Date/Time: Tue, 26 Nov 2024 00:50:00 +0000
changing the color of the candle wick
View Count: 214
[2024-01-21 22:53:18] |
User601708 - Posts: 5 |
good morning, I would like to ask for short instructions on how to set the type of candle, e.g. the candle body is empty inside, there is only a frame and the color of the wick is different. Thank you, |
[2024-01-22 15:52:37] |
John - SC Support - Posts: 36286 |
Refer to the following: Chart Menu: Graph Draw Types (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
