Date/Time: Mon, 25 Nov 2024 22:26:52 +0000
OHLC text for each bar on chart
View Count: 1366
[2024-01-25 15:18:25]
rshimmin - Posts: 42
Hi
How do I display the high + low value for each bar in text on a chart. Ideally with the high text above the bar + low below the bar.
I know there is the chart value window but I’m wondering if all values can be displayed so no need to hover on one bar.
[2024-01-25 17:19:35]
John - SC Support - Posts: 36283
Use the "Study Subgraph Above/Below Bar as Text" study to do this. You will need two copies of the study, one for the High and one for the Low. Refer to the following:
