Date/Time: Mon, 25 Nov 2024 22:48:37 +0000
ASCIL Feature Request: Order Allocation Config access
View Count: 215
[2024-01-24 00:56:40]
PeteB - Posts: 17
I have a requests for a feature that would be very useful to myself and probably others. I have 20 accounts and a half-dozen Order Allocation configs. Using ASCIL, I programmatically enforce many rules, such as which twconfigs can be used on which accounts, which symbols can be traded, etc. But I have to manually deal with the Order Allocation configs and it is a mess because the setup configs do not scale basically. The functionality itself works flawlessly with my broker, so I rely heavily upon it. But the admin is completely manual as you know.
So it would be great if you could add a function to index through all accounts that are defined to Order Allocation for a particular chart. Also, I need a flag to test if Order Allocation is actually enabled on in the Trade Window.
Thanks!
[2024-01-24 02:43:14]
Sierra_Chart Engineering - Posts: 17177
We cannot take new features at this time.
[2024-01-24 17:10:41]
PeteB - Posts: 17
Do you have a schedule for your dev cycle related to community requests like mine? Perhaps this is published somewhere? Thanks
Date Time Of Last Edit: 2024-01-24 17:21:20
[2024-01-24 21:16:04]
John - SC Support - Posts: 36285
We occasionally post in the Sticky threads at the top of the Support Board some of the larger items we work on, but we do not get down into all the little things that are being done. We do what we can when we can. We just can not comment on any particular items, as we have no idea when we might get to them.
