Date/Time: Mon, 25 Nov 2024 22:33:50 +0000
I changed brokers and data and now it keeps trying to download the data from the old broke
View Count: 170
[2024-01-25 22:05:42]
Santi - Posts: 4
I changed brokers and data and now it keeps trying to download the data from the old broker with the old symbol, and keeps filling up my inbox non-stop.
imageCaptura de tela 2024-01-25 185717.png / V - Attached On 2024-01-25 22:04:13 UTC - Size: 100.81 KB - 49 views
[2024-01-25 22:36:54]
John - SC Support - Posts: 36284
What order routing service are you using with your new broker?
We need to know this to point you to the proper instructions for that new broker.
[2024-01-25 22:45:23]
Santi - Posts: 4
I'm using rithimic and the other one I was using teton
[2024-01-26 14:23:54]
Your log shows that you are setup to connect to Rithmic, but you do not have the correct symbols. Open your Chartbooks and select "Edit >> Translate Symbols to Current Service". This will update the symbols to be the Rithmic symbols.
