Date/Time: Mon, 25 Nov 2024 23:50:13 +0000
Trading Statistics No Longer Showing
View Count: 230
[2024-01-20 23:18:46]
User920737 - Posts: 5
I may have a similar issue to here: simulation can not be found in trade activity log
Trading stats previously displayed for SIM but is no longer loading any data running version 2550 64bit on Windows 10.
If I set filters to All Activity, All Internal IDs, SIM All Symbols, All Accounts, All Notes, with a time range of several months none of my data loads. Query count is currently 0.
In the TradeActivityLogs folder my traders are not being written into the UTC. Sim1.simulated.data file.
Trade simulation are being run through chart replay using historical data.
Date Time Of Last Edit: 2024-01-20 23:37:17
[2024-01-22 14:58:27]
John - SC Support - Posts: 36286
On the "Trade Activity" page of the Trade Activity Log are the fills for these orders showing?
[2024-01-22 16:31:41]
I have two activity entries:
Activity Type: Orders
Symbol: [SIM]MESH24_FUT_CME
OrderActionSource: Replay 15x: MESH24_FUT_CME | Canceling non-market orders during Flatten | No working orders to cancel for Symbol and Account
Only two entries with the same information above after completing several simulated trading sessions. Previously, when it was working several months prior, my trades were listed in the Sim1.simulated.data file. This issue may have started to occur when my broker account was connected. Although I do not know if they are related or not.
[2024-01-22 17:59:03]
Connecting to your broker would not have any impact on this, as long as you are using the correct symbols.
Please do the following:
- Start a replay
- Please a single Market order to open a position
- Flatten the position after a few seconds
- Open the "Trade Activity Log"
- Set the filters at the top to show "Fills" for the current day for all simulated symbols.
See if the fills for that trade you just took are showing. They should be there. If not, then please give us an image of the Trade Activity Log.
[2024-01-22 22:35:21]
Alright thank you for walking me through this issue. I found the problem. For whatever reason I kept using the limited date range that you could select from the drop down menu. Once I typed in the historical date of the replay, it loaded the data for that day. Loading this information is not based upon when you play the sim and trade the sim but rather the historical date of the chart.
[2024-01-23 15:42:36]
Yes, when replaying a chart the orders are going to be from the time the order is placed within the replay.
