Date/Time: Tue, 26 Nov 2024 00:17:03 +0000
Point and Figure - not including all data available
View Count: 173
[2024-01-18 20:40:08] |
User652000 - Posts: 8 |
Hello, Not all prices are included in the chart below. It is a point and figure 50x3 for ESH24 tick size .25 with 10 seconds underlying bar data for 600 days. Example of why this chart is not working properly. High in picture is 4837.50. On January 11th after the next column of O's, we got back to 4838, so an additional X 2 columns over should be in place. Do you know how to fix this to where it is accounting for all data? Including link for image below. https://www.sierrachart.com/image.php?Image=170561029159.png |
[2024-01-19 00:25:02] |
Sierra_Chart Engineering - Posts: 17178 |
50x3 means 50 ticks per box. Which means there has to be 50 ticks of price movement to see a new X or O. For details and how these types of bars are constructed, refer to: Point and Figure Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
