Date/Time: Tue, 18 Feb 2025 23:06:22 +0000
[User Discussion] - Spread Sheet System questions and issue.
View Count: 178
[2024-01-24 21:53:38] |
IkonTrades - Posts: 15 |
Hello everyone. Firstly, I was wondering if anyone had a detailed list of formulas commonly used in the auto trade system. I found the ones in the help section but the listed is pretty limited. I would love to find a more in-depth list. Secondly, when I enter a formula in column K (Buy Entry) for instance, I can double click or press (F2) to open the formula window. But when I try to scroll to another column to select different cells the formula window closes. Is there a setting I can change that will keep the formula window open until I hit enter? I think it might be possible because sometimes the window stays open and I can select different columns/cells. Thanks |
[2024-01-24 22:24:01] |
John - SC Support - Posts: 38036 |
The full list of Spreadsheet Functions supported in the Sierra Chart spreadsheets is at the following link: Spreadsheet Functions The Sierra Chart spreadsheets is not Excel. Do not expect the same functionality. There are similarities, but there are lots of differences. When editing a cell, you can click on other cells to get that reference entered into the editing cell, but you can not use the cursor keys to move the selection around and then select another cell. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
