Date/Time: Mon, 25 Nov 2024 22:26:38 +0000
Disable quantity change on working order in DOM?
View Count: 224
[2024-01-25 00:30:40] |
joshtrader - Posts: 488 |
Working orders in the DOM can show the quantity. I would never want to actually click this quantity, adjust it in the popup, and save the change. So, is there a way to display the quantity of the order, but make it not clickable?
[2024-01-25 15:52:20] |
John - SC Support - Posts: 36283 |
There is not an option to do this. If the quantity is displayed, then it is editable.
[2024-01-26 00:03:50] |
Sierra_Chart Engineering - Posts: 17175 |
We will see if we can make this an option but if it is it would be implemented as a global option.
