Date/Time: Tue, 26 Nov 2024 00:48:22 +0000
Relative Volume Study but swap out volume for
View Count: 193
[2024-01-19 16:21:19]
User811487 - Posts: 10
Im looking to find a study that can compute an answer for this Question "over the last 20 days only looking at data between 9:30 to 9:35 what is the average range traded in ticks (high to low). ATR does not work because it doesn't isolate for that particular time period. Is there a way to Simply open the code and swap out the "Volume" input for "Bar Difference"? If not what other alternatives do I have to create something like this ?
Cheers,
[2024-01-19 17:47:40]
John - SC Support - Posts: 36286
You can do exactly what you want using the tools you have called out.
First, get the range of the bars you want using whatever tool you want (such as ATR).
Then use the "Relative Volume" study set to the study that gets you the bar range.
Refer to the following:
Relative Volume: Basing Relative Volume Study on Another Study for Non-Volume Comparisons
