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:39:31.507 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:39:31.507 | HD Request # 21 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:31.507 | 2024-04-24 22:39:31.507 | No download requests in the queue to start downloads for. 2024-04-24 22:39:31.553 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:31.553 | Socket (7) | Closed. 2024-04-24 22:39:33.276 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:33.276 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:33.276 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:33.276 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:33.276 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:33.332 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:33.332 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:33.332 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:33.332 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:33.496 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:33.496 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:33.496 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:33.496 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:33.496 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:33.496 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:33.496 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:33.496 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:39:33.496 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:39:33.496 | Triggering next historical data download in queue. 2024-04-24 22:39:33.496 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:33.496 | HD Request # 22 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:39:33.496 | HD Request # 22 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:33.496 | HD Request # 22 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:39:33.496 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:33.496 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:33.496 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:33.548 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:33.548 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:33.548 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:33.549 | HD Request # 22 | Sending historical data logon request message. 2024-04-24 22:39:33.549 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:33.549 | DTC Client socket (4) | Closed. 2024-04-24 22:39:33.549 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:33.549 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:33.549 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:33.711 | HD Request # 22 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:39:33.765 | Socket (7) | CloseSocket call. 2024-04-24 22:39:33.765 | HD Request # 22 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:39:33.765 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:33.765 | Historical data download thread signaled to stop. 2024-04-24 22:39:33.765 | HD Request # 22 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:39:33.765 | HD Request # 22 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:33.765 | HD Request # 22 | Completion time: 0s. 2024-04-24 22:39:33.765 | HD Request # 22 | Intraday data download complete for ESM24-CME. Unique request ID: 22 2024-04-24 22:39:33.765 | Removing historical data download ID 22. 2024-04-24 22:39:33.765 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:39:33.765 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:39:33.765 | HD Request # 22 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:33.765 | 2024-04-24 22:39:33.765 | No download requests in the queue to start downloads for. 2024-04-24 22:39:33.818 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:33.818 | Socket (7) | Closed. 2024-04-24 22:39:35.545 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:35.545 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:35.546 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:35.546 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:35.546 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:35.599 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:35.599 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:35.600 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:35.600 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:35.765 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:35.765 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:35.765 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:35.765 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:35.765 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:35.765 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:35.765 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:35.765 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:39:35.765 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:39:35.765 | Triggering next historical data download in queue. 2024-04-24 22:39:35.765 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:35.765 | HD Request # 23 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:39:35.765 | HD Request # 23 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:35.765 | HD Request # 23 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:39:35.765 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:35.765 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:35.765 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:35.819 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:35.819 | HD Request # 23 | Sending historical data logon request message. 2024-04-24 22:39:35.819 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:35.819 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:35.819 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:35.819 | DTC Client socket (4) | Closed. 2024-04-24 22:39:35.819 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:35.819 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:35.819 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:35.992 | HD Request # 23 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:39:36.045 | Socket (7) | CloseSocket call. 2024-04-24 22:39:36.045 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:36.046 | HD Request # 23 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:39:36.046 | Historical data download thread signaled to stop. 2024-04-24 22:39:36.046 | HD Request # 23 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:39:36.046 | HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:36.046 | HD Request # 23 | Completion time: 1s. 2024-04-24 22:39:36.046 | HD Request # 23 | Intraday data download complete for ESM24-CME. Unique request ID: 23 2024-04-24 22:39:36.046 | Removing historical data download ID 23. 2024-04-24 22:39:36.046 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:39:36.046 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:39:36.046 | HD Request # 23 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:36.046 | 2024-04-24 22:39:36.046 | No download requests in the queue to start downloads for. 2024-04-24 22:39:36.100 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:36.100 | Socket (7) | Closed. 2024-04-24 22:39:37.803 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:37.803 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:37.804 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:37.804 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:37.804 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:37.858 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:37.858 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:37.858 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:37.858 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:38.026 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:38.026 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:38.026 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:38.026 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:38.026 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:38.026 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:38.026 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:38.026 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:39:38.026 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:39:38.026 | Triggering next historical data download in queue. 2024-04-24 22:39:38.026 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:38.026 | HD Request # 24 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:39:38.027 | HD Request # 24 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:38.027 | HD Request # 24 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:39:38.027 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:38.027 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:38.027 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:38.081 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:38.081 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:38.081 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:38.081 | DTC Client socket (4) | Closed. 2024-04-24 22:39:38.081 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:38.082 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:38.082 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:38.082 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:38.082 | HD Request # 24 | Sending historical data logon request message. 2024-04-24 22:39:38.247 | HD Request # 24 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:39:38.300 | Socket (7) | CloseSocket call. 2024-04-24 22:39:38.300 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:38.300 | HD Request # 24 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:39:38.300 | Historical data download thread signaled to stop. 2024-04-24 22:39:38.300 | HD Request # 24 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:39:38.300 | HD Request # 24 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:38.300 | HD Request # 24 | Completion time: 0s. 2024-04-24 22:39:38.300 | HD Request # 24 | Intraday data download complete for ESM24-CME. Unique request ID: 24 2024-04-24 22:39:38.300 | Removing historical data download ID 24. 2024-04-24 22:39:38.300 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:39:38.300 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:39:38.300 | HD Request # 24 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:38.300 | 2024-04-24 22:39:38.300 | No download requests in the queue to start downloads for. 2024-04-24 22:39:38.355 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:38.355 | Socket (7) | Closed. 2024-04-24 22:39:40.071 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:40.071 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:40.076 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:40.076 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:40.076 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:40.132 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:40.132 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:40.132 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:40.132 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:40.297 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:40.297 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:40.297 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:40.297 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:40.297 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:40.297 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:40.297 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:40.297 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:39:40.297 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:39:40.297 | Triggering next historical data download in queue. 2024-04-24 22:39:40.297 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:40.297 | HD Request # 25 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:39:40.297 | HD Request # 25 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:40.298 | HD Request # 25 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:39:40.298 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:40.298 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:40.298 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:40.349 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:40.349 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:40.349 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:40.349 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:40.349 | DTC Client socket (4) | Closed. 2024-04-24 22:39:40.349 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:40.349 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:40.349 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:40.351 | HD Request # 25 | Sending historical data logon request message. 2024-04-24 22:39:40.515 | HD Request # 25 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:39:40.569 | Socket (7) | CloseSocket call. 2024-04-24 22:39:40.569 | HD Request # 25 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:39:40.569 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:40.569 | Historical data download thread signaled to stop. 2024-04-24 22:39:40.569 | HD Request # 25 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:39:40.570 | HD Request # 25 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:40.570 | HD Request # 25 | Completion time: 0s. 2024-04-24 22:39:40.570 | HD Request # 25 | Intraday data download complete for ESM24-CME. Unique request ID: 25 2024-04-24 22:39:40.570 | Removing historical data download ID 25. 2024-04-24 22:39:40.570 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:39:40.570 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:39:40.570 | HD Request # 25 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:40.570 | 2024-04-24 22:39:40.570 | No download requests in the queue to start downloads for. 2024-04-24 22:39:40.626 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:40.626 | Socket (7) | Closed. 2024-04-24 22:39:42.337 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:42.337 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:42.342 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:42.342 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:42.342 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:42.394 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:42.394 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:42.395 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:42.395 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:42.564 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:42.564 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:42.564 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:42.564 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:42.564 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:42.564 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:42.564 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:42.564 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:39:42.564 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:39:42.564 | Triggering next historical data download in queue. 2024-04-24 22:39:42.564 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:42.564 | HD Request # 26 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:39:42.564 | HD Request # 26 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:42.564 | HD Request # 26 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:39:42.564 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:42.565 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:42.565 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:42.616 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:42.616 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:42.616 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:42.616 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:42.616 | DTC Client socket (4) | Closed. 2024-04-24 22:39:42.617 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:42.617 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:42.617 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:42.618 | HD Request # 26 | Sending historical data logon request message. 2024-04-24 22:39:42.781 | HD Request # 26 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:39:42.835 | Socket (7) | CloseSocket call. 2024-04-24 22:39:42.835 | HD Request # 26 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:39:42.836 | Historical data download thread signaled to stop. 2024-04-24 22:39:42.836 | HD Request # 26 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:39:42.836 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:42.836 | HD Request # 26 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:42.836 | HD Request # 26 | Completion time: 0s. 2024-04-24 22:39:42.836 | HD Request # 26 | Intraday data download complete for ESM24-CME. Unique request ID: 26 2024-04-24 22:39:42.836 | Removing historical data download ID 26. 2024-04-24 22:39:42.836 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:39:42.836 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:39:42.836 | HD Request # 26 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:42.836 | 2024-04-24 22:39:42.836 | No download requests in the queue to start downloads for. 2024-04-24 22:39:42.889 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:42.889 | Socket (7) | Closed. 2024-04-24 22:39:44.605 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:44.605 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:44.606 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:44.606 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:44.606 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:44.659 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:44.659 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:44.659 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:44.659 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:44.827 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:44.827 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:44.827 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:44.827 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:44.827 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:44.827 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:44.827 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:44.827 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:39:44.827 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:39:44.827 | Triggering next historical data download in queue. 2024-04-24 22:39:44.827 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:44.827 | HD Request # 27 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:39:44.827 | HD Request # 27 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:44.827 | HD Request # 27 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:39:44.828 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:44.828 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:44.828 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:44.880 | HD Request # 27 | Sending historical data logon request message. 2024-04-24 22:39:44.880 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:44.880 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:44.880 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:44.880 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:44.880 | DTC Client socket (4) | Closed. 2024-04-24 22:39:44.881 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:44.881 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:44.881 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:45.043 | HD Request # 27 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:39:45.095 | Socket (7) | CloseSocket call. 2024-04-24 22:39:45.095 | HD Request # 27 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:39:45.095 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:45.095 | Historical data download thread signaled to stop. 2024-04-24 22:39:45.095 | HD Request # 27 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:39:45.096 | HD Request # 27 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:45.096 | HD Request # 27 | Completion time: 1s. 2024-04-24 22:39:45.096 | HD Request # 27 | Intraday data download complete for ESM24-CME. Unique request ID: 27 2024-04-24 22:39:45.096 | Removing historical data download ID 27. 2024-04-24 22:39:45.096 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:39:45.096 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:39:45.096 | HD Request # 27 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:45.096 | 2024-04-24 22:39:45.096 | No download requests in the queue to start downloads for. 2024-04-24 22:39:45.151 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:45.151 | Socket (7) | Closed. 2024-04-24 22:39:46.873 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:46.873 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:46.874 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:46.874 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:46.874 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:46.930 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:46.930 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:46.930 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:46.930 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:47.098 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:47.098 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:47.098 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:47.098 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:47.098 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:47.098 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:47.098 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:47.098 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:39:47.098 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:39:47.098 | Triggering next historical data download in queue. 2024-04-24 22:39:47.098 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:47.098 | HD Request # 28 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:39:47.098 | HD Request # 28 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:47.098 | HD Request # 28 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:39:47.098 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:47.098 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:47.098 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:47.152 | HD Request # 28 | Sending historical data logon request message. 2024-04-24 22:39:47.152 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:47.152 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:47.152 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:47.152 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:47.153 | DTC Client socket (4) | Closed. 2024-04-24 22:39:47.153 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:47.153 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:47.153 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:47.318 | HD Request # 28 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:39:47.373 | Socket (7) | CloseSocket call. 2024-04-24 22:39:47.373 | HD Request # 28 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:39:47.373 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:47.373 | Historical data download thread signaled to stop. 2024-04-24 22:39:47.373 | HD Request # 28 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:39:47.373 | HD Request # 28 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:47.373 | HD Request # 28 | Completion time: 0s. 2024-04-24 22:39:47.373 | HD Request # 28 | Intraday data download complete for ESM24-CME. Unique request ID: 28 2024-04-24 22:39:47.373 | Removing historical data download ID 28. 2024-04-24 22:39:47.373 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:39:47.373 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:39:47.373 | HD Request # 28 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:47.373 | 2024-04-24 22:39:47.373 | No download requests in the queue to start downloads for. 2024-04-24 22:39:47.427 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:47.427 | Socket (7) | Closed. 2024-04-24 22:39:49.141 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:49.141 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:49.142 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:49.142 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:49.142 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:49.198 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:49.198 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:49.198 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:49.198 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:49.364 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:49.364 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:49.364 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:49.364 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:49.364 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:49.364 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:49.364 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:49.364 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:39:49.364 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:39:49.364 | Triggering next historical data download in queue. 2024-04-24 22:39:49.364 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:49.364 | HD Request # 29 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:39:49.364 | HD Request # 29 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:49.364 | HD Request # 29 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:39:49.364 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:49.364 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:49.364 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:49.417 | HD Request # 29 | Sending historical data logon request message. 2024-04-24 22:39:49.418 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:49.418 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:49.418 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:49.418 | DTC Client socket (4) | Closed. 2024-04-24 22:39:49.418 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:49.418 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:49.418 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:49.418 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:49.585 | HD Request # 29 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:39:49.638 | Socket (7) | CloseSocket call. 2024-04-24 22:39:49.638 | HD Request # 29 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:39:49.638 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:49.638 | Historical data download thread signaled to stop. 2024-04-24 22:39:49.638 | HD Request # 29 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:39:49.639 | HD Request # 29 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:49.639 | HD Request # 29 | Completion time: 0s. 2024-04-24 22:39:49.639 | HD Request # 29 | Intraday data download complete for ESM24-CME. Unique request ID: 29 2024-04-24 22:39:49.639 | Removing historical data download ID 29. 2024-04-24 22:39:49.639 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:39:49.639 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:39:49.639 | HD Request # 29 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:49.639 | 2024-04-24 22:39:49.639 | No download requests in the queue to start downloads for. 2024-04-24 22:39:49.692 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:49.692 | Socket (7) | Closed. 2024-04-24 22:39:51.396 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:51.396 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:51.396 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:51.396 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:51.396 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:51.452 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:51.452 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:51.452 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:51.452 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:51.621 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:51.621 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:51.621 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:51.621 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:51.621 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:51.621 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:51.621 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:51.621 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:39:51.621 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:39:51.621 | Triggering next historical data download in queue. 2024-04-24 22:39:51.621 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:51.621 | HD Request # 30 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:39:51.622 | HD Request # 30 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:51.622 | HD Request # 30 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:39:51.622 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:51.623 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:51.623 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:51.677 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:51.677 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:51.677 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:51.678 | HD Request # 30 | Sending historical data logon request message. 2024-04-24 22:39:51.678 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:51.678 | DTC Client socket (4) | Closed. 2024-04-24 22:39:51.678 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:51.678 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:51.678 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:51.847 | HD Request # 30 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:39:51.902 | Socket (7) | CloseSocket call. 2024-04-24 22:39:51.902 | HD Request # 30 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:39:51.902 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:51.902 | Historical data download thread signaled to stop. 2024-04-24 22:39:51.902 | HD Request # 30 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:39:51.903 | HD Request # 30 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:51.903 | HD Request # 30 | Completion time: 0s. 2024-04-24 22:39:51.903 | HD Request # 30 | Intraday data download complete for ESM24-CME. Unique request ID: 30 2024-04-24 22:39:51.903 | Removing historical data download ID 30. 