Date/Time: Tue, 26 Nov 2024 00:50:00 +0000
Crosshair
View Count: 217
[2024-01-21 11:21:34] |
User644833 - Posts: 9 |
After installing Rev. 48734M, the crosshairs no longer work or are not displayed on my charts. When I move the crosshairs, I see a reaction in the price and time scale, but the line in the chart is not visible. The color settings in the global settings also have no effect. |
[2024-01-21 18:49:38] |
User59879 - Posts: 66 |
confirmed, same here
[2024-01-21 22:34:56] |
Sierra_Chart Engineering - Posts: 17178 |
This would mean that your color settings, are not correct for the Chart Values tool. You may have also set them specifically for the chart in Chart >> Graphics Settings. In any case the automatic color correction has been added back. Update to the latest prerelease with Help >> Download Prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-01-21 22:35:41
