Date/Time: Tue, 26 Nov 2024 00:30:25 +0000
Indicator to combine TWO different time frame MA's
View Count: 246
[2024-01-19 19:58:17]
TopGunTrader - Posts: 172
I love the Study : Moving Averages as I do Transparent Fill Rectangle Bottom and Top to easily show me the trend.
For instance on 1m chart might have 20 and 50ma so if 20>50 it fills green and if 20<50 fills red.
I want to do this on longer term charts and put a 15m 20ma and a 60m 20ma and if 15m 20ma> 60m 20ma the color is green and if < red.
Is there a study that can plot two other studies and thus allow me to pick the fill rectangle top and bottom to accomplish this?
Thanks in advance!
[2024-01-19 22:08:54]
John - SC Support - Posts: 36286
Study Subgraphs Reference (not the extra 's' in Subgraphs):
By default, this study is setup to show the fill between the referenced studies. Also be aware that by default the study is set to an "Independent" scale, so you may need to change it to "Same as Region" to get it to line up properly.
[2024-01-20 13:07:16]
This is SOOO good thank you!
