Date/Time: Tue, 26 Nov 2024 00:23:28 +0000
1 min Candlestick bar
View Count: 206
[2024-01-18 15:43:30]
User223734 - Posts: 103
Dear Sir,
I am using candlestick bar in my chart, how I can show the volume on every bars?
[2024-01-18 16:54:19]
John - SC Support - Posts: 36286
We are not sure exactly what you are looking for, so here are some options:
To view the volume as bars in another region, use the "Volume" study. Refer to the following:
Volume
To place the Volume numbers above or below the candlestick, use the "Study Subgraph Above/Below Bar as Text" study. Refer to the following:
[2024-01-19 01:04:29]
Dear Sir,
I want the volume numbers indicated on every candlestick.
Please advise the method.
[2024-01-19 15:38:55]
