Date/Time: Tue, 26 Nov 2024 00:32:56 +0000
On my dom sim for ZNH24-CBOT is not displaying the area I need to trade on.
View Count: 256
[2024-01-19 02:47:46] |
Robbo - Posts: 6 |
the buy/sell/price area is not showing properly on my dom for the treasury note 10 year dom? please advise what scale in charts I should have so it shows please maybe that will fix it? I haven't been able to attach a screenshot so if you can give me an email I can send it to you as I am not great with this platform?
Attachment Deleted. Screenshot (373).png / V - Attached On 2024-01-19 02:44:30 UTC - Size: 407.52 KB - 48 views Screenshot (373).png / V - Attached On 2024-01-19 02:45:05 UTC - Size: 407.52 KB - 42 views |
[2024-01-19 15:49:56] |
John - SC Support - Posts: 36286 |
From the image you attached, the DOM is showing fine. If you are referring to how the prices are displayed, then refer to this setting: General Settings Window: Display Fractions In Short Format (Global Settings >> General Settings >> Charts >> Charts) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
