Date/Time: Thu, 02 May 2024 11:09:50 +0000
[Programming Help] - CONNECT TO ECONOMIC CALENDAR TO READ THE NEWS WITH CUSTOM STUDY - ACSIL
View Count: 367
[2024-01-25 18:56:20] |
User103688 - Posts: 9 |
Hi everyone! Is there any chance is possible make a study able to read the data from an economic calendar? Thanks for the attention! |
[2024-01-25 20:27:38] |
User431178 - Posts: 412 |
It is certainly possible. What do you want to know? |
[2024-01-26 05:53:15] |
gcUserStudies - Posts: 91 |
I made one for Forex Factory calendar. You can download the study and all the code to see example from the link below. It doesn’t work with OpenGL but will be releasing a version that does shortly. https://gcuserstudies.github.io |
[2024-01-26 15:59:42] |
What do you want to know? So I need to make a function able to read the data in real-time and process it for scalping. But I don't find a documentation about implement economic calendar through a study |
[2024-01-26 16:04:36] |
The user above, gcUserStudies, has provided you with a working example, so maybe start there.
[2024-01-26 16:07:39] |
Thank you gcUserStudies fort the studies but I need something really fast and I need the possibility to read the data |
[2024-01-26 16:09:10] |
I saw it, but only show which are the events, not the data released... |
[2024-01-26 17:06:17] |
So, do you already have a data source in mind? One that also provdies live updates? |
[2024-01-26 17:14:35] |
One that also provdies live updates? Not really... I'm asking for help... |
[2024-01-26 18:59:38] |
Sawtooth - Posts: 3989 |
Frederik has one in his free bundlehttps://www.simplesystemtrading.com/freebundle/ |
[2024-01-27 10:22:03] |
https://www.simplesystemtrading.com/freebundle/ Thanks for the answer, the problem is that this study show me only when the events is coming, not the data those releas! |
[2024-04-07 08:45:30] |
stefkovic.m28 - Posts: 5 |
Hello, I have used this study in SC for ForexFactory news with https://gcuserstudies.github.io/#studies. But I can´t download the forex data with write bar study? After the export I see only NULL values in every column. So is there option to download this data to TXT file with write bar study? On the screen I see upcoming data, so I hope, I can download them. thanks |
