Date/Time: Mon, 21 Apr 2025 17:31:58 +0000
Imbalances - Column 1 transparency
View Count: 2884
[2025-01-22 13:55:37]
UnleashedPiglet - Posts: 65
I'm using Number Bars Calculated Values 2 as a source to plot separately ask and bid pulling/stacking values against a zero line.
[2025-01-22 19:16:13]
John - SC Support - Posts: 39380
Refer to the following setting:
Global Trade Settings Windows: Maximum Bid/Ask Market Depth Pulling/Stacking Levels (Global Settings >> Chart DOM Settings >> Other >> Other Settings)
This will affect what is displayed as well as the sums of the Pulling/Stacking columns.
[2025-01-23 11:25:49]
Thank you. So it's global. Can it be chart related?
[2025-01-23 15:25:25]
There is only the global setting.
[2025-02-04 10:31:53]
I'm reviewing the Feb CLG contract for training purposes. I'm setting it up in the subinstance and replaying. Not getting the market depth though. The DOM is on but not moving at all. I wish I could have all the orders visible on my heatmap. The data is DTC for subinstance. How can i get it done ?
[2025-02-04 16:31:19]
You need to have the Market Depth data already, or download the available historical market depth data that we have available to that sub-instance. Refer to the following:
Replaying Charts: Replaying of Market Depth Data
[2025-02-05 09:25:28]
1. How can such information be made visible over a TPO:
Average Sub-Period Range
Volume Value Area Range
TPO Value Area Range
Rotation Factor
2. Market Depth for CLG : I did everything as per your advice. Downloaded the latest update, depth is allowed for 100 levels, I'm not sure what to do with Allow Sierra Servers - it's on now. Does it matter with historical data ? Does it matter I'm having Rithmic on my main instance , I guess it might because the symbol is CLG5.NYMEX not CLG5-NYMEX....But I can't change DTC Subinstance [trading] for anything else, can I ?
So then, the heatmap is now empty. The DOM is out of volume, spits random readings jumping up and down by 10 ticks for no reason being 100 ticks from the actual price. No pull/stacks.
Date Time Of Last Edit: 2025-02-05 09:33:31
[2025-02-05 16:24:22]
1. Refer to the following and the 3 sections below it for how to display profile information on a TPO:
Time Price Opportunity (TPO) Profile Charts: Show Chart Values On Profile
If the information you are looking for is not part this, then there is not a way to get the information.
2. Rithmic is having issues right now, so if you are trying to connect to Rithmic, then you will have issues.
[2025-02-17 11:14:34]
Could you kindly guide me through how to make an alert concerning a spike in pulling stacking value? I would imagine it should be made in Number Bars Calculated Values 2 but not sure if i should add two separate studies or it can be made in one ? I'm hopeless with formulas on the top so a particular string to add would be of great help. Thank you.
[2025-02-17 17:23:14]
We need more information on what exactly you are wanting. What do you mean by a "spike in pulling stacking value"? What constitutes a spike? And when you ask "if I should add two separate studies or it can be made in one" are you referring to the Bid and Ask separately or something else? Do you want different notifications for the Bid and for the Ask, or can it just be a single notification?
