Date/Time: Mon, 25 Nov 2024 22:31:07 +0000
Quote board covering chart window
View Count: 190
[2024-01-25 15:12:10] |
User634406 - Posts: 36 |
I've linked the quote board with two chart windows, added symbols etc. That's working fine. Here's how it looks https://www.sierrachart.com/image.php?Image=17061947964.png I'd like to be able to maximize a chart window without the last part of it being covered by the quote board, like this; https://www.sierrachart.com/image.php?Image=1706195037574.png Is there a way to set the chart window to maximize up to the border of the quote board? If the quote board is not set as "always on top" or "attach window" via settings, it gets minimized when I click on charts, which is annoying. If it is, it covers the chart, as seen in the screenshot. There must be a better solution than manually expanding the chart window by pulling its edges. |
[2024-01-25 17:16:41] |
John - SC Support - Posts: 36284 |
The Quote Board is not managed by the main Sierra Chart window, therefore it is always separate. As such, the chart windows that are attached to the main window do not know about the Quote Board with regards to placement. Therefore, the only option is to manually change the size of the window to where you want it relative to the Quote Board.
