Date/Time: Mon, 25 Nov 2024 22:23:04 +0000
How to delete old accounts
View Count: 359
[2024-01-24 22:18:34] |
Jimmyz83 - Posts: 51 |
On the Trade Activity Log under the accounts drop down menu, I have a lot of old combine account numbers that are closed. I can not figure out how to remove them from this dropdown list. I have tried deleting all trade activity for each account to see if the account will disappear, but no luck. can you help.
[2024-01-25 08:48:32] |
Sierra_Chart Engineering - Posts: 17175 |
You do just need to delete the Trade Activity. Refer to: Trade Activity Log: Clearing Trade Activity Data You can also delete the files in the /TradeActivityLogs subfolder in the Sierra Chart installation folder. This will be a very fast way to do it and probably a better way. The file name of each file contains the account identifier and date it is for. After you delete the files, restart Sierra Chart. Also refer to: Trade Activity Log: Clearing Trade Activity Data Through Files Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-01-26 17:27:52
