Date/Time: Mon, 25 Nov 2024 22:31:20 +0000
DOM and Price Scale vs Chart Increments
View Count: 261
[2024-01-25 13:23:05] |
fried4104 - Posts: 66 |
Hello, I've searched the forums but found no answer. How can I setup the price scale to behave and show similar price increase/decrease as the main chart? Example, I have the ES showing 0.25 increments on the chart (as tick size), but when hovering on the price scale (and any DOM section) the increment shown is in 0.01. I need 0.25 everywhere. Tried fiddling with the Chart>Symbol settings, also with Scale Increment (Scale Settings) but nothing fixes my issue. Is there a way to solve this? I use the dom bid/ask field to enter trades and its very annoying to have an extra split second thinking if that's the right value I need to enter from. LE: I need to mention I have the crosshair activated (hand) all the time. LE2: I attached a pic to better explain. I dont want to see 4914.69 and all other 0.01 increments when trying to place a trade. My brain lags :) LE3: Added a gif showing the issue Date Time Of Last Edit: 2024-01-25 16:22:09
[2024-01-25 16:38:08] |
John - SC Support - Posts: 36284 |
This is being looked into. It is a combination of when you have the crosshair active and have the pointer in the DOM area.
[2024-01-25 16:56:21] |
Thanks @John Yes, as said, I open trade from the DOM, so I will always have the pointer in that area when opening. Looking forward for a solution, thanks again! |
