Date/Time: Tue, 26 Nov 2024 00:47:31 +0000
Data Feed Exchanges
View Count: 230
[2024-01-19 13:40:28]
sahandprs - Posts: 11
Apprently i was buying wrong data feed for a while, saw this picture (attached)
i have CME with Market Depth for non-professional Trading accounts but i dont use heat map, based on the picture there should be a cheaper option. i wonder which one is that
thank you
imagephoto_2024-01-19_14-35-40.jpg / V - Attached On 2024-01-19 13:38:08 UTC - Size: 97.98 KB - 51 views
[2024-01-19 16:45:05]
John - SC Support - Posts: 36286
The Market Depth data is what is populated in the Bid/Ask columns in the DOM. The "Market Depth Historical Graph" (Heatmap) gives you a view of this data over time.
If you are not using this data at all, then you could change to the "CME Non-Professional Top-of-Book" exchange.
To do this, you would "deactivate" the current exchange you have as soon as possible. You will still get the data for that exchange through the end of this month, since you have already paid for it.
Then when you get started on February 1, 2024 you will want to activate the "CME Non-Professional Top-of-Book" exchange.
The reason for the above process is that the exchanges work on a calendar month basis, and they do not give refunds.
[2024-01-20 10:53:35]
Thanks for the info, just one more question
what is the diffrence between Full CME Group (CME, CBOT, COMEX, NYMEX) for non-professional Trading accounts and CME non-professional top-of-book? I already have trading account do i need to buy the first one i said or only top of the book?
Date Time Of Last Edit: 2024-01-20 10:59:50
[2024-01-20 19:55:39]
Sierra_Chart Engineering - Posts: 17178
This one just includes data for the symbols that trade on the CME exchange:
This is all you need if you only need those symbols in real time. The others will be delayed.
Date Time Of Last Edit: 2024-01-20 19:55:59
