Date/Time: Mon, 25 Nov 2024 22:51:03 +0000
Volume by price study disappears
View Count: 215
[2024-01-25 13:53:36] |
vesak - Posts: 15 |
Hello, once I set the Volume by price study to align on far right to "Yes" the study completely disappears and I dont see it on the chart even though it is there when opening studies for the chart. Do you have any idea what might cause this? Please let me know if you need anything from my side. Thanks you. Roman |
[2024-01-25 16:42:37] |
John - SC Support - Posts: 36286 |
Please get us the chart that shows this issue by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-28 19:26:07] |
vesak - Posts: 15 |
Find attached the chart.
Chartbook1.Cht - Attached On 2024-01-28 19:25:29 UTC - Size: 4.23 KB - 294 views Attachment Deleted. |
[2024-01-29 17:53:49] |
Your DOM Graph is overwhelming the Volume by Price profile. You have the setting for "Chart >> Chart Settings >> Market Depth >> Width in Bars" set to "10000". Change this to a more realistic number like 10. Refer to the following: Trade Menu: Draw DOM Graph on Chart (Trade menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
