Date/Time: Thu, 19 Sep 2024 00:59:59 +0000
Calculating VWAP on each time frame versus Overlaying
View Count: 1313
[2014-08-01 14:55:59] |
moonmist - Posts: 127 |
Hi, Which of the following options is more CPU/computationally intensive: a) Calculate and draw VWAP on five intraday time frames separately. b) Calculate and draw VWAP on one time frame, and then overlay it on to the other four. Thanks. |
[2014-08-01 17:38:12] |
It makes no measurable difference.
