Date/Time: Mon, 25 Nov 2024 22:32:38 +0000
Calculate VWAP for today only
View Count: 347
[2024-01-25 03:53:32]
AntoineOpala - Posts: 66
I would like to calculate/display the VWAP for the current day only.
Having the VWAP show over the previous days' bars is clunky and unnecessary for me.
I figured out I can set "Start Date-Time" to "2024-01-25" for example in the study settings.
However, I would have to manually reset that date every new day.
Is there a formula that essentially means "current day"?
[2024-01-25 16:04:47]
John - SC Support - Posts: 36284
The easiest solution is to use the "Volume By Price" study and set the following Inputs:
- Draw Mode: POC, VAH, VAL, VWAP Lines Only
- Ticks per Volume Bar: 1
- One Period at End of Fixed Time Length
- Time Period for 'Fixed Time': Days
- Time Period Length for 'Fixed Time': 1
Then in the Subgraphs tab set the subgraphs for the POC, VAH, and VAL to all be "Ignore". This will then give you the single VWAP line for a single day.
A more complicated method would be to use the "Volume Weighted Average Price" study in combination with the "Spreadsheet Study" and create a condition based on the date and/or time to only display the data from a certain date/time. You can use the TODAY() function to get the current date and use that as part of the condition.
