Date/Time: Mon, 25 Nov 2024 22:47:57 +0000
Error loading intraday historical data . In a red box
View Count: 157
[2024-01-24 21:56:14] |
User756145 - Posts: 6 |
error as above . im at my wits end trying to load this cb i have 3 other seperate cbs on differant rithmic logins ,this one i have no idea what the problems are 1 i have a personal acc with ironbeam 2 i have rithmic acc with topstep ,apex and recently take profit trader 3 topstep apex work fine on seperate instalations problem cb with take profit trader shows error message as above ,it did load properly one day this week ? it will seem to load daily bars only and when i change to intraday ie volume or 5m bars all the bars go to the left side of the screen and looks weird i have read loads on chats done all of the steps recomended and cannot get this to load as it should i started this cb by sending charts from another chartbook of mine via the send file option as i did with my second instalation any help would be much appreciated kind regards |
[2024-01-24 22:26:07] |
John - SC Support - Posts: 36285 |
Is this a particular Chartbook for which you are having a problem, or is it an entire installation? Also, we need to know exactly what is stated in the Red Box that you are getting. And finally, we need to know what "Global Settings >> Data/Trade Service Settings >> Main Settings >> Current Selected Service" is set to for this installation where you are having trouble. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
