Date/Time: Mon, 25 Nov 2024 23:20:37 +0000
Current Bid Ask Lines showing only one line
View Count: 171
[2024-01-22 18:12:29]
vesak - Posts: 15
Hey,
can you give me advice on how to fix the issue, that with the "Current Bid Ask Lines" it only shows one line that changes from red to blue.. I want to have two lines one for the Ask and one for the Bid..
https://www.sierrachart.com/image.php?Image=1705947082929.png
Thanks!
imageScreenshot 2024-01-22 190728.png / V - Attached On 2024-01-22 18:09:15 UTC - Size: 202.54 KB - 45 views
[2024-01-22 19:37:52]
John - SC Support - Posts: 36286
If you are not getting the two lines then this would be due to the Rithmic data feed not sending the information for the Best Bid/Best Ask. Refer to the following:
Rithmic Trading Platform Service: Rithmic Market Data and Support Policy
