Date/Time: Tue, 26 Nov 2024 00:47:47 +0000
Market Profile annoying Rectangle
View Count: 215
[2024-01-18 16:14:57] |
userfifty3 - Posts: 7 |
In the Market Profile theres always if i am clicking a day on it, it rectangle the day. How can i remove that. I donĀ“t want this option if i am clicking on it it should show nothing. How can i change that? Which settings do i have to use? Thank you so much for your help. |
sierra chart.png / V - Attached On 2024-01-18 16:14:41 UTC - Size: 429.62 KB - 55 views |
[2024-01-22 14:49:14] |
Sierra_Chart Engineering - Posts: 17178 |
Refer to: Time Price Opportunity (TPO) Profile Charts: Keyboard Shortcuts for Splitting and Merging In particular step 5. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
