Date/Time: Mon, 25 Nov 2024 22:31:54 +0000
keyboard delete button
View Count: 203
[2024-01-25 17:12:24] |
SafSaf - Posts: 90 |
hi support, i've tried to do this by reading your self help pages and googling before contacting you without succcess .... i'd like to use the delete button on my keyboard to delete a drawing when i select it with my mouse?
[2024-01-25 17:56:32] |
John - SC Support - Posts: 36284 |
If the drawing is selected with the pointer, then it can be deleted by selecting the "Delete" button on your keyboard. You may want to set the following setting to "Yes" in order to help with this: Chart Drawing Tools: Support Left Click to Select Chart Drawings (Global Settings >> Tool Settings >> General >> Tool Options) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