2024-04-24 22:39:51.903 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:39:51.903 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:39:51.903 | HD Request # 30 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:51.903 | 2024-04-24 22:39:51.903 | No download requests in the queue to start downloads for. 2024-04-24 22:39:51.955 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:51.955 | Socket (7) | Closed. 2024-04-24 22:39:53.689 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:53.689 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:53.690 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:53.690 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:53.690 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:53.744 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:53.744 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:53.744 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:53.744 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:53.910 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:53.910 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:53.910 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:53.910 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:53.910 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:53.910 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:53.910 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:53.910 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:39:53.910 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:39:53.910 | Triggering next historical data download in queue. 2024-04-24 22:39:53.910 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:53.910 | HD Request # 31 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:39:53.910 | HD Request # 31 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:53.910 | HD Request # 31 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:39:53.910 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:53.910 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:53.910 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:53.966 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:53.966 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:53.966 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:53.966 | HD Request # 31 | Sending historical data logon request message. 2024-04-24 22:39:53.967 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:53.967 | DTC Client socket (4) | Closed. 2024-04-24 22:39:53.967 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:53.967 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:53.967 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:54.133 | HD Request # 31 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:39:54.187 | Socket (7) | CloseSocket call. 2024-04-24 22:39:54.187 | HD Request # 31 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:39:54.187 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:54.187 | Historical data download thread signaled to stop. 2024-04-24 22:39:54.187 | HD Request # 31 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:39:54.188 | HD Request # 31 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:54.188 | HD Request # 31 | Completion time: 1s. 2024-04-24 22:39:54.188 | HD Request # 31 | Intraday data download complete for ESM24-CME. Unique request ID: 31 2024-04-24 22:39:54.188 | Removing historical data download ID 31. 2024-04-24 22:39:54.188 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:39:54.188 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:39:54.188 | HD Request # 31 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:54.188 | 2024-04-24 22:39:54.188 | No download requests in the queue to start downloads for. 2024-04-24 22:39:54.241 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:54.241 | Socket (7) | Closed. 2024-04-24 22:39:55.962 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:55.962 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:55.963 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:55.963 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:55.963 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:56.017 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:56.017 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:56.017 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:56.017 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:56.185 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:56.185 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:56.185 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:56.185 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:56.185 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:56.185 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:56.185 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:56.185 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:39:56.185 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:39:56.185 | Triggering next historical data download in queue. 2024-04-24 22:39:56.185 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:56.185 | HD Request # 32 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:39:56.185 | HD Request # 32 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:56.185 | HD Request # 32 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:39:56.185 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:56.185 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:56.185 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:56.239 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:56.239 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:56.239 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:56.239 | DTC Client socket (4) | Closed. 2024-04-24 22:39:56.240 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:56.240 | HD Request # 32 | Sending historical data logon request message. 2024-04-24 22:39:56.240 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:56.240 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:56.240 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:56.407 | HD Request # 32 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:39:56.462 | Socket (7) | CloseSocket call. 2024-04-24 22:39:56.462 | HD Request # 32 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:39:56.462 | Historical data download thread signaled to stop. 2024-04-24 22:39:56.462 | HD Request # 32 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:39:56.462 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:56.462 | HD Request # 32 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:56.462 | HD Request # 32 | Completion time: 0s. 2024-04-24 22:39:56.462 | HD Request # 32 | Intraday data download complete for ESM24-CME. Unique request ID: 32 2024-04-24 22:39:56.462 | Removing historical data download ID 32. 2024-04-24 22:39:56.462 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:39:56.462 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:39:56.462 | HD Request # 32 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:56.462 | 2024-04-24 22:39:56.462 | No download requests in the queue to start downloads for. 2024-04-24 22:39:56.515 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:56.515 | Socket (7) | Closed. 2024-04-24 22:39:58.241 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:39:58.241 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:39:58.242 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:58.242 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:39:58.242 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:58.296 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:39:58.296 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:39:58.296 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:39:58.296 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:39:58.463 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:39:58.463 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:39:58.463 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:39:58.463 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:39:58.463 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:39:58.463 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:39:58.463 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:39:58.463 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:39:58.463 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:39:58.463 | Triggering next historical data download in queue. 2024-04-24 22:39:58.463 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:39:58.463 | HD Request # 33 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:39:58.463 | HD Request # 33 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:58.463 | HD Request # 33 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:39:58.463 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:39:58.464 | Socket (7) | New receive buffer size: 0 2024-04-24 22:39:58.464 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:39:58.517 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:39:58.517 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:39:58.517 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:39:58.517 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:39:58.517 | DTC Client socket (4) | Closed. 2024-04-24 22:39:58.518 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:39:58.518 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:39:58.518 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:39:58.518 | HD Request # 33 | Sending historical data logon request message. 2024-04-24 22:39:58.690 | HD Request # 33 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:39:58.744 | Socket (7) | CloseSocket call. 2024-04-24 22:39:58.744 | HD Request # 33 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:39:58.744 | Historical data download thread signaled to stop. 2024-04-24 22:39:58.744 | HD Request # 33 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:39:58.744 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:39:58.744 | HD Request # 33 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:39:58.745 | HD Request # 33 | Completion time: 0s. 2024-04-24 22:39:58.745 | HD Request # 33 | Intraday data download complete for ESM24-CME. Unique request ID: 33 2024-04-24 22:39:58.745 | Removing historical data download ID 33. 2024-04-24 22:39:58.745 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:39:58.745 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:39:58.745 | HD Request # 33 | Enabling Intraday chart updating for symbol. 2024-04-24 22:39:58.745 | 2024-04-24 22:39:58.745 | No download requests in the queue to start downloads for. 2024-04-24 22:39:58.800 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:39:58.800 | Socket (7) | Closed. 2024-04-24 22:40:00.505 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:00.505 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:00.510 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:00.511 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:00.511 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:00.566 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:00.566 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:00.566 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:00.566 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:00.728 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:00.728 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:00.728 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:00.728 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:00.728 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:00.728 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:00.728 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:00.728 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:00.728 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:00.728 | Triggering next historical data download in queue. 2024-04-24 22:40:00.728 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:00.728 | HD Request # 34 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:00.728 | HD Request # 34 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:00.728 | HD Request # 34 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:00.728 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:00.728 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:00.728 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:00.781 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:00.781 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:00.781 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:00.781 | DTC Client socket (4) | Closed. 2024-04-24 22:40:00.781 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:00.781 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:00.781 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:00.781 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:00.782 | HD Request # 34 | Sending historical data logon request message. 2024-04-24 22:40:00.943 | HD Request # 34 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:00.996 | Socket (7) | CloseSocket call. 2024-04-24 22:40:00.996 | HD Request # 34 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:00.996 | Historical data download thread signaled to stop. 2024-04-24 22:40:00.996 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:00.996 | HD Request # 34 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:00.996 | HD Request # 34 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:00.996 | HD Request # 34 | Completion time: 0s. 2024-04-24 22:40:00.996 | HD Request # 34 | Intraday data download complete for ESM24-CME. Unique request ID: 34 2024-04-24 22:40:00.996 | Removing historical data download ID 34. 2024-04-24 22:40:00.996 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:00.996 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:00.996 | HD Request # 34 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:00.996 | 2024-04-24 22:40:00.996 | No download requests in the queue to start downloads for. 2024-04-24 22:40:01.050 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:01.050 | Socket (7) | Closed. 2024-04-24 22:40:01.375 | Opened cached Intraday file: C:\SierraChart2\Data\SPY.scid. Thread ID: 3160 2024-04-24 22:40:02.770 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:02.770 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:02.770 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:02.770 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:02.770 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:02.824 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:02.824 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:02.824 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:02.824 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:02.989 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:02.989 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:02.989 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:02.989 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:02.989 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:02.989 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:02.989 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:02.989 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:02.989 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:02.989 | Triggering next historical data download in queue. 2024-04-24 22:40:02.989 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:02.989 | HD Request # 35 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:02.989 | HD Request # 35 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:02.989 | HD Request # 35 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:02.989 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:02.989 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:02.989 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:03.042 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:03.042 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:03.042 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:03.042 | DTC Client socket (4) | Closed. 2024-04-24 22:40:03.042 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:03.042 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:03.042 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:03.042 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:03.042 | HD Request # 35 | Sending historical data logon request message. 2024-04-24 22:40:03.209 | HD Request # 35 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:03.262 | Socket (7) | CloseSocket call. 2024-04-24 22:40:03.262 | HD Request # 35 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:03.262 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:03.262 | Historical data download thread signaled to stop. 2024-04-24 22:40:03.262 | HD Request # 35 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:03.262 | HD Request # 35 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:03.262 | HD Request # 35 | Completion time: 1s. 2024-04-24 22:40:03.262 | HD Request # 35 | Intraday data download complete for ESM24-CME. Unique request ID: 35 2024-04-24 22:40:03.262 | Removing historical data download ID 35. 2024-04-24 22:40:03.262 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:03.262 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:03.262 | HD Request # 35 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:03.262 | 2024-04-24 22:40:03.262 | No download requests in the queue to start downloads for. 2024-04-24 22:40:03.316 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:03.316 | Socket (7) | Closed. 2024-04-24 22:40:05.034 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:05.034 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:05.034 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:05.034 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:05.034 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:05.088 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:05.088 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:05.088 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:05.088 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:05.256 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:05.256 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:05.256 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:05.256 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:05.256 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:05.256 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:05.256 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:05.256 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:05.256 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:05.256 | Triggering next historical data download in queue. 2024-04-24 22:40:05.256 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:05.256 | HD Request # 36 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:05.256 | HD Request # 36 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:05.256 | HD Request # 36 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:05.256 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:05.256 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:05.256 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:05.310 | HD Request # 36 | Sending historical data logon request message. 2024-04-24 22:40:05.311 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:05.311 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:05.311 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:05.311 | DTC Client socket (4) | Closed. 2024-04-24 22:40:05.312 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:05.313 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:05.313 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:05.313 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:05.476 | HD Request # 36 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:05.529 | Socket (7) | CloseSocket call. 2024-04-24 22:40:05.529 | HD Request # 36 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:05.529 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:05.529 | Historical data download thread signaled to stop. 2024-04-24 22:40:05.529 | HD Request # 36 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:05.529 | HD Request # 36 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:05.529 | HD Request # 36 | Completion time: 0s. 2024-04-24 22:40:05.529 | HD Request # 36 | Intraday data download complete for ESM24-CME. Unique request ID: 36 2024-04-24 22:40:05.529 | Removing historical data download ID 36. 2024-04-24 22:40:05.529 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:05.529 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:05.529 | HD Request # 36 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:05.529 | 2024-04-24 22:40:05.529 | No download requests in the queue to start downloads for. 2024-04-24 22:40:05.583 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:05.583 | Socket (7) | Closed. 2024-04-24 22:40:07.309 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:07.309 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:07.309 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:07.309 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:07.309 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:07.364 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:07.364 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:07.364 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:07.364 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:07.529 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:07.529 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:07.529 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:07.529 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:07.529 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:07.529 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:07.529 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:07.529 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:07.529 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:07.529 | Triggering next historical data download in queue. 2024-04-24 22:40:07.529 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:07.530 | HD Request # 37 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:07.530 | HD Request # 37 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:07.530 | HD Request # 37 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:07.531 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:07.531 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:07.531 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:07.584 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:07.584 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:07.584 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:07.585 | HD Request # 37 | Sending historical data logon request message. 2024-04-24 22:40:07.585 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:07.585 | DTC Client socket (4) | Closed. 2024-04-24 22:40:07.585 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:07.585 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:07.585 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:07.752 | HD Request # 37 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:07.806 | Socket (7) | CloseSocket call. 2024-04-24 22:40:07.806 | HD Request # 37 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:07.806 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:07.806 | Historical data download thread signaled to stop. 2024-04-24 22:40:07.806 | HD Request # 37 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:07.806 | HD Request # 37 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:07.806 | HD Request # 37 | Completion time: 0s. 2024-04-24 22:40:07.806 | HD Request # 37 | Intraday data download complete for ESM24-CME. Unique request ID: 37 2024-04-24 22:40:07.806 | Removing historical data download ID 37. 2024-04-24 22:40:07.806 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:07.806 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:07.806 | HD Request # 37 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:07.806 | 2024-04-24 22:40:07.806 | No download requests in the queue to start downloads for. 2024-04-24 22:40:07.863 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:07.863 | Socket (7) | Closed. 2024-04-24 22:40:09.597 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:09.597 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:09.598 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:09.598 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:09.598 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:09.653 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:09.653 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:09.653 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:09.653 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:09.820 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:09.820 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:09.820 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:09.820 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:09.820 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:09.820 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:09.820 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:09.820 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:09.820 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:09.820 | Triggering next historical data download in queue. 2024-04-24 22:40:09.820 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:09.820 | HD Request # 38 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:09.820 | HD Request # 38 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:09.820 | HD Request # 38 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:09.820 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:09.820 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:09.820 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:09.873 | HD Request # 38 | Sending historical data logon request message. 2024-04-24 22:40:09.873 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:09.873 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:09.873 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:09.873 | DTC Client socket (4) | Closed. 2024-04-24 22:40:09.874 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:09.874 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:09.874 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:09.874 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:10.037 | HD Request # 38 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:10.090 | Socket (7) | CloseSocket call. 2024-04-24 22:40:10.090 | HD Request # 38 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:10.090 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:10.090 | Historical data download thread signaled to stop. 2024-04-24 22:40:10.090 | HD Request # 38 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:10.090 | HD Request # 38 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:10.090 | HD Request # 38 | Completion time: 1s. 2024-04-24 22:40:10.090 | HD Request # 38 | Intraday data download complete for ESM24-CME. Unique request ID: 38 2024-04-24 22:40:10.090 | Removing historical data download ID 38. 2024-04-24 22:40:10.090 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:10.090 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:10.090 | HD Request # 38 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:10.090 | 2024-04-24 22:40:10.090 | No download requests in the queue to start downloads for. 2024-04-24 22:40:10.144 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:10.144 | Socket (7) | Closed. 2024-04-24 22:40:11.875 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:11.875 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:11.876 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:11.877 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:11.877 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:11.931 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:11.931 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:11.932 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:11.932 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:12.098 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:12.098 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:12.098 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:12.098 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:12.098 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:12.098 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:12.098 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:12.098 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:12.098 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:12.098 | Triggering next historical data download in queue. 2024-04-24 22:40:12.098 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:12.098 | HD Request # 39 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:12.098 | HD Request # 39 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:12.098 | HD Request # 39 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:12.098 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:12.098 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:12.098 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:12.152 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:12.153 | HD Request # 39 | Sending historical data logon request message. 2024-04-24 22:40:12.153 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:12.153 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:12.153 | DTC Client socket (4) | Closed. 2024-04-24 22:40:12.153 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:12.154 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:12.154 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:12.154 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:12.318 | HD Request # 39 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:12.374 | Socket (7) | CloseSocket call. 2024-04-24 22:40:12.374 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:12.374 | HD Request # 39 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:12.374 | Historical data download thread signaled to stop. 2024-04-24 22:40:12.374 | HD Request # 39 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:12.374 | HD Request # 39 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:12.374 | HD Request # 39 | Completion time: 0s. 2024-04-24 22:40:12.374 | HD Request # 39 | Intraday data download complete for ESM24-CME. Unique request ID: 39 2024-04-24 22:40:12.374 | Removing historical data download ID 39. 