Date/Time: Mon, 25 Nov 2024 22:29:08 +0000
Footprint Charts
View Count: 433
[2024-01-24 18:49:51] |
User129228 - Posts: 1 |
Hello, When I am looking at my footprint chart based on a point and figure 20-1, there are certain periods where my charts appear to make new candles really fast and become choppy and hard to read. Attached is an example of what I am talking about. What do I need to do to fix the way this appears on my chart? Thanks, Victor https://www.sierrachart.com/image.php?Image=1706112054649.png |
[2024-01-25 08:46:04] |
Sierra_Chart Engineering - Posts: 17175 |
Adjust the Point and Figure Chart Settings to get the result that you want. This is all. Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-01-25 08:46:28
