Date/Time: Tue, 26 Nov 2024 00:47:23 +0000
[Bug Report] Sierra Installer Default Install Path
View Count: 386
[2024-01-21 17:29:04] |
SavantTrader - Posts: 110 |
Dear Support: Over the past several months, I've noticed that the Sierra installer no longer memorizes the last-used installation path (or displays the default install path). Each time I open the installer (for an update), I now have to explicitly set the installation path (to the default, ironically). Can you please correct this - to either memorize the last install path chosen, or default to the standard path. Thank you. |
SierraInstaller.png / V - Attached On 2024-01-21 17:28:53 UTC - Size: 70.24 KB - 60 views |
[2024-01-21 18:53:50] |
Sierra_Chart Engineering - Posts: 17178 |
Definitively no bug here at all. It never did this: Over the past several months, I've noticed that the Sierra installer no longer memorizes the last-used installation path
It will use the correct path if you update from within Sierra Chart: Help >> Download Current Version Or you run the installer: SierraChartFileDownloader.exe within the folder containing the Sierra Chart installation you want to update. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-21 22:32:56] |
I see... it must be because I'm now starting it from the start menu search feature, which has memorized a different path. Thank you for your swift reply. |
