Date/Time: Sun, 08 Sep 2024 02:06:19 +0000
Control Bar Button > target order tick down > Increase Tick Movement Size
View Count: 142
[2024-01-22 18:14:33] |
User303857 - Posts: 72 |
Hello Support Board. I have working buttons on the control bar that can move the stops & targets up or down, they are working. Is it possible to have additional buttons or modify the existing buttons that move the stops & targets more than just one tick at a time? Does a custom ACSIL have to be built or can the existing button code be modified? For example move STOP 5 ticks up or down per click? For example move TARGET 5 ticks up or down per click? Thank You |
[2024-01-22 19:39:29] |
We do not have a built-in option for a Control Bar or Keyboard shortcut to move the Stop/Target other than 1 tick at a time. This would be something you would have to create a custom study to do. Refer to the following: Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