2024-04-24 22:40:12.374 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:12.374 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:12.374 | HD Request # 39 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:12.374 | 2024-04-24 22:40:12.374 | No download requests in the queue to start downloads for. 2024-04-24 22:40:12.426 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:12.426 | Socket (7) | Closed. 2024-04-24 22:40:14.148 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:14.148 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:14.149 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:14.149 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:14.149 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:14.203 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:14.203 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:14.203 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:14.203 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:14.369 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:14.369 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:14.369 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:14.369 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:14.369 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:14.369 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:14.369 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:14.369 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:14.369 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:14.369 | Triggering next historical data download in queue. 2024-04-24 22:40:14.369 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:14.369 | HD Request # 40 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:14.369 | HD Request # 40 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:14.369 | HD Request # 40 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:14.369 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:14.370 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:14.370 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:14.423 | HD Request # 40 | Sending historical data logon request message. 2024-04-24 22:40:14.423 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:14.423 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:14.423 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:14.423 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:14.423 | DTC Client socket (4) | Closed. 2024-04-24 22:40:14.424 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:14.424 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:14.424 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:14.587 | HD Request # 40 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:14.640 | Socket (7) | CloseSocket call. 2024-04-24 22:40:14.640 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:14.640 | HD Request # 40 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:14.640 | Historical data download thread signaled to stop. 2024-04-24 22:40:14.640 | HD Request # 40 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:14.640 | HD Request # 40 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:14.640 | HD Request # 40 | Completion time: 0s. 2024-04-24 22:40:14.640 | HD Request # 40 | Intraday data download complete for ESM24-CME. Unique request ID: 40 2024-04-24 22:40:14.640 | Removing historical data download ID 40. 2024-04-24 22:40:14.640 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:14.640 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:14.640 | HD Request # 40 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:14.640 | 2024-04-24 22:40:14.640 | No download requests in the queue to start downloads for. 2024-04-24 22:40:14.695 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:14.695 | Socket (7) | Closed. 2024-04-24 22:40:16.428 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:16.428 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:16.429 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:16.430 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:16.430 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:16.485 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:16.485 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:16.485 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:16.485 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:16.652 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:16.652 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:16.652 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:16.652 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:16.652 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:16.652 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:16.652 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:16.652 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:16.652 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:16.652 | Triggering next historical data download in queue. 2024-04-24 22:40:16.652 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:16.652 | HD Request # 41 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:16.652 | HD Request # 41 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:16.652 | HD Request # 41 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:16.652 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:16.652 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:16.652 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:16.706 | HD Request # 41 | Sending historical data logon request message. 2024-04-24 22:40:16.707 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:16.707 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:16.707 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:16.707 | DTC Client socket (4) | Closed. 2024-04-24 22:40:16.708 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:16.709 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:16.709 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:16.709 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:16.872 | HD Request # 41 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:16.926 | Socket (7) | CloseSocket call. 2024-04-24 22:40:16.926 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:16.926 | HD Request # 41 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:16.926 | Historical data download thread signaled to stop. 2024-04-24 22:40:16.926 | HD Request # 41 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:16.926 | HD Request # 41 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:16.926 | HD Request # 41 | Completion time: 0s. 2024-04-24 22:40:16.926 | HD Request # 41 | Intraday data download complete for ESM24-CME. Unique request ID: 41 2024-04-24 22:40:16.926 | Removing historical data download ID 41. 2024-04-24 22:40:16.926 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:16.926 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:16.926 | HD Request # 41 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:16.926 | 2024-04-24 22:40:16.926 | No download requests in the queue to start downloads for. 2024-04-24 22:40:16.980 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:16.980 | Socket (7) | Closed. 2024-04-24 22:40:18.691 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:18.691 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:18.692 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:18.692 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:18.692 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:18.750 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:18.750 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:18.750 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:18.750 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:18.913 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:18.913 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:18.913 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:18.913 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:18.913 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:18.913 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:18.913 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:18.913 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:18.913 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:18.913 | Triggering next historical data download in queue. 2024-04-24 22:40:18.913 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:18.913 | HD Request # 42 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:18.913 | HD Request # 42 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:18.913 | HD Request # 42 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:18.913 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:18.913 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:18.913 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:18.967 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:18.967 | HD Request # 42 | Sending historical data logon request message. 2024-04-24 22:40:18.967 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:18.967 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:18.967 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:18.967 | DTC Client socket (4) | Closed. 2024-04-24 22:40:18.968 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:18.968 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:18.968 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:19.137 | HD Request # 42 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:19.190 | Socket (7) | CloseSocket call. 2024-04-24 22:40:19.190 | HD Request # 42 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:19.190 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:19.190 | Historical data download thread signaled to stop. 2024-04-24 22:40:19.190 | HD Request # 42 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:19.190 | HD Request # 42 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:19.190 | HD Request # 42 | Completion time: 1s. 2024-04-24 22:40:19.190 | HD Request # 42 | Intraday data download complete for ESM24-CME. Unique request ID: 42 2024-04-24 22:40:19.190 | Removing historical data download ID 42. 2024-04-24 22:40:19.190 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:19.190 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:19.190 | HD Request # 42 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:19.190 | 2024-04-24 22:40:19.190 | No download requests in the queue to start downloads for. 2024-04-24 22:40:19.245 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:19.245 | Socket (7) | Closed. 2024-04-24 22:40:20.966 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:20.966 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:20.967 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:20.967 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:20.967 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:21.030 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:21.030 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:21.030 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:21.030 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:21.194 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:21.194 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:21.194 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:21.194 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:21.194 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:21.194 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:21.194 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:21.194 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:21.194 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:21.194 | Triggering next historical data download in queue. 2024-04-24 22:40:21.194 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:21.194 | HD Request # 43 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:21.194 | HD Request # 43 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:21.194 | HD Request # 43 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:21.194 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:21.194 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:21.194 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:21.247 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:21.247 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:21.247 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:21.247 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:21.247 | DTC Client socket (4) | Closed. 2024-04-24 22:40:21.248 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:21.248 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:21.248 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:21.251 | HD Request # 43 | Sending historical data logon request message. 2024-04-24 22:40:21.418 | HD Request # 43 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:21.475 | Socket (7) | CloseSocket call. 2024-04-24 22:40:21.475 | HD Request # 43 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:21.475 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:21.475 | Historical data download thread signaled to stop. 2024-04-24 22:40:21.475 | HD Request # 43 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:21.475 | HD Request # 43 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:21.475 | HD Request # 43 | Completion time: 0s. 2024-04-24 22:40:21.475 | HD Request # 43 | Intraday data download complete for ESM24-CME. Unique request ID: 43 2024-04-24 22:40:21.475 | Removing historical data download ID 43. 2024-04-24 22:40:21.475 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:21.475 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:21.475 | HD Request # 43 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:21.475 | 2024-04-24 22:40:21.475 | No download requests in the queue to start downloads for. 2024-04-24 22:40:21.531 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:21.531 | Socket (7) | Closed. 2024-04-24 22:40:23.251 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:23.251 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:23.251 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:23.251 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:23.251 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:23.305 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:23.305 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:23.305 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:23.305 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:23.472 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:23.472 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:23.472 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:23.472 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:23.472 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:23.472 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:23.472 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:23.472 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:23.472 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:23.472 | Triggering next historical data download in queue. 2024-04-24 22:40:23.472 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:23.472 | HD Request # 44 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:23.472 | HD Request # 44 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:23.472 | HD Request # 44 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:23.472 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:23.473 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:23.473 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:23.525 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:23.525 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:23.525 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:23.525 | DTC Client socket (4) | Closed. 2024-04-24 22:40:23.526 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:23.526 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:23.526 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:23.526 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:23.528 | HD Request # 44 | Sending historical data logon request message. 2024-04-24 22:40:23.697 | HD Request # 44 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:23.751 | Socket (7) | CloseSocket call. 2024-04-24 22:40:23.751 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:23.751 | HD Request # 44 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:23.751 | Historical data download thread signaled to stop. 2024-04-24 22:40:23.752 | HD Request # 44 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:23.752 | HD Request # 44 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:23.752 | HD Request # 44 | Completion time: 0s. 2024-04-24 22:40:23.752 | HD Request # 44 | Intraday data download complete for ESM24-CME. Unique request ID: 44 2024-04-24 22:40:23.752 | Removing historical data download ID 44. 2024-04-24 22:40:23.752 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:23.752 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:23.752 | HD Request # 44 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:23.752 | 2024-04-24 22:40:23.752 | No download requests in the queue to start downloads for. 2024-04-24 22:40:23.807 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:23.807 | Socket (7) | Closed. 2024-04-24 22:40:25.524 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:25.524 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:25.524 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:25.524 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:25.524 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:25.580 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:25.580 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:25.580 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:25.580 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:25.743 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:25.743 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:25.743 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:25.743 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:25.743 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:25.743 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:25.743 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:25.743 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:25.743 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:25.743 | Triggering next historical data download in queue. 2024-04-24 22:40:25.743 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:25.743 | HD Request # 45 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:25.743 | HD Request # 45 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:25.743 | HD Request # 45 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:25.743 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:25.743 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:25.743 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:25.797 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:25.797 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:25.797 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:25.797 | HD Request # 45 | Sending historical data logon request message. 2024-04-24 22:40:25.797 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:25.797 | DTC Client socket (4) | Closed. 2024-04-24 22:40:25.797 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:25.797 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:25.797 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:25.959 | HD Request # 45 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:26.013 | Socket (7) | CloseSocket call. 2024-04-24 22:40:26.013 | HD Request # 45 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:26.013 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:26.013 | Historical data download thread signaled to stop. 2024-04-24 22:40:26.013 | HD Request # 45 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:26.013 | HD Request # 45 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:26.013 | HD Request # 45 | Completion time: 1s. 2024-04-24 22:40:26.013 | HD Request # 45 | Intraday data download complete for ESM24-CME. Unique request ID: 45 2024-04-24 22:40:26.013 | Removing historical data download ID 45. 2024-04-24 22:40:26.013 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:26.013 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:26.013 | HD Request # 45 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:26.013 | 2024-04-24 22:40:26.013 | No download requests in the queue to start downloads for. 2024-04-24 22:40:26.068 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:26.068 | Socket (7) | Closed. 2024-04-24 22:40:27.786 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:27.786 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:27.787 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:27.787 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:27.787 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:27.840 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:27.840 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:27.840 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:27.840 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:28.008 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:28.008 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:28.008 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:28.008 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:28.008 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:28.008 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:28.008 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:28.008 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:28.008 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:28.008 | Triggering next historical data download in queue. 2024-04-24 22:40:28.008 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:28.008 | HD Request # 46 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:28.009 | HD Request # 46 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:28.009 | HD Request # 46 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:28.009 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:28.009 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:28.009 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:28.069 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:28.069 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:28.069 | HD Request # 46 | Sending historical data logon request message. 2024-04-24 22:40:28.069 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:28.069 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:28.069 | DTC Client socket (4) | Closed. 2024-04-24 22:40:28.071 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:28.071 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:28.071 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:28.236 | HD Request # 46 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:28.291 | Socket (7) | CloseSocket call. 2024-04-24 22:40:28.291 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:28.292 | HD Request # 46 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:28.292 | Historical data download thread signaled to stop. 2024-04-24 22:40:28.292 | HD Request # 46 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:28.292 | HD Request # 46 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:28.292 | HD Request # 46 | Completion time: 0s. 2024-04-24 22:40:28.292 | HD Request # 46 | Intraday data download complete for ESM24-CME. Unique request ID: 46 2024-04-24 22:40:28.292 | Removing historical data download ID 46. 2024-04-24 22:40:28.292 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:28.292 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:28.292 | HD Request # 46 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:28.292 | 2024-04-24 22:40:28.292 | No download requests in the queue to start downloads for. 2024-04-24 22:40:28.346 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:28.347 | Socket (7) | Closed. 2024-04-24 22:40:30.078 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:30.078 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:30.079 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:30.079 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:30.079 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:30.135 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:30.135 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:30.135 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:30.135 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:30.309 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:30.309 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:30.309 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:30.309 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:30.309 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:30.309 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:30.309 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:30.309 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:30.309 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:30.309 | Triggering next historical data download in queue. 2024-04-24 22:40:30.309 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:30.309 | HD Request # 47 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:30.309 | HD Request # 47 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:30.309 | HD Request # 47 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:30.309 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:30.309 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:30.309 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:30.362 | HD Request # 47 | Sending historical data logon request message. 2024-04-24 22:40:30.363 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:30.363 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:30.363 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:30.363 | DTC Client socket (4) | Closed. 2024-04-24 22:40:30.363 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:30.363 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:30.363 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:30.363 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:30.525 | HD Request # 47 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:30.577 | Socket (7) | CloseSocket call. 2024-04-24 22:40:30.578 | HD Request # 47 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:30.578 | Historical data download thread signaled to stop. 2024-04-24 22:40:30.578 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:30.578 | HD Request # 47 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:30.578 | HD Request # 47 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:30.578 | HD Request # 47 | Completion time: 0s. 2024-04-24 22:40:30.578 | HD Request # 47 | Intraday data download complete for ESM24-CME. Unique request ID: 47 2024-04-24 22:40:30.578 | Removing historical data download ID 47. 2024-04-24 22:40:30.578 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:30.578 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:30.578 | HD Request # 47 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:30.578 | 2024-04-24 22:40:30.578 | No download requests in the queue to start downloads for. 2024-04-24 22:40:30.632 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:30.633 | Socket (7) | Closed. 2024-04-24 22:40:32.377 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:32.377 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:32.384 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:32.384 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:32.384 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:32.437 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:32.437 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:32.437 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:32.437 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:32.600 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:32.600 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:32.600 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:32.600 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:32.600 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:32.600 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:32.600 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:32.600 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:32.600 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:32.600 | Triggering next historical data download in queue. 2024-04-24 22:40:32.600 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:32.600 | HD Request # 48 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:32.600 | HD Request # 48 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:32.600 | HD Request # 48 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:32.600 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:32.600 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:32.600 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:32.655 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:32.655 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:32.655 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:32.656 | HD Request # 48 | Sending historical data logon request message. 2024-04-24 22:40:32.656 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:32.656 | DTC Client socket (4) | Closed. 2024-04-24 22:40:32.656 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:32.656 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:32.656 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:32.823 | HD Request # 48 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:32.876 | Socket (7) | CloseSocket call. 2024-04-24 22:40:32.876 | HD Request # 48 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:32.876 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:32.876 | Historical data download thread signaled to stop. 2024-04-24 22:40:32.876 | HD Request # 48 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:32.878 | HD Request # 48 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:32.878 | HD Request # 48 | Completion time: 0s. 2024-04-24 22:40:32.878 | HD Request # 48 | Intraday data download complete for ESM24-CME. Unique request ID: 48 2024-04-24 22:40:32.878 | Removing historical data download ID 48. 