Date/Time: Wed, 27 Nov 2024 04:39:27 +0000
Try Trial
View Count: 1130
[2014-08-01 17:07:25] |
User39118 - Posts: 1 |
Hello! I cant connect trial Software version: 1167 | 2014-08-01 16:50:27 Your usage time has ended. You are in FREE MODE. Features are restricted. | 2014-08-01 16:50:27 To purchase more time select Help>>Purchase on the menu. | 2014-08-01 16:50:27 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-08-01 16:50:27 Active service: SC Forex Data (FXCM) | 2014-08-01 16:50:27 Time Zone: +00:00:00 (UTC+00) | 2014-08-01 16:50:27 2014-08-01 16:50:27 Local computer clock time | 2014-08-01 16:50:27 2014-08-01 16:50:27 GMT time | 2014-08-01 16:50:27 2014-08-01 16:50:27 Time zone adjusted time | 2014-08-01 16:50:27 Time difference to server time: 3 seconds. | 2014-08-01 16:50:27 Program path: D:\Sierra\ | 2014-08-01 16:50:27 Data Files path: D:\Sierra\Data\ | 2014-08-01 16:50:27 OS Version Number: 6.1 | 2014-08-01 16:50:27 Checking for new symbol settings for fxcm | 2014-08-01 16:50:27 AsyncHTTP2 socket (0) | Resolved address sierrachart.com to IP 188.40.121.148 | 2014-08-01 16:50:28 AsyncHTTP2 socket (988) | Connected. | 2014-08-01 16:50:28 Symbol settings are up-to-date for fxcm | 2014-08-01 16:50:28 Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2014-08-01 16:50:33 AsyncHTTP2 socket (988) | Closed. No error. | 2014-08-01 16:50:38 AsyncHTTP2 socket (988) | Shutdown and closed. | 2014-08-01 16:50:38 Current selected Data/Trading service: SC Forex Data (FXCM) | 2014-08-01 16:51:35 Current selected Data/Trading service: SC Historical Data | 2014-08-01 16:57:07 Checking for new symbol settings for ddf | 2014-08-01 16:57:07 AsyncHTTP2 socket (0) | Resolved address sierrachart.com to IP 188.40.121.148 | 2014-08-01 16:57:08 AsyncHTTP2 socket (1544) | Connected. | 2014-08-01 16:57:08 Requesting symbol settings for ddf. Overwrite = on. | 2014-08-01 16:57:08 Symbol settings received. | 2014-08-01 16:57:16 Processed received symbol settings | 2014-08-01 16:57:16 AsyncHTTP2 socket (1544) | Closed. No error. | 2014-08-01 16:57:25 AsyncHTTP2 socket (1544) | Shutdown and closed. | 2014-08-01 16:57:25 Current selected Data/Trading service: SC Forex Data (FXCM) | 2014-08-01 16:57:59 Checking for new symbol settings for fxcm | 2014-08-01 16:57:59 AsyncHTTP2 socket (0) | Resolved address sierrachart.com to IP 188.40.121.148 | 2014-08-01 16:57:59 AsyncHTTP2 socket (1488) | Connected. | 2014-08-01 16:57:59 Requesting symbol settings for fxcm. Overwrite = on. | 2014-08-01 16:57:59 Symbol settings received. | 2014-08-01 16:58:00 Processed received symbol settings | 2014-08-01 16:58:01 AsyncHTTP2 socket (1488) | Closed. No error. | 2014-08-01 16:58:10 AsyncHTTP2 socket (1488) | Shutdown and closed. | 2014-08-01 16:58:10 Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2014-08-01 16:58:47 Currently no data in file to display. Will start historical data download and real-time updates. File: D:\Sierra\Data\AUDCAD.scid | 2014-08-01 17:06:58 Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2014-08-01 17:06:59 Historical data service client indicated that downloads are not enabled for data type. | 2014-08-01 17:06:59 |
[2014-08-01 17:39:14] |
Your account was activated earlier. Restart Sierra Chart.
