Date/Time: Mon, 25 Nov 2024 22:28:45 +0000
Using Alert manager alerts with keyboard
View Count: 194
[2024-01-24 22:29:02]
User361939 - Posts: 165
Is it possible to use alert manager alerts with keybords and loading automatically chart?
When i scann stocks, and got 80 alerts i need manually click on every single one of them.
i would like to navigate on rows of alet manager simply by "UP" or "Down" button on keyboard with loading chart for ALERT if row is active (example at the attachment).
Is it possible to do this?
Or maybe you can add this option?
Similiar mechanism works good in Tradingview watchlist.
imageScreenshot_1.png / V - Attached On 2024-01-24 22:26:36 UTC - Size: 4.23 KB - 60 views
[2024-01-25 15:50:11]
John - SC Support - Posts: 36284
This functionality as you have specifically described it, does not exist.
You can double click on an alert and it will take you to the chart, or you can select the alert row and then select the button at the top for "Go To Chart".
[2024-01-25 15:52:18]
thank you for clarifying.
Would you consider adding such option for alert manager?
Regards
[2024-01-25 17:28:27]
We take in all requests for changes, but we can not say when we would get to any particular item.
