Date/Time: Mon, 25 Nov 2024 22:44:16 +0000
vwap for cash open
View Count: 181
[2024-01-24 17:21:56] |
Steve Leon - Posts: 301 |
What is the best way to create a vwap study for starting at cash open session everyday without having to reset the study parameters I tried to create a separate chart (same symbol/same time frame) and set the session start and end times to the cash session - but it is not working. 1) even though i set it to ignore the evening session it automatically reverts back to yes for the evening session on the primary chart with vwap study. also when i use the study price overlay it does not seem to correlate with the source chart in terms of the prices where it displays what do you suggest ? thank you |
[2024-01-24 21:25:51] |
John - SC Support - Posts: 36285 |
As you have done, the main option in order to get the Volume Weighted Average Price study to start at the Cash Open is to have a separate chart that has the Session Times set to that there is not an "Evening Session". If your chart is not maintaining the changes you are making to the Session Times, then refer to the following: Chart Session Times: Session Times Automatically Changing Unexpectedly Also, you should not have any issue with the Study/Price Overlay. Refer to the information for the Inputs to the Study/Price Overlay for "Data Copy Mode" and "Bar Time Matching Method" starting at the following link: Study/Price Overlay Study: Data Copy Mode For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
