Date/Time: Mon, 25 Nov 2024 22:35:01 +0000
About the MBO orders
View Count: 164
[2024-01-23 20:10:50] |
Forward - Posts: 65 |
Hello, about MBO data i read : Currently only Market by Order data that has an order quantity greater than or equal to 3 is transmitted and displayed in the Trade/Chart DOM market orders columns. It means that the smaller orders 1 , 2 are not included in the data and filter out ? So if there are on these orders 7,14,21,3,1,1,1 i see JUST 7,14,21,3. Correct ? |
[2024-01-23 21:33:01] |
John - SC Support - Posts: 36284 |
Yes, that is correct. You can also adjust the value for the minimum quantity that will be displayed to be something greater than 2. Refer to the following: Market By Order Data: Adjusting Minimum Quantity to Display for Market by Order Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