2024-04-24 22:40:32.878 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:32.878 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:32.878 | HD Request # 48 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:32.878 | 2024-04-24 22:40:32.878 | No download requests in the queue to start downloads for. 2024-04-24 22:40:32.930 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:32.930 | Socket (7) | Closed. 2024-04-24 22:40:34.658 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:34.658 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:34.658 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:34.658 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:34.658 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:34.713 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:34.713 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:34.713 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:34.713 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:34.876 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:34.876 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:34.876 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:34.876 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:34.876 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:34.876 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:34.876 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:34.876 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:34.876 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:34.876 | Triggering next historical data download in queue. 2024-04-24 22:40:34.876 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:34.876 | HD Request # 49 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:34.876 | HD Request # 49 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:34.876 | HD Request # 49 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:34.876 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:34.876 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:34.876 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:34.930 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:34.930 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:34.930 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:34.931 | HD Request # 49 | Sending historical data logon request message. 2024-04-24 22:40:34.931 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:34.931 | DTC Client socket (4) | Closed. 2024-04-24 22:40:34.931 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:34.931 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:34.931 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:35.100 | HD Request # 49 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:35.155 | Socket (7) | CloseSocket call. 2024-04-24 22:40:35.155 | HD Request # 49 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:35.155 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:35.155 | Historical data download thread signaled to stop. 2024-04-24 22:40:35.155 | HD Request # 49 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:35.156 | HD Request # 49 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:35.156 | HD Request # 49 | Completion time: 1s. 2024-04-24 22:40:35.156 | HD Request # 49 | Intraday data download complete for ESM24-CME. Unique request ID: 49 2024-04-24 22:40:35.156 | Removing historical data download ID 49. 2024-04-24 22:40:35.156 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:35.156 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:35.156 | HD Request # 49 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:35.156 | 2024-04-24 22:40:35.156 | No download requests in the queue to start downloads for. 2024-04-24 22:40:35.207 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:35.207 | Socket (7) | Closed. 2024-04-24 22:40:36.944 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:36.944 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:36.945 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:36.945 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:36.945 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:36.999 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:36.999 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:36.999 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:36.999 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:37.161 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:37.161 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:37.161 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:37.161 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:37.161 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:37.161 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:37.161 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:37.162 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:37.162 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:37.162 | Triggering next historical data download in queue. 2024-04-24 22:40:37.162 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:37.162 | HD Request # 50 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:37.162 | HD Request # 50 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:37.162 | HD Request # 50 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:37.162 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:37.162 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:37.162 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:37.214 | HD Request # 50 | Sending historical data logon request message. 2024-04-24 22:40:37.215 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:37.215 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:37.215 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:37.215 | DTC Client socket (4) | Closed. 2024-04-24 22:40:37.215 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:37.215 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:37.215 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:37.215 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:37.382 | HD Request # 50 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:37.437 | Socket (7) | CloseSocket call. 2024-04-24 22:40:37.437 | HD Request # 50 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:37.437 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:37.437 | Historical data download thread signaled to stop. 2024-04-24 22:40:37.437 | HD Request # 50 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:37.438 | HD Request # 50 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:37.438 | HD Request # 50 | Completion time: 0s. 2024-04-24 22:40:37.438 | HD Request # 50 | Intraday data download complete for ESM24-CME. Unique request ID: 50 2024-04-24 22:40:37.438 | Removing historical data download ID 50. 2024-04-24 22:40:37.438 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:37.438 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:37.438 | HD Request # 50 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:37.438 | 2024-04-24 22:40:37.438 | No download requests in the queue to start downloads for. 2024-04-24 22:40:37.490 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:37.490 | Socket (7) | Closed. 2024-04-24 22:40:39.211 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:39.211 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:39.212 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:39.212 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:39.212 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:39.266 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:39.266 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:39.266 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:39.266 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:39.430 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:39.430 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:39.430 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:39.430 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:39.430 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:39.430 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:39.430 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:39.430 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:39.430 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:39.430 | Triggering next historical data download in queue. 2024-04-24 22:40:39.430 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:39.430 | HD Request # 51 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:39.430 | HD Request # 51 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:39.430 | HD Request # 51 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:39.430 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:39.430 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:39.430 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:39.488 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:39.488 | HD Request # 51 | Sending historical data logon request message. 2024-04-24 22:40:39.488 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:39.488 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:39.488 | DTC Client socket (4) | Closed. 2024-04-24 22:40:39.488 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:39.489 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:39.489 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:39.489 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:39.650 | HD Request # 51 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:39.702 | Socket (7) | CloseSocket call. 2024-04-24 22:40:39.702 | HD Request # 51 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:39.702 | Historical data download thread signaled to stop. 2024-04-24 22:40:39.702 | HD Request # 51 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:39.702 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:39.702 | HD Request # 51 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:39.702 | HD Request # 51 | Completion time: 0s. 2024-04-24 22:40:39.702 | HD Request # 51 | Intraday data download complete for ESM24-CME. Unique request ID: 51 2024-04-24 22:40:39.702 | Removing historical data download ID 51. 2024-04-24 22:40:39.702 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:39.702 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:39.702 | HD Request # 51 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:39.702 | 2024-04-24 22:40:39.702 | No download requests in the queue to start downloads for. 2024-04-24 22:40:39.755 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:39.755 | Socket (7) | Closed. 2024-04-24 22:40:41.492 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:41.492 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:41.493 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:41.493 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:41.493 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:41.547 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:41.547 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:41.548 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:41.548 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:41.712 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:41.712 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:41.712 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:41.712 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:41.712 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:41.712 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:41.712 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:41.712 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:41.712 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:41.712 | Triggering next historical data download in queue. 2024-04-24 22:40:41.712 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:41.712 | HD Request # 52 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:41.712 | HD Request # 52 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:41.712 | HD Request # 52 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:41.712 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:41.712 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:41.712 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:41.766 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:41.766 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:41.766 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:41.766 | HD Request # 52 | Sending historical data logon request message. 2024-04-24 22:40:41.766 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:41.766 | DTC Client socket (4) | Closed. 2024-04-24 22:40:41.766 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:41.766 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:41.766 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:41.931 | HD Request # 52 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:41.986 | Socket (7) | CloseSocket call. 2024-04-24 22:40:41.986 | HD Request # 52 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:41.986 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:41.986 | Historical data download thread signaled to stop. 2024-04-24 22:40:41.986 | HD Request # 52 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:41.986 | HD Request # 52 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:41.986 | HD Request # 52 | Completion time: 0s. 2024-04-24 22:40:41.986 | HD Request # 52 | Intraday data download complete for ESM24-CME. Unique request ID: 52 2024-04-24 22:40:41.986 | Removing historical data download ID 52. 2024-04-24 22:40:41.986 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:41.986 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:41.986 | HD Request # 52 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:41.986 | 2024-04-24 22:40:41.986 | No download requests in the queue to start downloads for. 2024-04-24 22:40:42.041 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:42.041 | Socket (7) | Closed. 2024-04-24 22:40:43.756 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:43.756 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:43.758 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:43.758 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:43.758 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:43.813 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:43.813 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:43.813 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:43.813 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:43.980 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:43.980 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:43.980 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:43.980 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:43.980 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:43.980 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:43.980 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:43.980 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:43.980 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:43.980 | Triggering next historical data download in queue. 2024-04-24 22:40:43.980 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:43.980 | HD Request # 53 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:43.980 | HD Request # 53 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:43.980 | HD Request # 53 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:43.981 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:43.981 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:43.981 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:44.033 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:44.033 | HD Request # 53 | Sending historical data logon request message. 2024-04-24 22:40:44.033 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:44.033 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:44.033 | DTC Client socket (4) | Closed. 2024-04-24 22:40:44.034 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:44.034 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:44.034 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:44.034 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:44.196 | HD Request # 53 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:44.250 | Socket (7) | CloseSocket call. 2024-04-24 22:40:44.250 | HD Request # 53 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:44.250 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:44.250 | Historical data download thread signaled to stop. 2024-04-24 22:40:44.250 | HD Request # 53 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:44.250 | HD Request # 53 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:44.250 | HD Request # 53 | Completion time: 1s. 2024-04-24 22:40:44.250 | HD Request # 53 | Intraday data download complete for ESM24-CME. Unique request ID: 53 2024-04-24 22:40:44.250 | Removing historical data download ID 53. 2024-04-24 22:40:44.250 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:44.250 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:44.250 | HD Request # 53 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:44.250 | 2024-04-24 22:40:44.250 | No download requests in the queue to start downloads for. 2024-04-24 22:40:44.304 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:44.304 | Socket (7) | Closed. 2024-04-24 22:40:46.044 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:46.044 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:46.045 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:46.045 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:46.045 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:46.100 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:46.100 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:46.100 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:46.100 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:46.264 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:46.264 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:46.264 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:46.264 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:46.264 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:46.264 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:46.264 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:46.264 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:46.264 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:46.264 | Triggering next historical data download in queue. 2024-04-24 22:40:46.264 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:46.264 | HD Request # 54 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:46.264 | HD Request # 54 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:46.264 | HD Request # 54 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:46.264 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:46.264 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:46.264 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:46.318 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:46.318 | HD Request # 54 | Sending historical data logon request message. 2024-04-24 22:40:46.318 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:46.318 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:46.318 | DTC Client socket (4) | Closed. 2024-04-24 22:40:46.319 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:46.319 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:46.319 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:46.319 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:46.484 | HD Request # 54 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:46.538 | Socket (7) | CloseSocket call. 2024-04-24 22:40:46.538 | HD Request # 54 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:46.539 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:46.539 | Historical data download thread signaled to stop. 2024-04-24 22:40:46.539 | HD Request # 54 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:46.539 | HD Request # 54 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:46.539 | HD Request # 54 | Completion time: 0s. 2024-04-24 22:40:46.539 | HD Request # 54 | Intraday data download complete for ESM24-CME. Unique request ID: 54 2024-04-24 22:40:46.539 | Removing historical data download ID 54. 2024-04-24 22:40:46.539 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:46.539 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:46.539 | HD Request # 54 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:46.539 | 2024-04-24 22:40:46.539 | No download requests in the queue to start downloads for. 2024-04-24 22:40:46.593 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:46.593 | Socket (7) | Closed. 2024-04-24 22:40:48.328 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:48.328 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:48.333 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:48.333 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:48.333 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:48.387 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:48.387 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:48.387 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:48.387 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:48.553 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:48.553 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:48.553 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:48.553 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:48.553 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:48.553 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:48.553 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:48.553 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:48.553 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:48.553 | Triggering next historical data download in queue. 2024-04-24 22:40:48.553 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:48.553 | HD Request # 55 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:48.553 | HD Request # 55 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:48.553 | HD Request # 55 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:48.554 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:48.554 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:48.554 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:48.608 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:48.608 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:48.608 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:48.608 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:48.608 | DTC Client socket (4) | Closed. 2024-04-24 22:40:48.608 | HD Request # 55 | Sending historical data logon request message. 2024-04-24 22:40:48.609 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:48.609 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:48.609 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:48.770 | HD Request # 55 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:48.822 | Socket (7) | CloseSocket call. 2024-04-24 22:40:48.822 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:48.823 | HD Request # 55 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:48.823 | Historical data download thread signaled to stop. 2024-04-24 22:40:48.823 | HD Request # 55 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:48.823 | HD Request # 55 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:48.823 | HD Request # 55 | Completion time: 0s. 2024-04-24 22:40:48.823 | HD Request # 55 | Intraday data download complete for ESM24-CME. Unique request ID: 55 2024-04-24 22:40:48.823 | Removing historical data download ID 55. 2024-04-24 22:40:48.823 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:48.823 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:48.823 | HD Request # 55 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:48.823 | 2024-04-24 22:40:48.823 | No download requests in the queue to start downloads for. 2024-04-24 22:40:48.875 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:48.875 | Socket (7) | Closed. 2024-04-24 22:40:50.605 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:50.605 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:50.606 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:50.606 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:50.606 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:50.660 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:50.660 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:50.660 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:50.660 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:50.827 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:50.827 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:50.827 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:50.827 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:50.827 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:50.827 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:50.827 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:50.827 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:50.827 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:50.827 | Triggering next historical data download in queue. 2024-04-24 22:40:50.827 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:50.827 | HD Request # 56 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:50.827 | HD Request # 56 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:50.827 | HD Request # 56 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:50.827 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:50.827 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:50.827 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:50.884 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:50.884 | HD Request # 56 | Sending historical data logon request message. 2024-04-24 22:40:50.884 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:50.884 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:50.884 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:50.884 | DTC Client socket (4) | Closed. 2024-04-24 22:40:50.884 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:50.884 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:50.884 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:51.046 | HD Request # 56 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:51.099 | Socket (7) | CloseSocket call. 2024-04-24 22:40:51.099 | HD Request # 56 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:51.099 | Historical data download thread signaled to stop. 2024-04-24 22:40:51.099 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:51.099 | HD Request # 56 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:51.099 | HD Request # 56 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:51.099 | HD Request # 56 | Completion time: 1s. 2024-04-24 22:40:51.099 | HD Request # 56 | Intraday data download complete for ESM24-CME. Unique request ID: 56 2024-04-24 22:40:51.099 | Removing historical data download ID 56. 2024-04-24 22:40:51.099 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:51.099 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:51.099 | HD Request # 56 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:51.099 | 2024-04-24 22:40:51.099 | No download requests in the queue to start downloads for. 2024-04-24 22:40:51.151 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:51.151 | Socket (7) | Closed. 2024-04-24 22:40:52.885 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:52.885 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:52.886 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:52.886 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:52.886 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:52.941 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:52.941 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:52.941 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:52.941 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:53.104 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:53.104 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:53.104 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:53.104 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:53.104 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:53.104 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:53.104 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:53.104 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:53.104 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:53.104 | Triggering next historical data download in queue. 2024-04-24 22:40:53.104 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:53.104 | HD Request # 57 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:53.104 | HD Request # 57 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:53.104 | HD Request # 57 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:53.104 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:53.104 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:53.104 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:53.156 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:53.156 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:53.157 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:53.157 | DTC Client socket (4) | Closed. 2024-04-24 22:40:53.157 | HD Request # 57 | Sending historical data logon request message. 2024-04-24 22:40:53.157 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:53.157 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:53.157 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:53.157 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:53.321 | HD Request # 57 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:53.375 | Socket (7) | CloseSocket call. 2024-04-24 22:40:53.375 | HD Request # 57 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:53.375 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:53.375 | Historical data download thread signaled to stop. 2024-04-24 22:40:53.375 | HD Request # 57 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:53.375 | HD Request # 57 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:53.375 | HD Request # 57 | Completion time: 0s. 2024-04-24 22:40:53.375 | HD Request # 57 | Intraday data download complete for ESM24-CME. Unique request ID: 57 2024-04-24 22:40:53.375 | Removing historical data download ID 57. 2024-04-24 22:40:53.375 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:53.375 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:53.375 | HD Request # 57 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:53.375 | 2024-04-24 22:40:53.375 | No download requests in the queue to start downloads for. 2024-04-24 22:40:53.429 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:53.429 | Socket (7) | Closed. 