Date/Time: Mon, 25 Nov 2024 23:35:44 +0000
Incorrect P/L and Order Connecting Lines
View Count: 162
[2024-01-23 03:08:11] |
Chamil90 - Posts: 1 |
I am experiencing an issue with the display of order connecting lines and faulty DPL. Specifically, the problem is the lines connecting a CLOSED order to the next OPEN order, resulting in an inaccurate representation of losses on the Daily Profit/Loss. I have attached a chart that illustrates the issue. The connecting lines appear to originate from the last CLOSED trade and extend to the next OPEN trade. I never hold positions overnight and I trade only one symbol. I would greatly appreciate your assistance in resolving this matter and identifying the root cause of the problem. Any guidance or support you can provide to help figure this out would be highly valuable. Thank you in advance for your prompt attention to this issue. I look forward to your guidance in resolving the order connecting lines discrepancy. Best regards, Chamil. https://www.sierrachart.com/image.php?Image=1705979238673.png |
Attachment Deleted. MESH24_FUT_CME [CB][M] 30 Min #10 2024-01-22 18_46_41.47.png / V - Attached On 2024-01-23 03:00:49 UTC - Size: 26.95 KB - 48 views |
[2024-01-23 15:06:51] |
Sierra_Chart Engineering - Posts: 17178 |
For help with this, refer to: Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities And: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
