Date/Time: Mon, 25 Nov 2024 22:29:33 +0000
Candlesticks not synced up with time.
View Count: 145
[2024-01-25 15:17:17] |
User609927 - Posts: 7 |
Hi, I'm having an issue with my candlestick charts, they are not synced up with my time. My 30 min chart is printing a new candle 15 min later then it should. Example: if it's 8:00 AM my 30 min doesn't print a new one until 8:15 AM. This is only happing on my candlestick charts, I have Footprint charts that are correct. I will attach screen shots of my charts. I have tried to resolve by 1. Disconnecting my data and reloading 2. Checking my time and time zones (all correct) 3. I have two different data feeds, so I switched data provider from Rithmic to SC data feed, problem still remained on both |
Private File |
[2024-01-25 15:47:32] |
ForgivingComputers.com - Posts: 960 |
Check the session times in the chart settings. If it starts on the quarter hour, your 30-minute bar will also start then.