2024-04-24 22:40:55.148 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:55.148 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:55.148 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:55.149 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:55.149 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:55.203 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:55.203 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:55.203 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:55.203 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:55.370 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:55.370 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:55.370 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:55.370 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:55.370 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:55.370 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:55.370 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:55.370 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:55.370 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:55.370 | Triggering next historical data download in queue. 2024-04-24 22:40:55.370 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:55.370 | HD Request # 58 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:55.371 | HD Request # 58 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:55.371 | HD Request # 58 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:55.371 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:55.371 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:55.371 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:55.424 | HD Request # 58 | Sending historical data logon request message. 2024-04-24 22:40:55.424 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:55.424 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:55.424 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:55.424 | DTC Client socket (4) | Closed. 2024-04-24 22:40:55.424 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:55.425 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:55.425 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:55.425 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:55.604 | HD Request # 58 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:55.657 | Socket (7) | CloseSocket call. 2024-04-24 22:40:55.657 | HD Request # 58 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:55.657 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:55.657 | Historical data download thread signaled to stop. 2024-04-24 22:40:55.657 | HD Request # 58 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:55.657 | HD Request # 58 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:55.657 | HD Request # 58 | Completion time: 0s. 2024-04-24 22:40:55.657 | HD Request # 58 | Intraday data download complete for ESM24-CME. Unique request ID: 58 2024-04-24 22:40:55.657 | Removing historical data download ID 58. 2024-04-24 22:40:55.657 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:55.657 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:55.657 | HD Request # 58 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:55.657 | 2024-04-24 22:40:55.657 | No download requests in the queue to start downloads for. 2024-04-24 22:40:55.712 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:55.712 | Socket (7) | Closed. 2024-04-24 22:40:57.426 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:57.426 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:57.427 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:57.427 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:57.427 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:57.481 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:57.481 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:57.482 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:57.482 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:57.649 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:57.649 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:57.649 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:57.649 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:57.649 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:57.649 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:57.649 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:57.649 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:57.649 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:57.649 | Triggering next historical data download in queue. 2024-04-24 22:40:57.649 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:57.649 | HD Request # 59 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:57.649 | HD Request # 59 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:57.649 | HD Request # 59 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:57.649 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:57.649 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:57.649 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:57.704 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:57.704 | HD Request # 59 | Sending historical data logon request message. 2024-04-24 22:40:57.704 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:57.704 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:57.704 | DTC Client socket (4) | Closed. 2024-04-24 22:40:57.705 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:57.705 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:57.705 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:57.705 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:40:57.876 | HD Request # 59 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:40:57.936 | Socket (7) | CloseSocket call. 2024-04-24 22:40:57.936 | HD Request # 59 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:40:57.936 | Historical data download thread signaled to stop. 2024-04-24 22:40:57.936 | HD Request # 59 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:40:57.936 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:40:57.936 | HD Request # 59 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:57.936 | HD Request # 59 | Completion time: 0s. 2024-04-24 22:40:57.936 | HD Request # 59 | Intraday data download complete for ESM24-CME. Unique request ID: 59 2024-04-24 22:40:57.936 | Removing historical data download ID 59. 2024-04-24 22:40:57.936 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:40:57.936 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:40:57.936 | HD Request # 59 | Enabling Intraday chart updating for symbol. 2024-04-24 22:40:57.936 | 2024-04-24 22:40:57.936 | No download requests in the queue to start downloads for. 2024-04-24 22:40:57.989 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:40:57.989 | Socket (7) | Closed. 2024-04-24 22:40:59.694 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:40:59.695 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:40:59.695 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:59.696 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:40:59.696 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:59.748 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:40:59.748 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:40:59.748 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:40:59.748 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:40:59.912 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:40:59.912 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:40:59.912 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:40:59.912 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:40:59.912 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:40:59.912 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:40:59.912 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:40:59.912 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:40:59.912 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:40:59.912 | Triggering next historical data download in queue. 2024-04-24 22:40:59.912 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:40:59.912 | HD Request # 60 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:40:59.912 | HD Request # 60 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:40:59.912 | HD Request # 60 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:40:59.913 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:40:59.913 | Socket (7) | New receive buffer size: 0 2024-04-24 22:40:59.913 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:40:59.967 | HD Request # 60 | Sending historical data logon request message. 2024-04-24 22:40:59.967 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:40:59.967 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:40:59.967 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:40:59.967 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:40:59.967 | DTC Client socket (4) | Closed. 2024-04-24 22:40:59.967 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:40:59.967 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:40:59.967 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:00.137 | HD Request # 60 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:00.189 | Socket (7) | CloseSocket call. 2024-04-24 22:41:00.189 | HD Request # 60 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:00.189 | Historical data download thread signaled to stop. 2024-04-24 22:41:00.189 | HD Request # 60 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:00.190 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:00.190 | HD Request # 60 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:00.190 | HD Request # 60 | Completion time: 1s. 2024-04-24 22:41:00.190 | HD Request # 60 | Intraday data download complete for ESM24-CME. Unique request ID: 60 2024-04-24 22:41:00.190 | Removing historical data download ID 60. 2024-04-24 22:41:00.190 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:00.190 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:00.190 | HD Request # 60 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:00.190 | 2024-04-24 22:41:00.190 | No download requests in the queue to start downloads for. 2024-04-24 22:41:00.243 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:00.243 | Socket (7) | Closed. 2024-04-24 22:41:01.960 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:01.960 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:01.961 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:01.961 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:01.961 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:02.015 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:02.016 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:02.016 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:02.016 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:02.179 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:02.179 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:02.179 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:02.179 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:02.179 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:02.179 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:02.179 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:02.179 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:02.179 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:02.179 | Triggering next historical data download in queue. 2024-04-24 22:41:02.179 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:02.179 | HD Request # 61 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:02.179 | HD Request # 61 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:02.179 | HD Request # 61 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:02.179 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:02.179 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:02.179 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:02.232 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:02.232 | HD Request # 61 | Sending historical data logon request message. 2024-04-24 22:41:02.232 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:02.232 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:02.232 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:02.232 | DTC Client socket (4) | Closed. 2024-04-24 22:41:02.233 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:02.233 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:02.233 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:02.399 | HD Request # 61 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:02.452 | Socket (7) | CloseSocket call. 2024-04-24 22:41:02.452 | HD Request # 61 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:02.452 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:02.452 | Historical data download thread signaled to stop. 2024-04-24 22:41:02.452 | HD Request # 61 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:02.452 | HD Request # 61 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:02.452 | HD Request # 61 | Completion time: 0s. 2024-04-24 22:41:02.452 | HD Request # 61 | Intraday data download complete for ESM24-CME. Unique request ID: 61 2024-04-24 22:41:02.452 | Removing historical data download ID 61. 2024-04-24 22:41:02.452 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:02.452 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:02.452 | HD Request # 61 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:02.452 | 2024-04-24 22:41:02.452 | No download requests in the queue to start downloads for. 2024-04-24 22:41:02.505 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:02.505 | Socket (7) | Closed. 2024-04-24 22:41:04.225 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:04.225 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:04.232 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:04.232 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:04.232 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:04.288 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:04.288 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:04.288 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:04.288 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:04.454 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:04.454 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:04.454 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:04.454 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:04.454 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:04.454 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:04.454 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:04.454 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:04.454 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:04.454 | Triggering next historical data download in queue. 2024-04-24 22:41:04.454 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:04.454 | HD Request # 62 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:04.454 | HD Request # 62 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:04.454 | HD Request # 62 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:04.454 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:04.454 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:04.454 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:04.508 | HD Request # 62 | Sending historical data logon request message. 2024-04-24 22:41:04.508 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:04.508 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:04.509 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:04.509 | DTC Client socket (4) | Closed. 2024-04-24 22:41:04.509 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:04.510 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:04.510 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:04.510 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:04.674 | HD Request # 62 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:04.728 | Socket (7) | CloseSocket call. 2024-04-24 22:41:04.728 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:04.728 | HD Request # 62 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:04.728 | Historical data download thread signaled to stop. 2024-04-24 22:41:04.728 | HD Request # 62 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:04.728 | HD Request # 62 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:04.728 | HD Request # 62 | Completion time: 0s. 2024-04-24 22:41:04.728 | HD Request # 62 | Intraday data download complete for ESM24-CME. Unique request ID: 62 2024-04-24 22:41:04.728 | Removing historical data download ID 62. 2024-04-24 22:41:04.728 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:04.728 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:04.728 | HD Request # 62 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:04.728 | 2024-04-24 22:41:04.728 | No download requests in the queue to start downloads for. 2024-04-24 22:41:04.784 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:04.784 | Socket (7) | Closed. 2024-04-24 22:41:06.503 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:06.504 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:06.504 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:06.504 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:06.504 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:06.558 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:06.558 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:06.558 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:06.558 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:06.720 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:06.720 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:06.720 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:06.720 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:06.720 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:06.720 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:06.720 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:06.720 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:06.720 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:06.720 | Triggering next historical data download in queue. 2024-04-24 22:41:06.720 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:06.720 | HD Request # 63 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:06.720 | HD Request # 63 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:06.720 | HD Request # 63 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:06.721 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:06.721 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:06.721 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:06.774 | HD Request # 63 | Sending historical data logon request message. 2024-04-24 22:41:06.774 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:06.775 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:06.775 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:06.775 | DTC Client socket (4) | Closed. 2024-04-24 22:41:06.775 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:06.775 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:06.775 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:06.775 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:06.941 | HD Request # 63 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:06.995 | Socket (7) | CloseSocket call. 2024-04-24 22:41:06.995 | HD Request # 63 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:06.995 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:06.995 | Historical data download thread signaled to stop. 2024-04-24 22:41:06.995 | HD Request # 63 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:06.995 | HD Request # 63 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:06.995 | HD Request # 63 | Completion time: 0s. 2024-04-24 22:41:06.995 | HD Request # 63 | Intraday data download complete for ESM24-CME. Unique request ID: 63 2024-04-24 22:41:06.995 | Removing historical data download ID 63. 2024-04-24 22:41:06.995 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:06.995 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:06.995 | HD Request # 63 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:06.995 | 2024-04-24 22:41:06.995 | No download requests in the queue to start downloads for. 2024-04-24 22:41:07.049 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:07.049 | Socket (7) | Closed. 2024-04-24 22:41:08.783 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:08.783 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:08.783 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:08.783 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:08.783 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:08.840 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:08.840 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:08.840 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:08.840 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:09.010 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:09.010 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:09.010 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:09.010 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:09.010 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:09.010 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:09.010 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:09.010 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:09.010 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:09.010 | Triggering next historical data download in queue. 2024-04-24 22:41:09.010 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:09.010 | HD Request # 64 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:09.011 | HD Request # 64 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:09.011 | HD Request # 64 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:09.011 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:09.011 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:09.011 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:09.064 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:09.064 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:09.064 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:09.064 | DTC Client socket (4) | Closed. 2024-04-24 22:41:09.064 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:09.065 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:09.065 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:09.065 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:09.065 | HD Request # 64 | Sending historical data logon request message. 2024-04-24 22:41:09.235 | HD Request # 64 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:09.290 | Socket (7) | CloseSocket call. 2024-04-24 22:41:09.290 | HD Request # 64 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:09.290 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:09.290 | Historical data download thread signaled to stop. 2024-04-24 22:41:09.290 | HD Request # 64 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:09.290 | HD Request # 64 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:09.290 | HD Request # 64 | Completion time: 0s. 2024-04-24 22:41:09.290 | HD Request # 64 | Intraday data download complete for ESM24-CME. Unique request ID: 64 2024-04-24 22:41:09.290 | Removing historical data download ID 64. 2024-04-24 22:41:09.290 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:09.290 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:09.290 | HD Request # 64 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:09.290 | 2024-04-24 22:41:09.290 | No download requests in the queue to start downloads for. 2024-04-24 22:41:09.345 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:09.345 | Socket (7) | Closed. 2024-04-24 22:41:11.061 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:11.061 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:11.062 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:11.062 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:11.062 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:11.116 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:11.116 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:11.116 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:11.116 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:11.289 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:11.289 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:11.289 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:11.289 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:11.289 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:11.289 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:11.289 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:11.289 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:11.289 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:11.289 | Triggering next historical data download in queue. 2024-04-24 22:41:11.289 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:11.289 | HD Request # 65 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:11.290 | HD Request # 65 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:11.290 | HD Request # 65 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:11.290 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:11.290 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:11.290 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:11.344 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:11.344 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:11.344 | HD Request # 65 | Sending historical data logon request message. 2024-04-24 22:41:11.344 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:11.345 | DTC Client socket (4) | Closed. 2024-04-24 22:41:11.345 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:11.346 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:11.346 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:11.346 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:11.510 | HD Request # 65 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:11.563 | Socket (7) | CloseSocket call. 2024-04-24 22:41:11.563 | HD Request # 65 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:11.563 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:11.563 | Historical data download thread signaled to stop. 2024-04-24 22:41:11.563 | HD Request # 65 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:11.563 | HD Request # 65 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:11.563 | HD Request # 65 | Completion time: 0s. 2024-04-24 22:41:11.563 | HD Request # 65 | Intraday data download complete for ESM24-CME. Unique request ID: 65 2024-04-24 22:41:11.563 | Removing historical data download ID 65. 2024-04-24 22:41:11.563 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:11.563 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:11.563 | HD Request # 65 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:11.563 | 2024-04-24 22:41:11.563 | No download requests in the queue to start downloads for. 2024-04-24 22:41:11.619 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:11.619 | Socket (7) | Closed. 2024-04-24 22:41:13.343 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:13.343 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:13.344 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:13.345 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:13.345 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:13.398 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:13.398 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:13.399 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:13.399 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:13.565 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:13.565 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:13.565 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:13.565 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:13.565 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:13.565 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:13.565 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:13.565 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:13.565 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:13.565 | Triggering next historical data download in queue. 2024-04-24 22:41:13.565 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:13.565 | HD Request # 66 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:13.565 | HD Request # 66 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:13.565 | HD Request # 66 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:13.565 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:13.566 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:13.566 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:13.619 | HD Request # 66 | Sending historical data logon request message. 2024-04-24 22:41:13.619 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:13.620 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:13.620 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:13.620 | DTC Client socket (4) | Closed. 2024-04-24 22:41:13.620 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:13.620 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:13.620 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:13.620 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:13.782 | HD Request # 66 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:13.835 | Socket (7) | CloseSocket call. 2024-04-24 22:41:13.835 | HD Request # 66 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:13.835 | Historical data download thread signaled to stop. 2024-04-24 22:41:13.835 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:13.835 | HD Request # 66 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:13.835 | HD Request # 66 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:13.835 | HD Request # 66 | Completion time: 0s. 2024-04-24 22:41:13.835 | HD Request # 66 | Intraday data download complete for ESM24-CME. Unique request ID: 66 2024-04-24 22:41:13.835 | Removing historical data download ID 66. 2024-04-24 22:41:13.835 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:13.835 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:13.835 | HD Request # 66 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:13.835 | 2024-04-24 22:41:13.835 | No download requests in the queue to start downloads for. 2024-04-24 22:41:13.890 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:13.890 | Socket (7) | Closed. 2024-04-24 22:41:15.627 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:15.627 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:15.628 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:15.628 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:15.628 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:15.681 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:15.681 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:15.681 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:15.681 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:15.845 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:15.845 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:15.845 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:15.845 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:15.845 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:15.845 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:15.845 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:15.845 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:15.845 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:15.845 | Triggering next historical data download in queue. 2024-04-24 22:41:15.845 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:15.845 | HD Request # 67 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:15.845 | HD Request # 67 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:15.845 | HD Request # 67 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:15.845 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:15.845 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:15.845 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:15.897 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:15.897 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:15.897 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:15.897 | DTC Client socket (4) | Closed. 2024-04-24 22:41:15.897 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:15.898 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:15.898 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:15.898 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:15.899 | HD Request # 67 | Sending historical data logon request message. 2024-04-24 22:41:16.070 | HD Request # 67 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:16.123 | Socket (7) | CloseSocket call. 2024-04-24 22:41:16.123 | HD Request # 67 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:16.123 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:16.123 | Historical data download thread signaled to stop. 2024-04-24 22:41:16.123 | HD Request # 67 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:16.123 | HD Request # 67 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:16.124 | HD Request # 67 | Completion time: 1s. 2024-04-24 22:41:16.124 | HD Request # 67 | Intraday data download complete for ESM24-CME. Unique request ID: 67 2024-04-24 22:41:16.124 | Removing historical data download ID 67. 2024-04-24 22:41:16.124 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:16.124 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:16.124 | HD Request # 67 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:16.124 | 2024-04-24 22:41:16.124 | No download requests in the queue to start downloads for. 2024-04-24 22:41:16.176 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:16.177 | Socket (7) | Closed. 2024-04-24 22:41:17.894 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:17.894 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:17.895 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:17.895 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:17.895 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:17.950 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:17.950 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:17.950 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:17.950 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:18.122 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:18.122 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:18.122 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:18.122 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:18.122 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:18.122 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:18.122 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:18.123 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:18.123 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:18.123 | Triggering next historical data download in queue. 2024-04-24 22:41:18.123 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:18.123 | HD Request # 68 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:18.123 | HD Request # 68 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:18.123 | HD Request # 68 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:18.123 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:18.123 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:18.123 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:18.177 | HD Request # 68 | Sending historical data logon request message. 2024-04-24 22:41:18.177 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:18.177 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:18.177 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:18.177 | DTC Client socket (4) | Closed. 2024-04-24 22:41:18.177 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:18.177 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:18.177 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:18.177 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:18.341 | HD Request # 68 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:18.397 | Socket (7) | CloseSocket call. 2024-04-24 22:41:18.397 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:18.397 | HD Request # 68 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:18.397 | Historical data download thread signaled to stop. 2024-04-24 22:41:18.397 | HD Request # 68 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:18.397 | HD Request # 68 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:18.397 | HD Request # 68 | Completion time: 0s. 2024-04-24 22:41:18.397 | HD Request # 68 | Intraday data download complete for ESM24-CME. Unique request ID: 68 2024-04-24 22:41:18.397 | Removing historical data download ID 68. 2024-04-24 22:41:18.397 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:18.397 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:18.397 | HD Request # 68 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:18.397 | 2024-04-24 22:41:18.397 | No download requests in the queue to start downloads for. 2024-04-24 22:41:18.451 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:18.451 | Socket (7) | Closed. 2024-04-24 22:41:20.160 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:20.160 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:20.164 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:20.164 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:20.164 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:20.219 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:20.219 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:20.219 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:20.219 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:20.386 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:20.386 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:20.386 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:20.386 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:20.386 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:20.386 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:20.386 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:20.386 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:20.386 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:20.386 | Triggering next historical data download in queue. 2024-04-24 22:41:20.386 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:20.386 | HD Request # 69 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:20.387 | HD Request # 69 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:20.387 | HD Request # 69 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:20.387 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:20.387 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:20.387 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:20.440 | HD Request # 69 | Sending historical data logon request message. 2024-04-24 22:41:20.440 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:20.440 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:20.440 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:20.440 | DTC Client socket (4) | Closed. 2024-04-24 22:41:20.440 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:20.441 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:20.441 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:20.441 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:20.605 | HD Request # 69 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:20.658 | Socket (7) | CloseSocket call. 2024-04-24 22:41:20.658 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:20.658 | HD Request # 69 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:20.658 | Historical data download thread signaled to stop. 2024-04-24 22:41:20.658 | HD Request # 69 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:20.658 | HD Request # 69 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:20.658 | HD Request # 69 | Completion time: 0s. 2024-04-24 22:41:20.658 | HD Request # 69 | Intraday data download complete for ESM24-CME. Unique request ID: 69 2024-04-24 22:41:20.658 | Removing historical data download ID 69. 2024-04-24 22:41:20.658 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:20.658 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:20.658 | HD Request # 69 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:20.658 | 2024-04-24 22:41:20.658 | No download requests in the queue to start downloads for. 2024-04-24 22:41:20.713 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:20.713 | Socket (7) | Closed. 2024-04-24 22:41:22.443 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:22.443 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:22.444 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:22.444 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:22.444 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:22.500 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:22.500 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:22.500 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:22.500 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:22.664 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:22.664 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:22.664 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:22.664 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:22.664 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:22.664 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:22.664 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:22.664 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:22.664 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:22.664 | Triggering next historical data download in queue. 2024-04-24 22:41:22.664 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:22.664 | HD Request # 70 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:22.664 | HD Request # 70 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:22.664 | HD Request # 70 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:22.664 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:22.664 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:22.664 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:22.720 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:22.720 | HD Request # 70 | Sending historical data logon request message. 2024-04-24 22:41:22.720 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:22.720 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:22.720 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:22.720 | DTC Client socket (4) | Closed. 2024-04-24 22:41:22.720 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:22.720 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:22.720 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:22.884 | HD Request # 70 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:22.940 | Socket (7) | CloseSocket call. 2024-04-24 22:41:22.940 | HD Request # 70 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:22.940 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:22.941 | Historical data download thread signaled to stop. 2024-04-24 22:41:22.941 | HD Request # 70 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:22.941 | HD Request # 70 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:22.941 | HD Request # 70 | Completion time: 0s. 2024-04-24 22:41:22.941 | HD Request # 70 | Intraday data download complete for ESM24-CME. Unique request ID: 70 2024-04-24 22:41:22.941 | Removing historical data download ID 70. 2024-04-24 22:41:22.941 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:22.941 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:22.941 | HD Request # 70 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:22.941 | 2024-04-24 22:41:22.941 | No download requests in the queue to start downloads for. 2024-04-24 22:41:22.995 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:22.996 | Socket (7) | Closed. 2024-04-24 22:41:24.705 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:24.705 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:24.705 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:24.706 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:24.706 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:24.762 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:24.762 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:24.762 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:24.762 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:24.929 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:24.929 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:24.929 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:24.929 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:24.929 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:24.929 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:24.929 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:24.929 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:24.929 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:24.929 | Triggering next historical data download in queue. 2024-04-24 22:41:24.929 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:24.929 | HD Request # 71 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:24.929 | HD Request # 71 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:24.929 | HD Request # 71 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:24.930 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:24.930 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:24.930 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:24.987 | HD Request # 71 | Sending historical data logon request message. 2024-04-24 22:41:24.988 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:24.988 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:24.988 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:24.988 | DTC Client socket (4) | Closed. 2024-04-24 22:41:24.988 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:24.988 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:24.988 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:24.988 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:25.153 | HD Request # 71 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:25.206 | Socket (7) | CloseSocket call. 2024-04-24 22:41:25.206 | HD Request # 71 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:25.206 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:25.206 | Historical data download thread signaled to stop. 2024-04-24 22:41:25.206 | HD Request # 71 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:25.207 | HD Request # 71 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:25.207 | HD Request # 71 | Completion time: 1s. 2024-04-24 22:41:25.207 | HD Request # 71 | Intraday data download complete for ESM24-CME. Unique request ID: 71 2024-04-24 22:41:25.207 | Removing historical data download ID 71. 2024-04-24 22:41:25.207 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:25.207 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:25.207 | HD Request # 71 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:25.207 | 2024-04-24 22:41:25.207 | No download requests in the queue to start downloads for. 2024-04-24 22:41:25.260 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:25.260 | Socket (7) | Closed. 2024-04-24 22:41:26.995 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:26.995 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:26.996 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:26.996 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:26.996 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:27.051 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:27.051 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:27.051 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:27.051 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:27.216 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:27.216 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:27.216 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:27.216 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:27.216 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:27.216 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:27.216 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:27.216 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:27.216 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:27.216 | Triggering next historical data download in queue. 2024-04-24 22:41:27.216 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:27.216 | HD Request # 72 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:27.216 | HD Request # 72 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:27.216 | HD Request # 72 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:27.217 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:27.217 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:27.217 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:27.269 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:27.269 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:27.269 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:27.270 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:27.270 | DTC Client socket (4) | Closed. 2024-04-24 22:41:27.270 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:27.270 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:27.270 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:27.271 | HD Request # 72 | Sending historical data logon request message. 2024-04-24 22:41:27.436 | HD Request # 72 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:27.490 | Socket (7) | CloseSocket call. 2024-04-24 22:41:27.490 | HD Request # 72 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:27.490 | Historical data download thread signaled to stop. 2024-04-24 22:41:27.490 | HD Request # 72 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:27.490 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:27.491 | HD Request # 72 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:27.491 | HD Request # 72 | Completion time: 0s. 2024-04-24 22:41:27.491 | HD Request # 72 | Intraday data download complete for ESM24-CME. Unique request ID: 72 2024-04-24 22:41:27.491 | Removing historical data download ID 72. 2024-04-24 22:41:27.491 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:27.491 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:27.491 | HD Request # 72 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:27.491 | 2024-04-24 22:41:27.491 | No download requests in the queue to start downloads for. 2024-04-24 22:41:27.545 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:27.545 | Socket (7) | Closed. 2024-04-24 22:41:29.275 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:29.275 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:29.276 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:29.276 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:29.276 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:29.331 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:29.331 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:29.331 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:29.331 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:29.497 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:29.497 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:29.497 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:29.497 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:29.497 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:29.497 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:29.497 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:29.497 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:29.497 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:29.497 | Triggering next historical data download in queue. 2024-04-24 22:41:29.497 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:29.497 | HD Request # 73 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:29.497 | HD Request # 73 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:29.497 | HD Request # 73 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:29.497 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:29.497 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:29.497 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:29.550 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:29.551 | HD Request # 73 | Sending historical data logon request message. 2024-04-24 22:41:29.551 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:29.551 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:29.551 | DTC Client socket (4) | Closed. 2024-04-24 22:41:29.552 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:29.553 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:29.553 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:29.553 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:29.719 | HD Request # 73 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:29.773 | Socket (7) | CloseSocket call. 2024-04-24 22:41:29.773 | HD Request # 73 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:29.773 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:29.773 | Historical data download thread signaled to stop. 2024-04-24 22:41:29.773 | HD Request # 73 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:29.773 | HD Request # 73 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:29.773 | HD Request # 73 | Completion time: 0s. 2024-04-24 22:41:29.773 | HD Request # 73 | Intraday data download complete for ESM24-CME. Unique request ID: 73 2024-04-24 22:41:29.773 | Removing historical data download ID 73. 2024-04-24 22:41:29.773 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:29.773 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:29.773 | HD Request # 73 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:29.773 | 2024-04-24 22:41:29.773 | No download requests in the queue to start downloads for. 2024-04-24 22:41:29.829 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:29.829 | Socket (7) | Closed. 2024-04-24 22:41:31.556 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:31.556 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:31.556 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:31.556 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:31.556 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:31.610 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:31.610 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:31.610 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:31.610 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:31.777 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:31.777 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:31.777 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:31.777 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:31.777 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:31.777 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:31.777 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:31.777 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:31.777 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:31.777 | Triggering next historical data download in queue. 2024-04-24 22:41:31.777 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:31.778 | HD Request # 74 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:31.778 | HD Request # 74 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:31.778 | HD Request # 74 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:31.778 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:31.778 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:31.778 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:31.831 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:31.831 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:31.831 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:31.831 | DTC Client socket (4) | Closed. 2024-04-24 22:41:31.832 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:31.832 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:31.832 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:31.832 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:31.834 | HD Request # 74 | Sending historical data logon request message. 2024-04-24 22:41:31.997 | HD Request # 74 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:32.053 | Socket (7) | CloseSocket call. 2024-04-24 22:41:32.053 | HD Request # 74 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:32.053 | Historical data download thread signaled to stop. 2024-04-24 22:41:32.053 | HD Request # 74 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:32.053 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:32.053 | HD Request # 74 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:32.053 | HD Request # 74 | Completion time: 1s. 2024-04-24 22:41:32.053 | HD Request # 74 | Intraday data download complete for ESM24-CME. Unique request ID: 74 2024-04-24 22:41:32.053 | Removing historical data download ID 74. 2024-04-24 22:41:32.053 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:32.053 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:32.053 | HD Request # 74 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:32.053 | 2024-04-24 22:41:32.053 | No download requests in the queue to start downloads for. 2024-04-24 22:41:32.109 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:32.109 | Socket (7) | Closed. 2024-04-24 22:41:33.841 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:33.841 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:33.842 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:33.842 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:33.842 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:33.895 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:33.895 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:33.895 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:33.895 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:34.066 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:34.066 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:34.066 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:34.066 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:34.066 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:34.066 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:34.066 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:34.066 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:34.066 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:34.066 | Triggering next historical data download in queue. 2024-04-24 22:41:34.066 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:34.066 | HD Request # 75 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:34.066 | HD Request # 75 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:34.066 | HD Request # 75 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:34.067 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:34.067 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:34.067 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:34.121 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:34.121 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:34.121 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:34.122 | HD Request # 75 | Sending historical data logon request message. 2024-04-24 22:41:34.122 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:34.122 | DTC Client socket (4) | Closed. 2024-04-24 22:41:34.123 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:34.123 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:34.123 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:34.289 | HD Request # 75 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:34.343 | Socket (7) | CloseSocket call. 2024-04-24 22:41:34.343 | HD Request # 75 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:34.343 | Historical data download thread signaled to stop. 2024-04-24 22:41:34.343 | HD Request # 75 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:34.343 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:34.343 | HD Request # 75 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:34.343 | HD Request # 75 | Completion time: 0s. 2024-04-24 22:41:34.343 | HD Request # 75 | Intraday data download complete for ESM24-CME. Unique request ID: 75 2024-04-24 22:41:34.343 | Removing historical data download ID 75. 2024-04-24 22:41:34.343 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:34.343 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:34.343 | HD Request # 75 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:34.343 | 2024-04-24 22:41:34.343 | No download requests in the queue to start downloads for. 2024-04-24 22:41:34.396 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:34.396 | Socket (7) | Closed. 