Date/Time: Tue, 26 Nov 2024 00:56:35 +0000
CV calculation
View Count: 189
[2024-01-19 11:17:35]
mmiklauz - Posts: 3
Hi SierraChart Support Team,
could you help me with currency value per tick calculation, because I think it calculates incorrectly.
So, if Difference in tick is 20, and Currency Value per Tick is 0.625 shouldn't a CV be 12.5 and not 25 as shown.
20 X 0.625 = 12.5
Thank you,
imageCapture.PNG / V - Attached On 2024-01-19 11:16:10 UTC - Size: 48.41 KB - 45 views
[2024-01-19 16:24:54]
John - SC Support - Posts: 36286
The Chart calculator also takes into account the current Quantity setting. From what you are seeing, it looks like you have a quantity of 2 set for your chart. Refer to the following:
Chart Drawing Tools: Chart Calculator Configuration
