Date/Time: Tue, 26 Nov 2024 00:25:57 +0000
[Programming Help] - ACSIL study value after SC restart
View Count: 209
[2024-01-19 18:04:50] |
tomas262 - Posts: 141 |
I wondered how to save important variable values while my strategy is running on multiple symbols I save values into persist vars such as signal bar index, entry and attached order internal IDs etc. My idea was saving those values into a file Once SC is restarted it can load and set persist vars right back by reading from the file Any better options are there? Can anybody give a hint on this? Thx |
[2024-01-19 18:09:05] |
User431178 - Posts: 541 |
Depending how much data you actually need to save, there is the option of ACSIL Interface Members - Variables and Arrays: sc.StorageBlock