2024-04-24 22:41:36.111 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:36.111 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:36.115 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:36.115 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:36.115 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:36.170 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:36.170 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:36.170 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:36.170 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:36.336 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:36.336 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:36.336 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:36.336 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:36.336 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:36.336 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:36.336 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:36.336 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:36.336 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:36.336 | Triggering next historical data download in queue. 2024-04-24 22:41:36.336 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:36.336 | HD Request # 76 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:36.336 | HD Request # 76 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:36.336 | HD Request # 76 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:36.336 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:36.337 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:36.337 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:36.391 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:36.391 | HD Request # 76 | Sending historical data logon request message. 2024-04-24 22:41:36.391 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:36.391 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:36.391 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:36.391 | DTC Client socket (4) | Closed. 2024-04-24 22:41:36.391 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:36.391 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:36.391 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:36.554 | HD Request # 76 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:36.608 | Socket (7) | CloseSocket call. 2024-04-24 22:41:36.608 | HD Request # 76 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:36.608 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:36.608 | Historical data download thread signaled to stop. 2024-04-24 22:41:36.608 | HD Request # 76 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:36.609 | HD Request # 76 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:36.609 | HD Request # 76 | Completion time: 0s. 2024-04-24 22:41:36.609 | HD Request # 76 | Intraday data download complete for ESM24-CME. Unique request ID: 76 2024-04-24 22:41:36.609 | Removing historical data download ID 76. 2024-04-24 22:41:36.609 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:36.609 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:36.609 | HD Request # 76 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:36.609 | 2024-04-24 22:41:36.609 | No download requests in the queue to start downloads for. 2024-04-24 22:41:36.663 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:36.663 | Socket (7) | Closed. 2024-04-24 22:41:38.382 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:38.382 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:38.382 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:38.382 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:38.382 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:38.438 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:38.438 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:38.438 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:38.438 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:38.604 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:38.604 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:38.604 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:38.604 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:38.604 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:38.604 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:38.604 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:38.604 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:38.604 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:38.604 | Triggering next historical data download in queue. 2024-04-24 22:41:38.604 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:38.604 | HD Request # 77 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:38.605 | HD Request # 77 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:38.605 | HD Request # 77 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:38.605 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:38.605 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:38.605 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:38.659 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:38.659 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:38.659 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:38.659 | HD Request # 77 | Sending historical data logon request message. 2024-04-24 22:41:38.659 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:38.659 | DTC Client socket (4) | Closed. 2024-04-24 22:41:38.660 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:38.660 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:38.660 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:38.828 | HD Request # 77 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:38.883 | Socket (7) | CloseSocket call. 2024-04-24 22:41:38.883 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:38.883 | HD Request # 77 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:38.883 | Historical data download thread signaled to stop. 2024-04-24 22:41:38.883 | HD Request # 77 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:38.884 | HD Request # 77 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:38.884 | HD Request # 77 | Completion time: 0s. 2024-04-24 22:41:38.884 | HD Request # 77 | Intraday data download complete for ESM24-CME. Unique request ID: 77 2024-04-24 22:41:38.884 | Removing historical data download ID 77. 2024-04-24 22:41:38.884 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:38.884 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:38.884 | HD Request # 77 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:38.884 | 2024-04-24 22:41:38.884 | No download requests in the queue to start downloads for. 2024-04-24 22:41:38.936 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:38.937 | Socket (7) | Closed. 2024-04-24 22:41:40.662 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:40.662 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:40.663 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:40.663 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:40.663 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:40.717 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:40.717 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:40.717 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:40.717 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:40.879 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:40.879 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:40.879 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:40.879 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:40.879 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:40.879 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:40.879 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:40.879 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:40.879 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:40.879 | Triggering next historical data download in queue. 2024-04-24 22:41:40.879 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:40.879 | HD Request # 78 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:40.880 | HD Request # 78 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:40.880 | HD Request # 78 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:40.880 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:40.880 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:40.880 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:40.932 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:40.932 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:40.933 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:40.933 | HD Request # 78 | Sending historical data logon request message. 2024-04-24 22:41:40.933 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:40.933 | DTC Client socket (4) | Closed. 2024-04-24 22:41:40.933 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:40.933 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:40.933 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:41.098 | HD Request # 78 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:41.154 | Socket (7) | CloseSocket call. 2024-04-24 22:41:41.154 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:41.154 | HD Request # 78 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:41.154 | Historical data download thread signaled to stop. 2024-04-24 22:41:41.154 | HD Request # 78 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:41.155 | HD Request # 78 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:41.155 | HD Request # 78 | Completion time: 1s. 2024-04-24 22:41:41.155 | HD Request # 78 | Intraday data download complete for ESM24-CME. Unique request ID: 78 2024-04-24 22:41:41.155 | Removing historical data download ID 78. 2024-04-24 22:41:41.155 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:41.155 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:41.155 | HD Request # 78 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:41.155 | 2024-04-24 22:41:41.155 | No download requests in the queue to start downloads for. 2024-04-24 22:41:41.208 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:41.208 | Socket (7) | Closed. 2024-04-24 22:41:42.927 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:42.927 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:42.928 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:42.928 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:42.928 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:42.982 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:42.982 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:42.982 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:42.982 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:43.147 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:43.147 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:43.147 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:43.147 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:43.147 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:43.147 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:43.147 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:43.147 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:43.147 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:43.147 | Triggering next historical data download in queue. 2024-04-24 22:41:43.147 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:43.147 | HD Request # 79 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:43.148 | HD Request # 79 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:43.148 | HD Request # 79 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:43.148 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:43.148 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:43.148 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:43.203 | HD Request # 79 | Sending historical data logon request message. 2024-04-24 22:41:43.203 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:43.203 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:43.203 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:43.203 | DTC Client socket (4) | Closed. 2024-04-24 22:41:43.204 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:43.204 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:43.204 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:43.204 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:43.367 | HD Request # 79 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:43.421 | Socket (7) | CloseSocket call. 2024-04-24 22:41:43.421 | HD Request # 79 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:43.421 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:43.421 | Historical data download thread signaled to stop. 2024-04-24 22:41:43.421 | HD Request # 79 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:43.421 | HD Request # 79 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:43.421 | HD Request # 79 | Completion time: 0s. 2024-04-24 22:41:43.421 | HD Request # 79 | Intraday data download complete for ESM24-CME. Unique request ID: 79 2024-04-24 22:41:43.421 | Removing historical data download ID 79. 2024-04-24 22:41:43.421 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:43.421 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:43.421 | HD Request # 79 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:43.421 | 2024-04-24 22:41:43.421 | No download requests in the queue to start downloads for. 2024-04-24 22:41:43.475 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:43.475 | Socket (7) | Closed. 2024-04-24 22:41:45.192 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:45.192 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:45.193 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:45.193 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:45.193 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:45.247 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:45.247 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:45.247 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:45.247 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:45.416 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:45.416 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:45.416 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:45.416 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:45.416 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:45.416 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:45.416 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:45.416 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:45.416 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:45.416 | Triggering next historical data download in queue. 2024-04-24 22:41:45.416 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:45.416 | HD Request # 80 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:45.416 | HD Request # 80 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:45.416 | HD Request # 80 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:45.416 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:45.416 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:45.416 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:45.469 | HD Request # 80 | Sending historical data logon request message. 2024-04-24 22:41:45.470 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:45.471 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:45.471 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:45.471 | DTC Client socket (4) | Closed. 2024-04-24 22:41:45.471 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:45.472 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:45.472 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:45.472 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:45.636 | HD Request # 80 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:45.691 | Socket (7) | CloseSocket call. 2024-04-24 22:41:45.691 | HD Request # 80 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:45.691 | Historical data download thread signaled to stop. 2024-04-24 22:41:45.691 | HD Request # 80 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:45.691 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:45.691 | HD Request # 80 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:45.691 | HD Request # 80 | Completion time: 0s. 2024-04-24 22:41:45.691 | HD Request # 80 | Intraday data download complete for ESM24-CME. Unique request ID: 80 2024-04-24 22:41:45.691 | Removing historical data download ID 80. 2024-04-24 22:41:45.691 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:45.691 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:45.691 | HD Request # 80 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:45.691 | 2024-04-24 22:41:45.691 | No download requests in the queue to start downloads for. 2024-04-24 22:41:45.746 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:45.746 | Socket (7) | Closed. 2024-04-24 22:41:47.470 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:47.470 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:47.471 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:47.471 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:47.471 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:47.527 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:47.527 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:47.527 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:47.527 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:47.691 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:47.691 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:47.691 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:47.691 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:47.691 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:47.691 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:47.691 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:47.691 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:47.691 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:47.691 | Triggering next historical data download in queue. 2024-04-24 22:41:47.691 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:47.691 | HD Request # 81 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:47.691 | HD Request # 81 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:47.691 | HD Request # 81 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:47.691 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:47.691 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:47.691 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:47.745 | HD Request # 81 | Sending historical data logon request message. 2024-04-24 22:41:47.745 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:47.745 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:47.745 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:47.746 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:47.746 | DTC Client socket (4) | Closed. 2024-04-24 22:41:47.747 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:47.747 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:47.747 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:47.908 | HD Request # 81 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:47.965 | Socket (7) | CloseSocket call. 2024-04-24 22:41:47.965 | HD Request # 81 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:47.965 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:47.966 | Historical data download thread signaled to stop. 2024-04-24 22:41:47.966 | HD Request # 81 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:47.966 | HD Request # 81 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:47.966 | HD Request # 81 | Completion time: 0s. 2024-04-24 22:41:47.966 | HD Request # 81 | Intraday data download complete for ESM24-CME. Unique request ID: 81 2024-04-24 22:41:47.966 | Removing historical data download ID 81. 2024-04-24 22:41:47.966 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:47.966 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:47.966 | HD Request # 81 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:47.966 | 2024-04-24 22:41:47.966 | No download requests in the queue to start downloads for. 2024-04-24 22:41:48.020 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:48.020 | Socket (7) | Closed. 2024-04-24 22:41:49.741 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:49.741 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:49.741 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:49.741 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:49.741 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:49.795 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:49.795 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:49.795 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:49.795 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:49.961 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:49.961 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:49.961 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:49.961 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:49.961 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:49.961 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:49.961 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:49.962 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:49.962 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:49.962 | Triggering next historical data download in queue. 2024-04-24 22:41:49.962 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:49.962 | HD Request # 82 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:49.962 | HD Request # 82 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:49.962 | HD Request # 82 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:49.962 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:49.962 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:49.962 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:50.015 | HD Request # 82 | Sending historical data logon request message. 2024-04-24 22:41:50.015 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:50.015 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:50.015 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:50.015 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:50.015 | DTC Client socket (4) | Closed. 2024-04-24 22:41:50.016 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:50.016 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:50.016 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:50.187 | HD Request # 82 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:50.240 | Socket (7) | CloseSocket call. 2024-04-24 22:41:50.240 | HD Request # 82 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:50.240 | Historical data download thread signaled to stop. 2024-04-24 22:41:50.240 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:50.240 | HD Request # 82 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:50.240 | HD Request # 82 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:50.240 | HD Request # 82 | Completion time: 1s. 2024-04-24 22:41:50.240 | HD Request # 82 | Intraday data download complete for ESM24-CME. Unique request ID: 82 2024-04-24 22:41:50.240 | Removing historical data download ID 82. 2024-04-24 22:41:50.240 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:50.240 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:50.240 | HD Request # 82 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:50.240 | 2024-04-24 22:41:50.240 | No download requests in the queue to start downloads for. 2024-04-24 22:41:50.294 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:50.294 | Socket (7) | Closed. 2024-04-24 22:41:52.012 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:52.012 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:52.016 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:52.016 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:52.016 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:52.070 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:52.070 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:52.070 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:52.070 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:52.232 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:52.232 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:52.232 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:52.232 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:52.232 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:52.232 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:52.232 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:52.232 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:52.232 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:52.232 | Triggering next historical data download in queue. 2024-04-24 22:41:52.232 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:52.232 | HD Request # 83 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:52.232 | HD Request # 83 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:52.232 | HD Request # 83 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:52.232 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:52.232 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:52.232 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:52.286 | HD Request # 83 | Sending historical data logon request message. 2024-04-24 22:41:52.286 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:52.287 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:52.287 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:52.287 | DTC Client socket (4) | Closed. 2024-04-24 22:41:52.288 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:52.288 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:52.288 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:52.288 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:52.450 | HD Request # 83 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:52.503 | Socket (7) | CloseSocket call. 2024-04-24 22:41:52.503 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:52.503 | HD Request # 83 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:52.503 | Historical data download thread signaled to stop. 2024-04-24 22:41:52.503 | HD Request # 83 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:52.503 | HD Request # 83 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:52.503 | HD Request # 83 | Completion time: 0s. 2024-04-24 22:41:52.503 | HD Request # 83 | Intraday data download complete for ESM24-CME. Unique request ID: 83 2024-04-24 22:41:52.503 | Removing historical data download ID 83. 2024-04-24 22:41:52.503 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:52.503 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:52.503 | HD Request # 83 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:52.503 | 2024-04-24 22:41:52.503 | No download requests in the queue to start downloads for. 2024-04-24 22:41:52.557 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:52.557 | Socket (7) | Closed. 2024-04-24 22:41:54.286 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:54.286 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:54.287 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:54.287 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:54.287 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:54.341 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:54.341 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:54.341 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:54.341 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:54.503 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:54.503 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:54.503 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:54.503 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:54.503 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:54.503 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:54.503 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:54.503 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:54.503 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:54.503 | Triggering next historical data download in queue. 2024-04-24 22:41:54.503 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:54.503 | HD Request # 84 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:54.503 | HD Request # 84 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:54.503 | HD Request # 84 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:54.503 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:54.503 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:54.504 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:54.556 | HD Request # 84 | Sending historical data logon request message. 2024-04-24 22:41:54.557 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:54.557 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:54.557 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:54.557 | DTC Client socket (4) | Closed. 2024-04-24 22:41:54.557 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:54.557 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:54.557 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:54.557 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:54.719 | HD Request # 84 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:54.772 | Socket (7) | CloseSocket call. 2024-04-24 22:41:54.772 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:54.772 | HD Request # 84 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:54.772 | Historical data download thread signaled to stop. 2024-04-24 22:41:54.772 | HD Request # 84 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:54.772 | HD Request # 84 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:54.772 | HD Request # 84 | Completion time: 0s. 2024-04-24 22:41:54.772 | HD Request # 84 | Intraday data download complete for ESM24-CME. Unique request ID: 84 2024-04-24 22:41:54.772 | Removing historical data download ID 84. 2024-04-24 22:41:54.772 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:54.772 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:54.772 | HD Request # 84 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:54.772 | 2024-04-24 22:41:54.772 | No download requests in the queue to start downloads for. 2024-04-24 22:41:54.824 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:54.824 | Socket (7) | Closed. 