Date/Time: Mon, 25 Nov 2024 22:50:50 +0000
'Move to breakeven' key command not working!
View Count: 173
[2024-01-23 22:01:08]
J DIDDY - Posts: 129
'Move to breakeven' key command not working...
Not sure if there is an issue somewhere, as I have assigned 2 other key commands and they work fine.
Yes I did press 'Assign'
Sending you a pic of my setting!
I'm on a Mac using Crossover if that makes a difference!
Thx
Private File
[2024-01-23 22:10:06]
John - SC Support - Posts: 36286
We do not recommend using a single key for keyboard shortcuts. This can often lead to confusion on the part of the system as to whether you are requesting the shortcut or entering text for some reason. Please try using one of the modifiers (CTRL, ALT, SHIFT) with it to see if it works that way. Once it is working, then you can modify from there and play with options that will work for you.
[2024-01-24 01:50:46]
Many thanks!
