Date/Time: Mon, 21 Apr 2025 18:57:55 +0000
When I Load Chartbooks My Scaling is Jumbled together
View Count: 292
[2024-01-25 14:11:57] |
BasBucks - Posts: 1 |
Hi, I have downloaded some cht. file templates but when I open the chartbook the scale of the text and numbers are either to small or jumbled together. I was able to change the X & Y font to normal size in global settings but it distorts everything else. Any help is appreciated. I'm using a Windows 13in if that helps. https://www.sierrachart.com/image.php?Image=1706191764216.png |
[2024-01-25 16:53:21] |
John - SC Support - Posts: 39385 |
After you open that Chartbook, for each chart select "Chart >> Graphics Settings - Chart" and enable the option at the top for "Use Global Graphics Settings Instead of These Settings". This will change the chart to use the Global Graphics Settings that you have setup, which should be set to your liking. Refer to the following: Graphics Settings: Use Global Graphics Settings Instead of These Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