2024-04-24 22:41:56.563 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:56.563 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:56.564 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:56.564 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:56.564 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:56.618 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:56.618 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:56.618 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:56.618 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:56.781 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:56.781 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:56.781 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:56.781 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:56.781 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:56.781 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:56.781 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:56.781 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:56.781 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:56.781 | Triggering next historical data download in queue. 2024-04-24 22:41:56.781 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:56.781 | HD Request # 85 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:56.781 | HD Request # 85 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:56.781 | HD Request # 85 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:56.782 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:56.782 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:56.782 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:56.836 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:56.836 | HD Request # 85 | Sending historical data logon request message. 2024-04-24 22:41:56.836 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:56.836 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:56.836 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:56.836 | DTC Client socket (4) | Closed. 2024-04-24 22:41:56.837 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:56.837 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:56.837 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:57.000 | HD Request # 85 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:57.054 | Socket (7) | CloseSocket call. 2024-04-24 22:41:57.054 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:57.054 | HD Request # 85 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:57.054 | Historical data download thread signaled to stop. 2024-04-24 22:41:57.054 | HD Request # 85 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:57.054 | HD Request # 85 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:57.054 | HD Request # 85 | Completion time: 1s. 2024-04-24 22:41:57.054 | HD Request # 85 | Intraday data download complete for ESM24-CME. Unique request ID: 85 2024-04-24 22:41:57.054 | Removing historical data download ID 85. 2024-04-24 22:41:57.054 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:57.054 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:57.054 | HD Request # 85 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:57.054 | 2024-04-24 22:41:57.054 | No download requests in the queue to start downloads for. 2024-04-24 22:41:57.108 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:57.108 | Socket (7) | Closed. 2024-04-24 22:41:58.844 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:41:58.844 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:41:58.846 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:58.846 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:41:58.846 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:58.902 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:41:58.902 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:41:58.902 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:41:58.902 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:41:59.068 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:41:59.068 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:41:59.068 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:41:59.068 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:41:59.068 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:41:59.068 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:41:59.068 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:41:59.068 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:41:59.068 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:41:59.068 | Triggering next historical data download in queue. 2024-04-24 22:41:59.068 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:41:59.068 | HD Request # 86 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:41:59.068 | HD Request # 86 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:59.068 | HD Request # 86 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:41:59.068 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:41:59.068 | Socket (7) | New receive buffer size: 0 2024-04-24 22:41:59.068 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:41:59.122 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:41:59.122 | HD Request # 86 | Sending historical data logon request message. 2024-04-24 22:41:59.122 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:41:59.122 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:41:59.122 | DTC Client socket (4) | Closed. 2024-04-24 22:41:59.122 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:41:59.122 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:41:59.122 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:41:59.122 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:41:59.288 | HD Request # 86 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:41:59.341 | Socket (7) | CloseSocket call. 2024-04-24 22:41:59.341 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:41:59.341 | HD Request # 86 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:41:59.341 | Historical data download thread signaled to stop. 2024-04-24 22:41:59.341 | HD Request # 86 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:41:59.341 | HD Request # 86 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:41:59.341 | HD Request # 86 | Completion time: 0s. 2024-04-24 22:41:59.341 | HD Request # 86 | Intraday data download complete for ESM24-CME. Unique request ID: 86 2024-04-24 22:41:59.341 | Removing historical data download ID 86. 2024-04-24 22:41:59.341 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:41:59.341 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:41:59.341 | HD Request # 86 | Enabling Intraday chart updating for symbol. 2024-04-24 22:41:59.341 | 2024-04-24 22:41:59.341 | No download requests in the queue to start downloads for. 2024-04-24 22:41:59.394 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:41:59.394 | Socket (7) | Closed. 2024-04-24 22:42:01.113 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:42:01.113 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:42:01.113 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:42:01.113 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:42:01.113 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:42:01.168 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:42:01.168 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:42:01.168 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:42:01.168 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:42:01.334 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:42:01.334 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:42:01.334 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:42:01.334 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:42:01.334 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:42:01.334 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:42:01.334 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:42:01.334 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:42:01.334 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:42:01.334 | Triggering next historical data download in queue. 2024-04-24 22:42:01.334 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:42:01.334 | HD Request # 87 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:42:01.334 | HD Request # 87 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:42:01.335 | HD Request # 87 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:42:01.335 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:42:01.335 | Socket (7) | New receive buffer size: 0 2024-04-24 22:42:01.335 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:42:01.389 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:42:01.389 | HD Request # 87 | Sending historical data logon request message. 2024-04-24 22:42:01.389 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:42:01.389 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:42:01.389 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:42:01.389 | DTC Client socket (4) | Closed. 2024-04-24 22:42:01.390 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:42:01.390 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:42:01.390 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:42:01.557 | HD Request # 87 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:42:01.610 | Socket (7) | CloseSocket call. 2024-04-24 22:42:01.610 | HD Request # 87 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:42:01.610 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:42:01.610 | Historical data download thread signaled to stop. 2024-04-24 22:42:01.611 | HD Request # 87 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:42:01.611 | HD Request # 87 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:42:01.611 | HD Request # 87 | Completion time: 0s. 2024-04-24 22:42:01.611 | HD Request # 87 | Intraday data download complete for ESM24-CME. Unique request ID: 87 2024-04-24 22:42:01.611 | Removing historical data download ID 87. 2024-04-24 22:42:01.611 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:42:01.611 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:42:01.611 | HD Request # 87 | Enabling Intraday chart updating for symbol. 2024-04-24 22:42:01.611 | 2024-04-24 22:42:01.611 | No download requests in the queue to start downloads for. 2024-04-24 22:42:01.665 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:42:01.665 | Socket (7) | Closed. 2024-04-24 22:42:03.377 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:42:03.377 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:42:03.377 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:42:03.377 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:42:03.377 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:42:03.430 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:42:03.430 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:42:03.430 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:42:03.430 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:42:03.598 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:42:03.598 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:42:03.598 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:42:03.598 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:42:03.598 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:42:03.598 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:42:03.598 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:42:03.598 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:42:03.598 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:42:03.598 | Triggering next historical data download in queue. 2024-04-24 22:42:03.598 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:42:03.598 | HD Request # 88 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:42:03.598 | HD Request # 88 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:42:03.598 | HD Request # 88 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:42:03.598 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:42:03.598 | Socket (7) | New receive buffer size: 0 2024-04-24 22:42:03.598 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:42:03.651 | HD Request # 88 | Sending historical data logon request message. 2024-04-24 22:42:03.652 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:42:03.652 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:42:03.652 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:42:03.652 | DTC Client socket (4) | Closed. 2024-04-24 22:42:03.652 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:42:03.653 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:42:03.653 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:42:03.653 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:42:03.817 | HD Request # 88 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:42:03.871 | Socket (7) | CloseSocket call. 2024-04-24 22:42:03.871 | HD Request # 88 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:42:03.871 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:42:03.871 | Historical data download thread signaled to stop. 2024-04-24 22:42:03.871 | HD Request # 88 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:42:03.872 | HD Request # 88 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:42:03.872 | HD Request # 88 | Completion time: 0s. 2024-04-24 22:42:03.872 | HD Request # 88 | Intraday data download complete for ESM24-CME. Unique request ID: 88 2024-04-24 22:42:03.872 | Removing historical data download ID 88. 2024-04-24 22:42:03.872 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:42:03.872 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:42:03.872 | HD Request # 88 | Enabling Intraday chart updating for symbol. 2024-04-24 22:42:03.872 | 2024-04-24 22:42:03.872 | No download requests in the queue to start downloads for. 2024-04-24 22:42:03.926 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:42:03.927 | Socket (7) | Closed. 2024-04-24 22:42:05.644 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:42:05.644 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:42:05.645 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:42:05.645 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:42:05.645 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:42:05.699 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:42:05.699 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:42:05.699 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:42:05.699 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:42:05.872 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:42:05.872 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:42:05.872 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:42:05.872 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:42:05.872 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:42:05.872 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:42:05.872 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:42:05.872 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:42:05.872 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:42:05.872 | Triggering next historical data download in queue. 2024-04-24 22:42:05.872 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:42:05.872 | HD Request # 89 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:42:05.872 | HD Request # 89 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:42:05.872 | HD Request # 89 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:42:05.872 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:42:05.872 | Socket (7) | New receive buffer size: 0 2024-04-24 22:42:05.872 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:42:05.929 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:42:05.929 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:42:05.929 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:42:05.929 | DTC Client socket (4) | Closed. 2024-04-24 22:42:05.929 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:42:05.929 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:42:05.929 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:42:05.929 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:42:05.929 | HD Request # 89 | Sending historical data logon request message. 2024-04-24 22:42:06.096 | HD Request # 89 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:42:06.161 | Socket (7) | CloseSocket call. 2024-04-24 22:42:06.161 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:42:06.162 | HD Request # 89 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:42:06.162 | Historical data download thread signaled to stop. 2024-04-24 22:42:06.162 | HD Request # 89 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:42:06.162 | HD Request # 89 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:42:06.162 | HD Request # 89 | Completion time: 1s. 2024-04-24 22:42:06.162 | HD Request # 89 | Intraday data download complete for ESM24-CME. Unique request ID: 89 2024-04-24 22:42:06.162 | Removing historical data download ID 89. 2024-04-24 22:42:06.162 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:42:06.162 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:42:06.162 | HD Request # 89 | Enabling Intraday chart updating for symbol. 2024-04-24 22:42:06.162 | 2024-04-24 22:42:06.162 | No download requests in the queue to start downloads for. 2024-04-24 22:42:06.217 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:42:06.217 | Socket (7) | Closed. 2024-04-24 22:42:07.925 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:42:07.925 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:42:07.931 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:42:07.931 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:42:07.931 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:42:07.985 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:42:07.985 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:42:07.985 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:42:07.985 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:42:08.153 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-24 22:42:08.153 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-24 22:42:08.153 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-24 22:42:08.153 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-24 22:42:08.153 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-24 22:42:08.153 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-24 22:42:08.153 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-24 22:42:08.153 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-24 22:42:08.153 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-24 22:42:08.153 | Triggering next historical data download in queue. 2024-04-24 22:42:08.153 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM24-CME 2024-04-24 22:42:08.153 | HD Request # 90 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: rithmic_v2.trading 2024-04-24 22:42:08.153 | HD Request # 90 | Download start date-time: 2024-04-23 16:34:06.000000. File last date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:42:08.153 | HD Request # 90 | Using server: rsc.rithmic.com port 50510. Use encryption. 2024-04-24 22:42:08.153 | Socket (7) | Creating socket. Using TLS 1.2. 2024-04-24 22:42:08.153 | Socket (7) | New receive buffer size: 0 2024-04-24 22:42:08.153 | Socket (7) | Connecting to IP: 216.57.156.163. 2024-04-24 22:42:08.207 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:42:08.208 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:42:08.208 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:42:08.208 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:42:08.208 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:42:08.208 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:42:08.208 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:42:08.208 | DTC Client socket (4) | Closed. 2024-04-24 22:42:08.208 | HD Request # 90 | Sending historical data logon request message. 2024-04-24 22:42:08.372 | HD Request # 90 | Requesting Intraday data. Start date-time: 2024-04-23 16:34:06. Record interval: 0. Symbol: ESM24-CME 2024-04-24 22:42:08.425 | Socket (7) | CloseSocket call. 2024-04-24 22:42:08.425 | HD Request # 90 | Error downloading historical Intraday data for ESM24-CME. Exchange not specified 2024-04-24 22:42:08.425 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-04-24 22:42:08.425 | Historical data download thread signaled to stop. 2024-04-24 22:42:08.425 | HD Request # 90 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM24-CME 2024-04-24 22:42:08.425 | HD Request # 90 | Add time&sales data | Remembered last file record date-time: 2024-04-23 16:34:06.000000 2024-04-24 22:42:08.425 | HD Request # 90 | Completion time: 0s. 2024-04-24 22:42:08.425 | HD Request # 90 | Intraday data download complete for ESM24-CME. Unique request ID: 90 2024-04-24 22:42:08.425 | Removing historical data download ID 90. 2024-04-24 22:42:08.425 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-24 22:42:08.425 | Intraday chart data file opened for ESM24-CME 2024-04-24 22:42:08.425 | HD Request # 90 | Enabling Intraday chart updating for symbol. 2024-04-24 22:42:08.425 | 2024-04-24 22:42:08.425 | No download requests in the queue to start downloads for. 2024-04-24 22:42:08.480 | Socket (7) | Socket gracefully closed by remote side. 2024-04-24 22:42:08.480 | Socket (7) | Closed. 2024-04-24 22:42:10.211 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:42:10.211 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:42:10.211 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:42:10.211 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:42:10.211 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:42:10.267 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:42:10.267 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:42:10.267 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:42:10.267 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:42:31.899 | DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2024-04-24 22:42:31.899 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:42:31.899 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:42:31.899 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:42:31.899 | DTC Client socket (4) | Closed. 2024-04-24 22:42:31.899 | Rithmic Direct - DTC (Data) | Failed connections: 1 2024-04-24 22:42:31.899 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:42:31.900 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:42:31.900 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:42:31.900 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:42:33.894 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:42:33.894 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:42:33.894 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:42:33.894 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:42:33.894 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:42:33.951 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:42:33.951 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:42:33.951 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:42:33.951 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:42:53.183 | DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2024-04-24 22:42:53.183 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:42:53.183 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:42:53.183 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:42:53.183 | DTC Client socket (4) | Closed. 2024-04-24 22:42:53.183 | Rithmic Direct - DTC (Data) | Failed connections: 2 2024-04-24 22:42:53.183 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:42:53.183 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:42:53.183 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:42:53.183 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:42:55.177 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:42:55.177 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:42:55.183 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:42:55.183 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:42:55.183 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:42:55.236 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:42:55.236 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:42:55.236 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:42:55.236 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:43:14.473 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:43:14.473 | DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2024-04-24 22:43:14.473 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:43:14.473 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:43:14.473 | DTC Client socket (4) | Closed. 2024-04-24 22:43:14.473 | Rithmic Direct - DTC (Data) | Failed connections: 3 2024-04-24 22:43:14.473 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:43:14.473 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:43:14.473 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:43:14.473 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:43:16.485 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:43:16.485 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:43:16.486 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:43:16.486 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:43:16.486 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:43:16.541 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:43:16.541 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:43:16.541 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:43:16.541 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:43:35.794 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:43:35.794 | DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2024-04-24 22:43:35.794 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:43:35.794 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:43:35.794 | DTC Client socket (4) | Closed. 2024-04-24 22:43:35.794 | Rithmic Direct - DTC (Data) | Failed connections: 4 2024-04-24 22:43:35.794 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:43:35.794 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:43:35.794 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:43:35.794 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:43:37.787 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:43:37.787 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:43:37.788 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:43:37.788 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:43:37.788 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:43:37.848 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:43:37.848 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:43:37.848 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:43:37.848 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:43:57.081 | DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2024-04-24 22:43:57.081 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:43:57.081 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:43:57.082 | Rithmic Direct - DTC (Data) | Failed connections: 5 2024-04-24 22:43:57.082 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:43:57.082 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:43:57.082 | DTC Client socket (4) | Closed. 2024-04-24 22:43:57.082 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:43:57.082 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:43:57.082 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2024-04-24 22:43:59.093 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2024-04-24 22:43:59.093 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2024-04-24 22:43:59.094 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2024-04-24 22:43:59.094 | DTC Client socket (4) | New receive buffer size: 0 2024-04-24 22:43:59.095 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2024-04-24 22:43:59.149 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-24 22:43:59.149 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-24 22:43:59.149 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-24 22:43:59.149 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-24 22:44:18.393 | DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2024-04-24 22:44:18.394 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-04-24 22:44:18.394 | DTC Client socket (4) | CloseSocket call. 2024-04-24 22:44:18.394 | Rithmic Direct - DTC (Data) | Failed connections: 6 2024-04-24 22:44:18.394 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-24 22:44:18.394 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-24 22:44:18.395 | DTC Client socket (4) | Closed. 2024-04-24 22:44:18.395 | DTC Client socket (0) | CloseSocket call. 2024-04-24 22:44:18.395 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-24 22:44:18.395 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. |
[2024-04-24 23:05:48] |
coachted - Posts: 286 |
in addition i am now getting this message in my teton account "2024-04-24 22:58:29.164 | Trade Order Error - The order quantity for the Parent is 1 and this is less than the total order quantity of 3 for the Attached Orders. Adjust the order quantities so the parent is greater or equal to the Attached Orders. * Please advise |
[2024-04-24 23:23:16] |
John - SC Support - Posts: 31533 |
We can not say why you are having this issue with Rithmic. There is something occurring with the connectivity is all we can say. We have seen this occur relatively often, but there is not a specific solution that we can provide. With regards to the Teton error, it is telling you that you are trying to submit an order where the Attached Order's quantity is greater than the quantity of the Parent order. In particular the parent order has a quantity of 1, but your attached orders have a quantity of 3. This is not allowed. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-24 23:35:54] |
i am really sorry i dont know what that means or how to fix it....here is a couple of screen shots...can you please help me resolve this
Screenshot 2024-04-24 193438.png / V - Attached On 2024-04-24 23:35:08 UTC - Size: 70.33 KB - 13 views Screenshot 2024-04-24 193520.png / V - Attached On 2024-04-24 23:35:28 UTC - Size: 73.84 KB - 11 views |
[2024-04-25 14:41:47] |
Since you now have the Parent order as a quantity of 3, you are fine. Previously, you had a quantity of 1, but you had 3 targets, each with an individual quantity of 1, meaning a total quantity of 3. You can not have attached orders that have a greater quantity than the parent order.
[2024-04-25 15:20:47] |
i never changed the settings, those were the settings when i was getting that error
[2024-04-25 15:24:52] |
The error clearly stated that the parent quantity was 1. Are you still having an issue with the parent quantity set to 3? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-25 16:11:37] |
yes
[2024-04-25 16:11:38] |
yes
